sources/libs/ds3d/gst/custom_lib_factory.h
1 /*
2  * SPDX-FileCopyrightText: Copyright (c) 2021-2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
4  *
11  */
12
13 #ifndef NVDS3D_CUSTOMLIB_FACTORY_HPP
14 #define NVDS3D_CUSTOMLIB_FACTORY_HPP
15
16 #include <dlfcn.h>
17 #include <ds3d/common/common.h>
18 #include <errno.h>
19
20 #include <functional>
21 #include <iostream>
22
23 namespace ds3d {
24
25 template <class T>
26 T*
27 dlsym_ptr(void* handle, char const* name)
28 {
29  return reinterpret_cast<T*>(dlsym(handle, name));
30 }
31
33 public:
34  CustomLibFactory() = default;
35
37  {
38  if (_libHandle && !_keepOpen) {
39  LOG_DEBUG("dlclose %s", _libName.c_str());
40  dlclose(_libHandle);
41  }
42  }
43  void keepOpen(bool b) { _keepOpen = b; }
44
45  template <class CustomRefCtx>
46  CustomRefCtx* CreateCtx(const std::string& libName, const std::string& symName)
47  {
48  if (!_libHandle) {
49  _libName = libName;
50  _libHandle = dlopen(libName.c_str(), RTLD_NOW | RTLD_LOCAL);
51  } else {
53  _libName == libName || libName.empty(), nullptr,
54  "CustomLibFactory existing libname: %s is different from new lib: %s",
55  _libName.c_str(), libName.c_str());
56  }
58  _libHandle, nullptr, "open custome-lib: %s failed. dlerr: %s", _libName.c_str(),
59  dlerror());
60  LOG_INFO("Library Opened Successfully");
61
62  std::function<CustomRefCtx*()> createCtxFunc =
63  dlsym_ptr<CustomRefCtx*()>(_libHandle, symName.c_str());
65  createCtxFunc, nullptr, "dlsym: %s not found, error: %s", symName.c_str(), dlerror());
66
67  CustomRefCtx* customCtx = createCtxFunc();
69  customCtx, nullptr, "create custom context failed during call: %s", symName.c_str());
70  LOG_INFO("Custom Context created from %s", symName.c_str());
71  return customCtx;
72  }
73
74 public:
75  void* _libHandle = nullptr;
76  std::string _libName;
77  bool _keepOpen = false;
78 };
79
80 } // namespace ds3d
81
82 #endif
ds3d::dlsym_ptr
T * dlsym_ptr(void *handle, char const *name)
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:27
ds3d::CustomLibFactory::_libHandle
void * _libHandle
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:75
DS3D_FAILED_RETURN
#define DS3D_FAILED_RETURN(condition, ret, fmt,...)
Definition: sources/includes/ds3d/common/defines.h:64
ds3d::CustomLibFactory::CreateCtx
CustomRefCtx * CreateCtx(const std::string &libName, const std::string &symName)
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:46
LOG_DEBUG
#define LOG_DEBUG(fmt,...)
Definition: sources/apps/sample_apps/deepstream-3d-action-recognition/deepstream_action.h:49
ds3d::CustomLibFactory::keepOpen
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:43
ds3d::CustomLibFactory::_libName
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:76
LOG_INFO
#define LOG_INFO(fmt,...)
Definition: sources/apps/sample_apps/deepstream-3d-action-recognition/custom_sequence_preprocess/seq_process_common.h:63
ds3d::CustomLibFactory::~CustomLibFactory
~CustomLibFactory()
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:36
ds3d::CustomLibFactory::CustomLibFactory
CustomLibFactory()=default
ds3d::CustomLibFactory::_keepOpen
bool _keepOpen
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:77
Definition: sources/libs/ds3d/gst/custom_lib_factory.h:32
ds3d
Definition: sources/includes/ds3d/common/abi_dataprocess.h:21
