Definition at line 87 of file sources/apps/apps-common/includes/deepstream_sinks.h.
Data Fields | |
| NvDsSinkType | type |
| gint | width |
| gint | height |
| gint | sync |
| gboolean | qos |
| gboolean | qos_value_specified |
| guint | gpu_id |
| guint | nvbuf_memory_type |
| guint | offset_x |
| guint | offset_y |
| guint | color_range |
| guint | conn_id |
| guint | plane_id |
| gboolean | set_mode |
| guint NvDsSinkRenderConfig::color_range |
Definition at line 99 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::conn_id |
Definition at line 100 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::gpu_id |
Definition at line 95 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gint NvDsSinkRenderConfig::height |
Definition at line 91 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::nvbuf_memory_type |
Definition at line 96 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::offset_x |
Definition at line 97 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::offset_y |
Definition at line 98 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| guint NvDsSinkRenderConfig::plane_id |
Definition at line 101 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gboolean NvDsSinkRenderConfig::qos |
Definition at line 93 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gboolean NvDsSinkRenderConfig::qos_value_specified |
Definition at line 94 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gboolean NvDsSinkRenderConfig::set_mode |
Definition at line 102 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gint NvDsSinkRenderConfig::sync |
Definition at line 92 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| NvDsSinkType NvDsSinkRenderConfig::type |
Definition at line 89 of file sources/apps/apps-common/includes/deepstream_sinks.h.
| gint NvDsSinkRenderConfig::width |
Definition at line 90 of file sources/apps/apps-common/includes/deepstream_sinks.h.
