8.0 Release
sources/includes/gst-nvdscustomevent.h File Reference
NVIDIA GStreamer DeepStream: Custom Events
Description: This file specifies the NVIDIA DeepStream GStreamer custom event functions, used to map events to individual sources which are batched together by Gst-nvstreammux.
Definition in file sources/includes/gst-nvdscustomevent.h.
Data Structures
struct  RoiDimension
 Defines Roi structure for GST_NVCUSTOMEVENT_ROI_UPDATE custom event. More...
Macros
#define FLAG(name)   GST_EVENT_TYPE_##name
Typedefs
typedef struct RoiDimension RoiDimension
Enumerations
enum  GstNvDsCustomEventType {
  GST_NVEVENT_ROI_UPDATE = GST_EVENT_MAKE_TYPE (406, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_INFER_INTERVAL_UPDATE = GST_EVENT_MAKE_TYPE (407, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_OSD_PROCESS_MODE_UPDATE = GST_EVENT_MAKE_TYPE (408, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_ANALYTICS_RELOAD_CONFIG_UPDATE = GST_EVENT_MAKE_TYPE (409, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_NVTRACKER_CONFIG_UPDATE = GST_EVENT_MAKE_TYPE (410, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
 Defines supported types of custom events. More...
Functions
GstEvent * gst_nvevent_new_roi_update (gchar *stream_id, guint roi_count, RoiDimension *roi_dim)
 Creates a new "roi-update" event. More...
void gst_nvevent_parse_roi_update (GstEvent *event, gchar **stream_id, guint *roi_count, RoiDimension **roi_dim)
 Parses a "roi-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_infer_interval_update (gchar *stream_id, guint interval)
 Creates a new "nv-infer-interval-update" event. More...
void gst_nvevent_parse_infer_interval_update (GstEvent *event, gchar **stream_id, guint *interval)
 Parses a "nv-infer-interval-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_nvtracker_config_update (gchar *stream_id, gchar *configStr)
 Creates a new "nv-tracker-config-update" event. More...
void gst_nvevent_parse_nvtracker_config_update (GstEvent *event, gchar **stream_id, gchar **configStr)
 Parses a "nv-tracker-config-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_osd_process_mode_update (gchar *stream_id, guint process_mode)
 Creates a new "nv-osd-process-mode-update" event. More...
void gst_nvevent_parse_osd_process_mode_update (GstEvent *event, gchar **stream_id, guint *process_mode)
 Parses a "nv-osd-process-mode-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_analytics_reload_config_update (gchar *config_file_path)
 Creates a new "nv-analytics-reload_config-update" event. More...
void gst_nvevent_parse_analytics_reload_config_update (GstEvent *event, gchar **config_file_path)
 Parses a "nv-analytics-reload_config-update" event. More...
