Events: Custom Events API
Specifies GStreamer custom event functions.
Specifies GStreamer custom event functions, used to map events to individual sources which are batched together by Gst-nvstreammux.
Data Structures
struct  RoiDimension
 Defines Roi structure for GST_NVCUSTOMEVENT_ROI_UPDATE custom event. More...
Macros
#define FLAG(name)   GST_EVENT_TYPE_##name
Typedefs
typedef struct RoiDimension RoiDimension
Enumerations
enum  GstNvCustomEventType {
  GST_NVEVENT_DEC_DROP_FRAME_INTERVAL_UPDATE = GST_EVENT_MAKE_TYPE (500, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_DEC_SKIP_FRAME_UPDATE = GST_EVENT_MAKE_TYPE (501, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_DEC_ENABLE_LOW_LATENCY_MODE = GST_EVENT_MAKE_TYPE (502, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_ENC_BITRATE_UPDATE = GST_EVENT_MAKE_TYPE (503, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_ENC_FORCE_IDR = GST_EVENT_MAKE_TYPE (504, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_ENC_FORCE_INTRA = GST_EVENT_MAKE_TYPE (505, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
  GST_NVEVENT_ENC_IFRAME_INTERVAL_UPDATE = GST_EVENT_MAKE_TYPE (506, FLAG(DOWNSTREAM) | FLAG(SERIALIZED)),
 Defines supported types of custom events. More...
enum  GstNvDsCustomEventType {
  GST_NVEVENT_ROI_UPDATE = GST_EVENT_MAKE_TYPE (406, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_INFER_INTERVAL_UPDATE = GST_EVENT_MAKE_TYPE (407, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_OSD_PROCESS_MODE_UPDATE = GST_EVENT_MAKE_TYPE (408, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_ANALYTICS_RELOAD_CONFIG_UPDATE = GST_EVENT_MAKE_TYPE (409, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
  GST_NVEVENT_NVTRACKER_CONFIG_UPDATE = GST_EVENT_MAKE_TYPE (410, FLAG (DOWNSTREAM) | FLAG (SERIALIZED)),
enum  GstNvEventType {
  GST_NVEVENT_PAD_ADDED,
  GST_NVEVENT_PAD_DELETED,
  GST_NVEVENT_STREAM_EOS,
  GST_NVEVENT_STREAM_SEGMENT,
  GST_NVEVENT_STREAM_RESET,
  GST_NVEVENT_STREAM_START,
  GST_NVEVENT_UPDATE_CAPS,
Functions
GstEvent * gst_nvevent_dec_drop_frame_interval_update (gchar *stream_id, guint interval)
 Creates a new "nv-dec-drop-frame-interval-update" event. More...
void gst_nvevent_parse_dec_drop_frame_interval_update (GstEvent *event, gchar **stream_id, guint *interval)
 Parses a "nv-dec-drop-frame-interval-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_dec_skip_frame_update (gchar *stream_id, guint frame_type)
 Creates a new "nv-dec-skip-frame-update" event. More...
void gst_nvevent_parse_dec_skip_frame_update (GstEvent *event, gchar **stream_id, guint *frame_type)
 Parses a "nv-dec-skip-frame-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_dec_enable_low_latency_mode (gchar *stream_id, gint enable)
 Creates a new "nv-dec-enable-low-latency-mode" event. More...
void gst_nvevent_parse_dec_enable_low_latency_mode (GstEvent *event, gchar **stream_id, gint *enable)
 Parses a "nv-dec-enable-low-latency-mode" event received on the sinkpad. More...
GstEvent * gst_nvevent_enc_bitrate_update (gchar *stream_id, guint bitrate)
 Creates a new "nv-enc-bitrate-update" event. More...
void gst_nvevent_parse_enc_bitrate_update (GstEvent *event, gchar **stream_id, guint *bitrate)
 Parses a "nv-enc-bitrate-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_enc_force_idr (gchar *stream_id, gint force)
 Creates a new "nv-enc-force-idr" event. More...
void gst_nvevent_parse_enc_force_idr (GstEvent *event, gchar **stream_id, gint *force)
 Parses a "nv-enc-force-idr" event received on the sinkpad. More...
GstEvent * gst_nvevent_enc_force_intra (gchar *stream_id, gint force)
 Creates a new "nv-enc-force-intra" event. More...
void gst_nvevent_parse_enc_force_intra (GstEvent *event, gchar **stream_id, gint *force)
 Parses a "nv-enc-force-intra" event received on the sinkpad. More...
GstEvent * gst_nvevent_enc_iframeinterval_update (gchar *stream_id, guint interval)
 Creates a new "nv-enc-iframeinterval-update" event. More...
void gst_nvevent_parse_enc_iframeinterval_update (GstEvent *event, gchar **stream_id, guint *interval)
 Parses a "nv-enc-iframeinterval-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_new_roi_update (gchar *stream_id, guint roi_count, RoiDimension *roi_dim)
 Creates a new "roi-update" event. More...
void gst_nvevent_parse_roi_update (GstEvent *event, gchar **stream_id, guint *roi_count, RoiDimension **roi_dim)
 Parses a "roi-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_infer_interval_update (gchar *stream_id, guint interval)
 Creates a new "nv-infer-interval-update" event. More...
void gst_nvevent_parse_infer_interval_update (GstEvent *event, gchar **stream_id, guint *interval)
 Parses a "nv-infer-interval-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_nvtracker_config_update (gchar *stream_id, gchar *configStr)
 Creates a new "nv-tracker-config-update" event. More...
void gst_nvevent_parse_nvtracker_config_update (GstEvent *event, gchar **stream_id, gchar **configStr)
 Parses a "nv-tracker-config-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_osd_process_mode_update (gchar *stream_id, guint process_mode)
 Creates a new "nv-osd-process-mode-update" event. More...
void gst_nvevent_parse_osd_process_mode_update (GstEvent *event, gchar **stream_id, guint *process_mode)
 Parses a "nv-osd-process-mode-update" event received on the sinkpad. More...
GstEvent * gst_nvevent_analytics_reload_config_update (gchar *config_file_path)
 Creates a new "nv-analytics-reload_config-update" event. More...
void gst_nvevent_parse_analytics_reload_config_update (GstEvent *event, gchar **config_file_path)
 Parses a "nv-analytics-reload_config-update" event. More...
GstEvent * gst_nvevent_new_pad_added (guint source_id)
 Creates a "custom pad added" event for the specified source. More...
GstEvent * gst_nvevent_new_pad_deleted (guint source_id)
 Creates a "custom pad deleted" event for the specified source. More...
GstEvent * gst_nvevent_new_stream_eos (guint source_id)
 Creates a "custom EOS" event for the specified source. More...
GstEvent * gst_nvevent_new_stream_segment (guint source_id, GstSegment *segment)
 Creates a "custom segment" event for the specified source. More...
GstEvent * gst_nvevent_new_stream_reset (guint source_id)
 Creates a "custom reset" event for the specified source. More...
GstEvent * gst_nvevent_new_update_caps (guint pad_id, guint width_val, guint height_val, GstStructure *caps_str, gchar *stream_id_str, gboolean is_audio)
 Creates a "updated caps" event for the specified source. More...
void gst_nvevent_parse_pad_added (GstEvent *event, guint *source_id)
 Parses a "pad added" event received on the sinkpad. More...
void gst_nvevent_parse_pad_deleted (GstEvent *event, guint *source_id)
 Parses a "pad deleted" event received on the sinkpad. More...
void gst_nvevent_parse_stream_eos (GstEvent *event, guint *source_id)
 Parses a "stream EOS" event received on the sinkpad. More...
void gst_nvevent_parse_stream_segment (GstEvent *event, guint *source_id, GstSegment **segment)
 Parses a "stream segment" event received on the sinkpad. More...
void gst_nvevent_parse_stream_reset (GstEvent *event, guint *source_id)
 Parses a "stream reset" event received on the sinkpad. More...
GstEvent * gst_nvevent_new_stream_start (guint source_id, gchar *stream_id)
 Creates a new "stream start" event. More...
void gst_nvevent_parse_stream_start (GstEvent *event, guint *source_id, gchar **stream_id)
 Parses a "stream start" event received on the sinkpad. More...
◆ FLAG [1/10]
#define FLAG (   name)    GST_EVENT_TYPE_##name
Definition at line 42 of file sources/includes/gst-nvevent.h.
◆ FLAG [2/10]
Definition at line 42 of file 9.0/sources/includes/gst-nvevent.h.
◆ FLAG [3/10]
◆ FLAG [4/10]
◆ FLAG [5/10]
Definition at line 51 of file sources/includes/gst-nvcustomevent.h.
◆ FLAG [6/10]
Definition at line 51 of file 9.0/sources/includes/gst-nvcustomevent.h.
◆ FLAG [7/10]
◆ FLAG [8/10]
◆ FLAG [9/10]
Definition at line 54 of file 9.0/sources/includes/gst-nvdscustomevent.h.
◆ FLAG [10/10]
Definition at line 54 of file sources/includes/gst-nvdscustomevent.h.
Typedef Documentation
◆ RoiDimension [1/4]
◆ RoiDimension [2/4]
◆ RoiDimension [3/4]
◆ RoiDimension [4/4]
◆ GstNvCustomEventType [1/4]
Enumerator
Specifies a custom event to indicate decoder drop frame interval update of a particular stream.
Specifies a custom event to indicate decoder skip frame update of a particular stream.
Specifies a custom event to enable decoder low-latency-mode of a particular stream.
Specifies a custom event to indicate encoder bitrate update of a particular stream.
Specifies a custom event to indicate encoder force IDR frame of a particular stream.
Specifies a custom event to indicate encoder force Intra frame of a particular stream.
Specifies a custom event to indicate iframe interval update of a particular stream.
Definition at line 54 of file sources/includes/gst-nvcustomevent.h.
◆ GstNvCustomEventType [2/4]
Enumerator
Definition at line 54 of file sources/libs/gstnvcustomhelper/gst-nvcustomevent.h.
◆ GstNvCustomEventType [3/4]
Enumerator
Definition at line 54 of file 9.0/sources/libs/gstnvcustomhelper/gst-nvcustomevent.h.
◆ GstNvCustomEventType [4/4]
Enumerator
Definition at line 54 of file 9.0/sources/includes/gst-nvcustomevent.h.
◆ GstNvDsCustomEventType [1/4]
Enumerator
Specifies a custom event to indicate ROI update for preprocess of a particular stream in a batch.
Specifies a custom event to indicate infer interval update of a particular stream in a batch.
Specifies a custom event to indicate osd process mode update of a particular stream in a batch.
Specifies a custom event to indicate analytics reload_config update of a particular stream in a batch.
Specifies a custom event to indicate nvTracker config update for all streams .
Definition at line 57 of file sources/includes/gst-nvdscustomevent.h.
◆ GstNvDsCustomEventType [2/4]
Enumerator
Definition at line 57 of file 9.0/sources/libs/gstnvdscustomhelper/gst-nvdscustomevent.h.
◆ GstNvDsCustomEventType [3/4]
Enumerator
Definition at line 57 of file sources/libs/gstnvdscustomhelper/gst-nvdscustomevent.h.
◆ GstNvDsCustomEventType [4/4]
Enumerator
Definition at line 57 of file 9.0/sources/includes/gst-nvdscustomevent.h.
◆ GstNvEventType [1/2]
STICKY and STICKY_MULTI flags are used to ensure that events are not dropped in case of leaky queue.
Enumerator
Specifies a custom event to indicate Pad Added.
Specifies a custom event to indicate Pad Deleted.
Specifies a custom event to indicate EOS of a particular stream in a batch.
Specifies a custom event to indicate a stream segment.
Specifies a custom event to indicate reset of a particular stream in a batch.
Specifies a custom event to indicate start of a particular stream in a batch.
Specifies a custom event to indicate update in caps of particular stream in a batch.
Definition at line 47 of file 9.0/sources/includes/gst-nvevent.h.
◆ GstNvEventType [2/2]
Enumerator
Definition at line 47 of file sources/includes/gst-nvevent.h.
Function Documentation
◆ gst_nvevent_analytics_reload_config_update()
GstEvent * gst_nvevent_analytics_reload_config_update ( gchar *  config_file_path)
Parameters
[out]config_file_pathThe config file path
◆ gst_nvevent_dec_drop_frame_interval_update()
GstEvent * gst_nvevent_dec_drop_frame_interval_update ( gchar *  stream_id,
guint  interval
Parameters
[out]stream_idStream ID of the stream for which decoder-drop-frame-interval is to be sent
[out]intervalThe decoder drop-frame interval obtained corresponding to stream ID for the event.
◆ gst_nvevent_dec_enable_low_latency_mode()
GstEvent * gst_nvevent_dec_enable_low_latency_mode ( gchar *  stream_id,
gint  enable
Parameters
[out]stream_idStream ID of the stream for which decoder-low-latenct-mode is to be sent
[out]enableThe decoder low latency mode to be enabled corresponding to stream ID for the event.
◆ gst_nvevent_dec_skip_frame_update()
GstEvent * gst_nvevent_dec_skip_frame_update ( gchar *  stream_id,
guint  frame_type
Parameters
[out]stream_idStream ID of the stream for which decoder-skip-frame-update is to be sent
[out]frame_typeThe decoder frame-type to be skipped obtained corresponding to stream ID for the event.
◆ gst_nvevent_enc_bitrate_update()
GstEvent * gst_nvevent_enc_bitrate_update ( gchar *  stream_id,
guint  bitrate
Parameters
[out]stream_idStream ID of the stream for which encoder-bitrate-update is to be sent
[out]bitrateThe encoder bitrate to be set corresponding to stream ID for the event.
◆ gst_nvevent_enc_force_idr()
GstEvent * gst_nvevent_enc_force_idr ( gchar *  stream_id,
gint  force
Parameters
[out]stream_idStream ID of the stream for which encoder-force-idr is to be sent
[out]forceThe encoder force IDR frame corresponding to stream ID for the event.
◆ gst_nvevent_enc_force_intra()
GstEvent * gst_nvevent_enc_force_intra ( gchar *  stream_id,
gint  force
Parameters
[out]stream_idStream ID of the stream for which encoder-force-intra is to be sent
[out]forceThe encoder force Intra frame corresponding to stream ID for the event.
◆ gst_nvevent_enc_iframeinterval_update()
GstEvent * gst_nvevent_enc_iframeinterval_update ( gchar *  stream_id,
guint  interval
Parameters
[out]stream_idStream ID of the stream for which encoder-iframeinterval-update is to be sent
[out]intervalThe encoder iframeinterval to be set corresponding to stream ID for the event.
◆ gst_nvevent_infer_interval_update()
GstEvent * gst_nvevent_infer_interval_update ( gchar *  stream_id,
guint  interval
Parameters
[out]stream_idStream ID of the stream for which infer-interval-update is to be sent
[out]intervalThe infer interval obtained corresponding to stream ID for the event.
◆ gst_nvevent_new_pad_added()
GstEvent * gst_nvevent_new_pad_added ( guint  source_id)
Parameters
[in]source_idSource ID of the stream to be added to the pipeline; also the pad ID of the sinkpad of the Gst-nvstreammux plugin for which the source is configured.
Returns
A pointer to the event corresponding to the request if successful, or NULL otherwise.
◆ gst_nvevent_new_pad_deleted()
GstEvent * gst_nvevent_new_pad_deleted ( guint  source_id)
Parameters
[in]source_idSource ID of the stream to be removed from the pipeline; also the pad ID of the sinkpad of the Gst-nvstreammux plugin for which the source is configured.
Returns
◆ gst_nvevent_new_roi_update()
GstEvent * gst_nvevent_new_roi_update ( gchar *  stream_id,
guint  roi_count,
RoiDimension roi_dim
Parameters
[out]stream_idStream ID of the stream for which nv-roi-update is to be sent
[out]roi_countThe roi_count obtained corresponding to stream ID for the event.
[out]roi_dimThe RoiDimension structure of size roi_count.
◆ gst_nvevent_new_stream_eos()
GstEvent * gst_nvevent_new_stream_eos ( guint  source_id)
Parameters
[in]source_idSource ID of the stream for which EOS is to be sent; also the pad ID of the sinkpad of the Gst-nvstreammux plugin for which the source is configured.
Returns
A pointer to the event corresponding to request if sucxessful, or NULL otherwise.
◆ gst_nvevent_new_stream_reset()
GstEvent * gst_nvevent_new_stream_reset ( guint  source_id)
Parameters
[in]source_idSource ID of the stream for which reset is to be sent; also the pad ID of the sinkpad of the Gst-nvstreammux plugin for which the source is configured.
Returns
◆ gst_nvevent_new_stream_segment()
GstEvent * gst_nvevent_new_stream_segment ( guint  source_id,
GstSegment *  segment
Parameters
[in]source_idSource ID of the stream for which a segment event is to be sent; also the pad ID of the sinkpad of the Gst-nvstreammux plugin for which the source is configured.
[in]segmentA pointer to a copy of the segment to be sent with the event; corresponds to the original segment for the specified source.
Returns
◆ gst_nvevent_new_stream_start()
GstEvent * gst_nvevent_new_stream_start ( guint  source_id,
gchar *  stream_id
Parameters
[out]source_idSource ID of the stream for which stream-start is to be sent
[out]stream_idThe stream-id string obtained from sink pad with gst_pad_get_stream_id(pad) corresponding to source ID for the event.
◆ gst_nvevent_new_update_caps()
GstEvent * gst_nvevent_new_update_caps ( guint  pad_id,
guint  width_val,
guint  height_val,
GstStructure *  caps_str,
gchar *  stream_id_str,
gboolean  is_audio
Parameters
[in]pad_idPadID of the stream for which caps has to be updated;
[in]width_valWidth the stream for which caps has to be updated;
[in]height_valHeight the stream for which caps has to be updated;
[in]caps_strIncoming CAPS the stream for which caps has to be updated;
[in]stream_id_strString of stream id of the stream for which caps has to be updated;
[in]is_audioAudio/Video flag of the stream for which caps has to be updated;
Returns
◆ gst_nvevent_nvtracker_config_update()
GstEvent * gst_nvevent_nvtracker_config_update ( gchar *  stream_id,
gchar *  configStr
Parameters
[out]configStrA reference to the parsed char string in the tracker plugin
◆ gst_nvevent_osd_process_mode_update()
GstEvent * gst_nvevent_osd_process_mode_update ( gchar *  stream_id,
guint  process_mode
Parameters
[out]stream_idStream ID of the stream for which osd-process-mode-update is to be sent
[out]process_modeThe infer interval obtained corresponding to stream ID for the event.
◆ gst_nvevent_parse_analytics_reload_config_update()
void gst_nvevent_parse_analytics_reload_config_update ( GstEvent *  event,
gchar **  config_file_path
Parameters
[in]eventThe event received on the sinkpad
[out]config_file_pathA pointer to the parsed config file path
◆ gst_nvevent_parse_dec_drop_frame_interval_update()
void gst_nvevent_parse_dec_drop_frame_interval_update ( GstEvent *  event,
gchar **  stream_id,
guint *  interval
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a dec-drop-frame-interval-update event.
[out]stream_idA pointer to the parsed stream ID for which the event is sent.
[out]intervalA pointer to the parsed interval corresponding to stream ID for the event.
◆ gst_nvevent_parse_dec_enable_low_latency_mode()
void gst_nvevent_parse_dec_enable_low_latency_mode ( GstEvent *  event,
gchar **  stream_id,
gint *  enable
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a enable-low-latency-mode event.
[out]enableA pointer to the parsed enable flag corresponding to stream ID for the event.
◆ gst_nvevent_parse_dec_skip_frame_update()
void gst_nvevent_parse_dec_skip_frame_update ( GstEvent *  event,
gchar **  stream_id,
guint *  frame_type
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a skip-frame-update event.
[out]frame_typeA pointer to the parsed frame_type corresponding to stream ID for the event.
◆ gst_nvevent_parse_enc_bitrate_update()
void gst_nvevent_parse_enc_bitrate_update ( GstEvent *  event,
gchar **  stream_id,
guint *  bitrate
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a bitrate-update event.
[out]bitrateA pointer to the parsed bitrate value corresponding to stream ID for the event.
◆ gst_nvevent_parse_enc_force_idr()
void gst_nvevent_parse_enc_force_idr ( GstEvent *  event,
gchar **  stream_id,
gint *  force
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a force-idr event.
[out]forceA pointer to the parsed force value corresponding to stream ID for the event.
◆ gst_nvevent_parse_enc_force_intra()
void gst_nvevent_parse_enc_force_intra ( GstEvent *  event,
gchar **  stream_id,
gint *  force
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a force-intra event.
◆ gst_nvevent_parse_enc_iframeinterval_update()
void gst_nvevent_parse_enc_iframeinterval_update ( GstEvent *  event,
gchar **  stream_id,
guint *  interval
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a iframeinterval-update event.
[out]bitrateA pointer to the parsed interval value corresponding to stream ID for the event.
◆ gst_nvevent_parse_infer_interval_update()
void gst_nvevent_parse_infer_interval_update ( GstEvent *  event,
gchar **  stream_id,
guint *  interval
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a infer-interval-update event.
◆ gst_nvevent_parse_nvtracker_config_update()
void gst_nvevent_parse_nvtracker_config_update ( GstEvent *  event,
gchar **  stream_id,
gchar **  configStr
Parameters
◆ gst_nvevent_parse_osd_process_mode_update()
void gst_nvevent_parse_osd_process_mode_update ( GstEvent *  event,
gchar **  stream_id,
guint *  process_mode
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a osd-process-mode-update event.
[out]process_modeA pointer to the parsed interval corresponding to stream ID for the event.
◆ gst_nvevent_parse_pad_added()
void gst_nvevent_parse_pad_added ( GstEvent *  event,
guint *  source_id
Parameters
[in]eventA pointer to the event received on the sinkpad when the pad is added to Gst-nvstreammux.
[out]source_idA pointer to the parsed source ID for the event.
◆ gst_nvevent_parse_pad_deleted()
void gst_nvevent_parse_pad_deleted ( GstEvent *  event,
guint *  source_id
Parameters
[in]eventA pointer to the event received on the sinkpad when the pad is deleted from Gst-nvstreammux.
◆ gst_nvevent_parse_roi_update()
void gst_nvevent_parse_roi_update ( GstEvent *  event,
gchar **  stream_id,
guint *  roi_count,
RoiDimension **  roi_dim
Parameters
[in]eventThe event received on the sinkpad when the stream ID sends a nv-roi-update event.
[out]roi_countA pointer to the parsed number of roi(s) corresponding to stream ID for the event.
[out]roi_dimA double pointer to the parsed RoiDimension structure of size roi_count. User MUST free roi_dim memory using g_free post usage.
◆ gst_nvevent_parse_stream_eos()
void gst_nvevent_parse_stream_eos ( GstEvent *  event,
guint *  source_id
Parameters
[in]eventA pointer to the event received on the sinkpad when the source ID sends the EOS event.
◆ gst_nvevent_parse_stream_reset()
void gst_nvevent_parse_stream_reset ( GstEvent *  event,
guint *  source_id
Parameters
[in]eventA pointer to the event received on the sinkpad when the source ID sends the reset event.
◆ gst_nvevent_parse_stream_segment()
void gst_nvevent_parse_stream_segment ( GstEvent *  event,
guint *  source_id,
GstSegment **  segment
Parameters
[in]eventThe event received on the sinkpad when the source ID sends a segment event.
[out]source_idA pointer to the parsed source ID for which the event is sent.
[out]segmentA double pointer to the parsed segment corresponding to source ID for the event.
◆ gst_nvevent_parse_stream_start()
void gst_nvevent_parse_stream_start ( GstEvent *  event,
guint *  source_id,
gchar **  stream_id
Parameters
[in]eventThe event received on the sinkpad when the source ID sends a stream-start event.
[out]segmentA double pointer to the parsed stream-id corresponding to source ID for the event.
