8.0 Release
NvDsPostProcessBatchOutput Struct Reference
Holds the output for all of the frames in a batch (an array of frame), and related buffer information.
Definition at line 537 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
Collaboration diagram for NvDsPostProcessBatchOutput:
Data Fields
NvDsPostProcessFrameOutputframes
 Holds a pointer to an array of outputs for each frame in the batch. More...
unsigned int numFrames
 Holds the number of elements in frames. More...
void ** outputDeviceBuffers
 Holds a pointer to an array of pointers to output device buffers for this batch. More...
unsigned int numOutputDeviceBuffers
 Holds the number of elements in *outputDeviceBuffers. More...
void ** hostBuffers
 Holds a pointer to an array of pointers to host buffers for this batch. More...
unsigned int numHostBuffers
 Holds the number of elements in hostBuffers. More...
void * priv
 Holds a private context pointer for the set of output buffers. More...
Field Documentation
◆ frames
NvDsPostProcessFrameOutput * NvDsPostProcessBatchOutput::frames
Definition at line 540 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ hostBuffers
void ** NvDsPostProcessBatchOutput::hostBuffers
The array elements are set by
Definition at line 552 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ numFrames
unsigned int NvDsPostProcessBatchOutput::numFrames
Definition at line 542 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ numHostBuffers
unsigned int NvDsPostProcessBatchOutput::numHostBuffers
Definition at line 554 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ numOutputDeviceBuffers
unsigned int NvDsPostProcessBatchOutput::numOutputDeviceBuffers
Definition at line 548 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ outputDeviceBuffers
void ** NvDsPostProcessBatchOutput::outputDeviceBuffers
Definition at line 546 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ priv
void * NvDsPostProcessBatchOutput::priv
Definition at line 557 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
