7.1 Release
NvStreammuxSourceProps Struct Reference
Definition at line 39 of file nvstreammux_batch.h.
Data Fields
unsigned int source_max_fps_n
unsigned int source_max_fps_d
unsigned int source_min_fps_n
unsigned int source_min_fps_d
unsigned int priority
unsigned int max_num_frames_per_batch
Field Documentation
◆ max_num_frames_per_batch
unsigned int NvStreammuxSourceProps::max_num_frames_per_batch
Definition at line 46 of file nvstreammux_batch.h.
◆ priority
unsigned int NvStreammuxSourceProps::priority
Definition at line 45 of file nvstreammux_batch.h.
◆ source_max_fps_d
unsigned int NvStreammuxSourceProps::source_max_fps_d
Definition at line 42 of file nvstreammux_batch.h.
◆ source_max_fps_n
unsigned int NvStreammuxSourceProps::source_max_fps_n
Definition at line 41 of file nvstreammux_batch.h.
◆ source_min_fps_d
unsigned int NvStreammuxSourceProps::source_min_fps_d
Definition at line 44 of file nvstreammux_batch.h.
◆ source_min_fps_n
unsigned int NvStreammuxSourceProps::source_min_fps_n
Definition at line 43 of file nvstreammux_batch.h.
