Holds the detection parameters required for parsing objects.
Definition at line 567 of file post_processor_struct.h.
Data Fields | |
| unsigned int | numClassesConfigured |
| Holds the number of classes requested to be parsed, starting with class ID 0. More... | |
| std::vector< float > | perClassPreclusterThreshold |
| Holds a per-class vector of detection confidence thresholds to be applied prior to the clustering operation. More... | |
| std::vector< float > | perClassPostclusterThreshold |
| unsigned int NvDsPostProcessParseDetectionParams::numClassesConfigured |
Parsing functions may only output objects with class ID less than this value.
Definition at line 572 of file post_processor_struct.h.
| std::vector<float> NvDsPostProcessParseDetectionParams::perClassPostclusterThreshold |
Definition at line 580 of file post_processor_struct.h.
| std::vector<float> NvDsPostProcessParseDetectionParams::perClassPreclusterThreshold |
Parsing functions may only output an object with detection confidence greater than or equal to the vector element indexed by the object's class ID.
Definition at line 578 of file post_processor_struct.h.
