sources/libs/nvstreammux/include/nvstreammux_pads.h File Reference
Data Structures
class  QueueEntry
class  BufferWrapper
class  NvDsBufferWrapper
class  EventWrapper
class  SourcePad
class  SinkPad
class  ISynchronizeBuffer
Typedefs
typedef std::chrono::duration< double, std::nano > NanoSecondsType
Enumerations
enum  SINK_EVENT {
  SINK_EVENT_EOS,
  SINK_EVENT_PLAY_START,
  SINK_EVENT_SEGMENT,
  SINK_EVENT_FLUSH_STOP,
  SINK_EVENT_STREAM_START,
  SINK_EVENT_STREAM_RESET,
  SINK_EVENT_EOS,
  SINK_EVENT_SEGMENT,
enum  SOURCE_STATE {
  SOURCE_STATE_IDLE,
  SOURCE_STATE_PAUSED,
  SOURCE_STATE_PLAYING,
  SOURCE_STATE_STOPPING,
  SOURCE_STATE_IDLE,
enum  ENTRY_TYPE {
  ENTRY_ALL,
  ENTRY_BUFFER,
  ENTRY_EVENT,
  ENTRY_ALL,
  ENTRY_BUFFER,
  ENTRY_EVENT
enum  BATCH_SEQUENCE_TYPE {
  BATCH_SEQUENCE_IN_BATCH,
  BATCH_SEQUENCE_PRE_BATCH,
  BATCH_SEQUENCE_POST_BATCH,
enum  PAD_MIME_TYPE {
  PAD_MIME_TYPE_INVALID,
  PAD_MIME_TYPE_VIDEO,
  PAD_MIME_TYPE_AUDIO,
  PAD_MIME_TYPE_AUDIO
enum  BUFFER_TS_STATUS {
  BUFFER_TS_EARLY,
  BUFFER_TS_ONTIME,
  BUFFER_TS_LATE,
  BUFFER_TS_EARLY,
  BUFFER_TS_ONTIME,
  BUFFER_TS_LATE
Typedef Documentation
◆ NanoSecondsType
typedef std::chrono::duration<double, std::nano> NanoSecondsType
◆ BATCH_SEQUENCE_TYPE
Enumerator
Definition at line 51 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
◆ BUFFER_TS_STATUS
Enumerator
BUFFER_TS_EARLY
BUFFER_TS_ONTIME
BUFFER_TS_LATE
BUFFER_TS_EARLY
BUFFER_TS_ONTIME
BUFFER_TS_LATE
Definition at line 66 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
◆ ENTRY_TYPE
enum ENTRY_TYPE
Enumerator
ENTRY_ALL
ENTRY_BUFFER
ENTRY_EVENT
ENTRY_ALL
ENTRY_BUFFER
ENTRY_EVENT
Definition at line 43 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
◆ PAD_MIME_TYPE
Enumerator
PAD_MIME_TYPE_VIDEO
PAD_MIME_TYPE_AUDIO
PAD_MIME_TYPE_VIDEO
PAD_MIME_TYPE_AUDIO
Definition at line 59 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
◆ SINK_EVENT
enum SINK_EVENT
Enumerator
SINK_EVENT_EOS
SINK_EVENT_SEGMENT
SINK_EVENT_EOS
SINK_EVENT_SEGMENT
Definition at line 24 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
◆ SOURCE_STATE
Enumerator
SOURCE_STATE_IDLE
SOURCE_STATE_PAUSED
SOURCE_STATE_IDLE
SOURCE_STATE_PAUSED
Definition at line 35 of file sources/libs/nvstreammux/include/nvstreammux_pads.h.
