nvdsinferserver::triton::BackendConfig Struct Reference
The backend configuration settings.
Definition at line 435 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
Data Fields
std::string backend
 Name of the backend. More...
std::string key
 Name of the setting. More...
std::string value
 Value of the setting. More...
Field Documentation
◆ backend
std::string nvdsinferserver::triton::BackendConfig::backend
Definition at line 439 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ key
std::string nvdsinferserver::triton::BackendConfig::key
Definition at line 443 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
◆ value
std::string nvdsinferserver::triton::BackendConfig::value
Definition at line 447 of file sources/libs/nvdsinferserver/infer_trtis_server.h.
