Holds information about one classified attribute.
Definition at line 353 of file post_processor_struct.h.
Data Fields | |
| unsigned int | attributeIndex |
| Holds the index of the attribute's label. More... | |
| unsigned int | attributeValue |
| Holds the the attribute's output value. More... | |
| float | attributeConfidence |
| Holds the attribute's confidence level. More... | |
| char * | attributeLabel |
| Holds a pointer to a string containing the attribute's label. More... | |
| float NvDsPostProcessAttribute::attributeConfidence |
Definition at line 362 of file post_processor_struct.h.
| unsigned int NvDsPostProcessAttribute::attributeIndex |
This index corresponds to the order of output layers specified in the outputCoverageLayerNames vector during initialization.
Definition at line 358 of file post_processor_struct.h.
| char* NvDsPostProcessAttribute::attributeLabel |
Memory for the string must not be freed. Custom parsing functions must allocate strings on heap using strdup or equivalent.
Definition at line 366 of file post_processor_struct.h.
| unsigned int NvDsPostProcessAttribute::attributeValue |
Definition at line 360 of file post_processor_struct.h.
