7.1 Release
NvDsOpticalFlowMeta Struct Reference
Holds optical flow metadata about a frame.
Definition at line 51 of file nvds_opticalflow_meta.h.
Data Fields
unsigned int rows
 Holds the number of rows in the frame for a given block size, e.g. More...
unsigned int cols
 Holds the number of columns in the frame for given block size, e.g. More...
unsigned int mv_size
 Holds the size of the motion vector. More...
unsigned int cost_size
 Holds the size of the confidence values of the motion vector. More...
unsigned long frame_num
 Holds the current frame number of the source. More...
void * data
 Holds a pointer to the motion vector. More...
void * cost
 Holds a pointer to the cost of the motion vector. More...
void * priv
 Reserved for internal use. More...
void * reserved
Field Documentation
◆ cols
unsigned int NvDsOpticalFlowMeta::cols
if block size is 4 and frame width is 1280, then the number of columns is (1280/4) = 320.
Definition at line 60 of file nvds_opticalflow_meta.h.
◆ cost
void* NvDsOpticalFlowMeta::cost
Definition at line 70 of file nvds_opticalflow_meta.h.
◆ cost_size
unsigned int NvDsOpticalFlowMeta::cost_size
Definition at line 64 of file nvds_opticalflow_meta.h.
◆ data
void* NvDsOpticalFlowMeta::data
Definition at line 68 of file nvds_opticalflow_meta.h.
◆ frame_num
unsigned long NvDsOpticalFlowMeta::frame_num
Definition at line 66 of file nvds_opticalflow_meta.h.
◆ mv_size
unsigned int NvDsOpticalFlowMeta::mv_size
See also
NvOFFlowVector.
Definition at line 62 of file nvds_opticalflow_meta.h.
◆ priv
void* NvDsOpticalFlowMeta::priv
Definition at line 72 of file nvds_opticalflow_meta.h.
◆ reserved
void* NvDsOpticalFlowMeta::reserved
Definition at line 74 of file nvds_opticalflow_meta.h.
◆ rows
unsigned int NvDsOpticalFlowMeta::rows
if block size is 4 and frame height is 720, then the number of rows is (720/4) = 180.
Definition at line 56 of file nvds_opticalflow_meta.h.
