8.0 Release
NvDsPostProcessObjectDetectionInfo Struct Reference
Holds information about one parsed object from a detector's output.
Definition at line 331 of file post_processor_struct.h.
Data Fields
unsigned int classId
 Holds the ID of the class to which the object belongs. More...
float left
 Holds the horizontal offset of the bounding box shape for the object. More...
float top
 Holds the vertical offset of the object's bounding box. More...
float width
 Holds the width of the object's bounding box. More...
float height
 Holds the height of the object's bounding box. More...
float detectionConfidence
 Holds the object detection confidence level; must in the range [0.0,1.0]. More...
Field Documentation
◆ classId
unsigned int NvDsPostProcessObjectDetectionInfo::classId
Definition at line 334 of file post_processor_struct.h.
◆ detectionConfidence
float NvDsPostProcessObjectDetectionInfo::detectionConfidence
Definition at line 347 of file post_processor_struct.h.
◆ height
float NvDsPostProcessObjectDetectionInfo::height
Definition at line 343 of file post_processor_struct.h.
◆ left
float NvDsPostProcessObjectDetectionInfo::left
Definition at line 337 of file post_processor_struct.h.
◆ top
float NvDsPostProcessObjectDetectionInfo::top
Definition at line 339 of file post_processor_struct.h.
◆ width
float NvDsPostProcessObjectDetectionInfo::width
Definition at line 341 of file post_processor_struct.h.
