NvDsPostProcessInstanceMaskInfo Struct Reference
Holds information about one parsed object and instance mask from a detector's output.
Definition at line 378 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
Data Fields
unsigned int classId
 Holds the ID of the class to which the object belongs. More...
float left
 Holds the horizontal offset of the bounding box shape for the object. More...
float top
 Holds the vertical offset of the object's bounding box. More...
float width
 Holds the width of the object's bounding box. More...
float height
 Holds the height of the object's bounding box. More...
float detectionConfidence
 Holds the object detection confidence level; must in the range [0.0,1.0]. More...
float * mask
 Holds object segment mask. More...
unsigned int mask_width
 Holds width of mask. More...
unsigned int mask_height
 Holds height of mask. More...
unsigned int mask_size
 Holds size of mask in bytes. More...
Field Documentation
◆ classId
unsigned int NvDsPostProcessInstanceMaskInfo::classId
Definition at line 381 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ detectionConfidence
float NvDsPostProcessInstanceMaskInfo::detectionConfidence
Definition at line 394 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ height
float NvDsPostProcessInstanceMaskInfo::height
Definition at line 390 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ left
float NvDsPostProcessInstanceMaskInfo::left
Definition at line 384 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ mask
float * NvDsPostProcessInstanceMaskInfo::mask
Definition at line 397 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ mask_height
unsigned int NvDsPostProcessInstanceMaskInfo::mask_height
◆ mask_size
unsigned int NvDsPostProcessInstanceMaskInfo::mask_size
Definition at line 403 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ mask_width
unsigned int NvDsPostProcessInstanceMaskInfo::mask_width
◆ top
float NvDsPostProcessInstanceMaskInfo::top
Definition at line 386 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
◆ width
float NvDsPostProcessInstanceMaskInfo::width
Definition at line 388 of file sources/gst-plugins/gst-nvdspostprocess/postprocesslib_impl/post_processor_struct.h.
