Holds information about the detected objects in the specific input source.
Definition at line 102 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
Data Fields | |
| GstNvInferServerObjectHistoryMap | object_history_map |
| Map of object tracking IDs and inference history of the object. More... | |
| gulong | last_cleanup_frame_num = 0 |
| Frame number of the buffer when the history map was last cleaned up. More... | |
| gulong | last_seen_frame_num = 0 |
| Frame number of the frame which . More... | |
| gulong gstnvinferserver::GstNvInferServerSourceInfo::last_cleanup_frame_num = 0 |
Definition at line 106 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| gulong gstnvinferserver::GstNvInferServerSourceInfo::last_seen_frame_num = 0 |
Definition at line 108 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
| GstNvInferServerObjectHistoryMap gstnvinferserver::GstNvInferServerSourceInfo::object_history_map |
Definition at line 104 of file sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.h.
