SignalHandler definition
A signal emitter is used to respond on a specific signal from an element to which it is attached, and the element must support certain signals.
More details about the type of signals supported by an element can be found in the plugin manual of Deepstream SDK
Definition in file signal_handler.hpp.
Data Structures | |
| class | deepstream::SignalHandler |
| SignalHandler class. More... | |
| struct | deepstream::SignalHandler::Callback |
| generic callback on the signal More... | |
| class | deepstream::SignalHandler::IActionProvider |
| required interface for a signal handler More... | |
Namespaces | |
| deepstream | |
