NvBufSurfacePlaneParams Struct Reference
Holds plane wise parameters of a buffer.
Definition at line 407 of file sources/includes/nvbufsurface.h.
Data Fields
uint32_t num_planes
 Holds the number of planes. More...
uint32_t width [NVBUF_MAX_PLANES]
 Holds the widths of planes. More...
uint32_t height [NVBUF_MAX_PLANES]
 Holds the heights of planes. More...
uint32_t pitch [NVBUF_MAX_PLANES]
 Holds the pitches of planes in bytes. More...
uint32_t offset [NVBUF_MAX_PLANES]
 Holds the offsets of planes in bytes. More...
uint32_t psize [NVBUF_MAX_PLANES]
 Holds the sizes of planes in bytes. More...
uint32_t bytesPerPix [NVBUF_MAX_PLANES]
 Holds the number of bytes occupied by a pixel in each plane. More...
void * _reserved [STRUCTURE_PADDING *NVBUF_MAX_PLANES]
 Holds the reserved space for future use. More...
