Holds detection and bounding box grouping parameters.
Definition at line 218 of file post_processor_struct.h.
Data Fields | |
float | preClusterThreshold |
Holds the bounding box detection threshold to be applied prior to clustering operation. More... | |
float | postClusterThreshold |
Hold the bounding box detection threshold to be applied post clustering operation. More... | |
float | eps |
Holds the epsilon to control merging of overlapping boxes. More... | |
int | minBoxes |
Holds the minimum number of boxes in a cluster to be considered an object during grouping using DBSCAN. More... | |
int | groupThreshold |
Holds the minimum number boxes in a cluster to be considered an object during grouping using OpenCV groupRectangles. More... | |
float | minScore |
Minimum score in a cluster for the cluster to be considered an object during grouping. More... | |
float | nmsIOUThreshold |
IOU threshold to be used with NMS mode of clustering. More... | |
int | topK |
Number of objects with objects to be filtered in the decensding order of probability. More... | |
unsigned int | roiTopOffset |
unsigned int | roiBottomOffset |
unsigned int | detectionMinWidth |
unsigned int | detectionMinHeight |
unsigned int | detectionMaxWidth |
unsigned int | detectionMaxHeight |
NvDsPostProcessColorParams | color_params |
NvDsPostProcessColorParams NvDsPostProcessDetectionParams::color_params |
Definition at line 253 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::detectionMaxHeight |
Definition at line 252 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::detectionMaxWidth |
Definition at line 251 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::detectionMinHeight |
Definition at line 250 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::detectionMinWidth |
Definition at line 249 of file post_processor_struct.h.
float NvDsPostProcessDetectionParams::eps |
Refer to OpenCV groupRectangles and DBSCAN documentation for more information on epsilon.
Definition at line 230 of file post_processor_struct.h.
int NvDsPostProcessDetectionParams::groupThreshold |
Definition at line 236 of file post_processor_struct.h.
int NvDsPostProcessDetectionParams::minBoxes |
Definition at line 233 of file post_processor_struct.h.
float NvDsPostProcessDetectionParams::minScore |
Different clustering may cause the algorithm to use different scores.
Definition at line 240 of file post_processor_struct.h.
float NvDsPostProcessDetectionParams::nmsIOUThreshold |
Definition at line 242 of file post_processor_struct.h.
float NvDsPostProcessDetectionParams::postClusterThreshold |
Definition at line 226 of file post_processor_struct.h.
float NvDsPostProcessDetectionParams::preClusterThreshold |
Definition at line 222 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::roiBottomOffset |
Definition at line 248 of file post_processor_struct.h.
unsigned int NvDsPostProcessDetectionParams::roiTopOffset |
Definition at line 247 of file post_processor_struct.h.
int NvDsPostProcessDetectionParams::topK |
Definition at line 245 of file post_processor_struct.h.
