7.1 Release
NvDsStreammuxConfig Struct Reference
Definition at line 23 of file deepstream_streammux.h.
Data Fields
gint pipeline_width
gint pipeline_height
gint buffer_pool_size
gint batch_size
gint batched_push_timeout
gint compute_hw
gint num_surface_per_frame
gint interpolation_method
guint64 frame_duration
guint gpu_id
guint nvbuf_memory_type
gboolean live_source
gboolean enable_padding
gboolean is_parsed
gboolean attach_sys_ts_as_ntp
gchar * config_file_path
gboolean sync_inputs
guint64 max_latency
gboolean frame_num_reset_on_eos
gboolean frame_num_reset_on_stream_reset
gboolean async_process
gboolean no_pipeline_eos
gboolean use_nvmultiurisrcbin
gboolean extract_sei_type5_data
Field Documentation
◆ async_process
gboolean NvDsStreammuxConfig::async_process
Definition at line 46 of file deepstream_streammux.h.
◆ attach_sys_ts_as_ntp
gboolean NvDsStreammuxConfig::attach_sys_ts_as_ntp
Definition at line 40 of file deepstream_streammux.h.
◆ batch_size
gint NvDsStreammuxConfig::batch_size
Definition at line 29 of file deepstream_streammux.h.
◆ batched_push_timeout
gint NvDsStreammuxConfig::batched_push_timeout
Definition at line 30 of file deepstream_streammux.h.
◆ buffer_pool_size
gint NvDsStreammuxConfig::buffer_pool_size
Definition at line 28 of file deepstream_streammux.h.
◆ compute_hw
gint NvDsStreammuxConfig::compute_hw
Definition at line 31 of file deepstream_streammux.h.
◆ config_file_path
gchar* NvDsStreammuxConfig::config_file_path
Definition at line 41 of file deepstream_streammux.h.
◆ enable_padding
gboolean NvDsStreammuxConfig::enable_padding
Definition at line 38 of file deepstream_streammux.h.
◆ extract_sei_type5_data
gboolean NvDsStreammuxConfig::extract_sei_type5_data
Definition at line 49 of file deepstream_streammux.h.
◆ frame_duration
guint64 NvDsStreammuxConfig::frame_duration
Definition at line 34 of file deepstream_streammux.h.
◆ frame_num_reset_on_eos
gboolean NvDsStreammuxConfig::frame_num_reset_on_eos
Definition at line 44 of file deepstream_streammux.h.
◆ frame_num_reset_on_stream_reset
gboolean NvDsStreammuxConfig::frame_num_reset_on_stream_reset
Definition at line 45 of file deepstream_streammux.h.
◆ gpu_id
guint NvDsStreammuxConfig::gpu_id
Definition at line 35 of file deepstream_streammux.h.
◆ interpolation_method
gint NvDsStreammuxConfig::interpolation_method
Definition at line 33 of file deepstream_streammux.h.
◆ is_parsed
gboolean NvDsStreammuxConfig::is_parsed
Definition at line 39 of file deepstream_streammux.h.
◆ live_source
gboolean NvDsStreammuxConfig::live_source
Definition at line 37 of file deepstream_streammux.h.
◆ max_latency
guint64 NvDsStreammuxConfig::max_latency
Definition at line 43 of file deepstream_streammux.h.
◆ no_pipeline_eos
gboolean NvDsStreammuxConfig::no_pipeline_eos
Definition at line 47 of file deepstream_streammux.h.
◆ num_surface_per_frame
gint NvDsStreammuxConfig::num_surface_per_frame
Definition at line 32 of file deepstream_streammux.h.
◆ nvbuf_memory_type
guint NvDsStreammuxConfig::nvbuf_memory_type
Definition at line 36 of file deepstream_streammux.h.
◆ pipeline_height
gint NvDsStreammuxConfig::pipeline_height
Definition at line 27 of file deepstream_streammux.h.
◆ pipeline_width
gint NvDsStreammuxConfig::pipeline_width
Definition at line 26 of file deepstream_streammux.h.
◆ sync_inputs
gboolean NvDsStreammuxConfig::sync_inputs
Definition at line 42 of file deepstream_streammux.h.
◆ use_nvmultiurisrcbin
gboolean NvDsStreammuxConfig::use_nvmultiurisrcbin
Definition at line 48 of file deepstream_streammux.h.
