Holds information about one detected object.
Definition at line 409 of file post_processor_struct.h.
Data Fields | |
float | left |
Holds the object's offset from the left boundary of the frame. More... | |
float | top |
Holds the object's offset from the top boundary of the frame. More... | |
float | width |
Holds the object's width. More... | |
float | height |
Holds the object's height. More... | |
int | classIndex |
Holds the index for the object's class. More... | |
char * | label |
Holds a pointer to a string containing a label for the object. More... | |
float | confidence |
float * | mask |
unsigned int | mask_width |
Holds width of mask. More... | |
unsigned int | mask_height |
Holds height of mask. More... | |
unsigned int | mask_size |
Holds size of mask in bytes. More... | |
int NvDsPostProcessObject::classIndex |
Definition at line 420 of file post_processor_struct.h.
float NvDsPostProcessObject::confidence |
Definition at line 424 of file post_processor_struct.h.
float NvDsPostProcessObject::height |
Definition at line 418 of file post_processor_struct.h.
char* NvDsPostProcessObject::label |
Definition at line 422 of file post_processor_struct.h.
float NvDsPostProcessObject::left |
Definition at line 412 of file post_processor_struct.h.
float* NvDsPostProcessObject::mask |
Definition at line 426 of file post_processor_struct.h.
unsigned int NvDsPostProcessObject::mask_height |
Definition at line 430 of file post_processor_struct.h.
unsigned int NvDsPostProcessObject::mask_size |
Definition at line 432 of file post_processor_struct.h.
unsigned int NvDsPostProcessObject::mask_width |
Definition at line 428 of file post_processor_struct.h.
float NvDsPostProcessObject::top |
Definition at line 414 of file post_processor_struct.h.
float NvDsPostProcessObject::width |
Definition at line 416 of file post_processor_struct.h.
