Holds information parsed from segmentation network output for one frame.
Definition at line 467 of file post_processor_struct.h.
Data Fields | |
| unsigned int | width |
| Holds the width of the output. More... | |
| unsigned int | height |
| Holds the height of the output. More... | |
| unsigned int | classes |
| Holds the number of classes supported by the network. More... | |
| int * | class_map |
| Holds a pointer to an array for the 2D pixel class map. More... | |
| float * | class_probability_map |
| Holds a pointer to an array containing raw probabilities. More... | |
| int* NvDsPostProcessSegmentationOutput::class_map |
The output for pixel (x,y) is at index (y*width+x).
Definition at line 477 of file post_processor_struct.h.
| float* NvDsPostProcessSegmentationOutput::class_probability_map |
The probability for class c and pixel (x,y) is at index (c*width*height + y*width+x).
Definition at line 481 of file post_processor_struct.h.
| unsigned int NvDsPostProcessSegmentationOutput::classes |
Definition at line 474 of file post_processor_struct.h.
| unsigned int NvDsPostProcessSegmentationOutput::height |
Same as network height.
Definition at line 472 of file post_processor_struct.h.
| unsigned int NvDsPostProcessSegmentationOutput::width |
Same as network width.
Definition at line 470 of file post_processor_struct.h.
