7.1 Release
NvDsDewarperConfig Struct Reference
Definition at line 35 of file deepstream_dewarper.h.
Data Fields
gboolean enable
guint gpu_id
guint num_out_buffers
guint dewarper_dump_frames
gchar * config_file
guint nvbuf_memory_type
guint source_id
guint num_surfaces_per_frame
guint num_batch_buffers
Field Documentation
◆ config_file
gchar* NvDsDewarperConfig::config_file
Definition at line 41 of file deepstream_dewarper.h.
◆ dewarper_dump_frames
guint NvDsDewarperConfig::dewarper_dump_frames
Definition at line 40 of file deepstream_dewarper.h.
◆ enable
gboolean NvDsDewarperConfig::enable
Definition at line 37 of file deepstream_dewarper.h.
◆ gpu_id
guint NvDsDewarperConfig::gpu_id
Definition at line 38 of file deepstream_dewarper.h.
◆ num_batch_buffers
guint NvDsDewarperConfig::num_batch_buffers
Definition at line 45 of file deepstream_dewarper.h.
◆ num_out_buffers
guint NvDsDewarperConfig::num_out_buffers
Definition at line 39 of file deepstream_dewarper.h.
◆ num_surfaces_per_frame
guint NvDsDewarperConfig::num_surfaces_per_frame
Definition at line 44 of file deepstream_dewarper.h.
◆ nvbuf_memory_type
guint NvDsDewarperConfig::nvbuf_memory_type
Definition at line 42 of file deepstream_dewarper.h.
◆ source_id
guint NvDsDewarperConfig::source_id
Definition at line 43 of file deepstream_dewarper.h.
