Definition at line 76 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
Data Fields | |
NvDsUriSrcBinType | src_type |
gboolean | loop |
gchar * | uri |
gchar * | sei_uuid |
gint | latency |
NvDsUriSrcBinSRType | smart_record |
gchar * | smart_rec_dir_path |
gchar * | smart_rec_file_prefix |
NvDsUriSrcBinSRCont | smart_rec_container |
NvDsUriSrcBinSRMode | smart_rec_mode |
guint | smart_rec_def_duration |
guint | smart_rec_cache_size |
guint | gpu_id |
gint | source_id |
NvDsUriSrcBinRtpProtocol | rtp_protocol |
guint | num_extra_surfaces |
NvDsUriSrcBinDecSkipFrame | skip_frames_type |
guint | cuda_memory_type |
guint | drop_frame_interval |
gboolean | low_latency_mode |
gboolean | extract_sei_type5_data |
gint | rtsp_reconnect_interval_sec |
gint | rtsp_reconnect_attempts |
gint | num_rtsp_reconnects |
guint | udp_buffer_size |
gchar * | sensorId |
unique Sensor ID string More... | |
gboolean | disable_passthrough |
gchar * | sensorName |
Sensor Name string; could be NULL. More... | |
gboolean | disable_audio |
gboolean | drop_on_latency |
gboolean | ipc_buffer_timestamp_copy |
gchar * | ipc_socket_path |
gint | ipc_connection_attempts |
guint64 | ipc_connection_interval |
guint _GstDsNvUriSrcConfig::cuda_memory_type |
Definition at line 95 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::disable_audio |
Definition at line 106 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::disable_passthrough |
Definition at line 104 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::drop_frame_interval |
Definition at line 96 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::drop_on_latency |
Definition at line 107 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::extract_sei_type5_data |
Definition at line 98 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::gpu_id |
Definition at line 90 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::ipc_buffer_timestamp_copy |
Definition at line 108 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::ipc_connection_attempts |
Definition at line 110 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint64 _GstDsNvUriSrcConfig::ipc_connection_interval |
Definition at line 111 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::ipc_socket_path |
Definition at line 109 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::latency |
Definition at line 82 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::loop |
Definition at line 79 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gboolean _GstDsNvUriSrcConfig::low_latency_mode |
Definition at line 97 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::num_extra_surfaces |
Definition at line 93 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::num_rtsp_reconnects |
Definition at line 101 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinRtpProtocol _GstDsNvUriSrcConfig::rtp_protocol |
Definition at line 92 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::rtsp_reconnect_attempts |
Definition at line 100 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::rtsp_reconnect_interval_sec |
Definition at line 99 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::sei_uuid |
Definition at line 81 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::sensorId |
Definition at line 103 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::sensorName |
Definition at line 105 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinDecSkipFrame _GstDsNvUriSrcConfig::skip_frames_type |
Definition at line 94 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::smart_rec_cache_size |
Definition at line 89 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinSRCont _GstDsNvUriSrcConfig::smart_rec_container |
Definition at line 86 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::smart_rec_def_duration |
Definition at line 88 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::smart_rec_dir_path |
Definition at line 84 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::smart_rec_file_prefix |
Definition at line 85 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinSRMode _GstDsNvUriSrcConfig::smart_rec_mode |
Definition at line 87 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinSRType _GstDsNvUriSrcConfig::smart_record |
Definition at line 83 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gint _GstDsNvUriSrcConfig::source_id |
Definition at line 91 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
NvDsUriSrcBinType _GstDsNvUriSrcConfig::src_type |
Definition at line 78 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
guint _GstDsNvUriSrcConfig::udp_buffer_size |
Definition at line 102 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
gchar * _GstDsNvUriSrcConfig::uri |
Definition at line 80 of file libs/gstnvdscustomhelper/gst-nvdscommonconfig.h.
