Holds a set of nvdsanalytics framelevel metadata.
Definition at line 73 of file nvds_analytics_meta.h.
Data Fields | |
| std::unordered_map< std::string, bool > | ocStatus |
| Holds a map of boolean status of overcrowding for configured ROIs, which can be accessed using key, value pair; where key is the ROI label. More... | |
| std::unordered_map< std::string, uint32_t > | objInROIcnt |
| Holds a map of total count of valid objects in ROI for configured ROIs, which can be accessed using key, value pair; where key is the ROI label. More... | |
| std::unordered_map< std::string, uint64_t > | objLCCurrCnt |
| Holds a map of total count of Line crossing in current frame for configured lines, which can be accessed using key, value pair; where key is the line crossing label. More... | |
| std::unordered_map< std::string, uint64_t > | objLCCumCnt |
| Holds a map of total cumulative count of Line crossing for configured lines, can be accessed using key, value pair; where key is the line crossing label. More... | |
| guint | unique_id |
| Holds unique identifier for nvdsanalytics instance. More... | |
| std::unordered_map< int, uint32_t > | objCnt |
| Holds a map of total count of objects for each class ID, can be accessed using key, value pair; where key is class ID. More... | |
| std::unordered_map<int, uint32_t> NvDsAnalyticsFrameMeta::objCnt |
Definition at line 101 of file nvds_analytics_meta.h.
| std::unordered_map<std::string, uint32_t> NvDsAnalyticsFrameMeta::objInROIcnt |
Definition at line 83 of file nvds_analytics_meta.h.
| std::unordered_map<std::string, uint64_t> NvDsAnalyticsFrameMeta::objLCCumCnt |
Definition at line 93 of file nvds_analytics_meta.h.
| std::unordered_map<std::string, uint64_t> NvDsAnalyticsFrameMeta::objLCCurrCnt |
Definition at line 88 of file nvds_analytics_meta.h.
| std::unordered_map<std::string, bool> NvDsAnalyticsFrameMeta::ocStatus |
Definition at line 78 of file nvds_analytics_meta.h.
| guint NvDsAnalyticsFrameMeta::unique_id |
Definition at line 96 of file nvds_analytics_meta.h.
