8.0 Release
sources/includes/ds3d/common/helper/check.hpp File Reference
Namespaces
 ds3d
Macros
#define DS3D_NVUNUSED2(a, b)
#define DS3D_NVUNUSED(a)   { (void)(a); }
#define DS3D_INFER_ASSERT(expr)
#define checkRuntime(call)   ds3d::check_runtime(call, #call, __LINE__, __FILE__)
#define checkKernel(...)
#define dprintf(...)
#define checkCudaErrors(cudaErrorCode)
#define Assertf(cond, fmt, ...)
#define Asserts(cond, s)
#define Assert(cond)
Functions
static bool ds3d::check_runtime (cudaError_t e, const char *call, int line, const char *file)
◆ Assert
#define Assert (   cond)
Value:
do { \
if (!(cond)) { \
fprintf(stderr, "Assert failed 💀. %s in file %s:%d\n", #cond, __FILE__, __LINE__); \
abort(); \
} while (false)
Definition at line 78 of file sources/includes/ds3d/common/helper/check.hpp.
◆ Assertf
#define Assertf (   cond,
  fmt,
Value:
do { \
if (!(cond)) { \
fprintf(stderr, "Assert failed 💀. %s in file %s:%d, message: " fmt "\n", #cond, __FILE__, __LINE__, __VA_ARGS__); \
abort(); \
} while (false)
Definition at line 62 of file sources/includes/ds3d/common/helper/check.hpp.
◆ Asserts
#define Asserts (   cond,
Value:
do { \
if (!(cond)) { \
fprintf(stderr, "Assert failed 💀. %s in file %s:%d, message: " s "\n", #cond, __FILE__, __LINE__); \
abort(); \
} while (false)
Definition at line 70 of file sources/includes/ds3d/common/helper/check.hpp.
◆ checkCudaErrors
#define checkCudaErrors (   cudaErrorCode)
Value:
cudaError_t status = cudaErrorCode; \
if (status != 0) { \
std::cout << "Cuda failure: " << cudaGetErrorString(status) << " at line " << __LINE__ \
<< " in file " << __FILE__ << " error status: " << status << std::endl; \
abort(); \
Definition at line 52 of file sources/includes/ds3d/common/helper/check.hpp.
◆ checkKernel
#define checkKernel (   ...)
Value:
do { \
__VA_ARGS__; \
ds3d::check_runtime(cudaPeekAtLastError(), #__VA_ARGS__, __LINE__, __FILE__); \
} while (false)
Definition at line 45 of file sources/includes/ds3d/common/helper/check.hpp.
◆ checkRuntime
#define checkRuntime (   call)    ds3d::check_runtime(call, #call, __LINE__, __FILE__)
◆ dprintf
#define dprintf (   ...)
◆ DS3D_INFER_ASSERT
#define DS3D_INFER_ASSERT (   expr)
Value:
do { \
if (!(expr)) { \
fprintf(stderr, "%s:%d ASSERT(%s) \n", __FILE__, __LINE__, #expr); \
std::abort(); \
} while (0)
Definition at line 34 of file sources/includes/ds3d/common/helper/check.hpp.
◆ DS3D_NVUNUSED
#define DS3D_NVUNUSED (   a)    { (void)(a); }
◆ DS3D_NVUNUSED2
#define DS3D_NVUNUSED2 (   a,
Value:
(void)(a); \
(void)(b); \
Definition at line 25 of file sources/includes/ds3d/common/helper/check.hpp.
ds3d::check_runtime
static bool check_runtime(cudaError_t e, const char *call, int line, const char *file)
Definition: sources/includes/ds3d/common/helper/check.hpp:86
