NvBufSurfacePlaneParamsEx Struct Reference
Holds plane wise parameters(extended) of a buffer.
Definition at line 386 of file sources/includes/nvbufsurface.h.
Data Fields
NvBufSurfaceDisplayScanFormat scanformat [NVBUF_MAX_PLANES]
 display scan format - progressive/interlaced. More...
uint32_t secondfieldoffset [NVBUF_MAX_PLANES]
 offset of the second field for interlaced buffer. More...
uint32_t blockheightlog2 [NVBUF_MAX_PLANES]
 block height of the planes for blockLinear layout buffer. More...
uint32_t physicaladdress [NVBUF_MAX_PLANES]
 physical address of allocated planes. More...
uint64_t flags [NVBUF_MAX_PLANES]
 flags associated with planes More...
uint64_t drmModifier [NVBUF_MAX_PLANES]
 DRM modifier for plane. More...
void * _reserved [STRUCTURE_PADDING *NVBUF_MAX_PLANES]
 Holds the reserved space for future use. More...
