sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2021-2026 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef _GST_NVDSUDP_COMMON_H_
14 #define _GST_NVDSUDP_COMMON_H_
15
16 #include <gst/gst.h>
17 #include <gio/gio.h>
18 #include <cuda.h>
19 #include <cuda_runtime.h>
20
21 #define CHECK_CUDA(err, err_str) \
22  do { \
23  if ((err) != cudaSuccess) { \
24  GST_WARNING (err_str ", cuda err: %s", cudaGetErrorName (err)); \
25  return FALSE; \
26  } \
27  } while (0)
28
29 #define INVALID_STREAM_ID ((rmx_stream_id)-1L)
30 #define MAX_ST2022_7_STREAMS 2
31
32 #define round_up(num, round) \
33  ((((num) + (round) - 1) / (round)) * (round))
34
35 typedef enum StreamType {
41 } StreamType;
42
43 typedef enum VideoType {
46 } VideoType;
47
48 typedef enum MemoryType {
53 } MemoryType;
54
55 gboolean
56 gst_udp_parse_uri (const gchar * uristr, gchar ** host, guint16 * port);
57
58 GInetAddress *
59 gst_udp_resolve_name (gpointer obj, const gchar * address);
60
61 #define LEAP_SECONDS (37)
62 #define DEFAULT_PTP_SRC NULL
63
64 // Define metadata structure
66
68  GstMeta meta;
69  guint32 rtp_timestamp;
71 };
72
73 // Declare functions
75 const GstMetaInfo *gst_rtp_timestamp_meta_get_info(void);
76
77 // Helper functions for adding/getting metadata
80
81 // GPU memory allocation related functions
82 void* gpu_allocate_memory (int gpuId, size_t size, size_t align);
83 size_t gpu_aligned_size (int gpuId, size_t allocSize);
84 gboolean cudaFreeMmap (uint64_t *ptr, size_t size);
85
86 #endif
VIDEO_2110_22_STREAM
@ VIDEO_2110_22_STREAM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:37
INTERLACE
@ INTERLACE
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:45
gst_buffer_get_rtp_timestamp_meta
GstRTPTimestampMeta * gst_buffer_get_rtp_timestamp_meta(GstBuffer *buffer)
gst_buffer_add_rtp_timestamp_meta
GstRTPTimestampMeta * gst_buffer_add_rtp_timestamp_meta(GstBuffer *buffer, guint32 timestamp)
ANCILLARY_2110_40_STREAM
@ ANCILLARY_2110_40_STREAM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:39
VideoType
VideoType
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:43
const GstMetaInfo * gst_rtp_timestamp_meta_get_info(void)
_GstRTPTimestampMeta::leap_seconds_adjusted
gboolean leap_seconds_adjusted
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:70
_GstRTPTimestampMeta::meta
GstMeta meta
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:68
VIDEO_2110_20_STREAM
@ VIDEO_2110_20_STREAM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:36
MEM_TYPE_SYSTEM
@ MEM_TYPE_SYSTEM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:51
MemoryType
MemoryType
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:48
gpu_allocate_memory
void * gpu_allocate_memory(int gpuId, size_t size, size_t align)
AUDIO_2110_30_31_STREAM
@ AUDIO_2110_30_31_STREAM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:38
gpu_aligned_size
size_t gpu_aligned_size(int gpuId, size_t allocSize)
MEM_TYPE_UNKNOWN
@ MEM_TYPE_UNKNOWN
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:52
gst_rtp_timestamp_meta_api_get_type
GType gst_rtp_timestamp_meta_api_get_type(void)
_GstRTPTimestampMeta::rtp_timestamp
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:69
APPLICATION_CUSTOM_STREAM
@ APPLICATION_CUSTOM_STREAM
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:40
PROGRESSIVE
@ PROGRESSIVE
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:44
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:67
gst_udp_parse_uri
gboolean gst_udp_parse_uri(const gchar *uristr, gchar **host, guint16 *port)
MEM_TYPE_DEVICE
@ MEM_TYPE_DEVICE
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:50
cudaFreeMmap
gboolean cudaFreeMmap(uint64_t *ptr, size_t size)
StreamType
StreamType
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:35
GInetAddress * gst_udp_resolve_name(gpointer obj, const gchar *address)
MEM_TYPE_HOST
@ MEM_TYPE_HOST
Definition: sources/gst-plugins/gst-nvdsudp/gstnvdsudpcommon.h:49
GstBuffer
struct _GstBuffer GstBuffer
Definition: sources/includes/ds3d/common/idatatype.h:19
