GstNvDsPreProcessMemory Struct Reference
This file describes the custom memory allocator for the Gstreamer TensorRT plugin.
The allocator allocates memory for a specified batch_size of frames of resolution equal to the network input resolution and RGBA color format. The frames are allocated on device memory. Holds the pointer for the allocated memory.
Definition at line 32 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
Collaboration diagram for GstNvDsPreProcessMemory:
Data Fields
NvBufSurfacesurf
 surface corresponding to memory allocated More...
std::vector< CUgraphicsResource > cuda_resources
 Vector of cuda resources created by registering the above egl images in CUDA. More...
std::vector< CUeglFrame > egl_frames
 Vector of CUDA eglFrames created by mapping the above cuda resources. More...
void * dev_memory_ptr
 Pointer to the memory allocated for the batch of frames (DGPU). More...
std::vector< void * > frame_memory_ptrs
 Vector of pointer to individual frame memories in the batch memory. More...
Field Documentation
◆ cuda_resources
std::vector< CUgraphicsResource > GstNvDsPreProcessMemory::cuda_resources
Definition at line 37 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
◆ dev_memory_ptr
void * GstNvDsPreProcessMemory::dev_memory_ptr
Definition at line 41 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
◆ egl_frames
std::vector< CUeglFrame > GstNvDsPreProcessMemory::egl_frames
Definition at line 39 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
◆ frame_memory_ptrs
std::vector< void * > GstNvDsPreProcessMemory::frame_memory_ptrs
Definition at line 43 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
◆ surf
NvBufSurface * GstNvDsPreProcessMemory::surf
Definition at line 35 of file sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess_allocator.h.
