Data structure contaning all the parameters specified in one row of an Aisle CSV file.
Definition at line 34 of file nv_aisle_csvparser.hpp.
Data Fields | |
| uint32_t | cameraId |
| Serial number for each Aisle View Camera Entry. More... | |
| uint32_t | rowId |
| Row entry number in the CSV file. More... | |
| string | level |
| Parking Level. More... | |
| string | cameraIDString |
| Camera ID String. More... | |
| string | aisleIdStr |
| Aisle ID string. More... | |
| uint32_t | aisleId |
| Set to 0/1 corrsponding to A0/A1 present in "aisleIdStr". More... | |
| double | dewarpTopAngle |
| Top & Bottom Field of View Angles, Viewing parameter : Pith, Yaw, Roll in degrees. More... | |
| double | dewarpBottomAngle |
| double | dewarpPitch |
| double | dewarpYaw |
| double | dewarpRoll |
| uint32_t | numROIpoints |
| Number of ROI co-ordinates. More... | |
| float | ROI_x0 |
| ROI Co-ordinates. More... | |
| float | ROI_y0 |
| float | ROI_x1 |
| float | ROI_y1 |
| float | ROI_x2 |
| float | ROI_y2 |
| float | ROI_x3 |
| float | ROI_y3 |
| float | ROI_x4 |
| float | ROI_y4 |
| float | ROI_x5 |
| float | ROI_y5 |
| float | ROI_x6 |
| float | ROI_y6 |
| float | ROI_x7 |
| float | ROI_y7 |
| float | gx0 |
| Global and Camera Co-ordinates. More... | |
| float | gy0 |
| float | gx1 |
| float | gy1 |
| float | gx2 |
| float | gy2 |
| float | gx3 |
| float | gy3 |
| float | cx0 |
| float | cy0 |
| float | cx1 |
| float | cy1 |
| float | cx2 |
| float | cy2 |
| float | cx3 |
| float | cy3 |
| int | entry |
| entry - 0 indicates no entry ROI, 1 indicates valid entry ROI More... | |
| int | exit |
| exit - 0 indicates no exit ROI, 1 indicates valid exit ROI More... | |
| float | entry_ROI_x0 |
| Entry ROI Co-ordinates. More... | |
| float | entry_ROI_y0 |
| float | entry_ROI_x1 |
| float | entry_ROI_y1 |
| float | entry_ROI_x2 |
| float | entry_ROI_y2 |
| float | entry_ROI_x3 |
| float | entry_ROI_y3 |
| float | exit_ROI_x0 |
| Exit ROI Co-ordinates. More... | |
| float | exit_ROI_y0 |
| float | exit_ROI_x1 |
| float | exit_ROI_y1 |
| float | exit_ROI_x2 |
| float | exit_ROI_y2 |
| float | exit_ROI_x3 |
| float | exit_ROI_y3 |
| string | sensorId |
| Sensor ID String. More... | |
| float | dewarpFocalLength |
| Focal Lenght of camera lens, in pixels per radian. More... | |
| uint32_t | dewarpWidth |
| dewarped surface width More... | |
| uint32_t | dewarpHeight |
| dewarped surface height More... | |
| double | h0 |
| Perspective Transformation Matrix matrix for camera points to global points transformation. More... | |
| double | h1 |
| double | h2 |
| double | h3 |
| double | h4 |
| double | h5 |
| double | h6 |
| double | h7 |
| double | h8 |
| uint32_t nvaisle_csv::_NvAisleCsvFields::aisleId |
Definition at line 42 of file nv_aisle_csvparser.hpp.
| string nvaisle_csv::_NvAisleCsvFields::aisleIdStr |
| uint32_t nvaisle_csv::_NvAisleCsvFields::cameraId |
1st column in CSV file
Definition at line 36 of file nv_aisle_csvparser.hpp.
| string nvaisle_csv::_NvAisleCsvFields::cameraIDString |
| float nvaisle_csv::_NvAisleCsvFields::cx0 |
Definition at line 52 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::cx1 |
| float nvaisle_csv::_NvAisleCsvFields::cx2 |
| float nvaisle_csv::_NvAisleCsvFields::cx3 |
| float nvaisle_csv::_NvAisleCsvFields::cy0 |
| float nvaisle_csv::_NvAisleCsvFields::cy1 |
| float nvaisle_csv::_NvAisleCsvFields::cy2 |
| float nvaisle_csv::_NvAisleCsvFields::cy3 |
| double nvaisle_csv::_NvAisleCsvFields::dewarpBottomAngle |
Definition at line 45 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::dewarpFocalLength |
Definition at line 63 of file nv_aisle_csvparser.hpp.
| uint32_t nvaisle_csv::_NvAisleCsvFields::dewarpHeight |
Definition at line 65 of file nv_aisle_csvparser.hpp.
| double nvaisle_csv::_NvAisleCsvFields::dewarpPitch |
| double nvaisle_csv::_NvAisleCsvFields::dewarpRoll |
| double nvaisle_csv::_NvAisleCsvFields::dewarpTopAngle |
| uint32_t nvaisle_csv::_NvAisleCsvFields::dewarpWidth |
Definition at line 64 of file nv_aisle_csvparser.hpp.
| double nvaisle_csv::_NvAisleCsvFields::dewarpYaw |
| int nvaisle_csv::_NvAisleCsvFields::entry |
Definition at line 54 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_x0 |
Definition at line 57 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_x1 |
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_x2 |
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_x3 |
Definition at line 58 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_y0 |
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_y1 |
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_y2 |
| float nvaisle_csv::_NvAisleCsvFields::entry_ROI_y3 |
| int nvaisle_csv::_NvAisleCsvFields::exit |
Definition at line 55 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_x0 |
Definition at line 60 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_x1 |
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_x2 |
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_x3 |
Definition at line 61 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_y0 |
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_y1 |
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_y2 |
| float nvaisle_csv::_NvAisleCsvFields::exit_ROI_y3 |
| float nvaisle_csv::_NvAisleCsvFields::gx0 |
| float nvaisle_csv::_NvAisleCsvFields::gx1 |
| float nvaisle_csv::_NvAisleCsvFields::gx2 |
| float nvaisle_csv::_NvAisleCsvFields::gx3 |
| float nvaisle_csv::_NvAisleCsvFields::gy0 |
| float nvaisle_csv::_NvAisleCsvFields::gy1 |
| float nvaisle_csv::_NvAisleCsvFields::gy2 |
| float nvaisle_csv::_NvAisleCsvFields::gy3 |
| double nvaisle_csv::_NvAisleCsvFields::h0 |
Definition at line 67 of file nv_aisle_csvparser.hpp.
| double nvaisle_csv::_NvAisleCsvFields::h1 |
| double nvaisle_csv::_NvAisleCsvFields::h2 |
| double nvaisle_csv::_NvAisleCsvFields::h3 |
| double nvaisle_csv::_NvAisleCsvFields::h4 |
| double nvaisle_csv::_NvAisleCsvFields::h5 |
| double nvaisle_csv::_NvAisleCsvFields::h6 |
| double nvaisle_csv::_NvAisleCsvFields::h7 |
| double nvaisle_csv::_NvAisleCsvFields::h8 |
| string nvaisle_csv::_NvAisleCsvFields::level |
| uint32_t nvaisle_csv::_NvAisleCsvFields::numROIpoints |
Definition at line 47 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::ROI_x0 |
ROI Co-ordinates.
Definition at line 49 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::ROI_x1 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_x2 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_x3 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_x4 |
Definition at line 50 of file nv_aisle_csvparser.hpp.
| float nvaisle_csv::_NvAisleCsvFields::ROI_x5 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_x6 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_x7 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y0 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y1 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y2 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y3 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y4 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y5 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y6 |
| float nvaisle_csv::_NvAisleCsvFields::ROI_y7 |
| uint32_t nvaisle_csv::_NvAisleCsvFields::rowId |
Definition at line 37 of file nv_aisle_csvparser.hpp.
| string nvaisle_csv::_NvAisleCsvFields::sensorId |
