NvDsInferParseDetectionParams Struct Reference
Holds the detection parameters required for parsing objects.
Definition at line 179 of file sources/includes/nvdsinfer_custom_impl.h.
Data Fields
unsigned int numClassesConfigured
 Holds the number of classes requested to be parsed, starting with class ID 0. More...
std::vector< float > perClassPreclusterThreshold
 Holds a per-class vector of detection confidence thresholds to be applied prior to the clustering operation. More...
std::vector< float > perClassPostclusterThreshold
std::vector< float > & perClassThreshold = perClassPreclusterThreshold
Field Documentation
◆ numClassesConfigured
unsigned int NvDsInferParseDetectionParams::numClassesConfigured
Parsing functions may only output objects with class ID less than this value.
Definition at line 184 of file sources/includes/nvdsinfer_custom_impl.h.
Referenced by deepstream::TensorMetaParser::handleData().
◆ perClassPostclusterThreshold
std::vector< float > NvDsInferParseDetectionParams::perClassPostclusterThreshold
Definition at line 192 of file sources/includes/nvdsinfer_custom_impl.h.
◆ perClassPreclusterThreshold
std::vector< float > NvDsInferParseDetectionParams::perClassPreclusterThreshold
Parsing functions may only output an object with detection confidence greater than or equal to the vector element indexed by the object's class ID.
Definition at line 190 of file sources/includes/nvdsinfer_custom_impl.h.
◆ perClassThreshold
std::vector< float > & NvDsInferParseDetectionParams::perClassThreshold = perClassPreclusterThreshold
Deprecated:
Use perClassPreclusterThreshold instead.
Reference to maintain backward compatibility.
Deprecated:
Definition at line 196 of file sources/includes/nvdsinfer_custom_impl.h.
