sources/gst-plugins/gst-nvdsanalytics/nvds_analytics.h File Reference
Data Structures
struct  ROIInfo
struct  OverCrowdingInfo
struct  LineCrossingInfo
struct  DirectionInfo
struct  StreamInfo
struct  ObjInf
struct  OverCrowdStatus
struct  NvDsAnalyticProcessParams
class  NvDsAnalyticCtx
Typedefs
using NvDsAnalyticCtxUptr = std::unique_ptr< NvDsAnalyticCtx >
Enumerations
enum  eMode {
  eMode::balanced,
  eMode::strict,
  eMode::loose,
  eMode::balanced,
  eMode::strict,
  eMode::loose,
  eMode::balanced,
  eMode::strict,
  eMode::loose,
  eMode::balanced,
  eMode::strict,
  eMode::loose
enum  eModeDir {
  eModeDir::use_dir,
  eModeDir::pos_to_neg,
  eModeDir::neg_to_pos,
  eModeDir::use_dir,
  eModeDir::use_dir,
  eModeDir::use_dir,
Variables
constexpr int LAST_N_FRAMES =10
constexpr int TIME_OUT_MSEC =8000
constexpr uint32_t MED_FILT_MSEC =1000
Typedef Documentation
◆ NvDsAnalyticCtxUptr
◆ eMode
enum eMode
strong
Enumerator
balanced
strict
loose
balanced
strict
loose
balanced
strict
loose
balanced
strict
loose
Definition at line 25 of file sources/gst-plugins/gst-nvdsanalytics/nvds_analytics.h.
◆ eModeDir
enum eModeDir
strong
Enumerator
use_dir
pos_to_neg
neg_to_pos
use_dir
pos_to_neg
neg_to_pos
use_dir
pos_to_neg
neg_to_pos
use_dir
pos_to_neg
neg_to_pos
Definition at line 31 of file sources/gst-plugins/gst-nvdsanalytics/nvds_analytics.h.
Variable Documentation
◆ LAST_N_FRAMES
constexpr
◆ MED_FILT_MSEC
constexpr
◆ TIME_OUT_MSEC
constexpr
