Holds the configuration information from the nvinferserver element properties.
Definition at line 114 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
Data Fields | |
| std::string | configPath |
| uint32_t | maxBatchSize = 0 |
| int32_t | interval = -1 |
| uint32_t | uniqueId = 0 |
| uint32_t | processMode = 0 |
| int32_t | inferOnGieId = -1 |
| bool | inputTensorFromMeta = false |
| std::vector< int32_t > | operateOnClassIds |
| std::string | classifierType |
| std::string gstnvinferserver::GstNvInferServerProperties::classifierType |
Definition at line 123 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
Referenced by gstnvinferserver::GstNvInferServerImpl::classifierType().
| std::string gstnvinferserver::GstNvInferServerProperties::configPath |
Definition at line 115 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| int32_t gstnvinferserver::GstNvInferServerProperties::inferOnGieId = -1 |
Definition at line 120 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| bool gstnvinferserver::GstNvInferServerProperties::inputTensorFromMeta = false |
Definition at line 121 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| int32_t gstnvinferserver::GstNvInferServerProperties::interval = -1 |
Definition at line 117 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| uint32_t gstnvinferserver::GstNvInferServerProperties::maxBatchSize = 0 |
Definition at line 116 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| std::vector< int32_t > gstnvinferserver::GstNvInferServerProperties::operateOnClassIds |
Definition at line 122 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| uint32_t gstnvinferserver::GstNvInferServerProperties::processMode = 0 |
Definition at line 119 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| uint32_t gstnvinferserver::GstNvInferServerProperties::uniqueId = 0 |
Definition at line 118 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
Referenced by gstnvinferserver::GstNvInferServerImpl::uniqueId().
