Holds parameters required to allocate an NvBufSurface.
Definition at line 447 of file sources/includes/nvbufsurface.h.
Data Fields | |
| uint32_t | gpuId |
| Holds the GPU ID. More... | |
| uint32_t | width |
| Holds the width of the buffer. More... | |
| uint32_t | height |
| Holds the height of the buffer. More... | |
| uint32_t | size |
| Holds the amount of memory to be allocated. More... | |
| bool | isContiguous |
| Holds a "contiguous memory" flag. More... | |
| NvBufSurfaceColorFormat | colorFormat |
| Holds the color format of the buffer. More... | |
| NvBufSurfaceLayout | layout |
| Holds the surface layout. More... | |
| NvBufSurfaceMemType | memType |
| Holds the type of memory to be allocated. More... | |
| void * | _reserved [STRUCTURE_PADDING] |
| Holds the reserved space for future use. More... | |
