Macros | |
| #define | TRITONSERVER_DECLSPEC |
| #define | TRITONSERVER_API_VERSION_MAJOR 1 |
| TRITONSERVER API Version. More... | |
| #define | TRITONSERVER_API_VERSION_MINOR 34 |
Typedefs | |
| typedef enum TRITONSERVER_datatype_enum | TRITONSERVER_DataType |
| TRITONSERVER_DataType. More... | |
| typedef enum TRITONSERVER_memorytype_enum | TRITONSERVER_MemoryType |
| TRITONSERVER_MemoryType. More... | |
| typedef enum TRITONSERVER_parametertype_enum | TRITONSERVER_ParameterType |
| TRITONSERVER_ParameterType. More... | |
| typedef enum TRITONSERVER_instancegroupkind_enum | TRITONSERVER_InstanceGroupKind |
| TRITONSERVER_InstanceGroupKind. More... | |
| typedef enum TRITONSERVER_loglevel_enum | TRITONSERVER_LogLevel |
| TRITONSERVER_Logging. More... | |
| typedef enum TRITONSERVER_logformat_enum | TRITONSERVER_LogFormat |
| Logging Formats. More... | |
| typedef enum TRITONSERVER_errorcode_enum | TRITONSERVER_Error_Code |
| TRITONSERVER_Error. More... | |
| typedef struct TRITONSERVER_Error *(* | TRITONSERVER_ResponseAllocatorAllocFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp, void **buffer, void **buffer_userp, TRITONSERVER_MemoryType *actual_memory_type, int64_t *actual_memory_type_id) |
| TRITONSERVER_ResponseAllocator. More... | |
| typedef struct TRITONSERVER_Error *(* | TRITONSERVER_ResponseAllocatorBufferAttributesFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, struct TRITONSERVER_BufferAttributes *buffer_attributes, void *userp, void *buffer_userp) |
| Type for allocation function that allocates a buffer to hold an output tensor with buffer attributes. More... | |
| typedef struct TRITONSERVER_Error *(* | TRITONSERVER_ResponseAllocatorQueryFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp, const char *tensor_name, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id) |
| Type for function that is called to query the allocator's preferred memory type and memory type ID. More... | |
| typedef struct TRITONSERVER_Error *(* | TRITONSERVER_ResponseAllocatorReleaseFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *buffer, void *buffer_userp, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id) |
| Type for function that is called when the server no longer holds any reference to a buffer allocated by TRITONSERVER_ResponseAllocatorAllocFn_t. More... | |
| typedef struct TRITONSERVER_Error *(* | TRITONSERVER_ResponseAllocatorStartFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp) |
| Type for function that is called to indicate that subsequent allocation requests will refer to a new response. More... | |
| typedef enum tritonserver_metricformat_enum | TRITONSERVER_MetricFormat |
| TRITONSERVER_Metrics. More... | |
| typedef enum tritonserver_tracelevel_enum | TRITONSERVER_InferenceTraceLevel |
| TRITONSERVER_InferenceTrace. More... | |
| typedef enum tritonserver_traceactivity_enum | TRITONSERVER_InferenceTraceActivity |
| Trace activities. More... | |
| typedef void(* | TRITONSERVER_InferenceTraceActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, uint64_t timestamp_ns, void *userp) |
| Type for trace timeline activity callback function. More... | |
| typedef void(* | TRITONSERVER_InferenceTraceTensorActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, const char *name, TRITONSERVER_DataType datatype, const void *base, size_t byte_size, const int64_t *shape, uint64_t dim_count, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp) |
| Type for trace tensor activity callback function. More... | |
| typedef void(* | TRITONSERVER_InferenceTraceReleaseFn_t) (struct TRITONSERVER_InferenceTrace *trace, void *userp) |
| Type for trace release callback function. More... | |
| typedef enum tritonserver_requestflag_enum | TRITONSERVER_RequestFlag |
| TRITONSERVER_InferenceRequest. More... | |
| typedef enum tritonserver_requestreleaseflag_enum | TRITONSERVER_RequestReleaseFlag |
| Inference request release flags. More... | |
| typedef enum tritonserver_responsecompleteflag_enum | TRITONSERVER_ResponseCompleteFlag |
| Inference response complete flags. More... | |
| typedef void(* | TRITONSERVER_InferenceRequestReleaseFn_t) (struct TRITONSERVER_InferenceRequest *request, const uint32_t flags, void *userp) |
| Type for inference request release callback function. More... | |
| typedef void(* | TRITONSERVER_InferenceResponseCompleteFn_t) (struct TRITONSERVER_InferenceResponse *response, const uint32_t flags, void *userp) |
| Type for callback function indicating that an inference response has completed. More... | |
| typedef enum tritonserver_modelcontrolmode_enum | TRITONSERVER_ModelControlMode |
| TRITONSERVER_ServerOptions. More... | |
| typedef enum tritonserver_ratelimitmode_enum | TRITONSERVER_RateLimitMode |
| Rate limit modes. More... | |
| typedef enum tritonserver_batchflag_enum | TRITONSERVER_ModelBatchFlag |
| TRITONSERVER_Server. More... | |
| typedef enum tritonserver_modelindexflag_enum | TRITONSERVER_ModelIndexFlag |
| Model index flags. The enum values must be power-of-2 values. More... | |
| typedef enum tritonserver_txn_property_flag_enum | TRITONSERVER_ModelTxnPropertyFlag |
| Model transaction policy flags. More... | |
| typedef enum TRITONSERVER_metrickind_enum | TRITONSERVER_MetricKind |
| TRITONSERVER_MetricKind. More... | |
Functions | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ApiVersion (uint32_t *major, uint32_t *minor) |
| Get the TRITONBACKEND API version supported by the Triton shared library. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_DataTypeString (TRITONSERVER_DataType datatype) |
| Get the string representation of a data type. More... | |
| TRITONSERVER_DECLSPEC TRITONSERVER_DataType | TRITONSERVER_StringToDataType (const char *dtype) |
| Get the Triton datatype corresponding to a string representation of a datatype. More... | |
| TRITONSERVER_DECLSPEC uint32_t | TRITONSERVER_DataTypeByteSize (TRITONSERVER_DataType datatype) |
| Get the size of a Triton datatype in bytes. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_MemoryTypeString (TRITONSERVER_MemoryType memtype) |
| Get the string representation of a memory type. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_ParameterTypeString (TRITONSERVER_ParameterType paramtype) |
| Get the string representation of a parameter type. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter * | TRITONSERVER_ParameterNew (const char *name, const TRITONSERVER_ParameterType type, const void *value) |
| Create a new parameter object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter * | TRITONSERVER_ParameterBytesNew (const char *name, const void *byte_ptr, const uint64_t size) |
| Create a new parameter object with type TRITONSERVER_PARAMETER_BYTES. More... | |
| TRITONSERVER_DECLSPEC void | TRITONSERVER_ParameterDelete (struct TRITONSERVER_Parameter *parameter) |
| Delete an parameter object. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_InstanceGroupKindString (TRITONSERVER_InstanceGroupKind kind) |
| Get the string representation of an instance-group kind. More... | |
| TRITONSERVER_DECLSPEC bool | TRITONSERVER_LogIsEnabled (TRITONSERVER_LogLevel level) |
| Is a log level enabled? More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_LogMessage (TRITONSERVER_LogLevel level, const char *filename, const int line, const char *msg) |
| Log a message at a given log level if that level is enabled. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ErrorNew (TRITONSERVER_Error_Code code, const char *msg) |
| Create a new error object. More... | |
| TRITONSERVER_DECLSPEC void | TRITONSERVER_ErrorDelete (struct TRITONSERVER_Error *error) |
| Delete an error object. More... | |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error_Code | TRITONSERVER_ErrorCode (struct TRITONSERVER_Error *error) |
| Get the error code. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_ErrorCodeString (struct TRITONSERVER_Error *error) |
| Get the string representation of an error code. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_ErrorMessage (struct TRITONSERVER_Error *error) |
| Get the error message. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ResponseAllocatorNew (struct TRITONSERVER_ResponseAllocator **allocator, TRITONSERVER_ResponseAllocatorAllocFn_t alloc_fn, TRITONSERVER_ResponseAllocatorReleaseFn_t release_fn, TRITONSERVER_ResponseAllocatorStartFn_t start_fn) |
| Create a new response allocator object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ResponseAllocatorSetBufferAttributesFunction (struct TRITONSERVER_ResponseAllocator *allocator, TRITONSERVER_ResponseAllocatorBufferAttributesFn_t buffer_attributes_fn) |
| Set the buffer attributes function for a response allocator object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ResponseAllocatorSetQueryFunction (struct TRITONSERVER_ResponseAllocator *allocator, TRITONSERVER_ResponseAllocatorQueryFn_t query_fn) |
| Set the query function to a response allocator object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ResponseAllocatorDelete (struct TRITONSERVER_ResponseAllocator *allocator) |
| Delete a response allocator. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MessageNewFromSerializedJson (struct TRITONSERVER_Message **message, const char *base, size_t byte_size) |
| TRITONSERVER_Message. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MessageDelete (struct TRITONSERVER_Message *message) |
| Delete a message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MessageSerializeToJson (struct TRITONSERVER_Message *message, const char **base, size_t *byte_size) |
| Get the base and size of the buffer containing the serialized message in JSON format. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricsDelete (struct TRITONSERVER_Metrics *metrics) |
| Delete a metrics object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricsFormatted (struct TRITONSERVER_Metrics *metrics, TRITONSERVER_MetricFormat format, const char **base, size_t *byte_size) |
| Get a buffer containing the metrics in the specified format. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_InferenceTraceLevelString (TRITONSERVER_InferenceTraceLevel level) |
| Get the string representation of a trace level. More... | |
| const TRITONSERVER_DECLSPEC char * | TRITONSERVER_InferenceTraceActivityString (TRITONSERVER_InferenceTraceActivity activity) |
| Get the string representation of a trace activity. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceNew (struct TRITONSERVER_InferenceTrace **trace, TRITONSERVER_InferenceTraceLevel level, uint64_t parent_id, TRITONSERVER_InferenceTraceActivityFn_t activity_fn, TRITONSERVER_InferenceTraceReleaseFn_t release_fn, void *trace_userp) |
| Create a new inference trace object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceTensorNew (struct TRITONSERVER_InferenceTrace **trace, TRITONSERVER_InferenceTraceLevel level, uint64_t parent_id, TRITONSERVER_InferenceTraceActivityFn_t activity_fn, TRITONSERVER_InferenceTraceTensorActivityFn_t tensor_activity_fn, TRITONSERVER_InferenceTraceReleaseFn_t release_fn, void *trace_userp) |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error * | TRITONSERVER_InferenceTraceReportActivity (TRITONSERVER_InferenceTrace *trace, uint64_t timestamp, const char *activity_name) |
| Report a trace activity. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceDelete (struct TRITONSERVER_InferenceTrace *trace) |
| Delete a trace object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceId (struct TRITONSERVER_InferenceTrace *trace, uint64_t *id) |
| Get the id associated with a trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceParentId (struct TRITONSERVER_InferenceTrace *trace, uint64_t *parent_id) |
| Get the parent id associated with a trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceModelName (struct TRITONSERVER_InferenceTrace *trace, const char **model_name) |
| Get the name of the model associated with a trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceModelVersion (struct TRITONSERVER_InferenceTrace *trace, int64_t *model_version) |
| Get the version of the model associated with a trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceRequestId (struct TRITONSERVER_InferenceTrace *trace, const char **request_id) |
| Get the request id associated with a trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceSpawnChildTrace (struct TRITONSERVER_InferenceTrace *trace, struct TRITONSERVER_InferenceTrace **child_trace) |
| Get the child trace, spawned from the parent trace. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceSetContext (struct TRITONSERVER_InferenceTrace *trace, const char *trace_context) |
| Set TRITONSERVER_InferenceTrace context. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceTraceContext (struct TRITONSERVER_InferenceTrace *trace, const char **trace_context) |
| Get TRITONSERVER_InferenceTrace context. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestNew (struct TRITONSERVER_InferenceRequest **inference_request, struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version) |
| Create a new inference request object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestDelete (struct TRITONSERVER_InferenceRequest *inference_request) |
| Delete an inference request object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestId (struct TRITONSERVER_InferenceRequest *inference_request, const char **id) |
| Get the ID for a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetId (struct TRITONSERVER_InferenceRequest *inference_request, const char *id) |
| Set the ID for a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestFlags (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t *flags) |
| Get the flag(s) associated with a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetFlags (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t flags) |
| Set the flag(s) associated with a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestCorrelationId (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *correlation_id) |
| Get the correlation ID of the inference request as an unsigned integer. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestCorrelationIdString (struct TRITONSERVER_InferenceRequest *inference_request, const char **correlation_id) |
| Get the correlation ID of the inference request as a string. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetCorrelationId (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t correlation_id) |
| Set the correlation ID of the inference request to be an unsigned integer. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetCorrelationIdString (struct TRITONSERVER_InferenceRequest *inference_request, const char *correlation_id) |
| Set the correlation ID of the inference request to be a string. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestCancel (struct TRITONSERVER_InferenceRequest *inference_request) |
| Cancel an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestIsCancelled (struct TRITONSERVER_InferenceRequest *inference_request, bool *is_cancelled) |
| Query whether the request is cancelled or not. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestPriority (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t *priority) |
| Deprecated. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestPriorityUInt64 (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *priority) |
| Get the priority for a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetPriority (struct TRITONSERVER_InferenceRequest *inference_request, uint32_t priority) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetPriorityUInt64 (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t priority) |
| Set the priority for a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestTimeoutMicroseconds (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t *timeout_us) |
| Get the timeout for a request, in microseconds. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetTimeoutMicroseconds (struct TRITONSERVER_InferenceRequest *inference_request, uint64_t timeout_us) |
| Set the timeout for a request, in microseconds. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAddInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const TRITONSERVER_DataType datatype, const int64_t *shape, uint64_t dim_count) |
| Add an input to a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAddRawInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name) |
| Add a raw input to a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestRemoveInput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name) |
| Remove an input from a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestRemoveAllInputs (struct TRITONSERVER_InferenceRequest *inference_request) |
| Remove all inputs from a request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAppendInputData (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id) |
| Assign a buffer of data to an input. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, const char *host_policy_name) |
| Assign a buffer of data to an input for execution on all model instances with the specified host policy. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAppendInputDataWithBufferAttributes (struct TRITONSERVER_InferenceRequest *inference_request, const char *name, const void *base, struct TRITONSERVER_BufferAttributes *buffer_attributes) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestRemoveAllInputData (struct TRITONSERVER_InferenceRequest *inference_request, const char *name) |
| Clear all input data from an input, releasing ownership of the buffer(s) that were appended to the input with TRITONSERVER_InferenceRequestAppendInputData or TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestAddRequestedOutput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name) |
| Add an output request to an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestRemoveRequestedOutput (struct TRITONSERVER_InferenceRequest *inference_request, const char *name) |
| Remove an output request from an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestRemoveAllRequestedOutputs (struct TRITONSERVER_InferenceRequest *inference_request) |
| Remove all output requests from an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetReleaseCallback (struct TRITONSERVER_InferenceRequest *inference_request, TRITONSERVER_InferenceRequestReleaseFn_t request_release_fn, void *request_release_userp) |
| Set the release callback for an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetResponseCallback (struct TRITONSERVER_InferenceRequest *inference_request, struct TRITONSERVER_ResponseAllocator *response_allocator, void *response_allocator_userp, TRITONSERVER_InferenceResponseCompleteFn_t response_fn, void *response_userp) |
| Set the allocator and response callback for an inference request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetStringParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const char *value) |
| Set a string parameter in the request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetIntParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const int64_t value) |
| Set an integer parameter in the request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetBoolParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const bool value) |
| Set a boolean parameter in the request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceRequestSetDoubleParameter (struct TRITONSERVER_InferenceRequest *request, const char *key, const double value) |
| Set a double parameter in the request. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseDelete (struct TRITONSERVER_InferenceResponse *inference_response) |
| TRITONSERVER_InferenceResponse. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseError (struct TRITONSERVER_InferenceResponse *inference_response) |
| Return the error status of an inference response. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseModel (struct TRITONSERVER_InferenceResponse *inference_response, const char **model_name, int64_t *model_version) |
| Get model used to produce a response. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseId (struct TRITONSERVER_InferenceResponse *inference_response, const char **request_id) |
| Get the ID of the request corresponding to a response. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseParameterCount (struct TRITONSERVER_InferenceResponse *inference_response, uint32_t *count) |
| Get the number of parameters available in the response. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseParameter (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const char **name, TRITONSERVER_ParameterType *type, const void **vvalue) |
| Get all information about a parameter. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseOutputCount (struct TRITONSERVER_InferenceResponse *inference_response, uint32_t *count) |
| Get the number of outputs available in the response. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseOutput (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const char **name, TRITONSERVER_DataType *datatype, const int64_t **shape, uint64_t *dim_count, const void **base, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id, void **userp) |
| Get all information about an output tensor. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_InferenceResponseOutputClassificationLabel (struct TRITONSERVER_InferenceResponse *inference_response, const uint32_t index, const size_t class_index, const char **label) |
| Get a classification label associated with an output for a given index. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesNew (struct TRITONSERVER_BufferAttributes **buffer_attributes) |
| TRITONSERVER_BufferAttributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesDelete (struct TRITONSERVER_BufferAttributes *buffer_attributes) |
| Delete a buffer attributes object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesSetMemoryTypeId (struct TRITONSERVER_BufferAttributes *buffer_attributes, int64_t memory_type_id) |
| Set the memory type id field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesSetMemoryType (struct TRITONSERVER_BufferAttributes *buffer_attributes, TRITONSERVER_MemoryType memory_type) |
| Set the memory type field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesSetCudaIpcHandle (struct TRITONSERVER_BufferAttributes *buffer_attributes, void *cuda_ipc_handle) |
| Set the CudaIpcHandle field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesSetByteSize (struct TRITONSERVER_BufferAttributes *buffer_attributes, size_t byte_size) |
| Set the byte size field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesMemoryTypeId (struct TRITONSERVER_BufferAttributes *buffer_attributes, int64_t *memory_type_id) |
| Get the memory type id field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesMemoryType (struct TRITONSERVER_BufferAttributes *buffer_attributes, TRITONSERVER_MemoryType *memory_type) |
| Get the memory type field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesCudaIpcHandle (struct TRITONSERVER_BufferAttributes *buffer_attributes, void **cuda_ipc_handle) |
| Get the CudaIpcHandle field of the buffer attributes object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_BufferAttributesByteSize (struct TRITONSERVER_BufferAttributes *buffer_attributes, size_t *byte_size) |
| Get the byte size field of the buffer attributes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsNew (struct TRITONSERVER_ServerOptions **options) |
| Create a new server options object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsDelete (struct TRITONSERVER_ServerOptions *options) |
| Delete a server options object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetServerId (struct TRITONSERVER_ServerOptions *options, const char *server_id) |
| Set the textual ID for the server in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelRepositoryPath (struct TRITONSERVER_ServerOptions *options, const char *model_repository_path) |
| Set the model repository path in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelControlMode (struct TRITONSERVER_ServerOptions *options, TRITONSERVER_ModelControlMode mode) |
| Set the model control mode in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetStartupModel (struct TRITONSERVER_ServerOptions *options, const char *model_name) |
| Set the model to be loaded at startup in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetStrictModelConfig (struct TRITONSERVER_ServerOptions *options, bool strict) |
| Enable or disable strict model configuration handling in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelConfigName (struct TRITONSERVER_ServerOptions *options, const char *model_config_name) |
| Set the custom model configuration name to load for all models. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetRateLimiterMode (struct TRITONSERVER_ServerOptions *options, TRITONSERVER_RateLimitMode mode) |
| Set the rate limit mode in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsAddRateLimiterResource (struct TRITONSERVER_ServerOptions *options, const char *resource_name, const size_t resource_count, const int device) |
| Add resource count for rate limiting. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetPinnedMemoryPoolByteSize (struct TRITONSERVER_ServerOptions *options, uint64_t size) |
| Set the total pinned memory byte size that the server can allocate in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetCudaMemoryPoolByteSize (struct TRITONSERVER_ServerOptions *options, int gpu_device, uint64_t size) |
| Set the total CUDA memory byte size that the server can allocate on given GPU device in a server options. More... | |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetCudaVirtualAddressSize (TRITONSERVER_ServerOptions *options, int gpu_device, size_t cuda_virtual_address_size) |
| Set the size of the virtual address space that will be used for growable memory in implicit state. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetResponseCacheByteSize (struct TRITONSERVER_ServerOptions *options, uint64_t size) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetCacheConfig (struct TRITONSERVER_ServerOptions *options, const char *cache_name, const char *config_json) |
| Set the cache config that will be used to initialize the cache implementation for "cache_name". More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetCacheDirectory (struct TRITONSERVER_ServerOptions *options, const char *cache_dir) |
| Set the directory containing cache shared libraries. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetMinSupportedComputeCapability (struct TRITONSERVER_ServerOptions *options, double cc) |
| Set the minimum support CUDA compute capability in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetExitOnError (struct TRITONSERVER_ServerOptions *options, bool exit) |
| Enable or disable exit-on-error in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetStrictReadiness (struct TRITONSERVER_ServerOptions *options, bool strict) |
| Enable or disable strict readiness handling in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetExitTimeout (struct TRITONSERVER_ServerOptions *options, unsigned int timeout) |
| Set the exit timeout, in seconds, for the server in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetBufferManagerThreadCount (struct TRITONSERVER_ServerOptions *options, unsigned int thread_count) |
| Set the number of threads used in buffer manager in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelLoadThreadCount (struct TRITONSERVER_ServerOptions *options, unsigned int thread_count) |
| Set the number of threads to concurrently load models in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelLoadRetryCount (struct TRITONSERVER_ServerOptions *options, unsigned int retry_count) |
| Set the number of retry to load a model in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelNamespacing (struct TRITONSERVER_ServerOptions *options, bool enable_namespace) |
| Enable model namespacing to allow serving models with the same name if they are in different namespaces. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetEnablePeerAccess (struct TRITONSERVER_ServerOptions *options, bool enable_peer_access) |
| Enable peer access to allow GPU device to directly access the memory of another GPU device. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogFile (struct TRITONSERVER_ServerOptions *options, const char *file) |
| Provide a log output file. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogInfo (struct TRITONSERVER_ServerOptions *options, bool log) |
| Enable or disable info level logging. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogWarn (struct TRITONSERVER_ServerOptions *options, bool log) |
| Enable or disable warning level logging. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogError (struct TRITONSERVER_ServerOptions *options, bool log) |
| Enable or disable error level logging. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogFormat (struct TRITONSERVER_ServerOptions *options, const TRITONSERVER_LogFormat format) |
| Set the logging format. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetLogVerbose (struct TRITONSERVER_ServerOptions *options, int level) |
| Set verbose logging level. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetMetrics (struct TRITONSERVER_ServerOptions *options, bool metrics) |
| Enable or disable metrics collection in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetGpuMetrics (struct TRITONSERVER_ServerOptions *options, bool gpu_metrics) |
| Enable or disable GPU metrics collection in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetCpuMetrics (struct TRITONSERVER_ServerOptions *options, bool cpu_metrics) |
| Enable or disable CPU metrics collection in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetMetricsInterval (struct TRITONSERVER_ServerOptions *options, uint64_t metrics_interval_ms) |
| Set the interval for metrics collection in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetBackendDirectory (struct TRITONSERVER_ServerOptions *options, const char *backend_dir) |
| Set the directory containing backend shared libraries. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetRepoAgentDirectory (struct TRITONSERVER_ServerOptions *options, const char *repoagent_dir) |
| Set the directory containing repository agent shared libraries. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetModelLoadDeviceLimit (struct TRITONSERVER_ServerOptions *options, const TRITONSERVER_InstanceGroupKind kind, const int device_id, const double fraction) |
| Specify the limit on memory usage as a fraction on the device identified by 'kind' and 'device_id'. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetBackendConfig (struct TRITONSERVER_ServerOptions *options, const char *backend_name, const char *setting, const char *value) |
| Set a configuration setting for a named backend in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetHostPolicy (struct TRITONSERVER_ServerOptions *options, const char *policy_name, const char *setting, const char *value) |
| Set a host policy setting for a given policy name in a server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerOptionsSetMetricsConfig (struct TRITONSERVER_ServerOptions *options, const char *name, const char *setting, const char *value) |
| Set a configuration setting for metrics in server options. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerNew (struct TRITONSERVER_Server **server, struct TRITONSERVER_ServerOptions *options) |
| Create a new server object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerDelete (struct TRITONSERVER_Server *server) |
| Delete a server object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerStop (struct TRITONSERVER_Server *server) |
| Stop a server object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerSetExitTimeout (struct TRITONSERVER_Server *server, unsigned int timeout) |
| Set the exit timeout on the server object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerRegisterModelRepository (struct TRITONSERVER_Server *server, const char *repository_path, const struct TRITONSERVER_Parameter **name_mapping, const uint32_t mapping_count) |
| Register a new model repository. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerUnregisterModelRepository (struct TRITONSERVER_Server *server, const char *repository_path) |
| Unregister a model repository. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerPollModelRepository (struct TRITONSERVER_Server *server) |
| Check the model repository for changes and update server state based on those changes. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerIsLive (struct TRITONSERVER_Server *server, bool *live) |
| Is the server live? More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerIsReady (struct TRITONSERVER_Server *server, bool *ready) |
| Is the server ready? More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelIsReady (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, bool *ready) |
| Is the model ready? More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelBatchProperties (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, uint32_t *flags, void **voidp) |
| Get the batch properties of the model. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelTransactionProperties (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, uint32_t *txn_flags, void **voidp) |
| Get the transaction policy of the model. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerMetadata (struct TRITONSERVER_Server *server, struct TRITONSERVER_Message **server_metadata) |
| Get the metadata of the server as a TRITONSERVER_Message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelMetadata (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, struct TRITONSERVER_Message **model_metadata) |
| Get the metadata of a model as a TRITONSERVER_Message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelStatistics (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, struct TRITONSERVER_Message **model_stats) |
| Get the statistics of a model as a TRITONSERVER_Message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelConfig (struct TRITONSERVER_Server *server, const char *model_name, const int64_t model_version, const uint32_t config_version, struct TRITONSERVER_Message **model_config) |
| Get the configuration of a model as a TRITONSERVER_Message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerModelIndex (struct TRITONSERVER_Server *server, uint32_t flags, struct TRITONSERVER_Message **model_index) |
| Get the index of all unique models in the model repositories as a TRITONSERVER_Message object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerLoadModel (struct TRITONSERVER_Server *server, const char *model_name) |
| Load the requested model or reload the model if it is already loaded. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerLoadModelWithParameters (struct TRITONSERVER_Server *server, const char *model_name, const struct TRITONSERVER_Parameter **parameters, const uint64_t parameter_count) |
| Load the requested model or reload the model if it is already loaded, with load parameters provided. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerUnloadModel (struct TRITONSERVER_Server *server, const char *model_name) |
| Unload the requested model. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerUnloadModelAndDependents (struct TRITONSERVER_Server *server, const char *model_name) |
| Unload the requested model, and also unload any dependent model that was loaded along with the requested model (for example, the models composing an ensemble). More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerMetrics (struct TRITONSERVER_Server *server, struct TRITONSERVER_Metrics **metrics) |
| Get the current metrics for the server. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_ServerInferAsync (struct TRITONSERVER_Server *server, struct TRITONSERVER_InferenceRequest *inference_request, struct TRITONSERVER_InferenceTrace *trace) |
| Perform inference using the meta-data and inputs supplied by the 'inference_request'. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricFamilyNew (struct TRITONSERVER_MetricFamily **family, const TRITONSERVER_MetricKind kind, const char *name, const char *description) |
| Create a new metric family object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricFamilyDelete (struct TRITONSERVER_MetricFamily *family) |
| Delete a metric family object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_GetMetricFamilyKind (struct TRITONSERVER_MetricFamily *family, TRITONSERVER_MetricKind *kind) |
| Get the TRITONSERVER_MetricKind of the metric family. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricArgsNew (struct TRITONSERVER_MetricArgs **args) |
| Create a new metric args object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricArgsSetHistogram (struct TRITONSERVER_MetricArgs *args, const double *buckets, const uint64_t buckets_count) |
| Set metric args with histogram metric parameter. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricArgsDelete (struct TRITONSERVER_MetricArgs *args) |
| Delete a metric args object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricNew (struct TRITONSERVER_Metric **metric, struct TRITONSERVER_MetricFamily *family, const struct TRITONSERVER_Parameter **labels, const uint64_t label_count) |
| Create a new metric object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricNewWithArgs (struct TRITONSERVER_Metric **metric, struct TRITONSERVER_MetricFamily *family, const struct TRITONSERVER_Parameter **labels, const uint64_t label_count, const struct TRITONSERVER_MetricArgs *args) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricDelete (struct TRITONSERVER_Metric *metric) |
| Delete a metric object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricValue (struct TRITONSERVER_Metric *metric, double *value) |
| Get the current value of a metric object. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricIncrement (struct TRITONSERVER_Metric *metric, double value) |
| Increment the current value of metric by value. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricSet (struct TRITONSERVER_Metric *metric, double value) |
| Set the current value of metric to value. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_MetricObserve (struct TRITONSERVER_Metric *metric, double value) |
| Sample an observation and count it to the appropriate bucket of a metric. More... | |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error * | TRITONSERVER_GetMetricKind (struct TRITONSERVER_Metric *metric, TRITONSERVER_MetricKind *kind) |
| Get the TRITONSERVER_MetricKind of metric of its corresponding family. More... | |
| #define TRITONSERVER_API_VERSION_MAJOR 1 |
The TRITONSERVER API is versioned with major and minor version numbers. Any change to the API that does not impact backwards compatibility (for example, adding a non-required function) increases the minor version number. Any change that breaks backwards compatibility (for example, deleting or changing the behavior of a function) increases the major version number. A client should check that the API version used to compile the client is compatible with the API version of the Triton shared library that it is linking against. This is typically done by code similar to the following which makes sure that the major versions are equal and that the minor version of the Triton shared library is >= the minor version used to build the client.
uint32_t api_version_major, api_version_minor; TRITONSERVER_ApiVersion(&api_version_major, &api_version_minor); if ((api_version_major != TRITONSERVER_API_VERSION_MAJOR) || (api_version_minor < TRITONSERVER_API_VERSION_MINOR)) { return TRITONSERVER_ErrorNew( TRITONSERVER_ERROR_UNSUPPORTED, "triton server API version does not support this client"); }
Definition at line 94 of file tritonserver.h.
| #define TRITONSERVER_API_VERSION_MINOR 34 |
Definition at line 95 of file tritonserver.h.
| #define TRITONSERVER_DECLSPEC |
Definition at line 50 of file tritonserver.h.
| typedef enum TRITONSERVER_datatype_enum TRITONSERVER_DataType |
Tensor data types recognized by TRITONSERVER.
| typedef enum TRITONSERVER_errorcode_enum TRITONSERVER_Error_Code |
TRITONSERVER_Error.
Errors are reported by a TRITONSERVER_Error object. A NULL TRITONSERVER_Error indicates no error, a non-NULL TRITONSERVER_Error indicates error and the code and message for the error can be retrieved from the object.
The caller takes ownership of a TRITONSERVER_Error object returned by the API and must call TRITONSERVER_ErrorDelete to release the object. The TRITONSERVER_Error error codes
| typedef void(* TRITONSERVER_InferenceRequestReleaseFn_t) (struct TRITONSERVER_InferenceRequest *request, const uint32_t flags, void *userp) |
The callback indicates what type of release is being performed on the request and for some of these the callback function takes ownership of the TRITONSERVER_InferenceRequest object. The 'userp' data is the data provided as 'request_release_userp' in the call to TRITONSERVER_InferenceRequestSetReleaseCallback.
One or more flags will be specified when the callback is invoked, and the callback must take the following actions:
Note that currently TRITONSERVER_REQUEST_RELEASE_ALL should always be set when the callback is invoked but in the future that may change, so the callback should explicitly check for the flag before taking ownership of the request object.
Definition at line 1004 of file tritonserver.h.
| typedef void(* TRITONSERVER_InferenceResponseCompleteFn_t) (struct TRITONSERVER_InferenceResponse *response, const uint32_t flags, void *userp) |
The callback function takes ownership of the TRITONSERVER_InferenceResponse object. The 'userp' data is the data provided as 'response_userp' in the call to TRITONSERVER_InferenceRequestSetResponseCallback.
One or more flags may be specified when the callback is invoked:
Definition at line 1025 of file tritonserver.h.
Trace activities.
| typedef void(* TRITONSERVER_InferenceTraceActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, uint64_t timestamp_ns, void *userp) |
This callback function is used to report activity occurring for a trace. This function does not take ownership of 'trace' and so any information needed from that object must be copied before returning. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceNew.
Definition at line 755 of file tritonserver.h.
Object that represents tracing for an inference request. Trace levels. The trace level controls the type of trace activities that are reported for an inference request.
Trace level values are power-of-2 and can be combined to trace multiple types of activities. For example, use (TRITONSERVER_TRACE_LEVEL_TIMESTAMPS | TRITONSERVER_TRACE_LEVEL_TENSORS) to trace both timestamps and tensors for an inference request.
TRITONSERVER_TRACE_LEVEL_MIN and TRITONSERVER_TRACE_LEVEL_MAX are deprecated and should not be used.
| typedef void(* TRITONSERVER_InferenceTraceReleaseFn_t) (struct TRITONSERVER_InferenceTrace *trace, void *userp) |
This callback function is called when all activity for the trace has completed. The callback function takes ownership of the TRITONSERVER_InferenceTrace object. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceNew.
Definition at line 778 of file tritonserver.h.
| typedef void(* TRITONSERVER_InferenceTraceTensorActivityFn_t) (struct TRITONSERVER_InferenceTrace *trace, TRITONSERVER_InferenceTraceActivity activity, const char *name, TRITONSERVER_DataType datatype, const void *base, size_t byte_size, const int64_t *shape, uint64_t dim_count, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp) |
This callback function is used to report tensor activity occurring for a trace. This function does not take ownership of 'trace' and so any information needed from that object must be copied before returning. The 'userp' data is the same as what is supplied in the call to TRITONSERVER_InferenceTraceTensorNew.
Definition at line 766 of file tritonserver.h.
Kinds of instance groups recognized by TRITONSERVER.
| typedef enum TRITONSERVER_logformat_enum TRITONSERVER_LogFormat |
Logging Formats.
The TRITONSERVER API offers two logging formats. The formats have a common set of fields but differ in how the timestamp for a log entry is represented. Messages are serialized according to JSON encoding rules by default. This behavior can be disabled by setting the environment variable TRITON_SERVER_ESCAPE_LOG_MESSAGES to "0".
<level><month><day><hour>:<min>:<sec>.<usec> <pid> <file>:<line>] <msg>
Example:
I0520 20:03:25.829575 3355 model_lifecycle.cc:441] "AsyncLoad() 'simple'"
<year>-<month>-<day>T<hour>:<min>:<sec>Z <level> <pid> <file>:<line>] <msg>
Example:
2024-05-20T20:03:26Z I 3415 model_lifecycle.cc:441] "AsyncLoad() 'simple'"
| typedef enum TRITONSERVER_loglevel_enum TRITONSERVER_LogLevel |
Types/levels of logging.
| typedef enum TRITONSERVER_memorytype_enum TRITONSERVER_MemoryType |
Types of memory recognized by TRITONSERVER.
| typedef enum tritonserver_metricformat_enum TRITONSERVER_MetricFormat |
Object representing metrics. Metric format types
| typedef enum TRITONSERVER_metrickind_enum TRITONSERVER_MetricKind |
Types of metrics recognized by TRITONSERVER.
| typedef enum tritonserver_batchflag_enum TRITONSERVER_ModelBatchFlag |
An inference server. Model batch flags. The enum values must be power-of-2 values.
Options to use when creating an inference server. Model control modes
Types of parameters recognized by TRITONSERVER.
Rate limit modes.
| typedef enum tritonserver_requestflag_enum TRITONSERVER_RequestFlag |
Object representing an inference request. The inference request provides the meta-data and input tensor values needed for an inference and returns the inference result meta-data and output tensors. An inference request object can be modified and reused multiple times. Inference request flags. The enum values must be power-of-2 values.
| typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorAllocFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id, void *userp, void **buffer, void **buffer_userp, TRITONSERVER_MemoryType *actual_memory_type, int64_t *actual_memory_type_id) |
Object representing a memory allocator for output tensors in an inference response. Type for allocation function that allocates a buffer to hold an output tensor.
| allocator | The allocator that is provided in the call to TRITONSERVER_InferenceRequestSetResponseCallback. |
| tensor_name | The name of the output tensor to allocate for. |
| byte_size | The size of the buffer to allocate. |
| memory_type | The type of memory that the caller prefers for the buffer allocation. |
| memory_type_id | The ID of the memory that the caller prefers for the buffer allocation. |
| userp | The user data pointer that is provided as 'response_allocator_userp' in the call to TRITONSERVER_InferenceRequestSetResponseCallback. |
| buffer | Returns a pointer to the allocated memory. |
| buffer_userp | Returns a user-specified value to associate with the buffer, or nullptr if no user-specified value should be associated with the buffer. This value will be provided in the call to TRITONSERVER_ResponseAllocatorReleaseFn_t when the buffer is released and will also be returned by TRITONSERVER_InferenceResponseOutput. |
| actual_memory_type | Returns the type of memory where the allocation resides. May be different than the type of memory requested by 'memory_type'. |
| actual_memory_type_id | Returns the ID of the memory where the allocation resides. May be different than the ID of the memory requested by 'memory_type_id'. |
Definition at line 414 of file tritonserver.h.
| typedef struct TRITONSERVER_Error*( * TRITONSERVER_ResponseAllocatorBufferAttributesFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, const char *tensor_name, struct TRITONSERVER_BufferAttributes *buffer_attributes, void *userp, void *buffer_userp) |
The callback function must fill in the appropriate buffer attributes information related to this buffer. If set, this function is always called after TRITONSERVER_ResponseAllocatorAllocFn_t function.
| buffer_attributes | The buffer attributes associated with the buffer. |
Definition at line 444 of file tritonserver.h.
| typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorQueryFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp, const char *tensor_name, size_t *byte_size, TRITONSERVER_MemoryType *memory_type, int64_t *memory_type_id) |
As much as possible, the allocator should attempt to return the same memory_type and memory_type_id values that will be returned by the subsequent call to TRITONSERVER_ResponseAllocatorAllocFn_t. But the allocator is not required to do so.
| tensor_name | The name of the output tensor. This is optional and it should be set to nullptr to indicate that the tensor name has not determined. |
| byte_size | The expected size of the buffer. This is optional and it should be set to nullptr to indicate that the byte size has not determined. |
| memory_type | Acts as both input and output. On input gives the memory type preferred by the caller. Returns memory type preferred by the allocator, taken account of the caller preferred type. |
| memory_type_id | Acts as both input and output. On input gives the memory type ID preferred by the caller. Returns memory type ID preferred by the allocator, taken account of the caller preferred type ID. |
Definition at line 473 of file tritonserver.h.
| typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorReleaseFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *buffer, void *buffer_userp, size_t byte_size, TRITONSERVER_MemoryType memory_type, int64_t memory_type_id) |
In practice this function is typically called when the response object associated with the buffer is deleted by TRITONSERVER_InferenceResponseDelete.
| buffer | Pointer to the buffer to be freed. |
| buffer_userp | The user-specified value associated with the buffer in TRITONSERVER_ResponseAllocatorAllocFn_t. |
| byte_size | The size of the buffer. |
| memory_type | The type of memory holding the buffer. |
| memory_type_id | The ID of the memory holding the buffer. |
Definition at line 495 of file tritonserver.h.
| typedef struct TRITONSERVER_Error*(* TRITONSERVER_ResponseAllocatorStartFn_t) (struct TRITONSERVER_ResponseAllocator *allocator, void *userp) |
Definition at line 509 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_BATCH_UNKNOWN | |
| TRITONSERVER_BATCH_FIRST_DIM | |
Definition at line 2270 of file tritonserver.h.
Definition at line 115 of file tritonserver.h.
TRITONSERVER_Error.
Definition at line 324 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_INSTANCEGROUPKIND_AUTO | |
| TRITONSERVER_INSTANCEGROUPKIND_CPU | |
| TRITONSERVER_INSTANCEGROUPKIND_GPU | |
| TRITONSERVER_INSTANCEGROUPKIND_MODEL | |
Definition at line 236 of file tritonserver.h.
Logging Formats.
Example:
Example:
| Enumerator | |
| TRITONSERVER_LOG_DEFAULT | |
| TRITONSERVER_LOG_ISO8601 | |
Definition at line 289 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_LOG_INFO | |
| TRITONSERVER_LOG_WARN | |
| TRITONSERVER_LOG_ERROR | |
| TRITONSERVER_LOG_VERBOSE | |
Definition at line 256 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_MEMORY_CPU | |
| TRITONSERVER_MEMORY_CPU_PINNED | |
| TRITONSERVER_MEMORY_GPU | |
Definition at line 163 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_METRIC_PROMETHEUS | |
Definition at line 652 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_METRIC_KIND_COUNTER | |
| TRITONSERVER_METRIC_KIND_GAUGE | |
| TRITONSERVER_METRIC_KIND_HISTOGRAM | |
Definition at line 2617 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_MODEL_CONTROL_NONE | |
| TRITONSERVER_MODEL_CONTROL_POLL | |
| TRITONSERVER_MODEL_CONTROL_EXPLICIT | |
Definition at line 1761 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_INDEX_FLAG_READY | |
Definition at line 2276 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_PARAMETER_STRING | |
| TRITONSERVER_PARAMETER_INT | |
| TRITONSERVER_PARAMETER_BOOL | |
| TRITONSERVER_PARAMETER_DOUBLE | |
| TRITONSERVER_PARAMETER_BYTES | |
Definition at line 182 of file tritonserver.h.
Rate limit modes.
| Enumerator | |
| TRITONSERVER_RATE_LIMIT_OFF | |
| TRITONSERVER_RATE_LIMIT_EXEC_COUNT | |
Definition at line 1768 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_REQUEST_FLAG_SEQUENCE_START | |
| TRITONSERVER_REQUEST_FLAG_SEQUENCE_END | |
Definition at line 957 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_REQUEST_RELEASE_ALL | |
| TRITONSERVER_REQUEST_RELEASE_RESCHEDULE | |
Definition at line 964 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_RESPONSE_COMPLETE_FINAL | |
Definition at line 971 of file tritonserver.h.
Trace activities.
Definition at line 726 of file tritonserver.h.
Definition at line 703 of file tritonserver.h.
| Enumerator | |
| TRITONSERVER_TXN_ONE_TO_ONE | |
| TRITONSERVER_TXN_DECOUPLED | |
Definition at line 2282 of file tritonserver.h.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ApiVersion | ( | uint32_t * | major, |
| uint32_t * | minor | ||
This value can be compared against the TRITONSERVER_API_VERSION_MAJOR and TRITONSERVER_API_VERSION_MINOR used to build the client to ensure that Triton shared library is compatible with the client.
| major | Returns the TRITONSERVER API major version supported by Triton. |
| minor | Returns the TRITONSERVER API minor version supported by Triton. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesByteSize | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| size_t * | byte_size | ||
| buffer_attributes | The buffer attributes object. |
| byte_size | Returns the byte size associated with the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesCudaIpcHandle | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| void ** | cuda_ipc_handle | ||
| cuda_ipc_handle | Returns the memory type associated with the buffer attributes object. If the cudaIpcHandle does not exist for the buffer, nullptr will be returned. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesDelete | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes | ) |
| buffer_attributes | The buffer_attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesMemoryType | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| TRITONSERVER_MemoryType * | memory_type | ||
| memory_type | Returns the memory type associated with the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesMemoryTypeId | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| int64_t * | memory_type_id | ||
| memory_type_id | Returns the memory type id associated with the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesNew | ( | struct TRITONSERVER_BufferAttributes ** | buffer_attributes | ) |
API to create, modify, or retrieve attributes associated with a buffer. Create a new buffer attributes object. The caller takes ownership of the TRITONSERVER_BufferAttributes object and must call TRITONSERVER_BufferAttributesDelete to release the object.
| buffer_attributes | Returns the new buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetByteSize | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| size_t | byte_size | ||
| byte_size | Byte size to assign to the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetCudaIpcHandle | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| void * | cuda_ipc_handle | ||
| cuda_ipc_handle | The CudaIpcHandle to assign to the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetMemoryType | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| TRITONSERVER_MemoryType | memory_type | ||
| memory_type | Memory type to assign to the buffer attributes object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_BufferAttributesSetMemoryTypeId | ( | struct TRITONSERVER_BufferAttributes * | buffer_attributes, |
| int64_t | memory_type_id | ||
| memory_type_id | Memory type id to assign to the buffer attributes object. |
| TRITONSERVER_DECLSPEC uint32_t TRITONSERVER_DataTypeByteSize | ( | TRITONSERVER_DataType | datatype | ) |
Zero is returned for TRITONSERVER_TYPE_BYTES because it have variable size. Zero is returned for TRITONSERVER_TYPE_INVALID.
| dtype | The datatype. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_DataTypeString | ( | TRITONSERVER_DataType | datatype | ) |
The returned string is not owned by the caller and so should not be modified or freed.
| datatype | The data type. |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error_Code TRITONSERVER_ErrorCode | ( | struct TRITONSERVER_Error * | error | ) |
Get the error code.
| error | The error object. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_ErrorCodeString | ( | struct TRITONSERVER_Error * | error | ) |
The returned string is not owned by the caller and so should not be modified or freed. The lifetime of the returned string extends only as long as 'error' and must not be accessed once 'error' is deleted.
| TRITONSERVER_DECLSPEC void TRITONSERVER_ErrorDelete | ( | struct TRITONSERVER_Error * | error | ) |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_ErrorMessage | ( | struct TRITONSERVER_Error * | error | ) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ErrorNew | ( | TRITONSERVER_Error_Code | code, |
| const char * | msg | ||
The caller takes ownership of the TRITONSERVER_Error object and must call TRITONSERVER_ErrorDelete to release the object.
| code | The error code. |
| msg | The error message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_GetMetricFamilyKind | ( | struct TRITONSERVER_MetricFamily * | family, |
| TRITONSERVER_MetricKind * | kind | ||
| family | The metric family object to query. |
| kind | Returns the TRITONSERVER_MetricKind of metric. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_GetMetricKind | ( | struct TRITONSERVER_Metric * | metric, |
| metric | The metric object to query. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddInput | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char * | name, | ||
| const TRITONSERVER_DataType | datatype, | ||
| const int64_t * | shape, | ||
| uint64_t | dim_count | ||
| inference_request | The request object. |
| name | The name of the input. |
| datatype | The type of the input. Valid type names are BOOL, UINT8, UINT16, UINT32, UINT64, INT8, INT16, INT32, INT64, FP16, FP32, FP64, and BYTES. |
| shape | The shape of the input. |
| dim_count | The number of dimensions of 'shape'. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddRawInput | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char * | name | ||
The name recognized by the model, data type and shape of the input will be deduced from model configuration. This function must be called at most once on request with no other input to ensure the deduction is accurate.
| name | The name of the input. This name is only used as a reference of the raw input in other Tritonserver APIs. It doesn't associate with the name used in the model. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAddRequestedOutput | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| name | The name of the output. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputData | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const void * | base, | ||
| size_t | byte_size, | ||
| TRITONSERVER_MemoryType | memory_type, | ||
The buffer will be appended to any existing buffers for that input. The 'inference_request' object takes ownership of the buffer and so the caller should not modify or free the buffer until that ownership is released by 'inference_request' being deleted or by the input being removed from 'inference_request'.
| base | The base address of the input data. |
| byte_size | The size, in bytes, of the input data. |
| memory_type | The memory type of the input data. |
| memory_type_id | The memory type id of the input data. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputDataWithBufferAttributes | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| struct TRITONSERVER_BufferAttributes * | buffer_attributes | ||
| buffer_attributes | The buffer attributes of the input. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestAppendInputDataWithHostPolicy | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| int64_t | memory_type_id, | ||
| const char * | host_policy_name | ||
The buffer will be appended to any existing buffers for that input on all devices with this host policy. The 'inference_request' object takes ownership of the buffer and so the caller should not modify or free the buffer until that ownership is released by 'inference_request' being deleted or by the input being removed from 'inference_request'. If the execution is scheduled on a device that does not have a input buffer specified using this function, then the input buffer specified with TRITONSERVER_InferenceRequestAppendInputData will be used so a non-host policy specific version of data must be added using that API.
| host_policy_name | All model instances executing with this host_policy will use this input buffer for execution. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCancel | ( | struct TRITONSERVER_InferenceRequest * | inference_request | ) |
Requests are canceled on a best effort basis and no guarantee is provided that cancelling a request will result in early termination. Note that the inference request cancellation status will be reset after TRITONSERVER_InferAsync is run. This means that if you cancel the request before calling TRITONSERVER_InferAsync the request will not be cancelled.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCorrelationId | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t * | correlation_id | ||
Default is 0, which indicates that the request has no correlation ID. If the correlation id associated with the inference request is a string, this function will return a failure. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
| correlation_id | Returns the correlation ID. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestCorrelationIdString | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char ** | correlation_id | ||
Default is empty "", which indicates that the request has no correlation ID. If the correlation id associated with the inference request is an unsigned integer, then this function will return a failure. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestDelete | ( | struct TRITONSERVER_InferenceRequest * | inference_request | ) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestFlags | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint32_t * | flags | ||
On return 'flags' holds a bitwise-or of all flag values, see TRITONSERVER_RequestFlag for available flags.
| flags | Returns the flags. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestId | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char ** | id | ||
The returned ID is owned by 'inference_request' and must not be modified or freed by the caller.
| id | Returns the ID. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestIsCancelled | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| bool * | is_cancelled | ||
If possible the backend should terminate any processing and send an error response with cancelled status.
| is_cancelled | Returns whether the inference request is cancelled or not. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestNew | ( | struct TRITONSERVER_InferenceRequest ** | inference_request, |
| struct TRITONSERVER_Server * | server, | ||
| const char * | model_name, | ||
| const int64_t | model_version | ||
| inference_request | Returns the new request object. |
| server | the inference server object. |
| model_name | The name of the model to use for the request. |
| model_version | The version of the model to use for the request. If -1 then the server will choose a version based on the model's policy. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestPriority | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint32_t * | priority | ||
Deprecated.
See TRITONSERVER_InferenceRequestPriorityUInt64 instead.
Get the priority for a request. The default is 0 indicating that the request does not specify a priority and so will use the model's default priority.
| priority | Returns the priority level. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestPriorityUInt64 | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t * | priority | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllInputData | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllInputs | ( | struct TRITONSERVER_InferenceRequest * | inference_request | ) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveAllRequestedOutputs | ( | struct TRITONSERVER_InferenceRequest * | inference_request | ) |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveInput | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestRemoveRequestedOutput | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetBoolParameter | ( | struct TRITONSERVER_InferenceRequest * | request, |
| const char * | key, | ||
| const bool | value | ||
| request | The request. |
| key | The name of the parameter. |
| value | The value of the parameter. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetCorrelationId | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t | correlation_id | ||
Default is 0, which indicates that the request has no correlation ID. The correlation ID is used to indicate two or more inference request are related to each other. How this relationship is handled by the inference server is determined by the model's scheduling policy.
| correlation_id | The correlation ID. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetCorrelationIdString | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char * | correlation_id | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetDoubleParameter | ( | struct TRITONSERVER_InferenceRequest * | request, |
| const double | value | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetFlags | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint32_t | flags | ||
Set the flag(s) associated with a request.
'flags' should hold a bitwise-or of all flag values, see TRITONSERVER_RequestFlag for available flags.
| flags | The flags. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetId | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| const char * | id | ||
Set the ID for a request.
| id | The ID. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetIntParameter | ( | struct TRITONSERVER_InferenceRequest * | request, |
| const int64_t | value | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetPriority | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint32_t | priority | ||
Deprecated.
See TRITONSERVER_InferenceRequestSetPriorityUInt64 instead.
Set the priority for a request. The default is 0 indicating that the request does not specify a priority and so will use the model's default priority.
| priority | The priority level. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetPriorityUInt64 | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t | priority | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetReleaseCallback | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| TRITONSERVER_InferenceRequestReleaseFn_t | request_release_fn, | ||
| void * | request_release_userp | ||
The release callback is called by Triton to return ownership of the request object.
| request_release_fn | The function called to return ownership of the 'inference_request' object. |
| request_release_userp | User-provided pointer that is delivered to the 'request_release_fn' callback. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetResponseCallback | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| struct TRITONSERVER_ResponseAllocator * | response_allocator, | ||
| void * | response_allocator_userp, | ||
| TRITONSERVER_InferenceResponseCompleteFn_t | response_fn, | ||
| void * | response_userp | ||
The allocator is used to allocate buffers for any output tensors included in responses that are produced for this request. The response callback is called to return response objects representing responses produced for this request. Typically 'response_allocator_userp' and 'response_userp' will no longer be referenced after 'response_fn' is invoked with 'TRITONSERVER_RESPONSE_COMPLETE_FINAL' flag, therefore the user may release 'response_allocator_userp' and 'response_userp' at that point.
| response_allocator | The TRITONSERVER_ResponseAllocator to use to allocate buffers to hold inference results. |
| response_allocator_userp | User-provided pointer that is delivered to the response allocator's start and allocation functions. |
| response_fn | The function called to deliver an inference response for this request. |
| response_userp | User-provided pointer that is delivered to the 'response_fn' callback. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetStringParameter | ( | struct TRITONSERVER_InferenceRequest * | request, |
| const char * | value | ||
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestSetTimeoutMicroseconds | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t | timeout_us | ||
Set the timeout for a request, in microseconds.
The default is 0 which indicates that the request has no timeout.
| timeout_us | The timeout, in microseconds. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceRequestTimeoutMicroseconds | ( | struct TRITONSERVER_InferenceRequest * | inference_request, |
| uint64_t * | timeout_us | ||
Get the timeout for a request, in microseconds.
| timeout_us | Returns the timeout, in microseconds. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseDelete | ( | struct TRITONSERVER_InferenceResponse * | inference_response | ) |
Object representing an inference response. The inference response provides the meta-data and output tensor values calculated by the inference. Delete an inference response object.
| inference_response | The response object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseError | ( | struct TRITONSERVER_InferenceResponse * | inference_response | ) |
Return a TRITONSERVER_Error object on failure, return nullptr on success. The returned error object is owned by 'inference_response' and so should not be deleted by the caller.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseId | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| const char ** | request_id | ||
The caller does not own the returned ID and must not modify or delete it. The lifetime of all returned values extends until 'inference_response' is deleted.
| request_id | Returns the ID of the request corresponding to this response. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseModel | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| const char ** | model_name, | ||
| int64_t * | model_version | ||
The caller does not own the returned model name value and must not modify or delete it. The lifetime of all returned values extends until 'inference_response' is deleted.
| model_name | Returns the name of the model. |
| model_version | Returns the version of the model. this response. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutput | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| const uint32_t | index, | ||
| const char ** | name, | ||
| TRITONSERVER_DataType * | datatype, | ||
| const int64_t ** | shape, | ||
| uint64_t * | dim_count, | ||
| const void ** | base, | ||
| size_t * | byte_size, | ||
| TRITONSERVER_MemoryType * | memory_type, | ||
| int64_t * | memory_type_id, | ||
| void ** | userp | ||
The tensor data is returned as the base pointer to the data and the size, in bytes, of the data. The caller does not own any of the returned values and must not modify or delete them. The lifetime of all returned values extends until 'inference_response' is deleted.
| index | The index of the output tensor, must be 0 <= index < count, where 'count' is the value returned by TRITONSERVER_InferenceResponseOutputCount. |
| name | Returns the name of the output. |
| datatype | Returns the type of the output. |
| shape | Returns the shape of the output. |
| dim_count | Returns the number of dimensions of the returned shape. |
| base | Returns the tensor data for the output. |
| byte_size | Returns the size, in bytes, of the data. |
| memory_type | Returns the memory type of the data. |
| memory_type_id | Returns the memory type id of the data. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutputClassificationLabel | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| const size_t | class_index, | ||
| const char ** | label | ||
The caller does not own the returned label and must not modify or delete it. The lifetime of all returned label extends until 'inference_response' is deleted.
| class_index | The index of the class. |
| name | Returns the label corresponding to 'class_index' or nullptr if no label. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseOutputCount | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| uint32_t * | count | ||
| count | Returns the number of output tensors. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseParameter | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
| TRITONSERVER_ParameterType * | type, | ||
| const void ** | vvalue | ||
The 'vvalue' returns a void* pointer that must be cast appropriately based on 'type'. For example:
void* vvalue; TRITONSERVER_ParameterType type; TRITONSERVER_InferenceResponseParameter( response, index, &name, &type, &vvalue); switch (type) { case TRITONSERVER_PARAMETER_BOOL: bool value = *(reinterpret_cast<bool*>(vvalue)); ... case TRITONSERVER_PARAMETER_INT: int64_t value = *(reinterpret_cast<int64_t*>(vvalue)); ... case TRITONSERVER_PARAMETER_STRING: const char* value = reinterpret_cast<const char*>(vvalue); ...
| index | The index of the parameter, must be 0 <= index < count, where 'count' is the value returned by TRITONSERVER_InferenceResponseParameterCount. |
| name | Returns the name of the parameter. |
| type | Returns the type of the parameter. |
| vvalue | Returns a pointer to the parameter value. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceResponseParameterCount | ( | struct TRITONSERVER_InferenceResponse * | inference_response, |
Get the number of parameters available in the response.
| count | Returns the number of parameters. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_InferenceTraceActivityString | ( | TRITONSERVER_InferenceTraceActivity | activity | ) |
Get the string representation of a trace activity.
| activity | The trace activity. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceContext | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| const char ** | trace_context | ||
Get TRITONSERVER_InferenceTrace context.
| trace | The trace. |
| trace_context | Returns the context associated with the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceDelete | ( | struct TRITONSERVER_InferenceTrace * | trace | ) |
Delete a trace object.
| trace | The trace object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceId | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| uint64_t * | id | ||
Get the id associated with a trace.
Every trace is assigned an id that is unique across all traces created for a Triton server.
| id | Returns the id associated with the trace. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_InferenceTraceLevelString | ( | TRITONSERVER_InferenceTraceLevel | level | ) |
Get the string representation of a trace level.
| level | The trace level. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceModelName | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| const char ** | model_name | ||
Get the name of the model associated with a trace.
The caller does not own the returned string and must not modify or delete it. The lifetime of the returned string extends only as long as 'trace'.
| model_name | Returns the name of the model associated with the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceModelVersion | ( | struct TRITONSERVER_InferenceTrace * | trace, |
Get the version of the model associated with a trace.
| model_version | Returns the version of the model associated with the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceNew | ( | struct TRITONSERVER_InferenceTrace ** | trace, |
| TRITONSERVER_InferenceTraceLevel | level, | ||
| uint64_t | parent_id, | ||
| TRITONSERVER_InferenceTraceActivityFn_t | activity_fn, | ||
| TRITONSERVER_InferenceTraceReleaseFn_t | release_fn, | ||
| void * | trace_userp | ||
Create a new inference trace object.
The caller takes ownership of the TRITONSERVER_InferenceTrace object and must call TRITONSERVER_InferenceTraceDelete to release the object.
The activity callback function will be called to report activity for 'trace' as well as for any child traces that are spawned by 'trace', and so the activity callback must check the trace object to determine specifically what activity is being reported.
The release callback is called for both 'trace' and for any child traces spawned by 'trace'.
| trace | Returns the new inference trace object. |
| level | The tracing level. |
| parent_id | The parent trace id for this trace. A value of 0 indicates that there is not parent trace. |
| activity_fn | The callback function where activity for the trace is reported. |
| release_fn | The callback function called when all activity is complete for the trace. |
| trace_userp | User-provided pointer that is delivered to the activity and release callback functions. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceParentId | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| uint64_t * | parent_id | ||
Get the parent id associated with a trace.
The parent id indicates a parent-child relationship between two traces. A parent id value of 0 indicates that there is no parent trace.
| id | Returns the parent id associated with the trace. |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error* TRITONSERVER_InferenceTraceReportActivity | ( | TRITONSERVER_InferenceTrace * | trace, |
| uint64_t | timestamp, | ||
| const char * | activity_name | ||
Report a trace activity.
All the traces reported using this API will be using TRITONSERVER_TRACE_CUSTOM_ACTIVITY type.
| timestamp | The timestamp associated with the trace activity. |
| name | The trace activity name. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceRequestId | ( | struct TRITONSERVER_InferenceTrace * | trace, |
Get the request id associated with a trace.
| request_id | Returns the version of the model associated with the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceSetContext | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| const char * | trace_context | ||
Set TRITONSERVER_InferenceTrace context.
| trace_context | A new trace context to associate with the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceSpawnChildTrace | ( | struct TRITONSERVER_InferenceTrace * | trace, |
| struct TRITONSERVER_InferenceTrace ** | child_trace | ||
Get the child trace, spawned from the parent trace.
The caller owns the returned object and must call TRITONSERVER_InferenceTraceDelete to release the object, unless ownership is transferred through other APIs (see TRITONSERVER_ServerInferAsync).
| child_trace | Returns the child trace, spawned from the trace. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_InferenceTraceTensorNew | ( | struct TRITONSERVER_InferenceTrace ** | trace, |
| TRITONSERVER_InferenceTraceTensorActivityFn_t | tensor_activity_fn, | ||
The timeline and tensor activity callback function will be called to report activity for 'trace' as well as for any child traces that are spawned by 'trace', and so the activity callback must check the trace object to determine specifically what activity is being reported.
| activity_fn | The callback function where timeline activity for the trace is reported. |
| tensor_activity_fn | The callback function where tensor activity for the trace is reported. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_InstanceGroupKindString | ( | TRITONSERVER_InstanceGroupKind | kind | ) |
Get the string representation of an instance-group kind.
| kind | The instance-group kind. |
| TRITONSERVER_DECLSPEC bool TRITONSERVER_LogIsEnabled | ( | TRITONSERVER_LogLevel | level | ) |
Is a log level enabled?
| level | The log level. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_LogMessage | ( | TRITONSERVER_LogLevel | level, |
| const char * | filename, | ||
| const int | line, | ||
Log a message at a given log level if that level is enabled.
| filename | The file name of the location of the log message. |
| line | The line number of the log message. |
| msg | The log message. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_MemoryTypeString | ( | TRITONSERVER_MemoryType | memtype | ) |
Get the string representation of a memory type.
| memtype | The memory type. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageDelete | ( | struct TRITONSERVER_Message * | message | ) |
Delete a message object.
| message | The message object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageNewFromSerializedJson | ( | struct TRITONSERVER_Message ** | message, |
| const char * | base, | ||
TRITONSERVER_Message.
Object representing a Triton Server message. Create a new message object from serialized JSON string.
| base | The base of the serialized JSON. |
| byte_size | The size, in bytes, of the serialized message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MessageSerializeToJson | ( | struct TRITONSERVER_Message * | message, |
| const char ** | base, | ||
Get the base and size of the buffer containing the serialized message in JSON format.
The buffer is owned by the TRITONSERVER_Message object and should not be modified or freed by the caller. The lifetime of the buffer extends only as long as 'message' and must not be accessed once 'message' is deleted.
| base | Returns the base of the serialized message. |
| byte_size | Returns the size, in bytes, of the serialized message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsDelete | ( | struct TRITONSERVER_MetricArgs * | args | ) |
| args | The metric args object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsNew | ( | struct TRITONSERVER_MetricArgs ** | args | ) |
The caller takes ownership of the TRITONSERVER_MetricArgs object and must call TRITONSERVER_MetricArgsDelete to release the object.
| args | Returns the new metric args object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricArgsSetHistogram | ( | struct TRITONSERVER_MetricArgs * | args, |
| const double * | buckets, | ||
| const uint64_t | buckets_count | ||
| args | The metric args object to set. |
| buckets | The array of bucket boundaries for the expected range of observed values. |
| buckets_count | The number of bucket boundaries. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricDelete | ( | struct TRITONSERVER_Metric * | metric | ) |
All TRITONSERVER_Metric* objects should be deleted BEFORE their corresponding TRITONSERVER_MetricFamily* objects have been deleted. If a family is deleted before its metrics, an error will be returned.
| metric | The metric object to delete. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricFamilyDelete | ( | struct TRITONSERVER_MetricFamily * | family | ) |
A TRITONSERVER_MetricFamily* object should be deleted AFTER its corresponding TRITONSERVER_Metric* objects have been deleted. Attempting to delete a family before its metrics will return an error.
| family | The metric family object to delete. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricFamilyNew | ( | struct TRITONSERVER_MetricFamily ** | family, |
| const TRITONSERVER_MetricKind | kind, | ||
| const char * | description | ||
The caller takes ownership of the TRITONSERVER_MetricFamily object and must call TRITONSERVER_MetricFamilyDelete to release the object.
| family | Returns the new metric family object. |
| kind | The type of metric family to create. |
| name | The name of the metric family seen when calling the metrics endpoint. |
| description | The description of the metric family seen when calling the metrics endpoint. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricIncrement | ( | struct TRITONSERVER_Metric * | metric, |
| double | value | ||
Supports metrics of kind TRITONSERVER_METRIC_KIND_GAUGE for any value, and TRITONSERVER_METRIC_KIND_COUNTER for non-negative values. Returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind and TRITONSERVER_ERROR_INVALID_ARG for negative values on a TRITONSERVER_METRIC_KIND_COUNTER metric.
| metric | The metric object to update. |
| value | The amount to increment the metric's value by. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricNew | ( | struct TRITONSERVER_Metric ** | metric, |
| struct TRITONSERVER_MetricFamily * | family, | ||
| const struct TRITONSERVER_Parameter ** | labels, | ||
| const uint64_t | label_count | ||
The caller takes ownership of the TRITONSERVER_Metric object and must call TRITONSERVER_MetricDelete to release the object. The caller is also responsible for ownership of the labels passed in. Each label can be deleted immediately after creating the metric with TRITONSERVER_ParameterDelete if not re-using the labels.
| metric | Returns the new metric object. |
| family | The metric family to add this new metric to. |
| labels | The array of labels to associate with this new metric. |
| label_count | The number of labels. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricNewWithArgs | ( | struct TRITONSERVER_Metric ** | metric, |
| const uint64_t | label_count, | ||
| const struct TRITONSERVER_MetricArgs * | args | ||
The caller takes ownership of the TRITONSERVER_Metric object and must call TRITONSERVER_MetricDelete to release the object. The caller is also responsible for ownership of the labels passed in. Each label can be deleted immediately after creating the metric with TRITONSERVER_ParameterDelete if not re-using the labels. Metric args can be deleted immediately after creating the metric with TRITONSERVER_MetricArgsDelete if not re-using the metric args.
| args | Metric args that store additional arguments to construct particular metric types, e.g. histogram. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricObserve | ( | struct TRITONSERVER_Metric * | metric, |
| double | value | ||
Supports metrics of kind TRITONSERVER_METRIC_KIND_HISTOGRAM and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
| value | The amount for metric to sample observation. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricsDelete | ( | struct TRITONSERVER_Metrics * | metrics | ) |
Delete a metrics object.
| metrics | The metrics object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricSet | ( | struct TRITONSERVER_Metric * | metric, |
| double | value | ||
Supports metrics of kind TRITONSERVER_METRIC_KIND_GAUGE and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
| value | The amount to set metric's value to. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricsFormatted | ( | struct TRITONSERVER_Metrics * | metrics, |
| TRITONSERVER_MetricFormat | format, | ||
Get a buffer containing the metrics in the specified format.
For each format the buffer contains the following:
TRITONSERVER_METRIC_PROMETHEUS: 'base' points to a single multiline string (char*) that gives a text representation of the metrics in prometheus format. 'byte_size' returns the length of the string in bytes.
The buffer is owned by the 'metrics' object and should not be modified or freed by the caller. The lifetime of the buffer extends only as long as 'metrics' and must not be accessed once 'metrics' is deleted.
| format | The format to use for the returned metrics. |
| base | Returns a pointer to the base of the formatted metrics, as described above. |
| byte_size | Returns the size, in bytes, of the formatted metrics. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_MetricValue | ( | struct TRITONSERVER_Metric * | metric, |
| double * | value | ||
Supports metrics of kind TRITONSERVER_METRIC_KIND_COUNTER and TRITONSERVER_METRIC_KIND_GAUGE, and returns TRITONSERVER_ERROR_UNSUPPORTED for unsupported TRITONSERVER_MetricKind.
| value | Returns the current value of the metric object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter* TRITONSERVER_ParameterBytesNew | ( | const char * | name, |
| const void * | byte_ptr, | ||
| const uint64_t | size | ||
Create a new parameter object with type TRITONSERVER_PARAMETER_BYTES.
The caller takes ownership of the TRITONSERVER_Parameter object and must call TRITONSERVER_ParameterDelete to release the object. The object only maintains a shallow copy of the 'byte_ptr' so the data content must be valid until the parameter object is deleted.
| name | The parameter name. |
| byte_ptr | The pointer to the data content. |
| size | The size of the data content. |
| TRITONSERVER_DECLSPEC void TRITONSERVER_ParameterDelete | ( | struct TRITONSERVER_Parameter * | parameter | ) |
Delete an parameter object.
| parameter | The parameter object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Parameter* TRITONSERVER_ParameterNew | ( | const char * | name, |
| const TRITONSERVER_ParameterType | type, | ||
| const void * | value | ||
Create a new parameter object.
The caller takes ownership of the TRITONSERVER_Parameter object and must call TRITONSERVER_ParameterDelete to release the object. The object will maintain its own copy of the 'value'
| type | The parameter type. |
| value | The pointer to the value. |
| const TRITONSERVER_DECLSPEC char* TRITONSERVER_ParameterTypeString | ( | TRITONSERVER_ParameterType | paramtype | ) |
Get the string representation of a parameter type.
| paramtype | The parameter type. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorDelete | ( | struct TRITONSERVER_ResponseAllocator * | allocator | ) |
Delete a response allocator.
| allocator | The response allocator object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorNew | ( | struct TRITONSERVER_ResponseAllocator ** | allocator, |
| TRITONSERVER_ResponseAllocatorAllocFn_t | alloc_fn, | ||
| TRITONSERVER_ResponseAllocatorReleaseFn_t | release_fn, | ||
| TRITONSERVER_ResponseAllocatorStartFn_t | start_fn | ||
Create a new response allocator object.
The response allocator object is used by Triton to allocate buffers to hold the output tensors in inference responses. Most models generate a single response for each inference request (TRITONSERVER_TXN_ONE_TO_ONE). For these models the order of callbacks will be:
TRITONSERVER_ServerInferAsync called
For models that generate multiple responses for each inference request (TRITONSERVER_TXN_DECOUPLED), the start_fn callback can be used to determine sets of alloc_fn callbacks that belong to the same response:
In all cases the start_fn, alloc_fn and release_fn callback functions must be thread-safe. Typically making these functions thread-safe does not require explicit locking. The recommended way to implement these functions is to have each inference request provide a 'response_allocator_userp' object that is unique to that request with TRITONSERVER_InferenceRequestSetResponseCallback. The callback functions then operate only on this unique state. Locking is required only when the callback function needs to access state that is shared across inference requests (for example, a common allocation pool).
| allocator | Returns the new response allocator object. |
| alloc_fn | The function to call to allocate buffers for result tensors. |
| release_fn | The function to call when the server no longer holds a reference to an allocated buffer. |
| start_fn | The function to call to indicate that the subsequent 'alloc_fn' calls are for a new response. This callback is optional (use nullptr to indicate that it should not be invoked). |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorSetBufferAttributesFunction | ( | struct TRITONSERVER_ResponseAllocator * | allocator, |
| TRITONSERVER_ResponseAllocatorBufferAttributesFn_t | buffer_attributes_fn | ||
Set the buffer attributes function for a response allocator object.
The function will be called after alloc_fn to set the buffer attributes associated with the output buffer.
The thread-safy requirement for buffer_attributes_fn is the same as other allocator callbacks.
| buffer_attributes_fn | The function to call to get the buffer attributes information for an allocated buffer. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ResponseAllocatorSetQueryFunction | ( | struct TRITONSERVER_ResponseAllocator * | allocator, |
| TRITONSERVER_ResponseAllocatorQueryFn_t | query_fn | ||
Set the query function to a response allocator object.
Usually the function will be called before alloc_fn to understand what is the allocator's preferred memory type and memory type ID at the current situation to make different execution decision.
The thread-safy requirement for query_fn is the same as other allocator callbacks.
| query_fn | The function to call to query allocator's preferred memory type and memory type ID. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerDelete | ( | struct TRITONSERVER_Server * | server | ) |
Delete a server object.
If server is not already stopped it is stopped before being deleted.
| server | The inference server object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerInferAsync | ( | struct TRITONSERVER_Server * | server, |
| struct TRITONSERVER_InferenceRequest * | inference_request, | ||
| struct TRITONSERVER_InferenceTrace * | trace | ||
Perform inference using the meta-data and inputs supplied by the 'inference_request'.
If the function returns success, then the caller releases ownership of 'inference_request' and must not access it in any way after this call, until ownership is returned via the 'request_release_fn' callback registered in the request object with TRITONSERVER_InferenceRequestSetReleaseCallback.
The function unconditionally takes ownership of 'trace' and so the caller must not access it in any way after this call (except in the trace activity callbacks) until ownership is returned via the trace's release_fn callback.
Responses produced for this request are returned using the allocator and callback registered with the request by TRITONSERVER_InferenceRequestSetResponseCallback.
| trace | The trace object for this request, or nullptr if no tracing. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerIsLive | ( | struct TRITONSERVER_Server * | server, |
| bool * | live | ||
Is the server live?
| live | Returns true if server is live, false otherwise. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerIsReady | ( | struct TRITONSERVER_Server * | server, |
| bool * | ready | ||
Is the server ready?
| ready | Returns true if server is ready, false otherwise. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerLoadModel | ( | struct TRITONSERVER_Server * | server, |
| const char * | model_name | ||
Load the requested model or reload the model if it is already loaded.
The function does not return until the model is loaded or fails to load. Returned error indicates if model loaded successfully or not.
| model_name | The name of the model. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerLoadModelWithParameters | ( | struct TRITONSERVER_Server * | server, |
| const struct TRITONSERVER_Parameter ** | parameters, | ||
| const uint64_t | parameter_count | ||
Load the requested model or reload the model if it is already loaded, with load parameters provided.
The function does not return until the model is loaded or fails to load. Returned error indicates if model loaded successfully or not. Currently the below parameter names are recognized:
| parameters | The array of load parameters. |
| parameter_count | The number of parameters. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerMetadata | ( | struct TRITONSERVER_Server * | server, |
| struct TRITONSERVER_Message ** | server_metadata | ||
Get the metadata of the server as a TRITONSERVER_Message object.
The caller takes ownership of the message object and must call TRITONSERVER_MessageDelete to release the object.
| server_metadata | Returns the server metadata message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerMetrics | ( | struct TRITONSERVER_Server * | server, |
| struct TRITONSERVER_Metrics ** | metrics | ||
Get the current metrics for the server.
The caller takes ownership of the metrics object and must call TRITONSERVER_MetricsDelete to release the object.
| metrics | Returns the metrics. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelBatchProperties | ( | struct TRITONSERVER_Server * | server, |
| const int64_t | model_version, | ||
| uint32_t * | flags, | ||
| void ** | voidp | ||
Get the batch properties of the model.
The properties are communicated by a flags value and an (optional) object returned by 'voidp'.
| model_version | The version of the model. If -1 then the server will choose a version based on the model's policy. |
| flags | Returns flags indicating the batch properties of the model. |
| voidp | If non-nullptr, returns a point specific to the 'flags' value. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelConfig | ( | struct TRITONSERVER_Server * | server, |
| const uint32_t | config_version, | ||
| struct TRITONSERVER_Message ** | model_config | ||
Get the configuration of a model as a TRITONSERVER_Message object.
| config_version | The model configuration will be returned in a format matching this version. If the configuration cannot be represented in the requested version's format then an error will be returned. Currently only version 1 is supported. |
| model_config | Returns the model config message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelIndex | ( | struct TRITONSERVER_Server * | server, |
| uint32_t | flags, | ||
| struct TRITONSERVER_Message ** | model_index | ||
Get the index of all unique models in the model repositories as a TRITONSERVER_Message object.
If TRITONSERVER_INDEX_FLAG_READY is set in 'flags' only the models that are loaded into the server and ready for inferencing are returned.
| flags | TRITONSERVER_ModelIndexFlag flags that control how to collect the index. |
| model_index | Return the model index message that holds the index of all models contained in the server's model repository(s). |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelIsReady | ( | struct TRITONSERVER_Server * | server, |
| bool * | ready | ||
Is the model ready?
| model_name | The name of the model to get readiness for. |
| model_version | The version of the model to get readiness for. If -1 then the server will choose a version based on the model's policy. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelMetadata | ( | struct TRITONSERVER_Server * | server, |
| struct TRITONSERVER_Message ** | model_metadata | ||
Get the metadata of a model as a TRITONSERVER_Message object.
| model_metadata | Returns the model metadata message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelStatistics | ( | struct TRITONSERVER_Server * | server, |
| struct TRITONSERVER_Message ** | model_stats | ||
Get the statistics of a model as a TRITONSERVER_Message object.
The caller takes ownership of the object and must call TRITONSERVER_MessageDelete to release the object.
| model_name | The name of the model. If empty, then statistics for all available models will be returned, and the server will choose a version based on those models' policies. |
| model_stats | Returns the model statistics message. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerModelTransactionProperties | ( | struct TRITONSERVER_Server * | server, |
| uint32_t * | txn_flags, | ||
Get the transaction policy of the model.
The policy is communicated by a flags value.
| txn_flags | Returns flags indicating the transaction policy of the model. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerNew | ( | struct TRITONSERVER_Server ** | server, |
| struct TRITONSERVER_ServerOptions * | options | ||
Create a new server object.
The caller takes ownership of the TRITONSERVER_Server object and must call TRITONSERVER_ServerDelete to release the object.
| server | Returns the new inference server object. |
| options | The inference server options object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsAddRateLimiterResource | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | resource_name, | ||
| const size_t | resource_count, | ||
| const int | device | ||
Add resource count for rate limiting.
| options | The server options object. |
| name | The name of the resource. |
| count | The count of the resource. |
| device | The device identifier for the resource. A value of -1 indicates that the specified number of resources are available on every device. The device value is ignored for a global resource. The server will use the rate limiter configuration specified for instance groups in model config to determine whether resource is global. In case of conflicting resource type in different model configurations, server will raise an appropriate error while loading model. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsDelete | ( | struct TRITONSERVER_ServerOptions * | options | ) |
Delete a server options object.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsNew | ( | struct TRITONSERVER_ServerOptions ** | options | ) |
Create a new server options object.
The caller takes ownership of the TRITONSERVER_ServerOptions object and must call TRITONSERVER_ServerOptionsDelete to release the object.
| options | Returns the new server options object. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBackendConfig | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | backend_name, | ||
| const char * | setting, | ||
Set a configuration setting for a named backend in a server options.
| backend_name | The name of the backend. |
| setting | The name of the setting. |
| value | The setting value. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBackendDirectory | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | backend_dir | ||
Set the directory containing backend shared libraries.
This directory is searched last after the version and model directory in the model repository when looking for the backend shared library for a model. If the backend is named 'be' the directory searched is 'backend_dir'/be/libtriton_be.so.
| backend_dir | The full path of the backend directory. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetBufferManagerThreadCount | ( | struct TRITONSERVER_ServerOptions * | options, |
| unsigned int | thread_count | ||
Set the number of threads used in buffer manager in a server options.
| thread_count | The number of threads. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCacheConfig | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | cache_name, | ||
| const char * | config_json | ||
Set the cache config that will be used to initialize the cache implementation for "cache_name".
It is expected that the "cache_name" provided matches a directory inside the "cache_dir" used for TRITONSERVER_ServerOptionsSetCacheDirectory. The default "cache_dir" is "/opt/tritonserver/caches", so for a "cache_name" of "local", Triton would expect to find the "local" cache implementation at "/opt/tritonserver/caches/local/libtritoncache_local.so"
Altogether an example for the "local" cache implementation would look like: std::string cache_name = "local"; std::string config_json = R"({"size": 1048576})" auto err = TRITONSERVER_ServerOptionsSetCacheConfig( options, cache_name, config_json);
| cache_name | The name of the cache. Example names would be "local", "redis", or the name of a custom cache implementation. |
| config_json | The string representation of config JSON that is used to initialize the cache implementation. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCacheDirectory | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | cache_dir | ||
Set the directory containing cache shared libraries.
This directory is searched when looking for cache implementations.
| cache_dir | The full path of the cache directory. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCpuMetrics | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | cpu_metrics | ||
Enable or disable CPU metrics collection in a server options.
CPU metrics are collected if both this option and TRITONSERVER_ServerOptionsSetMetrics are true.
| cpu_metrics | True to enable CPU metrics, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCudaMemoryPoolByteSize | ( | struct TRITONSERVER_ServerOptions * | options, |
| int | gpu_device, | ||
Set the total CUDA memory byte size that the server can allocate on given GPU device in a server options.
The pinned memory pool will be shared across Triton itself and the backends that use TRITONBACKEND_MemoryManager to allocate memory.
| gpu_device | The GPU device to allocate the memory pool. |
| size | The CUDA memory pool byte size. |
| TRITONSERVER_DECLSPEC TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetCudaVirtualAddressSize | ( | TRITONSERVER_ServerOptions * | options, |
| size_t | cuda_virtual_address_size | ||
Set the size of the virtual address space that will be used for growable memory in implicit state.
| gpu_device | The GPU device to set the CUDA virtual address space size |
| size | The size of the CUDA virtual address space. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetEnablePeerAccess | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | enable_peer_access | ||
Enable peer access to allow GPU device to directly access the memory of another GPU device.
Note that even when this option is set to True, Triton will only try to enable peer access and might fail to enable it if the underlying system doesn't support peer access.
| enable_peer_access | Whether to enable peer access or not. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetExitOnError | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | exit | ||
Enable or disable exit-on-error in a server options.
| exit | True to enable exiting on initialization error, false to continue. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetExitTimeout | ( | struct TRITONSERVER_ServerOptions * | options, |
| unsigned int | timeout | ||
Set the exit timeout, in seconds, for the server in a server options.
| timeout | The exit timeout, in seconds. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetGpuMetrics | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | gpu_metrics | ||
Enable or disable GPU metrics collection in a server options.
GPU metrics are collected if both this option and TRITONSERVER_ServerOptionsSetMetrics are true.
| gpu_metrics | True to enable GPU metrics, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetHostPolicy | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | policy_name, | ||
Set a host policy setting for a given policy name in a server options.
| policy_name | The name of the policy. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogError | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | log | ||
Enable or disable error level logging.
| log | True to enable error logging, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogFile | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | file | ||
Provide a log output file.
| file | a string defining the file where the log outputs will be saved. An empty string for the file name will cause triton to direct logging facilities to the console |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogFormat | ( | struct TRITONSERVER_ServerOptions * | options, |
| const TRITONSERVER_LogFormat | format | ||
Set the logging format.
| format | The logging format. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogInfo | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | log | ||
Enable or disable info level logging.
| log | True to enable info logging, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogVerbose | ( | struct TRITONSERVER_ServerOptions * | options, |
| int | level | ||
Set verbose logging level.
Level zero disables verbose logging.
| level | The verbose logging level. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetLogWarn | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | log | ||
Enable or disable warning level logging.
| log | True to enable warning logging, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetrics | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | metrics | ||
Enable or disable metrics collection in a server options.
| metrics | True to enable metrics, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetricsConfig | ( | struct TRITONSERVER_ServerOptions * | options, |
Set a configuration setting for metrics in server options.
| name | The name of the configuration group. An empty string indicates a global configuration option. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMetricsInterval | ( | struct TRITONSERVER_ServerOptions * | options, |
| uint64_t | metrics_interval_ms | ||
Set the interval for metrics collection in a server options.
This is 2000 milliseconds by default.
| metrics_interval_ms | The time interval in ms between successive metrics updates. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetMinSupportedComputeCapability | ( | struct TRITONSERVER_ServerOptions * | options, |
| double | cc | ||
Set the minimum support CUDA compute capability in a server options.
| cc | The minimum CUDA compute capability. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelConfigName | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | model_config_name | ||
Set the custom model configuration name to load for all models.
Fall back to default config file if empty.
| config_name | The name of the config file to load for all models. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelControlMode | ( | struct TRITONSERVER_ServerOptions * | options, |
| TRITONSERVER_ModelControlMode | mode | ||
Set the model control mode in a server options.
For each mode the models will be managed as the following:
TRITONSERVER_MODEL_CONTROL_NONE: the models in model repository will be loaded on startup. After startup any changes to the model repository will be ignored. Calling TRITONSERVER_ServerPollModelRepository will result in an error.
TRITONSERVER_MODEL_CONTROL_POLL: the models in model repository will be loaded on startup. The model repository can be polled periodically using TRITONSERVER_ServerPollModelRepository and the server will load, unload, and updated models according to changes in the model repository.
TRITONSERVER_MODEL_CONTROL_EXPLICIT: the models in model repository will not be loaded on startup. The corresponding model control APIs must be called to load / unload a model in the model repository.
| mode | The mode to use for the model control. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadDeviceLimit | ( | struct TRITONSERVER_ServerOptions * | options, |
| const TRITONSERVER_InstanceGroupKind | kind, | ||
| const int | device_id, | ||
| const double | fraction | ||
Specify the limit on memory usage as a fraction on the device identified by 'kind' and 'device_id'.
If model loading on the device is requested and the current memory usage exceeds the limit, the load will be rejected. If not specified, the limit will not be set.
Currently support TRITONSERVER_INSTANCEGROUPKIND_GPU
| kind | The kind of the device. |
| device_id | The id of the device. |
| fraction | The limit on memory usage as a fraction |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadRetryCount | ( | struct TRITONSERVER_ServerOptions * | options, |
| unsigned int | retry_count | ||
Set the number of retry to load a model in a server options.
| retry_count | The number of retry. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelLoadThreadCount | ( | struct TRITONSERVER_ServerOptions * | options, |
Set the number of threads to concurrently load models in a server options.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelNamespacing | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | enable_namespace | ||
Enable model namespacing to allow serving models with the same name if they are in different namespaces.
| enable_namespace | Whether to enable model namespacing or not. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetModelRepositoryPath | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | model_repository_path | ||
Set the model repository path in a server options.
The path must be the full absolute path to the model repository. This function can be called multiple times with different paths to set multiple model repositories. Note that if a model is not unique across all model repositories at any time, the model will not be available.
| model_repository_path | The full path to the model repository. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetPinnedMemoryPoolByteSize | ( | struct TRITONSERVER_ServerOptions * | options, |
Set the total pinned memory byte size that the server can allocate in a server options.
| size | The pinned memory pool byte size. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetRateLimiterMode | ( | struct TRITONSERVER_ServerOptions * | options, |
| TRITONSERVER_RateLimitMode | mode | ||
Set the rate limit mode in a server options.
TRITONSERVER_RATE_LIMIT_EXEC_COUNT: The rate limiting prioritizes the inference execution using the number of times each instance has got a chance to run. The execution gets to run only when its resource constraints are satisfied.
TRITONSERVER_RATE_LIMIT_OFF: The rate limiting is turned off and the inference gets executed whenever an instance is available.
| mode | The mode to use for the rate limiting. By default, execution count is used to determine the priorities. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetRepoAgentDirectory | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | repoagent_dir | ||
Set the directory containing repository agent shared libraries.
This directory is searched when looking for the repository agent shared library for a model. If the repo agent is named 'ra' the directory searched is 'repoagent_dir'/ra/libtritonrepoagent_ra.so.
| repoagent_dir | The full path of the repository agent directory. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetResponseCacheByteSize | ( | struct TRITONSERVER_ServerOptions * | options, |
Deprecated.
See TRITONSERVER_ServerOptionsSetCacheConfig instead.
Set the total response cache byte size that the server can allocate in CPU memory. The response cache will be shared across all inference requests and across all models.
| size | The total response cache byte size. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetServerId | ( | struct TRITONSERVER_ServerOptions * | options, |
| const char * | server_id | ||
Set the textual ID for the server in a server options.
The ID is a name that identifies the server.
| server_id | The server identifier. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStartupModel | ( | struct TRITONSERVER_ServerOptions * | options, |
Set the model to be loaded at startup in a server options.
The model must be present in one, and only one, of the specified model repositories. This function can be called multiple times with different model name to set multiple startup models. Note that it only takes affect on TRITONSERVER_MODEL_CONTROL_EXPLICIT mode.
| mode_name | The name of the model to load on startup. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStrictModelConfig | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | strict | ||
Enable or disable strict model configuration handling in a server options.
| strict | True to enable strict model configuration handling, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerOptionsSetStrictReadiness | ( | struct TRITONSERVER_ServerOptions * | options, |
| bool | strict | ||
Enable or disable strict readiness handling in a server options.
| strict | True to enable strict readiness handling, false to disable. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerPollModelRepository | ( | struct TRITONSERVER_Server * | server | ) |
Check the model repository for changes and update server state based on those changes.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerRegisterModelRepository | ( | struct TRITONSERVER_Server * | server, |
| const char * | repository_path, | ||
| const struct TRITONSERVER_Parameter ** | name_mapping, | ||
| const uint32_t | mapping_count | ||
Register a new model repository.
Not available in polling mode.
| name_mapping | List of name_mapping parameters. Each mapping has the model directory name as its key, overridden model name as its value. |
| model_count | Number of mappings provided. |
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerSetExitTimeout | ( | struct TRITONSERVER_Server * | server, |
Set the exit timeout on the server object.
This value overrides the value initially set through server options and provides a mechanism to update the exit timeout while the serving is running.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerStop | ( | struct TRITONSERVER_Server * | server | ) |
Stop a server object.
A server can't be restarted once it is stopped.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnloadModel | ( | struct TRITONSERVER_Server * | server, |
Unload the requested model.
Unloading a model that is not loaded on server has no affect and success code will be returned. The function does not wait for the requested model to be fully unload and success code will be returned. Returned error indicates if model unloaded successfully or not.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnloadModelAndDependents | ( | struct TRITONSERVER_Server * | server, |
Unload the requested model, and also unload any dependent model that was loaded along with the requested model (for example, the models composing an ensemble).
Unloading a model that is not loaded on server has no affect and success code will be returned. The function does not wait for the requested model and all dependent models to be fully unload and success code will be returned. Returned error indicates if model unloaded successfully or not.
| TRITONSERVER_DECLSPEC struct TRITONSERVER_Error* TRITONSERVER_ServerUnregisterModelRepository | ( | struct TRITONSERVER_Server * | server, |
| const char * | repository_path | ||
Unregister a model repository.
| TRITONSERVER_DECLSPEC TRITONSERVER_DataType TRITONSERVER_StringToDataType | ( | const char * | dtype | ) |
Get the Triton datatype corresponding to a string representation of a datatype.
| dtype | The datatype string representation. |
