struct denoting properties set by config file
Definition at line 146 of file gstnvdspreprocess.h.
Data Fields | |
| gboolean | processing_width |
| for config param : processsing-width More... | |
| gboolean | processing_height |
| for config param : processsing-height More... | |
| gboolean | network_input_order |
| for config param : network-input-order More... | |
| gboolean | network_input_shape |
| for config param : network-input-shape More... | |
| gboolean | network_color_format |
| for config param : network-color-format More... | |
| gboolean | tensor_data_type |
| for config param : tensor-data-type More... | |
| gboolean | tensor_name |
| for config param : tensor-name More... | |
| gboolean | custom_lib_path |
| for config param : custom-lib-path More... | |
| gboolean | custom_tensor_function_name |
| for config param : custom-tensor-function-name More... | |
| gboolean | src_ids |
| for config param : src-ids More... | |
| gboolean | operate_on_class_ids |
| for config param : operate-on-class-ids More... | |
| gboolean | process_on_roi |
| for config param : process-on-rois More... | |
| gboolean | process_on_all_objects |
| for config param : process-on-all-objects More... | |
| gboolean | roi_params_src |
| for config param : roi-params-src More... | |
| gboolean | scaling_pool_interpolation_filter |
| for config param : scaling-pool-interpolation-filter More... | |
| gboolean | scaling_pool_memory_type |
| for config param : scaling-pool-memory-type More... | |
| gboolean | draw_roi |
| for config param : draw_roi More... | |
| gboolean | roi_color |
| for config param : roi_color More... | |
| gboolean | min_input_object_width |
| for config param : input-object-min-width More... | |
| gboolean | min_input_object_height |
| for config param : input-object-min-height More... | |
| gboolean | max_input_object_width |
| for config param : input-object-max-width More... | |
| gboolean | max_input_object_height |
| for config param : input-object-max-height More... | |
| gboolean | interval |
| for config param : interval More... | |
| gboolean NvDsPreProcessPropertySet::custom_lib_path |
Definition at line 162 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::custom_tensor_function_name |
Definition at line 164 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::draw_roi |
Definition at line 180 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::interval |
Definition at line 192 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::max_input_object_height |
Definition at line 190 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::max_input_object_width |
Definition at line 188 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::min_input_object_height |
Definition at line 186 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::min_input_object_width |
Definition at line 184 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::network_color_format |
Definition at line 156 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::network_input_order |
Definition at line 152 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::network_input_shape |
Definition at line 154 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::operate_on_class_ids |
Definition at line 168 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::process_on_all_objects |
Definition at line 172 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::process_on_roi |
Definition at line 170 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::processing_height |
Definition at line 150 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::processing_width |
Definition at line 148 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::roi_color |
Definition at line 182 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::roi_params_src |
Definition at line 174 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::scaling_pool_interpolation_filter |
Definition at line 176 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::scaling_pool_memory_type |
Definition at line 178 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::src_ids |
Definition at line 166 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::tensor_data_type |
Definition at line 158 of file gstnvdspreprocess.h.
| gboolean NvDsPreProcessPropertySet::tensor_name |
Definition at line 160 of file gstnvdspreprocess.h.
