8.0 Release
deepstream::SignalHandler Class Reference
SignalHandler class.
Users must implement the IActionProvider interface to create a signal handler. Signal handlers can only be attached to elements that supports certain signals.
A signal handler can handle multiple signals from a single element
Definition at line 40 of file signal_handler.hpp.
Inheritance diagram for deepstream::SignalHandler:
Collaboration diagram for deepstream::SignalHandler:
Data Structures
struct  Callback
 generic callback on the signal More...
class  IActionProvider
 required interface for a signal handler More...
Public Member Functions
 SignalHandler (const std::string &name, IActionProvider *provider)
 Constructor. More...
 SignalHandler (const std::string &name, const char *factory, IActionProvider *provider)
virtual ~SignalHandler ()
 Destructor. More...
void * getCallbackFn (const std::string &name) const
 Return the callback for a specific signal. More...
const std::string getName () const
 Return the name assigned during the construction. More...
 operator bool () const noexcept
 Check if the object is void. More...
bool operator== (const Object &other) noexcept
 Check if the two objects are the same. More...
GstObjectgive ()
 Give up the ownership and return the opaque pointer. More...
GstObjectgetGObject ()
 Return the opaque object pointer. More...
Objecttake (GstObject *object)
 Takes the ownership of a object through the opaque pointer. More...
Objectseize (GstObject *object)
 Seize a opaque object to prevent it from being destroyed somewhere. More...
Objectset (const YAML::Node &params)
 Set the properties from key/value pairs in the yaml format. More...
Objectset (const std::string &name, const Value &value)
template<typename T , typename... Args>
Objectset (const std::string &name, const T &value, const Args &... args)
ObjectgetProperty (const std::string &name, T &value, Args &... args)
 Template for getting multiple properties. More...
std::vector< std::string > listSignals (bool is_action)
 List all the supported signals from the object. More...
bool connectSignal (const std::string &signal_name, SignalHandler &handler)
 Connect a signal handler to the object. More...
void emitSignal (const std::string &signal_name, va_list args)
 Emit a signal. More...
static unsigned long type ()
 Return the type id assigned to signal handler. More...
Protected Member Functions
virtual void set_ (const std::string &name, const Value &value)
virtual void set_ (const std::string &name, const YAML::Node &value)
virtual Value get_ (const std::string &name)
Protected Attributes
std::unique_ptr< IActionProviderprovider_
std::string param_spec_
 property spec in YAML format More...
std::map< std::string, Object::Valueproperties_
 property map More...
GstObjectobject_
◆ SignalHandler() [1/2]
deepstream::SignalHandler::SignalHandler ( const std::string &  name,
IActionProvider provider
Constructor.
Create a signal handler with a user implemented action provider interface
Parameters
[in]namename of the instance
[in]handlerimplementation of the IActionProvider interface
◆ SignalHandler() [2/2]
const char *  factory,
Constructor.
Parameters
[in]factoryname of the factory who creates the instance
◆ ~SignalHandler()
virtual deepstream::SignalHandler::~SignalHandler ( )
virtual
Destructor.
Member Function Documentation
◆ connectSignal()
bool deepstream::Object::connectSignal ( const std::string &  signal_name,
SignalHandler handler
inherited
Parameters
[in]signal_namename of the signal to be connected
[in]handlerhandler for the signal
◆ emitSignal()
void deepstream::Object::emitSignal ( const std::string &  signal_name,
va_list  args
inherited
Emit a signal.
◆ get_()
virtual Value deepstream::CustomObject::get_ ( const std::string &  name)
protectedvirtualinherited
Reimplemented from deepstream::Object.
◆ getCallbackFn()
void* deepstream::SignalHandler::getCallbackFn ( const std::string &  name) const
◆ getGObject()
GstObject* deepstream::Object::getGObject ( )
inlineinherited
Definition at line 140 of file object.hpp.
References deepstream::Object::object_.
◆ getName()
const std::string deepstream::Object::getName ( ) const
inherited
◆ getProperty()
Object& deepstream::Object::getProperty ( const std::string &  name,
T &  value,
Args &...  args
inlineinherited
◆ give()
GstObject* deepstream::Object::give ( )
inherited
◆ listSignals()
std::vector<std::string> deepstream::Object::listSignals ( bool  is_action)
inherited
◆ operator bool()
deepstream::Object::operator bool ( ) const
inlineexplicitnoexceptinherited
Definition at line 131 of file object.hpp.
◆ operator==()
bool deepstream::Object::operator== ( const Object other)
inlinenoexceptinherited
Definition at line 134 of file object.hpp.
◆ seize()
Object& deepstream::Object::seize ( GstObject object)
inherited
◆ set() [1/3]
Object& deepstream::Object::set ( const std::string &  name,
const T &  value,
inlineinherited
Definition at line 161 of file object.hpp.
References deepstream::Object::set(), and deepstream::Object::set_().
◆ set() [2/3]
const Value value
inlineinherited
Definition at line 154 of file object.hpp.
References deepstream::Object::set_().
◆ set() [3/3]
Object& deepstream::Object::set ( const YAML::Node &  params)
inherited
Referenced by deepstream::Pipeline::add(), and deepstream::Object::set().
◆ set_() [1/2]
virtual void deepstream::CustomObject::set_ ( const std::string &  name,
const Value value
◆ set_() [2/2]
const YAML::Node &  value
◆ take()
Object& deepstream::Object::take ( GstObject object)
inherited
◆ type()
static unsigned long deepstream::SignalHandler::type ( )
static
Field Documentation
◆ object_
GstObject* deepstream::Object::object_
protectedinherited
◆ param_spec_
std::string deepstream::CustomObject::param_spec_
protectedinherited
Definition at line 51 of file custom_object.hpp.
◆ properties_
std::map<std::string, Object::Value> deepstream::CustomObject::properties_
protectedinherited
property map
Definition at line 53 of file custom_object.hpp.
◆ provider_
std::unique_ptr<IActionProvider> deepstream::SignalHandler::provider_
protected
Definition at line 91 of file signal_handler.hpp.
