Definition at line 105 of file deepstream_sinks.h.
Data Fields | |
gboolean | enable |
gchar * | config_file_path |
MsgConv settings. More... | |
guint | conv_payload_type |
gchar * | conv_msg2p_lib |
guint | conv_comp_id |
gchar * | debug_payload_dir |
gboolean | multiple_payloads |
gboolean | conv_msg2p_new_api |
guint | conv_frame_interval |
gboolean | conv_dummy_payload |
gchar * | proto_lib |
Broker settings. More... | |
gchar * | conn_str |
gchar * | topic |
gchar * | broker_config_file_path |
guint | broker_comp_id |
gboolean | disable_msgconv |
gint | sync |
gboolean | new_api |
guint | broker_sleep_time |
guint NvDsSinkMsgConvBrokerConfig::broker_comp_id |
Definition at line 123 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::broker_config_file_path |
Definition at line 122 of file deepstream_sinks.h.
guint NvDsSinkMsgConvBrokerConfig::broker_sleep_time |
Definition at line 127 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::config_file_path |
MsgConv settings.
Definition at line 109 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::conn_str |
Definition at line 120 of file deepstream_sinks.h.
guint NvDsSinkMsgConvBrokerConfig::conv_comp_id |
Definition at line 112 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::conv_dummy_payload |
Definition at line 117 of file deepstream_sinks.h.
guint NvDsSinkMsgConvBrokerConfig::conv_frame_interval |
Definition at line 116 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::conv_msg2p_lib |
Definition at line 111 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::conv_msg2p_new_api |
Definition at line 115 of file deepstream_sinks.h.
guint NvDsSinkMsgConvBrokerConfig::conv_payload_type |
Definition at line 110 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::debug_payload_dir |
Definition at line 113 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::disable_msgconv |
Definition at line 124 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::enable |
Definition at line 107 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::multiple_payloads |
Definition at line 114 of file deepstream_sinks.h.
gboolean NvDsSinkMsgConvBrokerConfig::new_api |
Definition at line 126 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::proto_lib |
Broker settings.
Definition at line 119 of file deepstream_sinks.h.
gint NvDsSinkMsgConvBrokerConfig::sync |
Definition at line 125 of file deepstream_sinks.h.
gchar* NvDsSinkMsgConvBrokerConfig::topic |
Definition at line 121 of file deepstream_sinks.h.
