7.1 Release
_NvDewarperSurfaceMeta Struct Reference
Holds a set of dewarper metadata.
Definition at line 93 of file nvds_dewarper_meta.h.
Data Fields
guint type [MAX_DEWARPED_VIEWS]
 Holds an array of the types of dewarped surfaces. More...
guint index [MAX_DEWARPED_VIEWS]
 Holds an array of indices of dewarped surfaces. More...
guint source_id
 Holds the source ID of the frame, e.g. More...
guint num_filled_surfaces
 Holds the number of filled surfaces in the frame. More...
Field Documentation
◆ index
guint _NvDewarperSurfaceMeta::index[MAX_DEWARPED_VIEWS]
Definition at line 97 of file nvds_dewarper_meta.h.
◆ num_filled_surfaces
guint _NvDewarperSurfaceMeta::num_filled_surfaces
Definition at line 101 of file nvds_dewarper_meta.h.
◆ source_id
guint _NvDewarperSurfaceMeta::source_id
the camera ID.
Definition at line 99 of file nvds_dewarper_meta.h.
◆ type
guint _NvDewarperSurfaceMeta::type[MAX_DEWARPED_VIEWS]
Definition at line 95 of file nvds_dewarper_meta.h.
