NVIDIA DeepStream Yaml Parser API Specification
Description: This file specifies the APIs to set DeepStream GStreamer Element properties by parsing YAML file.
Definition in file sources/includes/nvds_yml_parser.h.
Data Structures | |
| struct | NvDsYamlCodecStatus |
| Enum for codec type for the API call on a encoder. More... | |
Typedefs | |
| typedef enum NvDsYamlParserStatus | NvDsYamlParserStatus |
| Enum for Yaml parsing status for the API call on a GstElement. More... | |
| typedef struct NvDsYamlCodecStatus | NvDsYamlCodecStatus |
Enumerations | |
| enum | NvDsYamlParserStatus { NVDS_YAML_PARSER_SUCCESS, NVDS_YAML_PARSER_DISABLED, NVDS_YAML_PARSER_ERROR, NVDS_YAML_PARSER_SUCCESS, NVDS_YAML_PARSER_DISABLED, NVDS_YAML_PARSER_ERROR } |
| enum | NvDsGieType { NVDS_GIE_PLUGIN_INFER = 0, NVDS_GIE_PLUGIN_INFER_SERVER, NVDS_GIE_PLUGIN_INFER = 0, NVDS_GIE_PLUGIN_INFER_SERVER } |
| Enum for specifying the inference plugin type. More... | |
Functions | |
| NvDsYamlParserStatus | nvds_parse_file_source (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a filesrc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_uridecodebin (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a uridecodebin element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_rtsp_source (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a rtspsrc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvarguscamerasrc (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvarguscamerasrc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_v4l2src (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a v4l2src element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_multifilesrc (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a multifilesrc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_alsasrc (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a alsasrc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_source_list (GList **src_list, gchar *cfg_file_path, const char *group) |
| Parse semicolon separated uri(s) in the source-list group and store it in a GList. More... | |
| NvDsYamlParserStatus | nvds_parse_streammux (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvstreammux element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_tracker (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvtracker element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_osd (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvdsosd element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_tiler (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvtiler element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_msgbroker (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvmsgbroker element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_msgconv (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvmsgconv element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_gie (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvinfer element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_gie_type (NvDsGieType *gie_type, gchar *cfg_file_path, const char *group) |
| Get the GIE type, nvinfer or invinferserver, from the YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_egl_sink (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nveglglessink element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_3d_sink (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nv3dsink element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_file_sink (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a filesink element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_fake_sink (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a fakesink element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_codec_status (gchar *cfg_file_path, const char *group, NvDsYamlCodecStatus *codec_status) |
| Parses codec type and enable status values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvv4l2h264enc (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvv4l2h264enc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvv4l2h265enc (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvv4l2h265enc element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_multiurisrcbin (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvmultiurisrcbin element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvxfer (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvdsxfer element from values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvxfer_position (gchar *cfg_file_path, const char *group, guint *position) |
| Parses nvdsxfer plugin position values specified in a YAML configuration file. More... | |
| NvDsYamlParserStatus | nvds_parse_nvdsanalytics (GstElement *element, gchar *cfg_file_path, const char *group) |
| Set properties of a nvdsanalytics element from values specified in a YAML configuration file. More... | |
| gboolean | check_enable_status (gchar *cfg_file_path, const char *group) |
| Function definition to check if the rest server is enabled in the YAML config file. More... | |
