Defines types and functions of NvBufSurface application programming interface.
Data Structures | |
| struct | NvBufSurfacePlaneParamsEx |
| Holds plane wise parameters(extended) of a buffer. More... | |
| struct | NvBufSurfacePlaneParams |
| Holds plane wise parameters of a buffer. More... | |
| struct | NvBufSurfaceChromaSubsamplingParams |
| Holds Chroma Subsampling parameters for NvBufSurface allocation. More... | |
| struct | NvBufSurfaceCreateParams |
| Holds parameters required to allocate an NvBufSurface. More... | |
| struct | NvBufSurfaceAllocateParams |
| Hold extended parameters required to allocate NvBufSurface. More... | |
| struct | NvBufSurfaceMappedAddr |
| Hold the pointers of mapped buffer. More... | |
| struct | NvBufSurfaceParamsEx |
| Hold the information(extended) of single buffer in the batch. More... | |
| struct | NvBufSurfaceCudaBuffer |
| Holds information of CUDA buffer. More... | |
| struct | NvBufSurfaceParams |
| Hold the information of single buffer in the batch. More... | |
| struct | NvBufSurface |
| Holds information about batched buffers. More... | |
| struct | NvBufSurfaceMapPlaneParams |
| Holds plane parameters to map the buffer received from another process. More... | |
| struct | NvBufSurfaceCudaIpcMemHandle_t |
| CUDA IPC memory handle for NvBufSurface. More... | |
| struct | NvBufSurfaceExtendedMapParams_t |
| The extended map parameters NvBufSurface. More... | |
| struct | NvBufSurfaceMapParams |
| Holds buffer parameters to map the buffer received from another process. More... | |
| struct | NvBufSurfaceNvmmBuffer |
| Holds information about mapped CUDA buffer. More... | |
| struct | NvBufSurfaceDeviceInfo |
| Holds information about the underlying device. More... | |
| struct | NvBufSurfaceGPUL2SyncParams |
Macros | |
| #define | STRUCTURE_PADDING 4 |
| Defines the default padding length for reserved fields of structures. More... | |
| #define | NVBUF_MAX_PLANES 4 |
| Defines the maximum number of planes. More... | |
| #define | NVBUFSURFACE_CHROMA_SUBSAMPLING_HORIZ_DEFAULT 0 |
| Defines the default values for chroma subsampling. More... | |
| #define | NVBUFSURFACE_CHROMA_SUBSAMPLING_VERT_DEFAULT 1 |
| #define | NVBUFSURFACE_CHROMA_SUBSAMPLING_PARAMS_DEFAULT |
Typedefs | |
| typedef struct NvBufSurfacePlaneParamsEx | NvBufSurfacePlaneParamsEx |
| typedef struct NvBufSurfacePlaneParams | NvBufSurfacePlaneParams |
| typedef struct NvBufSurfaceChromaSubsamplingParams | NvBufSurfaceChromaSubsamplingParams |
| typedef struct NvBufSurfaceCreateParams | NvBufSurfaceCreateParams |
| typedef struct NvBufSurfaceAllocateParams | NvBufSurfaceAllocateParams |
| typedef struct NvBufSurfaceMappedAddr | NvBufSurfaceMappedAddr |
| typedef struct NvBufSurfaceParamsEx | NvBufSurfaceParamsEx |
| typedef struct NvBufSurfaceCudaBuffer | NvBufSurfaceCudaBuffer |
| typedef struct NvBufSurfaceParams | NvBufSurfaceParams |
| typedef struct NvBufSurface | NvBufSurface |
| typedef struct NvBufSurfaceMapPlaneParams | NvBufSurfaceMapPlaneParams |
| typedef struct NvBufSurfaceCudaIpcMemHandle_t | NvBufSurfaceCudaIpcMemHandle |
| typedef struct NvBufSurfaceExtendedMapParams_t | NvBufSurfaceExtendedMapParams |
| typedef struct NvBufSurfaceMapParams | NvBufSurfaceMapParams |
| typedef struct NvBufSurfaceNvmmBuffer | NvBufSurfaceNvmmBuffer |
| typedef struct NvBufSurfaceDeviceInfo | NvBufSurfaceDeviceInfo |
| typedef enum NvBufSurfaceGPUL2SyncCacheOps | NvBufSurfaceGPUL2SyncCacheOps |
| typedef struct NvBufSurfaceGPUL2SyncParams | NvBufSurfaceGPUL2SyncParams |
Functions | |
| int | NvBufSurfaceCreate (NvBufSurface **surf, uint32_t batchSize, NvBufSurfaceCreateParams *params) |
| Allocates a batch of buffers. More... | |
| int | NvBufSurfaceAllocate (NvBufSurface **surf, uint32_t batchSize, NvBufSurfaceAllocateParams *paramsext) |
| Allocate batch of buffers. More... | |
| int | NvBufSurfaceDestroy (NvBufSurface *surf) |
| Free the batched buffers previously allocated through NvBufSurfaceCreate. More... | |
| int | NvBufSurfaceMap (NvBufSurface *surf, int index, int plane, NvBufSurfaceMemMapFlags type) |
| Maps hardware batched buffers to the HOST or CPU address space. More... | |
| int | NvBufSurfaceUnMap (NvBufSurface *surf, int index, int plane) |
| Unmaps previously mapped buffer(s). More... | |
| int | NvBufSurfaceCopy (NvBufSurface *srcSurf, NvBufSurface *dstSurf) |
| Copies the content of source batched buffer(s) to destination batched buffer(s). More... | |
| int | NvBufSurface2Raw (NvBufSurface *Surf, unsigned int index, unsigned int plane, unsigned int out_width, unsigned int out_height, unsigned char *ptr) |
| Copies the NvBufSurface plane memory content to a raw buffer plane for a specific batched buffer. More... | |
| int | Raw2NvBufSurface (unsigned char *ptr, unsigned int index, unsigned int plane, unsigned int in_width, unsigned int in_height, NvBufSurface *Surf) |
| Copies the raw buffer plane memory content to the NvBufSurface plane memory of a specific batched buffer. More... | |
| int | NvBufSurfaceSyncForCpu (NvBufSurface *surf, int index, int plane) |
| Syncs the HW memory cache for the CPU. More... | |
| int | NvBufSurfaceSyncForDevice (NvBufSurface *surf, int index, int plane) |
| Syncs the hardware memory cache for the device. More... | |
| int | NvBufSurfaceFromFd (int dmabuf_fd, void **buffer) |
| Gets the NvBufSurface from the DMABUF FD. More... | |
| int | NvBufSurfaceMemSet (NvBufSurface *surf, int index, int plane, uint8_t value) |
| Fills each byte of the buffer(s) in an NvBufSurface with a provided value. More... | |
| int | NvBufSurfaceMapEglImage (NvBufSurface *surf, int index) |
| Creates an EGLImage from the memory of one or more NvBufSurface buffers. More... | |
| int | NvBufSurfaceUnMapEglImage (NvBufSurface *surf, int index) |
| Destroys the previously created EGLImage object(s). More... | |
| int | NvBufSurfaceImport (NvBufSurface **out_nvbuf_surf, const NvBufSurfaceMapParams *in_params) |
| Import parameters received from another process and create hardware buffer. More... | |
| int | NvBufSurfaceGetMapParams (const NvBufSurface *surf, int index, NvBufSurfaceMapParams *params) |
| Get buffer information to map the buffer in another process. More... | |
| int | NvBufSurfaceMapCudaBuffer (NvBufSurface *surf, int index) |
| Creates an CUDA buffer from the memory of one or more NvBufSurface buffers. More... | |
| int | NvBufSurfaceUnMapCudaBuffer (NvBufSurface *surf, int index) |
| Destroys the previously created CUDA buffer. More... | |
| int | NvBufSurfaceMapNvmmBuffer (NvBufSurface *surf, int index) |
| Creates an NVMM buffer from the memory of one or more NvBufSurface buffers. More... | |
| int | NvBufSurfaceUnMapNvmmBuffer (NvBufSurface *surf, int index) |
| Destroys the previously created NVMM buffer. More... | |
| int | NvBufSurfaceGetDeviceInfo (NvBufSurfaceDeviceInfo *info) |
| Retrieves information about the underlying GPU device driver. More... | |
| int | NvBufSurfaceSyncGpuL2CacheForDevice (NvBufSurface *surf, int index, NvBufSurfaceGPUL2SyncParams *params) |
| Syncs the GPU L2 cache memory for the device. More... | |
| #define NVBUF_MAX_PLANES 4 |
Definition at line 51 of file sources/includes/nvbufsurface.h.
Definition at line 51 of file 9.0/sources/includes/nvbufsurface.h.
| #define NVBUFSURFACE_CHROMA_SUBSAMPLING_HORIZ_DEFAULT 0 |
The default value matches JPEG/MPEG use cases.
Definition at line 57 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 57 of file sources/includes/nvbufsurface.h.
| #define NVBUFSURFACE_CHROMA_SUBSAMPLING_PARAMS_DEFAULT |
Definition at line 60 of file sources/includes/nvbufsurface.h.
Definition at line 60 of file 9.0/sources/includes/nvbufsurface.h.
| #define NVBUFSURFACE_CHROMA_SUBSAMPLING_VERT_DEFAULT 1 |
Definition at line 58 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 58 of file sources/includes/nvbufsurface.h.
| #define STRUCTURE_PADDING 4 |
Definition at line 48 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 48 of file sources/includes/nvbufsurface.h.
| typedef struct NvBufSurface NvBufSurface |
| typedef struct NvBufSurfaceAllocateParams NvBufSurfaceAllocateParams |
(Applicable for NvBufSurfaceAllocate API)
The members chromaLocHoriz and chromaLocVert accept these values: 0: Left horizontal or top vertical position 1: Center horizontal or center vertical position 2: Right horizontal or bottom vertical position
| typedef struct NvBufSurfaceCreateParams NvBufSurfaceCreateParams |
| typedef struct NvBufSurfaceCudaBuffer NvBufSurfaceCudaBuffer |
Applicable for tegra OpenRM only.
| typedef struct NvBufSurfaceCudaIpcMemHandle_t NvBufSurfaceCudaIpcMemHandle |
| typedef struct NvBufSurfaceDeviceInfo NvBufSurfaceDeviceInfo |
| typedef struct NvBufSurfaceExtendedMapParams_t NvBufSurfaceExtendedMapParams |
| typedef struct NvBufSurfaceGPUL2SyncParams NvBufSurfaceGPUL2SyncParams |
| typedef struct NvBufSurfaceMapParams NvBufSurfaceMapParams |
| typedef struct NvBufSurfaceMappedAddr NvBufSurfaceMappedAddr |
| typedef struct NvBufSurfaceMapPlaneParams NvBufSurfaceMapPlaneParams |
| typedef struct NvBufSurfaceNvmmBuffer NvBufSurfaceNvmmBuffer |
| typedef struct NvBufSurfaceParams NvBufSurfaceParams |
| typedef struct NvBufSurfaceParamsEx NvBufSurfaceParamsEx |
| typedef struct NvBufSurfacePlaneParams NvBufSurfacePlaneParams |
| typedef struct NvBufSurfacePlaneParamsEx NvBufSurfacePlaneParamsEx |
Defines color formats for NvBufSurface.
Definition at line 105 of file sources/includes/nvbufsurface.h.
Definition at line 105 of file 9.0/sources/includes/nvbufsurface.h.
Defines display scan formats for NvBufSurface video planes.
Definition at line 375 of file sources/includes/nvbufsurface.h.
Definition at line 375 of file 9.0/sources/includes/nvbufsurface.h.
Defines the type of underlying kernel driver detected for GPU access.
| Enumerator | |
| NVBUF_DRIVER_TYPE_UNKNOWN | |
| NVBUF_DRIVER_TYPE_NVGPU | |
| NVBUF_DRIVER_TYPE_RM | |
Definition at line 705 of file 9.0/sources/includes/nvbufsurface.h.
| Enumerator | |
Definition at line 705 of file sources/includes/nvbufsurface.h.
| Enumerator | |
| NVBUF_GPU_L2_CACHE_INVALIDATE | |
| NVBUF_GPU_L2_CACHE_FLUSH | |
| NVBUF_GPU_L2_CACHE_FLUSH_INVALIDATE | |
Definition at line 739 of file sources/includes/nvbufsurface.h.
| Enumerator | |
Definition at line 739 of file 9.0/sources/includes/nvbufsurface.h.
| enum NvBufSurfaceLayout |
Specifies layout formats for NvBufSurface video planes.
Definition at line 339 of file sources/includes/nvbufsurface.h.
Definition at line 339 of file 9.0/sources/includes/nvbufsurface.h.
Defines mapping types of NvBufSurface.
| Enumerator | |
| NVBUF_MAP_READ | Specifies NvBufSurface mapping type "read.". |
| NVBUF_MAP_WRITE | Specifies NvBufSurface mapping type "write.". |
| NVBUF_MAP_READ_WRITE | Specifies NvBufSurface mapping type "read/write.". |
Definition at line 69 of file 9.0/sources/includes/nvbufsurface.h.
| Enumerator | |
Definition at line 69 of file sources/includes/nvbufsurface.h.
| enum NvBufSurfaceMemType |
Specifies memory types for NvBufSurface.
| Enumerator | |
| NVBUF_MEM_DEFAULT | Specifies the default memory type, i.e. NVBUF_MEM_CUDA_DEVICE for dGPU, NVBUF_MEM_SURFACE_ARRAY for Jetson. Use NVBUF_MEM_DEFAULT to allocate whichever type of memory is appropriate for the platform. |
| NVBUF_MEM_CUDA_PINNED | Specifies CUDA Host memory type. |
| NVBUF_MEM_CUDA_DEVICE | Specifies CUDA Device memory type. |
| NVBUF_MEM_CUDA_UNIFIED | Specifies CUDA Unified memory type. |
| NVBUF_MEM_SURFACE_ARRAY | Specifies NVRM Surface Array type. Valid only for Jetson. |
| NVBUF_MEM_HANDLE | Specifies NVRM Handle type. Valid only for Jetson. |
| NVBUF_MEM_SYSTEM | Specifies memory allocated by malloc(). |
| NVBUF_MEM_CUDA_ARRAY | Specifies CUDA Array memory type. Valid only for Jetson. |
Definition at line 350 of file sources/includes/nvbufsurface.h.
| Enumerator | |
Definition at line 350 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 711 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 711 of file sources/includes/nvbufsurface.h.
| enum NvBufSurfaceTag |
Defines tags that identify the components requesting a memory allocation.
The tags can be used later to identify the total memory allocated to particular types of components. TODO: Check if DeepStream require more tags to be defined.
Definition at line 84 of file 9.0/sources/includes/nvbufsurface.h.
Definition at line 84 of file sources/includes/nvbufsurface.h.
| int NvBufSurface2Raw | ( | NvBufSurface * | Surf, |
| unsigned int | index, | ||
| unsigned int | plane, | ||
| unsigned int | out_width, | ||
| unsigned int | out_height, | ||
| unsigned char * | ptr | ||
This function can be used to copy plane memory content from source raw buffer pointer to specific destination batch buffer of supported memory type.
| [in] | Surf | pointer to NvBufSurface structure. |
| [in] | index | index of buffer in the batch. |
| [in] | plane | index of plane in buffer. |
| [in] | out_width | aligned width of the raw data plane. |
| [in] | out_height | aligned height of the raw data plane. |
| [in] | ptr | pointer to the output raw plane data. |
| int NvBufSurfaceAllocate | ( | NvBufSurface ** | surf, |
| uint32_t | batchSize, | ||
| NvBufSurfaceAllocateParams * | paramsext | ||
(Using extended buffer allocation parameters)
Allocates memory for batchSize buffers and returns in *surf a pointer to allocated NvBufSurface. params structure should have allocation parameters of single buffer. If size field in params is set, buffer of that size will be allocated and all other parameters (w, h, color format etc.) will be ignored.
Use NvBufSurfaceDestroy to free all the resources.
| [out] | surf | pointer to allocated batched buffers. |
| [in] | batchSize | batch size of buffers. |
| [in] | paramsext | pointer to NvBufSurfaceAllocateParams structure. |
| int NvBufSurfaceCopy | ( | NvBufSurface * | srcSurf, |
| NvBufSurface * | dstSurf | ||
You can use this function to copy source buffer(s) of one memory type to destination buffer(s) of another memory type, e.g. CUDA host to CUDA device, malloc'ed memory to CUDA device, etc.
The source and destination NvBufSurface objects must have same buffer and batch size.
| [in] | srcSurf | A pointer to the source NvBufSurface structure. |
| [in] | dstSurf | A pointer to the destination NvBufSurface structure. |
| int NvBufSurfaceCreate | ( | NvBufSurface ** | surf, |
| NvBufSurfaceCreateParams * | params | ||
Allocates memory for batchSize buffers and returns a pointer to an allocated NvBufSurface. The params structure must have the allocation parameters of a single buffer. If params.size is set, a buffer of that size is allocated, and all other parameters (width, height, color format, etc.) are ignored.
Call NvBufSurfaceDestroy() to free resources allocated by this function.
| [out] | surf | An indirect pointer to the allocated batched buffers. |
| [in] | batchSize | Batch size of buffers. |
| [in] | params | A pointer to an NvBufSurfaceCreateParams structure. |
| int NvBufSurfaceDestroy | ( | NvBufSurface * | surf | ) |
| [in] | surf | A pointer to an NvBufSurface to be freed. |
| int NvBufSurfaceFromFd | ( | int | dmabuf_fd, |
| void ** | buffer | ||
| [in] | dmabuf_fd | DMABUF FD of the buffer. |
| [out] | buffer | A pointer to the NvBufSurface. |
| int NvBufSurfaceGetDeviceInfo | ( | NvBufSurfaceDeviceInfo * | info | ) |
| [out] | info | Pointer to NvBufSurfaceDeviceInfo structure. |
This function attempts to determine the below system information:
| int NvBufSurfaceGetMapParams | ( | const NvBufSurface * | surf, |
| int | index, | ||
| NvBufSurfaceMapParams * | params | ||
| [in] | surf | Pointer to NvBufSurface structure. |
| [in] | index | Index of a buffer in the batch. |
| [out] | params | Pointer to NvBufSurfaceMapParams information of the buffer. |
| int NvBufSurfaceImport | ( | NvBufSurface ** | out_nvbuf_surf, |
| const NvBufSurfaceMapParams * | in_params | ||
Calling process must need to call NvBufferDestroy() to remove reference count for hardware buffer handle of the imported DMA buffer.
| [out] | out_nvbuf_surf | Pointer to hardware buffer. |
| [in] | in_params | Parameters to create hardware buffer. |
| int NvBufSurfaceMap | ( | NvBufSurface * | surf, |
| int | index, | ||
| int | plane, | ||
| NvBufSurfaceMemMapFlags | type | ||
Valid for NVBUF_MEM_CUDA_UNIFIED type memory for dGPU and NVBUF_MEM_SURFACE_ARRAY and NVBUF_MEM_HANDLE type memory for Jetson.
This function fills an array of pointers at surf->surfaceList->mappedAddr->addr. surf is a pointer to an NvBufSurface. surfaceList is a pointer to an NvBufSurfaceParams. mappedAddr is a pointer to an NvBufSurfaceMappedAddr. addr is declared as an array of pointers to void, and holds pointers to the buffers.
The client must call NvBufSurfaceSyncForCpu() with the virtual address populated by this function before accessing mapped memory in the CPU.
After memory mapping is complete, mapped memory modification must be coordinated between the CPU and the hardware device as follows:
Use NvBufSurfaceUnMap() to unmap buffer(s) and release any resource.
| [in,out] | surf | A pointer to an NvBufSurface structure. The function stores pointers to the buffers in a descendant of this structure; see the notes above. |
| [in] | index | Index of a buffer in the batch. -1 refers to all buffers in the batch. |
| [in] | plane | Index of a plane in buffer. -1 refers to all planes in the buffer. |
| [in] | type | A flag for mapping type. |
| int NvBufSurfaceMapCudaBuffer | ( | NvBufSurface * | surf, |
| int | index | ||
Only memory type NVBUF_MEM_SURFACE_ARRAY is supported.
This function returns the created CUDA buffer by storing its address at surf->surfaceList->mappedAddr->cudaPtr. (surf is a pointer to an NvBufSurface. surfaceList is a pointer to an NvBufSurfaceParams. mappedAddr is a pointer to an NvBufSurfaceMappedAddr. cudaPtr is a pointer to an NvBufSurfaceCudaBuffer.
You can use this function in scenarios where a CUDA operation on Jetson hardware memory (identified by NVBUF_MEM_SURFACE_ARRAY) is required. The NvBufSurfaceCudaBuffer struct provided by this function can be used to get dataPtr of CUDA memory.
| [in,out] | surf | A pointer to an NvBufSurface structure. The function stores a pointer to the created CUDA buffer in a descendant of this structure; see the notes above. |
| [in] | index | Index of a buffer in the batch. -1 specifies all buffers in the batch. |
| int NvBufSurfaceMapEglImage | ( | NvBufSurface * | surf, |
| int | index | ||
This function returns the created EGLImage by storing its address at surf->surfaceList->mappedAddr->eglImage. (surf is a pointer to an NvBufSurface. surfaceList is a pointer to an NvBufSurfaceParams. mappedAddr is a pointer to an NvBufSurfaceMappedAddr. eglImage is declared as a pointer to void, and holds an EGLImageKHR.)
You can use this function in scenarios where a CUDA operation on Jetson hardware memory (identified by NVBUF_MEM_SURFACE_ARRAY) is required. The EGLImageKHR struct provided by this function can then be registered with CUDA for further CUDA operations.
| [in,out] | surf | A pointer to an NvBufSurface structure. The function stores a pointer to the created EGLImage in a descendant of this structure; see the notes above. |
| int NvBufSurfaceMapNvmmBuffer | ( | NvBufSurface * | surf, |
| int | index | ||
Only memory type NVBUF_MEM_CUDA_DEVICE and NVBUF_MEM_CUDA_PINNED and NVBUF_MEM_CUDA_ARRAY are supported.
This function returns the created NVMM buffer by storing its address at surf->surfaceList->mappedAddr->nvmmPtr. (surf is a pointer to an NvBufSurface. surfaceList is a pointer to an NvBufSurfaceParams. mappedAddr is a pointer to an NvBufSurfaceMappedAddr. nvmmPtr is a pointer to NVMM buffer of memory type NVBUF_MEM_SURFACE_ARRAY.
You can use this function in scenarios where a NVBUF_MEM_SURFACE_ARRAY operation on Jetson hardware memory identified by NVBUF_MEM_CUDA_DEVICE and NVBUF_MEM_CUDA_PINNED and NVBUF_MEM_CUDA_ARRAY are required.
| [in,out] | surf | A pointer to an NvBufSurface structure. The function stores a pointer to the created NVMM buffer in a descendant of this structure; see the notes above. |
| int NvBufSurfaceMemSet | ( | NvBufSurface * | surf, |
| int | index, | ||
| int | plane, | ||
| uint8_t | value | ||
You can also use this function to reset the buffer(s) in the batch.
| [in] | surf | A pointer to the NvBufSurface structure. |
| [in] | plane | Index of a plane in the buffer. -1 refers to all planes in the buffer. |
| [in] | value | The value to be used as fill. |
| int NvBufSurfaceSyncForCpu | ( | NvBufSurface * | surf, |
| int | index, | ||
| int | plane | ||
Valid only for memory types NVBUF_MEM_SURFACE_ARRAY and NVBUF_MEM_HANDLE.
| [in] | surf | A pointer to an NvBufSurface structure. |
| [in] | index | Index of the buffer in the batch. -1 refers to all buffers in the batch. |
| int NvBufSurfaceSyncForDevice | ( | NvBufSurface * | surf, |
| int | index, | ||
| int | plane | ||
| int NvBufSurfaceSyncGpuL2CacheForDevice | ( | NvBufSurface * | surf, |
| int | index, | ||
| NvBufSurfaceGPUL2SyncParams * | params | ||
Valid only for memory types NVBUF_MEM_CUDA_DEVICE, NVBUF_MEM_CUDA_ARRAY and NVBUF_MEM_SURFACE_ARRAY.
| [in] | params | Parameters for the GPU L2 cache sync operation. |
| int NvBufSurfaceUnMap | ( | NvBufSurface * | surf, |
| int | index, | ||
| int | plane | ||
| [in] | index | Index of a buffer in the batch. -1 indicates all buffers in the batch. |
| [in] | plane | Index of a plane in the buffer. -1 indicates all planes in the buffer. |
| int NvBufSurfaceUnMapCudaBuffer | ( | NvBufSurface * | surf, |
| int | index | ||
| [in] | index | The index of a buffer in the batch. -1 specifies all buffers in the batch. |
| int NvBufSurfaceUnMapEglImage | ( | NvBufSurface * | surf, |
| int | index | ||
| int NvBufSurfaceUnMapNvmmBuffer | ( | NvBufSurface * | surf, |
| int | index | ||
| int Raw2NvBufSurface | ( | unsigned char * | ptr, |
| unsigned int | in_width, | ||
| unsigned int | in_height, | ||
| NvBufSurface * | Surf | ||
This function can be used to copy plane memory content from batch buffer to specific destination raw buffer pointer.
| [in] | ptr | pointer to the input raw plane data. |
| [in] | in_width | aligned width of the raw data plane. |
| [in] | in_height | aligned height of the raw data plane. |
| uint8_t NvBufSurfaceChromaSubsamplingParams::_reserved |
Reserved for alignment.
Definition at line 441 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfacePlaneParamsEx::_reserved |
Holds the reserved space for future use.
Definition at line 401 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfacePlaneParams::_reserved |
Definition at line 424 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceCreateParams::_reserved |
Definition at line 468 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceAllocateParams::_reserved |
Definition at line 493 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMappedAddr::_reserved |
Definition at line 509 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceParamsEx::_reserved |
Definition at line 530 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceParams::_reserved |
Definition at line 591 of file sources/includes/nvbufsurface.h.
| void * NvBufSurface::_reserved |
Definition at line 615 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMapParams::_reserved |
Definition at line 687 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceAllocateParams::_reservedParam |
Used void* from custom param for 64 bit machine, using other uint32_t param.
Definition at line 491 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMappedAddr::addr |
Holds planewise pointers to a CPU mapped buffer.
Definition at line 501 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceCudaBuffer::basePtr |
Holds a base pointer to allocated CUDA memory.
It is different from dataPtr when CUDA allocated address is not page aligned for image buffers. It is same as dataPtr for other buffers.
Definition at line 544 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurface::batchSize |
Holds the batch size.
Definition at line 601 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::blockheightlog2 |
Holds block height of the planes for blockLinear layout buffer.
Definition at line 636 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParamsEx::blockheightlog2 |
Definition at line 393 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfaceParams::bufferDesc |
Holds a DMABUF FD.
Valid only for NVBUF_MEM_SURFACE_ARRAY and NVBUF_MEM_HANDLE type memory.
Definition at line 575 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfaceNvmmBuffer::bufferDesc |
Holds a DMABUF FD.
Definition at line 697 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::bytesPerPix |
Holds the number of bytes occupied by a pixel in each plane.
Definition at line 422 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceChromaSubsamplingParams::chromaLocHoriz |
location settings
Definition at line 438 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceChromaSubsamplingParams::chromaLocVert |
Definition at line 439 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceChromaSubsamplingParams NvBufSurfaceAllocateParams::chromaSubsampling |
Chroma Subsampling parameters.
Definition at line 481 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceChromaSubsamplingParams NvBufSurfaceParamsEx::chromaSubsampling |
chroma subsampling parameters.
(Applicable for NVBUF_MEM_SURFACE_ARRAY)
Definition at line 524 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceChromaSubsamplingParams NvBufSurfaceMapParams::chromaSubsampling |
Holds chroma subsampling parameters.
Definition at line 681 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceColorFormat NvBufSurfaceCreateParams::colorFormat |
Holds the color format of the buffer.
Definition at line 461 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceColorFormat NvBufSurfaceParams::colorFormat |
Definition at line 570 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceColorFormat NvBufSurfaceMapParams::colorFormat |
Holds the color format.
Definition at line 679 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceCudaBuffer * NvBufSurfaceParams::cudaBuffer |
Holds a pointer to CUDA buffer.
Applicable for CUDA Device, CUDA Host and CUDA Array memory on tegra OpenRM.
Definition at line 589 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMappedAddr::cudaPtr |
Holds a pointer to a mapped CUDA memory.
Definition at line 507 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceCudaBuffer::dataPtr |
Holds a page aligned data pointer to CUDA memory for image buffers if CUDA allocated address is not page aligned.
It is same as basePtr for other buffers.
Definition at line 550 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceParams::dataPtr |
Holds a pointer to allocated memory.
Not valid for NVBUF_MEM_SURFACE_ARRAY or NVBUF_MEM_HANDLE.
Definition at line 580 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceNvmmBuffer::dataPtr |
Holds a pointer to mapped nvmm memory.
Definition at line 695 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceParams::dataSize |
Holds the amount of allocated memory.
Definition at line 577 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceAllocateParams::disablePitchPadding |
disable pitch padding allocation only applicable for cuda and system memory allocation pitch would be width times bytes per pixel for the plane, for odd width it would be multiple of 2, also note for some non standard video resolution cuda kernels may fail due to unaligned pitch
Definition at line 489 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceDisplayScanFormat NvBufSurfaceAllocateParams::displayscanformat |
Display scan format.
Definition at line 479 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceDriverType NvBufSurfaceDeviceInfo::driverType |
The detected device type (nvgpu, OpenRM, etc.).
Definition at line 726 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfacePlaneParamsEx::drmModifier |
DRM modifier for plane.
Definition at line 399 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMappedAddr::eglImage |
Holds a pointer to a mapped EGLImage.
Definition at line 503 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMapParams::extendedMapParams |
Holds the extended Map parameters.
Definition at line 685 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceCudaBuffer::extMem |
Holds a pointer to external CUDA memory for imported CUDA buffers.
Definition at line 552 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfaceMapParams::fd |
Holds a DMABUF FD.
Definition at line 669 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfaceMapPlaneParams::flags |
Holds flags associated with the planes.
Definition at line 638 of file sources/includes/nvbufsurface.h.
| uint64_t NvBufSurfacePlaneParamsEx::flags |
flags associated with planes
Definition at line 397 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceCreateParams::gpuId |
Holds the GPU ID.
Valid only for a multi-GPU system.
Definition at line 449 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurface::gpuId |
Holds a GPU ID.
Definition at line 599 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapParams::gpuId |
Holds a GPU ID.
Definition at line 667 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceCreateParams::height |
Holds the height of the buffer.
Definition at line 453 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceParams::height |
Definition at line 566 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::height |
Holds the heights of planes.
Definition at line 626 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::height |
Definition at line 414 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceParamsEx::is_protected |
get buffer vpr information.
Definition at line 526 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceCreateParams::isContiguous |
Holds a "contiguous memory" flag.
If set, contiguous memory is allocated for the batch. Valid only for CUDA memory types.
Definition at line 459 of file sources/includes/nvbufsurface.h.
| bool NvBufSurface::isContiguous |
Holds an "is contiguous" flag.
If set, memory allocated for the batch is contiguous.
Definition at line 607 of file sources/includes/nvbufsurface.h.
Referenced by nvdsinferserver::SurfaceBuffer::getBufOffset().
| bool NvBufSurface::isImportedBuf |
Holds a flag for Imported buffer.
Definition at line 613 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceDeviceInfo::isIntegratedGpu |
Indicates GPU is integrated GPU or not.
Definition at line 730 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceDeviceInfo::isVicPresent |
Indicates if VIC is present on the platform.
Definition at line 728 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceLayout NvBufSurfaceCreateParams::layout |
Holds the surface layout.
May be Block Linear (BL) or Pitch Linear (PL). For a dGPU, only PL is valid.
Definition at line 464 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceLayout NvBufSurfaceParams::layout |
Holds BL or PL.
For dGPU, only PL is valid.
Definition at line 572 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceLayout NvBufSurfaceMapParams::layout |
Holds BL or PL layout.
Definition at line 675 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceMappedAddr NvBufSurfaceParams::mappedAddr |
Holds pointers to mapped buffers.
Initialized to NULL when the structure is created.
Definition at line 585 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceCudaIpcMemHandle NvBufSurfaceExtendedMapParams_t::memHandle |
Definition at line 656 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceTag NvBufSurfaceAllocateParams::memtag |
components tag to be used for memory allocation
Definition at line 483 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceMemType NvBufSurfaceCreateParams::memType |
Holds the type of memory to be allocated.
Definition at line 466 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceMemType NvBufSurface::memType |
Holds type of memory for buffers in the batch.
Definition at line 609 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceMemType NvBufSurfaceMapParams::memType |
Holds type of memory.
Definition at line 673 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceCudaBuffer::mipmap |
Holds a pointer to external CUDA mipmaped array for imported CUDA buffers.
Definition at line 554 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::num_planes |
Holds the number of planes.
Definition at line 410 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapParams::num_planes |
Definition at line 665 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurface::numFilled |
Holds the number valid and filled buffers.
Initialized to zero when an instance of the structure is created.
Definition at line 604 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceMappedAddr::nvmmPtr |
Holds a pointer to a mapped NVRM memory.
Definition at line 505 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::offset |
Holds the offsets of planes in bytes.
Definition at line 630 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::offset |
Definition at line 418 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceParamsEx * NvBufSurfaceParams::paramex |
pointers of extended parameters of single buffer in the batch.
Definition at line 587 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceCreateParams NvBufSurfaceAllocateParams::params |
Hold legacy NvBufSurface creation parameters.
Definition at line 477 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParamsEx::physicaladdress |
physical address of allocated planes.
Definition at line 395 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceParams::pitch |
Holds the pitch of the buffer.
Definition at line 568 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::pitch |
Holds the pitches of planes in bytes.
Definition at line 628 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::pitch |
Definition at line 416 of file sources/includes/nvbufsurface.h.
| NvBufSurfacePlaneParams NvBufSurfaceParams::planeParams |
Holds planewise information (width, height, pitch, offset, etc.).
Definition at line 582 of file sources/includes/nvbufsurface.h.
| NvBufSurfacePlaneParamsEx NvBufSurfaceParamsEx::planeParamsex |
plane wise extended info
Definition at line 528 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceMapPlaneParams NvBufSurfaceMapParams::planes |
Holds plane parameters.
Definition at line 683 of file sources/includes/nvbufsurface.h.
| NvBufSurfacePlatformType NvBufSurfaceDeviceInfo::platformType |
Indicates the Jetson platform type.
Definition at line 734 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::psize |
Holds the sizes of planes in bytes.
Definition at line 632 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::psize |
Definition at line 420 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceDeviceInfo::reserved |
Reserved for future use.
Definition at line 736 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceCudaBuffer::reserved |
Reserved.
Definition at line 556 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceMapPlaneParams::reserved |
Reserved.
Definition at line 640 of file sources/includes/nvbufsurface.h.
| char NvBufSurfaceCudaIpcMemHandle_t::reserved |
Definition at line 648 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceExtendedMapParams_t::reserved |
Definition at line 657 of file sources/includes/nvbufsurface.h.
| uint8_t NvBufSurfaceNvmmBuffer::reserved |
Reserved.
Definition at line 699 of file sources/includes/nvbufsurface.h.
| void * NvBufSurfaceGPUL2SyncParams::reserved |
Reserved fields for future use.
Definition at line 751 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceDeviceInfo::reserved1 |
Definition at line 731 of file sources/includes/nvbufsurface.h.
| bool NvBufSurfaceDeviceInfo::reserved2 |
Definition at line 732 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceDisplayScanFormat NvBufSurfaceMapParams::scanformat |
Holds display scan format.
Definition at line 677 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceDisplayScanFormat NvBufSurfacePlaneParamsEx::scanformat |
display scan format - progressive/interlaced.
Definition at line 389 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::secondfieldoffset |
Holds offset of the second field for interlaced buffer.
Definition at line 634 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParamsEx::secondfieldoffset |
Definition at line 391 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceCreateParams::size |
Holds the amount of memory to be allocated.
Optional; if set, all other parameters (width, height, etc.) are ignored.
Definition at line 456 of file sources/includes/nvbufsurface.h.
| int32_t NvBufSurfaceParamsEx::sizeofvaliddatainbytes |
size of the valid data from the first to the last valid byte.
(Applicable for NVBUF_MEM_HANDLE)
Definition at line 521 of file sources/includes/nvbufsurface.h.
| int32_t NvBufSurfaceParamsEx::startofvaliddata |
offset in bytes from the start of the buffer to the first valid byte.
Definition at line 518 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceParams * NvBufSurface::surfaceList |
Holds a pointer to an array of batched buffers.
Definition at line 611 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapParams::totalSize |
Holds the total size of allocated memory.
Definition at line 671 of file sources/includes/nvbufsurface.h.
| NvBufSurfaceGPUL2SyncCacheOps NvBufSurfaceGPUL2SyncParams::type |
Holds the type of GPU L2 cache sync operation.
Definition at line 749 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceCreateParams::width |
Holds the width of the buffer.
Definition at line 451 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceParams::width |
Definition at line 564 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfaceMapPlaneParams::width |
Holds the widths of planes.
Definition at line 624 of file sources/includes/nvbufsurface.h.
| uint32_t NvBufSurfacePlaneParams::width |
Definition at line 412 of file sources/includes/nvbufsurface.h.
