7.1 Release
NvDsPreProcessConfig Struct Reference
Definition at line 23 of file deepstream_preprocess.h.
Data Fields
gboolean enable
 create a bin for the element only if enabled More...
gint operate_on_gie_id
gboolean is_operate_on_gie_id_set
gchar * config_file_path
 config file path having properties for preprocess More...
Field Documentation
◆ config_file_path
gchar* NvDsPreProcessConfig::config_file_path
Definition at line 31 of file deepstream_preprocess.h.
◆ enable
gboolean NvDsPreProcessConfig::enable
Definition at line 26 of file deepstream_preprocess.h.
◆ is_operate_on_gie_id_set
gboolean NvDsPreProcessConfig::is_operate_on_gie_id_set
Definition at line 29 of file deepstream_preprocess.h.
◆ operate_on_gie_id
gint NvDsPreProcessConfig::operate_on_gie_id
Definition at line 28 of file deepstream_preprocess.h.
