NvBufSurfaceCudaBuffer Struct Reference
Holds information of CUDA buffer.
Applicable for tegra OpenRM only.
Definition at line 537 of file sources/includes/nvbufsurface.h.
Data Fields
void * basePtr
 Holds a base pointer to allocated CUDA memory. More...
void * dataPtr
 Holds a page aligned data pointer to CUDA memory for image buffers if CUDA allocated address is not page aligned. More...
void * extMem
 Holds a pointer to external CUDA memory for imported CUDA buffers. More...
void * mipmap
 Holds a pointer to external CUDA mipmaped array for imported CUDA buffers. More...
uint8_t reserved [64]
 Reserved. More...
