7.1 Release
NvDsAppPerfStruct Struct Reference
Definition at line 41 of file deepstream_perf.h.
Collaboration diagram for NvDsAppPerfStruct:
Data Fields
gdouble fps [MAX_SOURCE_BINS]
gdouble fps_avg [MAX_SOURCE_BINS]
guint num_instances
NvDsAppSourceDetail source_detail [MAX_SOURCE_BINS]
guint active_source_size
gboolean stream_name_display
gboolean use_nvmultiurisrcbin
Field Documentation
◆ active_source_size
guint NvDsAppPerfStruct::active_source_size
Definition at line 47 of file deepstream_perf.h.
◆ fps
gdouble NvDsAppPerfStruct::fps[MAX_SOURCE_BINS]
Definition at line 43 of file deepstream_perf.h.
◆ fps_avg
gdouble NvDsAppPerfStruct::fps_avg[MAX_SOURCE_BINS]
Definition at line 44 of file deepstream_perf.h.
◆ num_instances
guint NvDsAppPerfStruct::num_instances
Definition at line 45 of file deepstream_perf.h.
◆ source_detail
NvDsAppSourceDetail NvDsAppPerfStruct::source_detail[MAX_SOURCE_BINS]
Definition at line 46 of file deepstream_perf.h.
◆ stream_name_display
gboolean NvDsAppPerfStruct::stream_name_display
Definition at line 48 of file deepstream_perf.h.
◆ use_nvmultiurisrcbin
gboolean NvDsAppPerfStruct::use_nvmultiurisrcbin
Definition at line 49 of file deepstream_perf.h.
