7.1 Release
GstDsNvStreammuxConfig Struct Reference
Data Fields
gint pipeline_width
gint pipeline_height
gint batched_push_timeout
gint batch_size
gint buffer_pool_size
gint compute_hw
gint num_surfaces_per_frame
gint interpolation_method
guint gpu_id
guint nvbuf_memory_type
gboolean live_source
gboolean enable_padding
gboolean attach_sys_ts_as_ntp
gchar * config_file_path
gboolean sync_inputs
guint64 max_latency
gboolean frame_num_reset_on_eos
gboolean frame_num_reset_on_stream_reset
guint64 frame_duration
guint maxBatchSize
gboolean async_process
gboolean no_pipeline_eos
gboolean extract_sei_type5_data
Field Documentation
◆ async_process
gboolean GstDsNvStreammuxConfig::async_process
◆ attach_sys_ts_as_ntp
gboolean GstDsNvStreammuxConfig::attach_sys_ts_as_ntp
◆ batch_size
gint GstDsNvStreammuxConfig::batch_size
◆ batched_push_timeout
gint GstDsNvStreammuxConfig::batched_push_timeout
◆ buffer_pool_size
gint GstDsNvStreammuxConfig::buffer_pool_size
◆ compute_hw
gint GstDsNvStreammuxConfig::compute_hw
◆ config_file_path
gchar * GstDsNvStreammuxConfig::config_file_path
◆ enable_padding
gboolean GstDsNvStreammuxConfig::enable_padding
◆ extract_sei_type5_data
gboolean GstDsNvStreammuxConfig::extract_sei_type5_data
◆ frame_duration
guint64 GstDsNvStreammuxConfig::frame_duration
◆ frame_num_reset_on_eos
gboolean GstDsNvStreammuxConfig::frame_num_reset_on_eos
◆ frame_num_reset_on_stream_reset
gboolean GstDsNvStreammuxConfig::frame_num_reset_on_stream_reset
◆ gpu_id
guint GstDsNvStreammuxConfig::gpu_id
◆ interpolation_method
gint GstDsNvStreammuxConfig::interpolation_method
◆ live_source
gboolean GstDsNvStreammuxConfig::live_source
◆ max_latency
guint64 GstDsNvStreammuxConfig::max_latency
◆ maxBatchSize
guint GstDsNvStreammuxConfig::maxBatchSize
◆ no_pipeline_eos
gboolean GstDsNvStreammuxConfig::no_pipeline_eos
◆ num_surfaces_per_frame
gint GstDsNvStreammuxConfig::num_surfaces_per_frame
◆ nvbuf_memory_type
guint GstDsNvStreammuxConfig::nvbuf_memory_type
◆ pipeline_height
gint GstDsNvStreammuxConfig::pipeline_height
◆ pipeline_width
gint GstDsNvStreammuxConfig::pipeline_width
◆ sync_inputs
gboolean GstDsNvStreammuxConfig::sync_inputs
