sources/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.h File Reference
Macros
#define NVDS_RFC3339_STR_BUF_LEN   32
Typedefs
typedef struct _GstNvDsNtpCalculator GstNvDsNtpCalculator
Enumerations
enum  GstNvDsNtpCalculatorMode {
  GST_NVDS_NTP_CALC_MODE_SYSTEM_TIME,
  GST_NVDS_NTP_CALC_MODE_RTCP,
enum  GstNvDsNtpCorrectionMode {
  GST_NVDS_NTP_CORRECTION_DISABLED,
  GST_NVDS_NTP_CORRECTION_AUTOMATIC,
  GST_NVDS_NTP_CORRECTION_USER_FRAME_RATE,
Functions
void generate_rfc3339_str_from_ts (gchar *buf, GstClockTime ts)
GstNvDsNtpCalculatorgst_nvds_ntp_calculator_new (GstNvDsNtpCalculatorMode mode, GstClockTime frame_duration, GstElement *elem, guint source_id)
void gst_nvds_ntp_calculator_add_ntp_sync_values (GstNvDsNtpCalculator *calc, GstClockTime ntp_time_epoch_ns, GstClockTime ntp_frame_timestamp, GstClockTime avg_frame_time)
gboolean gst_nvds_ntp_calculator_have_ntp_sync_values (GstNvDsNtpCalculator *calc)
void gst_nvds_ntp_calculator_get_ntp_sync_values (GstNvDsNtpCalculator *calc, GstClockTime *ntp_time_epoch_ns, GstClockTime *ntp_frame_timestamp, GstClockTime *avg_frame_time, GstClockTime *ntp_time_epoch_ns_next, GstClockTime *ntp_frame_timestamp_next)
GstClockTime gst_nvds_ntp_calculator_get_buffer_ntp (GstNvDsNtpCalculator *calc, GstClockTime buf_pts)
void gst_nvds_ntp_calculator_reset (GstNvDsNtpCalculator *calc)
void gst_nvds_ntp_calculator_free (GstNvDsNtpCalculator *calc)
◆ NVDS_RFC3339_STR_BUF_LEN
Typedef Documentation
◆ GstNvDsNtpCalculator
◆ GstNvDsNtpCalculatorMode
Enumerator
Definition at line 25 of file sources/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.h.
◆ GstNvDsNtpCorrectionMode
Enumerator
Definition at line 32 of file sources/gst-plugins/gst-nvmultistream2/gstnvstreammux_ntp.h.
Function Documentation
◆ generate_rfc3339_str_from_ts()
void generate_rfc3339_str_from_ts ( gchar *  buf,
GstClockTime  ts
◆ gst_nvds_ntp_calculator_add_ntp_sync_values()
void gst_nvds_ntp_calculator_add_ntp_sync_values ( GstNvDsNtpCalculator calc,
◆ gst_nvds_ntp_calculator_free()
void gst_nvds_ntp_calculator_free ( GstNvDsNtpCalculator calc)
Referenced by GstSinkPad::~GstSinkPad().
◆ gst_nvds_ntp_calculator_get_buffer_ntp()
GstClockTime gst_nvds_ntp_calculator_get_buffer_ntp ( GstNvDsNtpCalculator calc,
◆ gst_nvds_ntp_calculator_get_ntp_sync_values()
void gst_nvds_ntp_calculator_get_ntp_sync_values ( GstNvDsNtpCalculator calc,
GstClockTime *  ntp_time_epoch_ns,
GstClockTime *  ntp_frame_timestamp,
GstClockTime *  avg_frame_time,
GstClockTime *  ntp_time_epoch_ns_next,
GstClockTime *  ntp_frame_timestamp_next
◆ gst_nvds_ntp_calculator_have_ntp_sync_values()
gboolean gst_nvds_ntp_calculator_have_ntp_sync_values ( GstNvDsNtpCalculator calc)
◆ gst_nvds_ntp_calculator_new()
GstNvDsNtpCalculator* gst_nvds_ntp_calculator_new ( GstNvDsNtpCalculatorMode  mode,
GstElement *  elem,
guint  source_id
◆ gst_nvds_ntp_calculator_reset()
void gst_nvds_ntp_calculator_reset ( GstNvDsNtpCalculator calc)
