Holds a set of nvdsanalytics object level metadata.
Definition at line 54 of file nvds_analytics_meta.h.
Data Fields | |
| std::vector< std::string > | roiStatus |
| Holds the array of ROI labels in which object is present. More... | |
| std::vector< std::string > | ocStatus |
| Holds the array of OverCrowding labels in which object is present More... | |
| std::vector< std::string > | lcStatus |
| Holds the array of line crossing labels which object has crossed. More... | |
| std::string | dirStatus |
| Holds the direction string for the tracked object. More... | |
| guint | unique_id |
| Holds unique identifier for nvdsanalytics instance. More... | |
| std::string | objStatus |
| Holds the status string for the tracked object. More... | |
| std::string NvDsAnalyticsObjInfo::dirStatus |
Definition at line 63 of file nvds_analytics_meta.h.
| std::vector<std::string> NvDsAnalyticsObjInfo::lcStatus |
Definition at line 61 of file nvds_analytics_meta.h.
| std::string NvDsAnalyticsObjInfo::objStatus |
Definition at line 67 of file nvds_analytics_meta.h.
| std::vector<std::string> NvDsAnalyticsObjInfo::ocStatus |
Definition at line 59 of file nvds_analytics_meta.h.
| std::vector<std::string> NvDsAnalyticsObjInfo::roiStatus |
Definition at line 57 of file nvds_analytics_meta.h.
| guint NvDsAnalyticsObjInfo::unique_id |
Definition at line 65 of file nvds_analytics_meta.h.
