ds3d::Lidar3DBbox Struct Reference
Object 3D bounding box description.
vector of data stored into FrameGuard, dims as [batch, N, sizeof(Lidar3DBbox)];
Definition at line 42 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
Collaboration diagram for ds3d::Lidar3DBbox:
Public Member Functions
 Lidar3DBbox ()=default
 Lidar3DBbox (float centerX_, float centerY_, float centerZ_, float length_, float width_, float height_, float yaw_, int cid_, float score_)
void dump () const
void dump () const
void dump () const
void dump () const
Data Fields
float centerX = 0.0f
float centerY = 0.0f
float centerZ = 0.0f
float dx = 0.0f
float dy = 0.0f
float dz = 0.0f
float yaw = 0.0f
int cid = 0
float score = 0.0f
vec4f bboxColor = {{1.0f, 1.0f, 0, 1.0f}}
char labels [DS3D_MAX_LABEL_SIZE] = {0}
◆ Lidar3DBbox() [1/8]
ds3d::Lidar3DBbox::Lidar3DBbox ( )
default
◆ Lidar3DBbox() [2/8]
ds3d::Lidar3DBbox::Lidar3DBbox ( float  centerX_,
float  centerY_,
float  centerZ_,
float  length_,
float  width_,
float  height_,
float  yaw_,
int  cid_,
float  score_
inline
◆ Lidar3DBbox() [3/8]
default
◆ Lidar3DBbox() [4/8]
float  centerY_,
float  centerZ_,
float  length_,
float  width_,
float  height_,
float  yaw_,
int  cid_,
float  score_
inline
◆ Lidar3DBbox() [5/8]
default
◆ Lidar3DBbox() [6/8]
float  centerY_,
float  centerZ_,
float  length_,
float  width_,
float  height_,
float  yaw_,
int  cid_,
float  score_
inline
◆ Lidar3DBbox() [7/8]
default
◆ Lidar3DBbox() [8/8]
float  centerY_,
float  centerZ_,
float  length_,
float  width_,
float  height_,
float  yaw_,
int  cid_,
float  score_
inline
Member Function Documentation
◆ dump() [1/4]
void ds3d::Lidar3DBbox::dump ( ) const
inline
◆ dump() [2/4]
inline
◆ dump() [3/4]
inline
◆ dump() [4/4]
inline
Field Documentation
◆ bboxColor
vec4f ds3d::Lidar3DBbox::bboxColor = {{1.0f, 1.0f, 0, 1.0f}}
◆ centerX
float ds3d::Lidar3DBbox::centerX = 0.0f
Definition at line 43 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
Referenced by dump().
◆ centerY
float ds3d::Lidar3DBbox::centerY = 0.0f
Definition at line 44 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ centerZ
float ds3d::Lidar3DBbox::centerZ = 0.0f
Definition at line 45 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ cid
int ds3d::Lidar3DBbox::cid = 0
◆ dx
float ds3d::Lidar3DBbox::dx = 0.0f
Definition at line 46 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ dy
float ds3d::Lidar3DBbox::dy = 0.0f
Definition at line 47 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ dz
float ds3d::Lidar3DBbox::dz = 0.0f
Definition at line 48 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ labels
char ds3d::Lidar3DBbox::labels = {0}
Definition at line 53 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ score
float ds3d::Lidar3DBbox::score = 0.0f
Definition at line 51 of file sources/includes/ds3d/common/ds3d_analysis_datatype.h.
◆ yaw
float ds3d::Lidar3DBbox::yaw = 0.0f
The documentation for this struct was generated from the following files:
