5.4. C/C++ Language Extensions#
5.4.1. Function and Variable Annotations#
5.4.1.1. Execution Space Specifiers#
The execution space specifiers __host__, __device__, and __global__ indicate whether a function executes on the host or the device.
Execution Space Specifier |
Executed on |
Callable from |
Host |
Device |
Host |
Device |
Constraints for __global__ functions:
Must return
void.Cannot be a member of a
class,struct, orunion.Requires an execution configuration as described in Kernel Configuration.
Does not support recursion.
Refer to
__global__function parameters for additional restrictions.
Calls to a __global__ function are asynchronous. They return to the host thread before the device completes execution.
Functions declared with __host__ __device__ are compiled for both the host and the device. The __CUDA_ARCH__ macro can be used to differentiate host and device code paths:
__host__ __device__ void func() {
#if defined(__CUDA_ARCH__)
// Device code path
#else
// Host code path
#endif
5.4.1.2. Memory Space Specifiers#
The memory space specifiers __device__, __managed__, __constant__, and __shared__ indicate the storage location of a variable on the device.
The following table summarizes the memory space properties:
Memory Space Specifier |
Location |
Accessible by |
Lifetime |
Unique instance |
Device global memory |
Device Threads (grid) / CUDA Runtime API |
Program/CUDA context |
Per device |
Device constant memory |
Per device |
Host and Device (automatic) |
Host/Device Threads |
Program |
Per program |
Device (streaming multiprocessor) |
Block Threads |
Block |
Block |
no specifier |
Device (registers) |
Single Thread |
Single Thread |
Single Thread |
Both
__device__and__constant__variables can be accessed from the host using the CUDA Runtime API functionscudaGetSymbolAddress(),cudaGetSymbolSize(),cudaMemcpyToSymbol(), andcudaMemcpyFromSymbol().__constant__variables are read-only in device code and can only be modified from the host using the CUDA Runtime API.
The following example illustrates how to use these APIs:
__device__ float device_var = 4.0f; // Variable in device memory
__constant__ float constant_mem_var = 4.0f; // Variable in constant memory
// For readability, the following example focuses on a device variable.
int main() {
float* device_ptr;
cudaGetSymbolAddress((void**) &device_ptr, device_var); // Gets address of device_var
size_t symbol_size;
cudaGetSymbolSize(&symbol_size, device_var); // Retrieves the size of the symbol (4 bytes).
float host_var;
cudaMemcpyFromSymbol(&host_var, device_var, sizeof(host_var)); // Copies from device to host.
host_var = 3.0f;
cudaMemcpyToSymbol(device_var, &host_var, sizeof(host_var)); // Copies from host to device.
See the example on Compiler Explorer.
5.4.1.2.2. __managed__ Memory#
__managed__ variables have the following restrictions:
The address of a
__managed__variable is not a constant expression.A
__managed__variable shall not have a reference typeT&.The address or value of a
__managed__variable shall not be used when the CUDA runtime may not be in a valid state, including the following cases:In static/dynamic initialization or destruction of an object with
staticorthread_localstorage duration.In code that executes after
exit()has been called. For example, a function marked with__attribute__((destructor)).In code that executes when the CUDA runtime may not be initialized. For example, a function marked with
__attribute__((constructor)).
A
__managed__variable cannot be used as an unparenthesized id-expression argument to adecltype()expression.__managed__variables have the same coherence and consistency behavior as specified for dynamically allocated managed memory.See also the restrictions for local variables.
Here are examples of legal and illegal uses of __managed__ variables:
#include <cassert>
__device__ __managed__ int global_var = 10; // OK
int* ptr = &global_var; // ERROR: use of a managed variable in static initialization
struct MyStruct1 {
int field;
MyStruct1() : field(global_var) {};
struct MyStruct2 {
~MyStruct2() { global_var = 10; }
MyStruct1 temp1; // ERROR: use of managed variable in dynamic initialization
MyStruct2 temp2; // ERROR: use of managed variable in the destructor of
// object with static storage duration
__device__ __managed__ const int const_var = 10; // ERROR: const-qualified type
__device__ __managed__ int& reference = global_var; // ERROR: reference type
template <int* Addr>
struct MyStruct3 {};
MyStruct3<&global_var> temp; // ERROR: address of managed variable is not a constant expression
__global__ void kernel(int* ptr) {
assert(ptr == &global_var); // OK
global_var = 20; // OK
int main() {
int* ptr = &global_var; // OK
kernel<<<1, 1>>>(ptr);
cudaDeviceSynchronize();
global_var++; // OK
decltype(global_var) var1; // ERROR: managed variable used as unparenthesized argument to decltype
decltype((global_var)) var2; // OK
5.4.1.3. Inlining Specifiers#
The following specifiers can be used to control inlining for __host__ and __device__ functions:
__noinline__: Instructsnvccnot to inline the function.__forceinline__: Forcesnvccto inline the function within a single translation unit.__inline_hint__: Enables aggressive inlining across translation units when using Link-Time Optimization.
These specifiers are mutually exclusive.
5.4.1.4. __restrict__ Pointers#
nvcc supports restricted pointers via the __restrict__ keyword.
Pointer aliasing occurs when two or more pointers refer to overlapping memory regions. This can inhibit optimizations such as code reordering and common sub-expression elimination.
A restrict-qualified pointer is a promise from the programmer that for the lifetime of the pointer, the memory it points to will only be accessed through that pointer. This allows the compiler to perform more aggressive optimizations.
all threads that access the device function only read from it; or
at most one thread writes to it, and no other thread reads from it.
The following example illustrates an aliasing issue and demonstrates how using a restricted pointer can help the compiler reduce the number of instructions:
__device__
void device_function(const float* a, const float* b, float* c) {
c[0] = a[0] * b[0];
c[1] = a[0] * b[0];
c[2] = a[0] * b[0] * a[1];
c[3] = a[0] * a[1];
c[4] = a[0] * b[0];
c[5] = b[0];
Because the pointers a, b, and c may be aliased, any write through c could modify elements of a or b. To guarantee functional correctness, the compiler cannot load a[0] and b[0] into registers, multiply them, and store the result in both c[0] and c[1]. This is because the results would differ from the abstract execution model if a[0] and c[0] were at the same location. The compiler cannot take advantage of the common sub-expression. Similarly, the compiler cannot reorder the computation of c[4] with the computations of c[0] and c[1] because a preceding write to c[3] could alter the inputs to the computation of c[4].
By declaring a, b, and c as restricted pointers, the programmer informs the compiler that the pointers are not aliased. This means that writing to c will never overwrite the elements of a or b. This changes the function prototype as follows:
__device__
void device_function(const float* __restrict__ a, const float* __restrict__ b, float* __restrict__ c);
Note that all pointer arguments must be restricted for the compiler optimizer to be effective. With the addition of the __restrict__ keywords, the compiler can reorder and perform common sub-expression elimination at will while maintaining identical functionality to the abstract execution model.
__device__
void device_function(const float* __restrict__ a, const float* __restrict__ b, float* __restrict__ c) {
float t0 = a[0];
float t1 = b[0];
float t2 = t0 * t1;
float t3 = a[1];
c[0] = t2;
c[1] = t2;
c[4] = t2;
c[2] = t2 * t3;
c[3] = t0 * t3;
c[5] = t1;
The result is a reduced number of memory accesses and computations, balanced by an increase in register pressure from caching loads and common sub-expressions in registers.
Since register pressure is a critical issue in many CUDA codes, the use of restricted pointers can negatively impact performance by reducing occupancy.
Accesses to __global__ function const pointers marked with __restrict__ are compiled as read-only cache loads, similar to the PTX ld.global.nc or __ldg() low-level load and store functions instructions.
__global__
void kernel1(const float* in, float* out) {
*out = *in; // PTX: ld.global
__global__
void kernel2(const float* __restrict__ in, float* out) {
*out = *in; // PTX: ld.global.nc
5.4.1.5. __grid_constant__ Parameters#
Annotating a __global__ function parameter with __grid_constant__ prevents the compiler from creating a per-thread copy of the parameter. Instead, all threads in the grid will access the parameter through a single address, which can improve performance.
The __grid_constant__ parameter has the following properties:
It has the lifetime of the kernel.
It is private to a single kernel, meaning the object is not accessible to threads from other grids, including sub-grids.
All threads in the kernel see the same address.
It is read-only. Modifying a
__grid_constant__object or any of its sub-objects, includingmutablemembers, is undefined behavior.
Requirements:
Kernel parameters annotated with
__grid_constant__must haveconst-qualified non-reference types.All function declarations must be consistent with any
__grid_constant__parameters.Function template specializations must match the primary template declaration with respect to any
__grid_constant__parameters.Function template instantiations must also match the primary template declaration with respect to any
Examples:
struct MyStruct {
int x;
mutable int y;
__device__ void external_function(const MyStruct&);
__global__ void kernel(const __grid_constant__ MyStruct s) {
// s.x++; // Compile error: tried to modify read-only memory
// s.y++; // Undefined Behavior: tried to modify read-only memory
// Compiler will NOT create a per-thread local copy of "s":
external_function(s);
5.4.1.6. Annotation Summary#
The following table summarizes the CUDA annotations and reports which execution space each annotation applies to and where it is valid.
Annotation |
Function |
Pointer Parameter |
Pointer Parameter |
Parameter |
Function |
Function |
Function |
5.4.2. Built-in Types and Variables#
5.4.2.1. Host Compiler Type Extensions#
The use of non-standard arithmetic types is permitted by CUDA, as long as the host compiler supports it. The following types are supported:
128-bit integer type
__int128.Supported on Linux when the host compiler defines the
__SIZEOF_INT128__macro.
128-bit floating-point types
__float128and_Float128are available on GPU devices with compute capability 10.0 and later. A constant expression of__float128type may be processed by the compiler in a floating-point representation with lower precision.Supported on Linux x86 when the host compiler defines the
__SIZEOF_FLOAT128__or__FLOAT128__macros.
_Complextypes are only supported in host code.
5.4.2.2. Built-in Variables#
The values used to specify and retrieve the kernel configuration for the grid and blocks along the x, y, and z dimensions are of type dim3. The variables used to obtain the block and thread indices are of type uint3. Both dim3 and uint3 are trivial structures consisting of three unsigned values named x, y, and z. In C++11 and later, the default value of all components of dim3 is 1.
Built-in device-only variables:
dim3 gridDim: contains the dimensions of the grid, namely the number of thread blocks, along the x, y, and z dimensions.dim3 blockDim: contains the dimensions of the thread block, namely the number of threads, along the x, y, and z dimensions.uint3 blockIdx: contains the block index within the grid, along the x, y, and z dimensions.uint3 threadIdx: contains the thread index within the block, along the x, y, and z dimensions.int warpSize: A run-time value defined as the number of threads in a warp, commonly32. See also Warps and SIMT for the definition of a warp.
5.4.2.3. Built-in Types#
CUDA provides vector types derived from basic integer and floating-point types that are supported for both the host and the device. The following table shows the available vector types.
C++ Fundamental Type |
Vector X1 |
Vector X2 |
Vector X3 |
Vector X4 |
Note that long4, ulong4, longlong4, ulonglong4, and double4 have been deprecated in CUDA 13, and may be removed in a future release.
The following table details the byte size and alignment requirements of the vector types:
Type |
Size |
Alignment |
1 |
1 |
2 |
2 |
3 |
1 |
4 |
4 |
2 |
2 |
4 |
4 |
6 |
2 |
8 |
8 |
4 |
4 |
8 |
8 |
12 |
4 |
16 |
16 |
4/8 * |
4/8 * |
8/16 * |
8/16 * |
12/24 * |
4/8 * |
16/32 * |
16 * |
16/32 * |
16 |
16/32 * |
32 |
8 |
8 |
16 |
16 |
24 |
8 |
32 |
16 |
32 |
16 |
32 |
32 |
4 |
4 |
8 |
8 |
12 |
4 |
16 |
16 |
8 |
8 |
16 |
16 |
24 |
8 |
32 |
16 |
32 |
16 |
32 |
32 |
* long is 4 bytes on C++ LLP64 data model (Windows 64-bit), while it is 8 bytes on C++ LP64 data model (Linux 64-bit).
Vector types are structures. Their first, second, third, and fourth components are accessible through the x, y, z, and w fields, respectively.
int sum(int4 value) {
return value.x + value.y + value.z + value.w;
They all have a factory function of the form make_<type_name>(); for example:
int4 add_one(int x, int y, int z, int w) {
return make_int4(x + 1, y + 1, z + 1, w + 1);
If host code is not compiled with nvcc, the vector types and related functions can be imported by including the cuda_runtime.h header provided in the CUDA toolkit.
5.4.3. Kernel Configuration#
Any call to a __global__ function must specify an execution configuration for that call. This execution configuration defines the dimensions of the grid and blocks that will be used to execute the function on the device, as well as the associated stream.
The execution configuration is specified by inserting an expression in the form <<<grid_dim, block_dim, dynamic_smem_bytes, stream>>> between the function name and the parenthesized argument list, where:
grid_dimis of type dim3 and specifies the dimension and size of the grid, such thatgrid_dim.x * grid_dim.y * grid_dim.zequals the number of blocks being launched;block_dimis of type dim3 and specifies the dimension and size of each block, such thatblock_dim.x * block_dim.y * block_dim.zequals the number of threads per block;dynamic_smem_bytesis an optionalsize_targument that defaults to zero. It specifies the number of bytes in shared memory that are dynamically allocated per block for this call in addition to the statically allocated memory. This memory is used byextern __shared__arrays (see __shared__ Memory).streamis of typecudaStream_t(pointer) and specifies the associated stream.streamis an optional argument that defaults toNULL.
The following example shows a kernel function declaration and call:
__global__ void kernel(float* parameter);
kernel<<<grid_dim, block_dim, dynamic_smem_bytes>>>(parameter);
The arguments for the execution configuration are evaluated before the arguments for the actual function.
The function call fails if grid_dim or block_dim exceeds the maximum sizes allowed for the device, as specified in Compute Capabilities, or if dynamic_smem_bytes is greater than the available shared memory after accounting for statically allocated memory.
5.4.3.1. Thread Block Cluster#
Compute capability 9.0 and higher allow users to specify compile-time thread block cluster dimensions so that the kernels can use the cluster hierarchy in CUDA. The compile-time cluster dimension can be specified using the __cluster_dims__ attribute with the following syntax: __cluster_dims__([x, [y, [z]]]). The example below shows a compile-time cluster size of 2 in the X dimension and 1 in the Y and Z dimensions.
__global__ void __cluster_dims__(2, 1, 1) kernel(float* parameter);
The default form of __cluster_dims__() specifies that a kernel is to be launched as a grid cluster. If a cluster dimension is not specified, the user can specify it at launch time. Failing to specify a dimension at launch time will result in a launch-time error.
The dimensions of the thread block cluster can also be specified at runtime, and the kernel with the cluster can be launched using the cudaLaunchKernelEx API. This API takes a configuration argument of type cudaLaunchConfig_t, a kernel function pointer, and kernel arguments. The example below shows runtime kernel configuration.
__global__ void kernel(float parameter1, int parameter2) {}
int main() {
cudaLaunchConfig_t config = {0};
// The grid dimension is not affected by cluster launch, and is still enumerated
// using the number of blocks.
// The grid dimension should be a multiple of cluster size.
config.gridDim = dim3{4}; // 4 blocks
config.blockDim = dim3{32}; // 32 threads per block
config.dynamicSmemBytes = 1024; // 1 KB
cudaLaunchAttribute attribute[1];
attribute[0].id = cudaLaunchAttributeClusterDimension;
attribute[0].val.clusterDim.x = 2; // Cluster size in X-dimension
attribute[0].val.clusterDim.y = 1;
attribute[0].val.clusterDim.z = 1;
config.attrs = attribute;
config.numAttrs = 1;
float parameter1 = 3.0f;
int parameter2 = 4;
cudaLaunchKernelEx(&config, kernel, parameter1, parameter2);
5.4.3.2. Launch Bounds#
As discussed in the Kernel Launch and Occupancy section, using fewer registers allows more threads and thread blocks to reside on a multiprocessor, which improves performance.
Therefore, the compiler uses heuristics to minimize register usage while keeping register spilling and instruction count to a minimum. Applications can optionally aid these heuristics by providing additional information to the compiler in the form of launch bounds that are specified using the __launch_bounds__() qualifier in the definition of a __global__ function:
__global__ void
__launch_bounds__(maxThreadsPerBlock, minBlocksPerMultiprocessor, maxBlocksPerCluster)
MyKernel(...) {
maxThreadsPerBlockspecifies the maximum number of threads per block with which the application will ever launchMyKernel(); it compiles to the.maxntidPTX directive.minBlocksPerMultiprocessoris optional and specifies the desired minimum number of resident blocks per multiprocessor; it compiles to the.minnctapersmPTX directive.maxBlocksPerClusteris optional and specifies the desired maximum number of thread blocks per cluster with which the application will ever launchMyKernel(); it compiles to the.maxclusterrankPTX directive.
If launch bounds are specified, the compiler first derives the upper limit, L, on the number of registers that the kernel should use. This ensures that minBlocksPerMultiprocessor blocks (or a single block, if minBlocksPerMultiprocessor is not specified) of maxThreadsPerBlock threads can reside on the multiprocessor. See the occupancy section for the relationship between the number of registers used by a kernel and the number of registers allocated per block. The compiler then optimizes register usage as follows:
If the initial register usage exceeds
L, the compiler reduces it until it is less than or equal toL. This usually results in increased local memory usage and/or a higher number of instructions.If the initial register usage is lower than
LIf
maxThreadsPerBlockis specified butminBlocksPerMultiprocessoris not, the compiler usesmaxThreadsPerBlockto determine the register usage thresholds for the transitions betweennandn + 1resident blocks. This occurs when using one less register makes room for an additional resident block. Then, the compiler applies similar heuristics as when no launch bounds are specified.If both
minBlocksPerMultiprocessorandmaxThreadsPerBlockare specified, the compiler may increase register usage up toLin order to reduce the number of instructions and better hide the latency of single-threaded instructions.
A kernel will fail to launch if it is executed with:
more threads per block than its launch bound
maxThreadsPerBlock.more thread blocks per cluster than its launch bound
maxBlocksPerCluster.
The per-thread resources required by a CUDA kernel may limit the maximum block size in an undesirable way. To maintain forward compatibility with future hardware and toolkits, and to ensure that at least one thread block can run on a streaming multiprocessor, developers should include the single argument __launch_bounds__(maxThreadsPerBlock) which specifies the largest block size with which the kernel will launch. Failure to do so could result in “too many resources requested for launch” errors. Providing the two-argument version of __launch_bounds__(maxThreadsPerBlock,minBlocksPerMultiprocessor) can improve performance in some cases. The best value for minBlocksPerMultiprocessor should be determined through a detailed analysis of each kernel.
The optimal launch bounds for a kernel typically differ across major architecture revisions. The following code sample illustrates how this is managed in device code with the __CUDA_ARCH__ macro.
#define THREADS_PER_BLOCK 256
#if __CUDA_ARCH__ >= 900
#define MY_KERNEL_MAX_THREADS (2 * THREADS_PER_BLOCK)
#define MY_KERNEL_MIN_BLOCKS 3
#else
#define MY_KERNEL_MAX_THREADS THREADS_PER_BLOCK
#define MY_KERNEL_MIN_BLOCKS 2
#endif
__global__ void
__launch_bounds__(MY_KERNEL_MAX_THREADS, MY_KERNEL_MIN_BLOCKS)
MyKernel(...) {
When MyKernel is invoked with the maximum number of threads per block, which is specified as the first parameter of __launch_bounds__(), it is tempting to use MY_KERNEL_MAX_THREADS as the number of threads per block in the execution configuration:
// Host code
MyKernel<<<blocksPerGrid, MY_KERNEL_MAX_THREADS>>>(...);
However, this will not work, since __CUDA_ARCH__ is undefined in host code as mentioned in the Execution Space Specifiers section. Therefore, MyKernel will launch with 256 threads per block. The number of threads per block should instead be determined:
Either at compile time using a macro or constant that does not depend on
__CUDA_ARCH__, for example// Host code MyKernel<<<blocksPerGrid, THREADS_PER_BLOCK>>>(...);
Or at runtime based on the compute capability
// Host code cudaGetDeviceProperties(&deviceProp, device); int threadsPerBlock = (deviceProp.major >= 9) ? 2 * THREADS_PER_BLOCK : THREADS_PER_BLOCK; MyKernel<<<blocksPerGrid, threadsPerBlock>>>(...);
The --resource-usage compiler option reports register usage. The CUDA profiler reports occupancy, which can be used to derive the number of resident blocks.
5.4.3.3. Maximum Number of Registers per Thread#
To enable low-level performance tuning, CUDA C++ offers the __maxnreg__() function qualifier, which passes performance tuning information to the backend optimizing compiler. The __maxnreg__() qualifier specifies the maximum number of registers that can be allocated to a single thread in a thread block. In the definition of a __global__ function:
__global__ void
__maxnreg__(maxNumberRegistersPerThread)
MyKernel(...) {
The maxNumberRegistersPerThread variable specifies the maximum number of registers to be allocated to a single thread in a thread block of the kernel MyKernel(); it compiles to the .maxnreg PTX directive.
The __launch_bounds__() and __maxnreg__() qualifiers cannot be applied to the same kernel together.
The --maxrregcount <N> compiler option can be used to control register usage for all __global__ functions in a file. This option is ignored for kernel functions with the __maxnreg__ qualifier.
5.4.4. Synchronization Primitives#
5.4.4.1. Thread Block Synchronization Functions#
void __syncthreads();
int __syncthreads_count(int predicate);
int __syncthreads_and(int predicate);
int __syncthreads_or(int predicate);
The intrinsics coordinate communication among threads within the same block. When threads in a block access the same addresses in shared or global memory, read-after-write, write-after-read, or write-after-write hazards can occur. These hazards can be avoided by synchronizing threads between such accesses.
The intrinsics have the following semantics:
__syncthreads*()wait until all non-exited threads in the thread block simultaneously reach the same__syncthreads*()intrinsic call in the program or exit.__syncthreads*()provide memory ordering among participating threads: the call to__syncthreads*()intrinsics strongly happens before (see C++ specification [intro.races]) any participating thread is unblocked from the wait or exits.
The following example shows how to use __syncthreads() to synchronize threads within a thread block and safely sum the elements of an array shared among the threads:
// assuming blockDim.x is 128
__global__ void example_syncthreads(int* input_data, int* output_data) {
__shared__ int shared_data[128];
// Every thread writes to a distinct element of 'shared_data':
shared_data[threadIdx.x] = input_data[threadIdx.x];
// All threads synchronize, guaranteeing all writes to 'shared_data' are ordered
// before any thread is unblocked from '__syncthreads()':
__syncthreads();
// A single thread safely reads 'shared_data':
if (threadIdx.x == 0) {
int sum = 0;
for (int i = 0; i < blockDim.x; ++i) {
sum += shared_data[i];
output_data[blockIdx.x] = sum;
The __syncthreads*() intrinsics are permitted in conditional code, but only if the condition evaluates uniformly across the entire thread block. Otherwise, execution may hang or produce unintended side effects.
The following example demonstrates a valid behavior:
__global__ void syncthreads_valid_behavior(int* input_data, int* output_data) {
if (blockIdx.x > 0) { // CORRECT, uniform condition across all block threads
__syncthreads();
output_data[threadIdx.x] = shared_data[128 - threadIdx.x];
while the following examples exhibit invalid behavior, such as kernel hang, or undefined behavior:
__global__ void syncthreads_invalid_behavior1(int* input_data, int* output_data) {
__shared__ int shared_data[256];
if (threadIdx.x > 0) { // WRONG, non-uniform condition
__syncthreads(); // Undefined Behavior
__global__ void syncthreads_invalid_behavior2(int* input_data, int* output_data) {
if (i == threadIdx.x) { // WRONG, non-uniform condition
__syncthreads() variants with predicate:
is identical to __syncthreads() except that it evaluates a predicate for all non-exited threads in the block and returns the number of threads for which the predicate evaluates to a non-zero value.
is identical to __syncthreads() except that it evaluates the predicate for all non-exited threads in the block. It returns a non-zero value if and only if the predicate evaluates to a non-zero value for all of them.
is identical to __syncthreads() except that it evaluates the predicate for all non-exited threads in the block. It returns a non-zero value if and only if the predicate evaluates to a non-zero value one or more of them.
5.4.4.2. Warp Synchronization Function#
void __syncwarp(unsigned mask = 0xFFFFFFFF);
The intrinsic function __syncwarp() coordinates communication between the threads within the same warp. When some threads within a warp access the same addresses in shared or global memory, potential read-after-write, write-after-read, or write-after-write hazards may occur. These data hazards can be avoided by synchronizing the threads between these accesses.
Calling __syncwarp(mask) provides memory ordering among the participating threads within a warp named in mask: the call to __syncwarp(mask) strongly happens before (see C++ specification [intro.races]) any warp thread named in mask is unblocked from the wait or exits.
The functions are subject to the Warp __sync Intrinsic Constraints.
The following example demonstrates how to use __syncwarp() to synchronize threads within a warp to safely access a shared memory array:
__global__ void example_syncwarp(int* input_data, int* output_data) {
if (threadIdx.x < warpSize) {
__shared__ int shared_data[warpSize];
__syncwarp(); // equivalent to __syncwarp(0xFFFFFFFF)
output_data[0] = shared_data[1];
5.4.4.3. Memory Fence Functions#
The CUDA programming model assumes a weakly ordered memory model. In other words, the order in which a CUDA thread writes data to shared memory, global memory, page-locked host memory, or the memory of a peer device is not necessarily the order in which another CUDA or host thread observes the data being written. Reading from or writing to the same memory location without memory fences or synchronization results in undefined behavior.
In the following example, thread 1 executes writeXY(), while thread 2 executes readXY().
__device__ int X = 1, Y = 2;
__device__ void writeXY() {
X = 10;
Y = 20;
__device__ void readXY() {
int B = Y;
int A = X;
The two threads simultaneously read and write to the same memory locations, X and Y. Any data race results in undefined behavior and has no defined semantics. Therefore, the resulting values for A and B can be anything.
Memory fence and synchronization functions enforce a sequentially consistent ordering of memory accesses. These functions differ in the thread scope in which orderings are enforced, but are independent of the accessed memory space, including shared memory, global memory, page-locked host memory, and the memory of a peer device.
Hint
It is suggested to use cuda::atomic_thread_fence provided by libcu++ whenever possible for safety and portability reasons.
Block-level memory fence
// <cuda/atomic> header
cuda::atomic_thread_fence(cuda::memory_order_seq_cst, cuda::thread_scope_block);
ensures that:
All writes to all memory made by the calling thread before the call to
cuda::atomic_thread_fence()are observed by all threads in the calling thread’s block as occurring before all writes to all memory made by the calling thread after the call tocuda::atomic_thread_fence();All reads from all memory made by the calling thread before the call to
cuda::atomic_thread_fence()are ordered before all reads from all memory made by the calling thread after the call tocuda::atomic_thread_fence().
void __threadfence_block();
ensures that:
__threadfence_block()are observed by all threads in the calling thread’s block as occurring before all writes to all memory made by the calling thread after the call to__threadfence_block();All reads from all memory made by the calling thread before the call to
__threadfence_block()are ordered before all reads from all memory made by the calling thread after the call to__threadfence_block().
Device-level memory fence
cuda::atomic_thread_fence(cuda::memory_order_seq_cst, cuda::thread_scope_device);
ensures that:
No writes to all memory made by the calling thread after the call to
cuda::atomic_thread_fence()are observed by any thread in the device as occurring before any write to all memory made by the calling thread before the call tocuda::atomic_thread_fence().
void __threadfence();
ensures that:
__threadfence()are observed by any thread in the device as occurring before any write to all memory made by the calling thread before the call to__threadfence().
System-level memory fence
cuda::atomic_thread_fence(cuda::memory_order_seq_cst, cuda::thread_scope_system);
ensures that:
cuda::atomic_thread_fence()are observed by all threads in the device, host threads, and all threads in peer devices as occurring before all writes to all memory made by the calling thread after the call tocuda::atomic_thread_fence().
void __threadfence_system();
ensures that:
__threadfence_system()are observed by all threads in the device, host threads, and all threads in peer devices as occurring before all writes to all memory made by the calling thread after the call to__threadfence_system().
In the previous code sample, we can insert memory fences in the code as follows:
#include <cuda/atomic>
X = 10;
Y = 20;
int B = Y;
int A = X;
X = 10;
__threadfence();
Y = 20;
int B = Y;
__threadfence();
int A = X;
For this code, the following outcomes can be observed:
Aequal to 1 andBequal to 2, namelyreadXY()is executed beforewriteXY(),Aequal to 10 andBequal to 20, namelywriteXY()is executed beforereadXY().Aequal to 10 andBequal to 2.The case where
Ais 1 andBis 20 is not possible, as the memory fence ensures that the write toXis visible before the write toY.
If threads 1 and 2 belong to the same block, it is enough to use a block-level fence. If threads 1 and 2 do not belong to the same block, a device-level fence must be used if they are CUDA threads from the same device, and a system-level fence must be used if they are CUDA threads from two different devices.
A common use case is illustrated by the following code sample, where threads consume data produced by other threads. This kernel computes the sum of an array of N numbers in a single call.
Each block first sums a subset of the array and stores the result in global memory.
When all the blocks have finished, the last block reads each of these partial sums from global memory and adds them together to obtain the final result.
To determine which block finished last, each block atomically increments a counter to signal completion of computing and storing its partial sum (see the Atomic Functions section for further details). The last block receives a counter value equal to
gridDim.x - 1.
Without a fence between storing the partial sum and incrementing the counter, the counter may increment before the partial sum is stored. This could cause the counter to reach gridDim.x - 1 and allow the last block to start reading partial sums before they are updated in memory.
Note
The memory fence only affects the order in which memory operations are executed; it does not guarantee visibility of these operations to other threads.
In the code sample below, the visibility of the memory operations on the result variable is ensured by declaring it as volatile. For more details, see the volatile-qualified variables section.
__device__ int count = 0;
__global__ void sum(const float* array,
int N,
volatile float* result) {
__shared__ bool isLastBlockDone;
// Each block sums a subset of the input array.
float partialSum = calculatePartialSum(array, N);
// Thread 0 of each block stores the partial sum to global memory.
// The compiler will use a store operation that bypasses the L1 cache
// since the "result" variable is declared as volatile.
// This ensures that the threads of the last block will read the correct
// partial sums computed by all other blocks.
result[blockIdx.x] = partialSum;
// Thread 0 makes sure that the increment of the "count" variable is
// only performed after the partial sum has been written to global memory.
// Thread 0 signals that it is done.
int count_old = atomicInc(&count, gridDim.x);
// Thread 0 determines if its block is the last block to be done.
isLastBlockDone = (count_old == (gridDim.x - 1));
// Synchronize to make sure that each thread reads the correct value of
// isLastBlockDone.
__syncthreads();
if (isLastBlockDone) {
// The last block sums the partial sums stored in result[0 .. gridDim.x-1]
float totalSum = calculateTotalSum(result);
// Thread 0 of last block stores the total sum to global memory and
// resets the count variable, so that the next kernel call works
// properly.
result[0] = totalSum;
count = 0;
5.4.5. Atomic Functions#
Atomic functions perform read-modify-write operations on shared data, making them appear to execute in a single step. Atomicity ensures that each operation either completes fully or not at all, providing all participating threads with a consistent view of the data.
CUDA provides atomic functions in four ways:
- Extended CUDA C++ atomic functions, cuda::atomic and cuda::atomic_ref.
They are allowed in both host and device code.
They follow the C++ standard atomic operations semantics.
They allow specifying the thread scope of the atomic operations.
- Standard C++ atomic functions, cuda::std::atomic and cuda::std::atomic_ref.
They do not allow specifying the thread scope of the atomic operations.
- Compiler built-in atomic functions,
__nv_atomic_<op>(). They have been available since CUDA 12.8.
They are only allowed in device code.
They follow the C++ standard atomic memory order semantics.
They have the same memory ordering semantics as C++ standard atomic operations.
They support a subset of the data types allowed by cuda::std::atomic and cuda::std::atomic_ref, except for 128-bit data types.
- Legacy atomic functions,
atomic<Op>(). They are only allowed in device code.
They only support
memory_order_relaxedC++ atomic memory semantics.They allow specifying the thread scope of the atomic operations as part of the function name.
Unlike built-in atomic functions, legacy atomic functions only ensure atomicity and do not introduce synchronization points (fences).
They support a subset of the data types allowed by built-in atomic functions. The atomic
addoperation supports additional data types.
Hint
Using the Extended CUDA C++ atomic functions provided by libcu++ is recommended for efficiency, safety, and portability.
5.4.5.1. Legacy Atomic Functions#
Legacy atomic functions perform atomic read-modify-write operations on a 32-, 64-, or 128-bit word stored in global or shared memory. For example, the atomicAdd() function reads a word at a specific address in global or shared memory, adds a number to it, and writes the result back to the same address.
Atomic functions can only be used in device functions.
For vector types such as
__half2,__nv_bfloat162,float2, andfloat4, the read-modify-write operation is performed on each element of the vector. The entire vector is not guaranteed to be atomic in a single access.
The atomic functions described in this section have a memory ordering of cuda::std::memory_order_relaxed and are only atomic at a particular thread scope:
Atomic APIs without a suffix, for example
atomicAdd, are atomic at scopecuda::thread_scope_device.Atomic APIs with the
_blocksuffix, for example,atomicAdd_block, are atomic at scopecuda::thread_scope_block.Atomic APIs with the
_systemsuffix, for example,atomicAdd_system, are atomic at scopecuda::thread_scope_systemif they meet particular conditions.
The following example shows the CPU and GPU atomically updating an integer value at address addr:
#include <cuda_runtime.h>
__global__ void atomicAdd_kernel(int* addr) {
atomicAdd_system(addr, 10);
void test_atomicAdd(int device_id) {
int* addr;
cudaMallocManaged(&addr, 4);
*addr = 0;
cudaDeviceProp deviceProp;
cudaGetDeviceProperties(&deviceProp, device_id);
if (deviceProp.concurrentManagedAccess != 1) {
return; // the device does not coherently access managed memory concurrently with the CPU
atomicAdd_kernel<<<...>>>(addr);
__sync_fetch_and_add(addr, 10); // CPU atomic operation
Note that any atomic operation can be implemented based on atomicCAS() (Compare and Swap). For example, atomicAdd() for single-precision floating-point numbers can be implemented as follows:
#include <cuda/memory>
#include <cuda/std/bit>
__device__ float customAtomicAdd(float* d_ptr, float value) {
volatile unsigned* d_ptr_unsigned = reinterpret_cast<unsigned*>(d_ptr);
unsigned old_value = *d_ptr_unsigned;
unsigned assumed;
do {
assumed = old_value;
float assumed_float = cuda::std::bit_cast<float>(assumed);
float expected_value = assumed_float + value;
unsigned expected_value_unsigned = cuda::std::bit_cast<unsigned>(expected_value);
old_value = atomicCAS(d_ptr_unsigned, assumed, expected_value_unsigned);
// Note: uses integer comparison to avoid hang in case of NaN (since NaN != NaN)
} while (assumed != old_value);
return cuda::std::bit_cast<float>(old_value);
5.4.5.1.1. atomicAdd()#
T atomicAdd(T* address, T val);
The function performs the following operations in one atomic transaction:
Reads the
oldvalue located at the addressaddressin global or shared memory.Computes
old + val.Stores the result back to memory at the same address.
The function returns the old value.
atomicAdd() supports the following data types:
int,unsigned,unsigned long long,float,double,__half2,__half.__nv_bfloat16,__nv_bfloat162on devices of compute capability 8.x and higher.float2,float4on devices of compute capability 9.x and higher, and only supported for global memory addresses.
The atomicity of atomicAdd() applied to vector types, for example __half2 or float4, is guaranteed separately for each of the components; the entire vector is not guaranteed to be atomic as a single access.
5.4.5.1.2. atomicSub()#
T atomicSub(T* address, T val);
Reads the
old - val.Stores the result back to memory at the same address.
atomicSub() supports the following data types:
int,unsigned
5.4.5.1.3. atomicInc()#
unsigned atomicInc(unsigned* address, unsigned val);
Reads the
old >= val ? 0 : (old + 1).Stores the result back to memory at the same address.
5.4.5.1.4. atomicDec()#
unsigned atomicDec(unsigned* address, unsigned val);
Reads the
(old == 0 || old > val) ? val : (old - 1).Stores the result back to memory at the same address.
5.4.5.1.5. atomicAnd()#
T atomicAnd(T* address, T val);
Reads the
old & val.Stores the result back to memory at the same address.
atomicAnd() supports the following data types:
int,unsigned,unsigned long long.
5.4.5.1.6. atomicOr()#
T atomicOr(T* address, T val);
Reads the
old | val.Stores the result back to memory at the same address.
atomicOr() supports the following data types:
5.4.5.1.7. atomicXor()#
T atomicXor(T* address, T val);
Reads the
old ^ val.Stores the result back to memory at the same address.
atomicXor() supports the following data types:
5.4.5.1.8. atomicMin()#
T atomicMin(T* address, T val);
Reads the
oldvalue located at the addressaddressin global or shared memory.Computes the minimum of
oldandval.Stores the result back to memory at the same address.
atomicMin() supports the following data types:
int,unsigned,unsigned long long,long long.
5.4.5.1.9. atomicMax()#
T atomicMax(T* address, T val);
Reads the
oldvalue located at the addressaddressin global or shared memory.Computes the maximum of
atomicMax() supports the following data types:
5.4.5.1.10. atomicExch()#
T atomicExch(T* address, T val);
template<typename T>
T atomicExch(T* address, T val); // only 128-bit types, compute capability 9.x and higher
Reads the
oldvalue located at the addressaddressin global or shared memory.Stores
valback to memory at the same address.
atomicExch() supports the following data types:
int,unsigned,unsigned long long,float.
The C++ template function atomicExch() supports 128-bit types with the following requirements:
Compute capability 9.x and higher.
Tmust be aligned to 16 bytes, namelyalignof(T) >= 16.Tmust be trivially copyable, namelystd::is_trivially_copyable_v<T>.For C++03 and older:
Tmust be trivially constructible, namelystd::is_default_constructible_v<T>.
5.4.5.1.11. atomicCAS()#
T atomicCAS(T* address, T compare, T val);
T atomicCAS(T* address, T compare, T val); // only 128-bit types, compute capability 9.x and higher
Reads the
old == compare ? val : old.Stores the result back to memory at the same address.
atomicCAS() supports the following data types:
int,unsigned,unsigned long long,unsigned short.
The C++ template function atomicCAS() supports 128-bit types with the following requirements:
5.4.5.2. Built-in Atomic Functions#
CUDA 12.8 and later support CUDA compiler built-in functions for atomic operations, following the same memory ordering semantics as C++ standard atomic operations and the CUDA thread scopes. The functions follow the GNU’s atomic built-in function signature with an extra argument for thread scope.
nvcc defines the macro __CUDACC_DEVICE_ATOMIC_BUILTINS__ when built-in atomic functions are supported.
Below are listed the raw enumerators for the memory orders and thread scopes, which are used as the order and scope arguments of the built-in atomic functions:
// atomic memory orders
enum {
__NV_ATOMIC_RELAXED,
__NV_ATOMIC_CONSUME,
__NV_ATOMIC_ACQUIRE,
__NV_ATOMIC_RELEASE,
__NV_ATOMIC_ACQ_REL,
__NV_ATOMIC_SEQ_CST
// thread scopes
enum {
__NV_THREAD_SCOPE_THREAD,
__NV_THREAD_SCOPE_BLOCK,
__NV_THREAD_SCOPE_CLUSTER,
__NV_THREAD_SCOPE_DEVICE,
__NV_THREAD_SCOPE_SYSTEM
The memory order corresponds to C++ standard atomic operations’ memory order.
The thread scope follows the
cuda::thread_scopedefinition.__NV_ATOMIC_CONSUMEmemory order is currently implemented using stronger__NV_ATOMIC_ACQUIREmemory order.__NV_THREAD_SCOPE_THREADthread scope is currently implemented using wider__NV_THREAD_SCOPE_BLOCKthread scope.
Example:
__device__ T __nv_atomic_load_n(T* pointer,
int memory_order,
int thread_scope = __NV_THREAD_SCOPE_SYSTEM);
Atomic built-in functions have the following restrictions:
They can only be used in device functions.
They cannot operate on local memory.
The addresses of these functions cannot be taken.
The
orderandscopearguments must be integer literals; they cannot be variables.The thread scope
__NV_THREAD_SCOPE_CLUSTERis supported on architecturessm_90and higher.
Example of unsupported cases:
// Not permitted in a host function
__host__ void bar() {
unsigned u1 = 1, u2 = 2;
__nv_atomic_load(&u1, &u2, __NV_ATOMIC_RELAXED, __NV_THREAD_SCOPE_SYSTEM);
// Not permitted to be applied to local memory
__device__ void foo() {
unsigned a = 1, b;
__nv_atomic_load(&a, &b, __NV_ATOMIC_RELAXED, __NV_THREAD_SCOPE_SYSTEM);
// Not permitted as a template default argument.
// The function address cannot be taken.
template<void *F = __nv_atomic_load_n>
class X {
void *f = F; // The function address cannot be taken.
// Not permitted to be called in a constructor initialization list.
class Y {
int a;
public:
__device__ Y(int *b): a(__nv_atomic_load_n(b, __NV_ATOMIC_RELAXED)) {}
5.4.5.2.1. __nv_atomic_fetch_add(), __nv_atomic_add()#
__device__ T __nv_atomic_fetch_add(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_add (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
The functions perform the following operations in one atomic transaction:
Reads the
__nv_atomic_fetch_addreturns theoldvalue.__nv_atomic_addhas no return value.
The functions support the following data types:
int,unsigned,unsigned long long,float,double.
5.4.5.2.2. __nv_atomic_fetch_sub(), __nv_atomic_sub()#
__device__ T __nv_atomic_fetch_sub(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_sub (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_subreturns theoldvalue.__nv_atomic_subhas no return value.
5.4.5.2.3. __nv_atomic_fetch_and(), __nv_atomic_and()#
__device__ T __nv_atomic_fetch_and(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_and (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_andreturns theoldvalue.__nv_atomic_andhas no return value.
Any integral type of size 4 or 8 bytes.
5.4.5.2.4. __nv_atomic_fetch_or(), __nv_atomic_or()#
__device__ T __nv_atomic_fetch_or(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_or (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_orreturns theoldvalue.__nv_atomic_orhas no return value.
5.4.5.2.5. __nv_atomic_fetch_xor(), __nv_atomic_xor()#
__device__ T __nv_atomic_fetch_xor(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_xor (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_xorreturns theoldvalue.__nv_atomic_xorhas no return value.
5.4.5.2.6. __nv_atomic_fetch_min(), __nv_atomic_min()#
__device__ T __nv_atomic_fetch_min(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_min (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_minreturns theoldvalue.__nv_atomic_minhas no return value.
unsigned,int,unsigned long long,long long.
5.4.5.2.7. __nv_atomic_fetch_max(), __nv_atomic_max()#
__device__ T __nv_atomic_fetch_max(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_max (T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
__nv_atomic_fetch_maxreturns theoldvalue.__nv_atomic_maxhas no return value.
5.4.5.2.8. __nv_atomic_exchange(), __nv_atomic_exchange_n()#
__device__ T __nv_atomic_exchange_n(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_exchange (T* address, T* val, T* ret, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
oldvalue located at the addressaddressin global or shared memory.__nv_atomic_exchange_nstoresvalto whereaddresspoints to.__nv_atomic_exchangestoresoldto whereretpoints to and stores the value located at the addressvalto whereaddresspoints to.
__nv_atomic_exchange_nreturns theoldvalue.__nv_atomic_exchangehas no return value.
Any data type of size of 4, 8 or 16 bytes.
The 16-byte data type is supported on devices of compute capability 9.x and higher.
5.4.5.2.9. __nv_atomic_compare_exchange(), __nv_atomic_compare_exchange_n()#
__device__ bool __nv_atomic_compare_exchange (T* address, T* expected, T* desired, bool weak, int success_order, int failure_order,
__device__ bool __nv_atomic_compare_exchange_n(T* address, T* expected, T desired, bool weak, int success_order, int failure_order,
Reads the
oldvalue located at the addressaddressin global or shared memory.Compare
oldwith the value whereexpectedpoints to.If they are equal, the return value is
trueanddesiredis stored to whereaddresspoints to. Otherwise, it returnsfalseandoldis stored to whereexpectedpoints to.
The parameter weak is ignored and it picks the stronger memory order between success_order and failure_order to execute the compare-and-exchange operation.
Any data type of size of 2, 4, 8 or 16 bytes.
The 16-byte data type is supported on devices with compute capability 9.x and higher.
5.4.5.2.10. __nv_atomic_load(), __nv_atomic_load_n()#
__device__ void __nv_atomic_load (T* address, T* ret, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ T __nv_atomic_load_n(T* address, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
oldvalue located at the addressaddressin global or shared memory.__nv_atomic_loadstoresoldto whereretpoints to.__nv_atomic_load_nreturnsold.
Any data type of size 1, 2, 4, 8 or 16 bytes.
order cannot be __NV_ATOMIC_RELEASE or __NV_ATOMIC_ACQ_REL.
5.4.5.2.11. __nv_atomic_store(), __nv_atomic_store_n()#
__device__ void __nv_atomic_store (T* address, T* val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
__device__ void __nv_atomic_store_n(T* address, T val, int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
Reads the
oldvalue located at the addressaddressin global or shared memory.__nv_atomic_storereads the value wherevalpoints to and stores to whereaddresspoints to.__nv_atomic_store_nstoresvalto whereaddresspoints to.
order cannot be __NV_ATOMIC_CONSUME, __NV_ATOMIC_ACQUIRE or __NV_ATOMIC_ACQ_REL.
5.4.5.2.12. __nv_atomic_thread_fence()#
__device__ void __nv_atomic_thread_fence(int order, int scope = __NV_THREAD_SCOPE_SYSTEM);
This atomic function establishes an ordering between memory accesses requested by this thread based on the specified memory order. The thread scope parameter specifies the set of threads that may observe the ordering effect of this operation.
5.4.6. Warp Functions#
The following section describes the warp functions that allow threads within a warp to communicate with each other and perform computations.
Hint
It is suggested to use the CUB Warp-Wide “Collective” Primitives to perform warp operations whenever possible for efficiency, safety, and portability reasons.
5.4.6.1. Warp Active Mask#
unsigned __activemask();
The function returns a 32-bit integer mask representing all currently active threads in the calling warp. The Nth bit is set if the Nth lane in the warp is active when __activemask() is called. Inactive threads are represented by 0 bits in the returned mask. Threads that have exited the program are always marked as inactive.
Warning
__activemask() cannot be used to determine which warp lanes execute a given branch. This function is intended for opportunistic warp-level programming and only provides an instantaneous snapshot of the active threads within a warp.
// Check whether at least one thread's predicate evaluates to true
if (pred) {
// Invalid: the value of 'at_least_one' is non-deterministic
// and could vary between executions.
at_least_one = __activemask() > 0;
Note that threads convergent at an __activemask() call are not guaranteed to remain convergent at subsequent instructions unless those instructions are warp synchronizing intrinsics (__sync).
For example, the compiler could reorder instructions, and the set of active threads might not be preserved:
unsigned mask = __activemask(); // Assume mask == 0xFFFFFFFF (all bits set, all threads active)
int predicate = threadIdx.x % 2 == 0; // 1 for even threads, 0 for odd threads
int result = __any_sync(mask, predicate); // Active threads might not be preserved
5.4.6.2. Warp Vote Functions#
int __all_sync (unsigned mask, int predicate);
int __any_sync (unsigned mask, int predicate);
unsigned __ballot_sync(unsigned mask, int predicate);
The warp vote functions enable the threads of a given warp to perform a reduction-and-broadcast operation. These functions take an integer predicate as input from each non-exited thread in the warp and compare those values with zero. The results of the comparisons are then combined (reduced) across the active threads of the warp in one of the following ways, broadcasting a single return value to each participating thread:
__all_sync(unsigned mask, predicate):Evaluates
predicatefor all non-exited threads inmaskand returns non-zero ifpredicateevaluates to non-zero for all of them.__any_sync(unsigned mask, predicate):Evaluates
predicatefor all non-exited threads inmaskand returns non-zero ifpredicateevaluates to non-zero for one or more of them.__ballot_sync(unsigned mask, predicate):Evaluates
predicatefor all non-exited threads inmaskand returns an integer whose Nth bit is set ifpredicateevaluates to non-zero for the Nth thread of the warp and the Nth thread is active. Otherwise, the Nth bit is zero.
Warning
These intrinsics do not provide any memory ordering.
5.4.6.3. Warp Match Functions#
Hint
It is suggested to use the libcu++ cuda::device::warp_match_all() function as a generalized and safer alternative to __match_all_sync function.
unsigned __match_any_sync(unsigned mask, T value);
unsigned __match_all_sync(unsigned mask, T value, int *pred);
The warp match functions perform a broadcast-and-compare operation of a variable between non-exited threads within a warp.
__match_any_syncReturns the mask of non-exited threads that have the same bitwise
valueinmask.__match_all_syncReturns
maskif all non-exited threads inmaskhave the same bitwisevalue; otherwise 0 is returned. Predicatepredis set totrueif all non-exited threads inmaskhave the same bitwisevalue; otherwise the predicate is set to false.
T can be int, unsigned, long, unsigned long, long long, unsigned long long, float or double.
Warning
5.4.6.4. Warp Reduce Functions#
Hint
It is suggested to use the CUB Warp-Wide “Collective” Primitives to perform a Warp Reduction whenever possible for efficiency, safety, and portability reasons.
Supported by devices of compute capability 8.x or higher.
T __reduce_add_sync(unsigned mask, T value);
T __reduce_min_sync(unsigned mask, T value);
T __reduce_max_sync(unsigned mask, T value);
unsigned __reduce_and_sync(unsigned mask, unsigned value);
unsigned __reduce_or_sync (unsigned mask, unsigned value);
unsigned __reduce_xor_sync(unsigned mask, unsigned value);
The __reduce_<op>_sync intrinsics perform a reduction operation on the data provided in value after synchronizing all non-exited threads named in mask.
__reduce_add_sync,__reduce_min_sync,__reduce_max_syncReturns the result of applying an arithmetic add, min, or max reduction operation on the values provided in
valueby each non-exited thread named inmask.Tcan be anunsignedorsignedinteger.__reduce_and_sync,__reduce_or_sync,__reduce_xor_syncReturns the result of applying a bitwise AND, OR, or XOR reduction operation on the values provided in
Warning
5.4.6.5. Warp Shuffle Functions#
Hint
It is suggested to use the libcu++ cuda::device::warp_shuffle() functions as a generalized and safer alternative to __shfl_sync() and __shfl_<op>_sync() intrinsics.
T __shfl_sync (unsigned mask, T value, int srcLane, int width=warpSize);
T __shfl_up_sync (unsigned mask, T value, unsigned delta, int width=warpSize);
T __shfl_down_sync(unsigned mask, T value, unsigned delta, int width=warpSize);
T __shfl_xor_sync (unsigned mask, T value, int laneMask, int width=warpSize);
Warp shuffle functions exchange a value between non-exited threads within a warp without the use of shared memory.
__shfl_sync(): Direct copy from indexed lane.The intrinsic function returns the value of
valueheld by the thread whose ID is given bysrcLane.If
widthis less thanwarpSize, then each subsection of the warp behaves as a separate entity with a starting logical lane ID of 0.If
srcLaneis outside the range[0, width - 1], the result corresponds to the value held by thesrcLane % width, which is within the same subsection.
__shfl_up_sync(): Copy from a lane with a lower ID than the caller’s.The intrinsic function calculates a source lane ID by subtracting
deltafrom the caller’s lane ID. The value ofvalueheld by the resulting lane ID is returned: in effect,valueis shifted up the warp bydeltalanes.If
widthis less thanwarpSize, then each subsection of the warp behaves as a separate entity with a starting logical lane ID of 0.The source lane index will not wrap around the value of
width, so the lowerdeltalanes will remain unchanged.
__shfl_down_sync(): Copy from a lane with a higher ID than the caller’s.The intrinsic function calculates a source lane ID by adding
deltato the caller’s lane ID. The value ofvalueheld by the resulting lane ID is returned: this has the effect of shiftingvaluedown the warp bydeltalanes.If
widthis less thanwarpSize, then each subsection of the warp behaves as a separate entity with a starting logical lane ID of 0.As for
__shfl_up_sync(), the ID number of the source lane will not wrap around the value of width and so the upperdeltalanes will effectively remain unchanged.
__shfl_xor_sync(): Copy from a lane based on bitwise XOR of own lane ID.The intrinsic function calculates a source lane ID by performing a bitwise XOR of the caller’s lane ID and
laneMask: the value ofvalueheld by the resulting lane ID is returned. This mode implements a butterfly addressing pattern, which is used in tree reduction and broadcast.If
widthis less thanwarpSize, then each group ofwidthconsecutive threads are able to access elements from earlier groups. However, if they attempt to access elements from later groups of threads their own value ofvaluewill be returned.
T can be:
int,unsigned,long,unsigned long,long long,unsigned long long,floatordouble.__halfand__half2with thecuda_fp16.hheader included.__nv_bfloat16and__nv_bfloat162with thecuda_bf16.hheader included.
Threads may only read data from another thread that is actively participating in the intrinsics. If the target thread is inactive, the retrieved value is undefined.
width must be a power of two in the range [1, warpSize], namely 1, 2, 4, 8, 16, or 32. Other values will produce undefined results.
Examples of valid warp shuffle usage:
int laneId = threadIdx.x % warpSize;
int data = ...
// all warp threads get 'data' from lane 0
int result1 = __shfl_sync(0xFFFFFFFF, data, 0);
if (laneId < 4) {
// lanes 0, 1, 2, 3 get 'data' from lane 1
int result2 = __shfl_sync(0xb1111, data, 1);
// lanes [0 - 15] get 'data' from lane 0
// lanes [16 - 31] get 'data' from lane 16
int result3 = __shfl_sync(0xFFFFFFFF, value, warpSize / 2);
// each lane gets 'data' from the lane two positions above
// lanes 30, 31 get their original value
int result4 = __shfl_down_sync(0xFFFFFFFF, data, 2);
Examples of invalid warp shuffle usage:
int value = ...
// undefined behavior: lane 0 does not participate in the call
int result = (laneId > 0) ? __shfl_sync(0xFFFFFFFF, value, 0) : 0;
if (laneId <= 4) {
// undefined behavior: destination lanes 5, 6 are not active for lanes 3, 4
result = __shfl_down_sync(0b11111, value, 2);
// undefined behavior: width is not a power of 2
__shfl_sync(0xFFFFFFFF, value, 0, /*width=*/31);
Warning
These intrinsics do not imply a memory barrier. They do not guarantee any memory ordering.
Example 1: Broadcast of a single value across a warp
#include <cassert>
#include <cuda/warp>
__global__ void warp_broadcast_kernel(int input) {
int laneId = threadIdx.x % 32;
int value;
if (laneId == 0) { // unused variable for all threads except lane 0
value = input;
value = cuda::device::warp_shuffle_idx(value, 0); // Synchronize all threads in warp, and get "value" from lane 0
assert(value == input);
int main() {
warp_broadcast_kernel<<<1, 32>>>(1234);
return 0;
#include <assert.h>
int value;
value = input;
value = __shfl_sync(0xFFFFFFFF, value, 0); // Synchronize all threads in warp, and get "value" from lane 0
int main() {
return 0;
Example 2: Inclusive plus-scan across sub-partitions of 8 threads
Hint
It is suggested to use the cub::WarpScan function for efficient and generalized warp scan functions.
#include <cstdio>
#include <cub/cub.cuh>
__global__ void scan_sub_partition_with_8_threads_kernel() {
using WarpScan = cub::WarpScan<int, 8>;
using TempStorage = typename WarpScan::TempStorage;
__shared__ TempStorage temp_storage;
int value = 31 - laneId; // starting value to accumulate
int partial_sum;
WarpScan(temp_storage).InclusiveSum(value, partial_sum);
printf("Thread %d final value = %d\n", threadIdx.x, partial_sum);
int main() {
scan_sub_partition_with_8_threads_kernel<<<1, 32>>>();
return 0;
#include <stdio.h>
// Loop to accumulate scan within my partition.
// Scan requires log2(8) == 3 steps for 8 threads
for (int delta = 1; delta <= 4; delta *= 2) {
int tmp = __shfl_up_sync(0xFFFFFFFF, value, delta, /*width=*/8); // read from laneId - delta
int source_lane = laneId % 8 - delta;
if (source_lane >= 0) // lanes with 'source_lane < 0' have their value unchanged
value += tmp;
printf("Thread %d final value = %d\n", threadIdx.x, value);
int main() {
return 0;
Example 3: Reduction across a warp
Hint
It is suggested to use the cub::WarpReduce function for efficient and generalized warp reduction functions.
#include <cstdio>
__global__ void warp_reduce_kernel() {
using WarpReduce = cub::WarpReduce<int>;
using TempStorage = typename WarpReduce::TempStorage;
auto aggregate = WarpReduce(temp_storage).Sum(value);
aggregate = cuda::device::warp_shuffle_idx(aggregate, 0);
printf("Thread %d final value = %d\n", threadIdx.x, aggregate);
int main() {
warp_reduce_kernel<<<1, 32>>>();
return 0;
#include <stdio.h>
// Use XOR mode to perform butterfly reduction
// A full-warp reduction requires log2(32) == 5 steps
for (int i = 1; i <= 16; i *= 2)
value += __shfl_xor_sync(0xFFFFFFFF, value, i);
// "value" now contains the sum across all threads
int main() {
return 0;
See the example on Compiler Explorer.
5.4.6.6. Warp __sync Intrinsic Constraints#
All warp __sync intrinsics, such as:
__shfl_sync,__shfl_up_sync,__shfl_down_sync,__shfl_xor_sync__match_any_sync,__match_all_sync__reduce_add_sync,__reduce_min_sync,__reduce_max_sync,__reduce_and_sync,__reduce_or_sync,__reduce_xor_sync__syncwarp
use the mask parameter to indicate which warp threads participate in the call. This parameter ensures proper convergence before the hardware executes the intrinsic.
mask corresponds to a thread’s lane ID (threadIdx.x % warpSize). The intrinsic waits until all non-exited warp threads specified in the mask reach the call.Each calling thread must have its corresponding bit set in the
mask.Each non-calling thread must have its corresponding bit set to zero in the
mask. Exited threads are ignored.All non-exited threads specified in the
maskmust execute the intrinsic with the samemaskvalue.Warp threads may call the intrinsic concurrently with different
maskvalues, provided the masks are disjoint. Such condition is valid even in divergent control flow.
The behavior of warp __sync functions is invalid, such as kernel hang, or undefined if:
A calling thread is not specified in the
mask.A non-exited thread specified in the
maskfails to either eventually exit or call the intrinsic at the same program point with the samemaskvalue.In conditional code, all conditions must evaluate identically across all non-exited threads specified in the
mask.
Note
The intrinsics achieve the best efficiency when all warp threads participate in the call, namely when the mask is set to 0xFFFFFFFF.
Examples of valid warp intrinsics usage:
__global__ void valid_examples() {
if (threadIdx.x < 4) { // threads 0, 1, 2, 3 are active
__all_sync(0b1111, pred); // CORRECT, threads 0, 1, 2, 3 participate in the call
return; // exit
// CORRECT, all non-exited threads participate in the call
__all_sync(0xFFFFFFFF, pred);
Disjoint mask examples:
__global__ void example_syncwarp_with_mask(int* input_data, int* output_data) {
unsigned mask = threadIdx.x < 16 ? 0xFFFF : 0xFFFF0000; // CORRECT
__syncwarp(mask);
if (threadIdx.x == 0 || threadIdx.x == 16)
output_data[threadIdx.x] = shared_data[threadIdx.x + 1];
__global__ void example_syncwarp_with_mask_branches(int* input_data, int* output_data) {
if (threadIdx.x < 16) {
unsigned mask = 0xFFFF; // CORRECT
__syncwarp(mask);
output_data[threadIdx.x] = shared_data[15 - threadIdx.x];
else {
unsigned mask = 0xFFFF0000; // CORRECT
__syncwarp(mask);
output_data[threadIdx.x] = shared_data[31 - threadIdx.x];
Examples of invalid warp intrinsics usage:
__all_sync(0b0000011, pred); // WRONG, threads 2, 3 are active but not set in mask
__all_sync(0b1111111, pred); // WRONG, threads 4, 5, 6 are not active but set in mask
// WRONG, participating threads have a different and overlapping mask
__all_sync(threadIdx.x == 0 ? 1 : 0xFFFFFFFF, pred);
5.4.7. CUDA-Specific Macros#
5.4.7.1. __CUDA_ARCH__#
The macro __CUDA_ARCH__ represents the virtual architecture of the NVIDIA GPU for which the code is being compiled. Its value may differ from the device’s actual compute capability. This macro enables the writing of code paths that are specialized for particular GPU architectures, which may be necessary for optimal performance or to use architecture-specific features and instructions. The macro can also be used to distinguish between host and device code.
__CUDA_ARCH__ is only defined in device code, namely in the __device__, __host__ __device__, and __global__ functions. The value of the macro is associated with the nvcc option compute_<version>, with the relation __CUDA_ARCH__ = <version> * 10.
Example:
nvcc --generate-code arch=compute_80,code=sm_90 prog.cu
defines __CUDA_ARCH__ as 800.
__CUDA_ARCH__ Constraints
1. The type signatures of the following entities shall not depend on whether __CUDA_ARCH__ is defined, nor on its value.
__global__functions and function templates.__device__and__constant__variables.Textures and surfaces.
Example:
#if !defined(__CUDA_ARCH__)
typedef int my_type;
#else
typedef double my_type;
#endif
__device__ my_type my_var; // ERROR: my_var's type depends on __CUDA_ARCH__
__global__ void kernel(my_type in) { // ERROR: kernel's type depends on __CUDA_ARCH__
2. If a __global__ function template is instantiated and launched from the host, then it must be instantiated with the same template arguments, regardless of whether __CUDA_ARCH__ is defined or its value.
Example:
__device__ int result;
template <typename T>
__global__ void kernel(T in) {
result = in;
__host__ __device__ void host_device_function(void) {
kernel<<<1, 1>>>(1); // ERROR: "kernel<int>" instantiation only
// when __CUDA_ARCH__ is undefined!
#endif
int main(void) {
host_device_function();
cudaDeviceSynchronize();
return 0;
3. In separate compilation mode, the presence or absence of a function or variable definition with external linkage shall not depend on the definition of __CUDA_ARCH__ or on its value.
Example:
void host_function(void) {} // ERROR: The definition of host_function()
// is only present when __CUDA_ARCH__
// is undefined
#endif
4. In separate compilation, the preprocessor macro __CUDA_ARCH__ must not be used in headers to prevent objects from having different behaviors. Alternatively, all objects must be compiled for the same virtual architecture. If a weak or template function is defined in a header and its behavior depends on __CUDA_ARCH__, then instances of that function in different objects could conflict if those objects are compiled for different compute architectures.
For example, if a header file a.h contains:
__device__ T* get_ptr() {
#if __CUDA_ARCH__ == 900
return nullptr; /* no address */
#else
__shared__ T arr[256];
return arr;
#endif
Then if a.cu and b.cu both include a.h and instantiate get_ptr() for the same type, and b.cu expects a non-NULL address, and compile with:
nvcc -arch=compute_70 -dc a.cu
nvcc -arch=compute_80 -dc b.cu
nvcc -arch=sm_80 a.o b.o
Only one version of the ``get_ptr()`` function is used at link time, so the behavior depends on which version is chosen. To avoid this issue, either ``a.cu`` and ``b.cu`` must be compiled for the same compute architecture, or ``__CUDA_ARCH__`` should not be used in the shared header function.
The compiler does not guarantee that a diagnostic will be generated for the unsupported uses of __CUDA_ARCH__ described above.
5.4.7.2. __CUDA_ARCH_SPECIFIC__ and __CUDA_ARCH_FAMILY_SPECIFIC__#
The macros __CUDA_ARCH_SPECIFIC__ and __CUDA_ARCH_FAMILY_SPECIFIC__ are defined to identify GPU devices with architecture- and family- specific features, respectively. See Feature Set Compiler Targets section for more information.
Similarly to __CUDA_ARCH__, __CUDA_ARCH_SPECIFIC__ and __CUDA_ARCH_FAMILY_SPECIFIC__ are only defined in the device code, namely in the __device__, __host__ __device__, and __global__ functions. The macros are associated with the nvcc options compute_<version>a and compute_<version>f.
nvcc --generate-code arch=compute_100a,code=sm_100a prog.cu
__CUDA_ARCH__ == 1000.__CUDA_ARCH_SPECIFIC__ == 1000.__CUDA_ARCH_FAMILY_SPECIFIC__ == 1000.
nvcc --generate-code arch=compute_100f,code=sm_103f prog.cu
__CUDA_ARCH__ == 1000.__CUDA_ARCH_FAMILY_SPECIFIC__ == 1000.__CUDA_ARCH_SPECIFIC__is not defined.
nvcc -arch=sm_100 prog.cu
__CUDA_ARCH__ == 1000.__CUDA_ARCH_FAMILY_SPECIFIC__is not defined.__CUDA_ARCH_SPECIFIC__is not defined.
nvcc -arch=sm_100a prog.cu
# equivalent to:
nvcc --generate-code arch=sm_100a,compute_100,compute_100a prog.cu
__CUDA_ARCH__ == 1000.__CUDA_ARCH_FAMILY_SPECIFIC__is not defined.__CUDA_ARCH_SPECIFIC__ == 1000and__CUDA_ARCH_SPECIFIC__not defined are both generated.
5.4.7.3. CUDA Feature Testing Macros#
nvcc provides the following preprocessor macros for feature testing. The macros are defined when a particular feature is supported by the CUDA front-end compiler.
__CUDACC_DEVICE_ATOMIC_BUILTINS__: Supports device atomic compiler builtins.__NVCC_DIAG_PRAGMA_SUPPORT__: Supports diagnostic control pragmas.__CUDACC_EXTENDED_LAMBDA__: Supports extended lambdas. Enabled by--expt-extended-lambdaor--extended-lambdaflag.__CUDACC_RELAXED_CONSTEXPR__: Support for relaxed constexpr functions. Enabled by the--expt-relaxed-constexprflag.
5.4.7.4. __nv_pure__ Attribute#
In C/C++, a pure function has no side effects on its parameters and can access global variables, though it does not modify them.
CUDA provides __nv_pure__ attribute supported for both host and device functions. The compiler translates __nv_pure__ to the pure GNU attribute or to the Microsoft Visual Studio noalias attribute.
__device__ __nv_pure__
int add(int a, int b) {
return a + b;
5.4.8. CUDA-Specific Functions#
5.4.8.1. Address Space Predicate Functions#
Address space predicate functions are used to determine the address space of a pointer.
Hint
It is suggested to use the cuda::device::is_address_from() and cuda::device::is_object_from() functions provided by libcu++ as a portable and safer alternative to Address Space Predicate intrinsic functions.
__device__ unsigned __isGlobal (const void* ptr);
__device__ unsigned __isShared (const void* ptr);
__device__ unsigned __isConstant (const void* ptr);
__device__ unsigned __isGridConstant(const void* ptr);
__device__ unsigned __isLocal (const void* ptr);
The functions return 1 if ptr contains the generic address of an object in the specified address space, 0 otherwise. Their behavior is unspecified if the argument is a NULL pointer.
__isGlobal(): global memory space.__isShared(): shared memory space.__isConstant(): constant memory space.__isGridConstant(): kernel parameter annotated with__grid_constant__.__isLocal(): local memory space.
5.4.8.2. Address Space Conversion Functions#
CUDA pointers (T*) can access objects regardless of where the objects are stored. For example, an int* can access int objects whether they reside in global or shared memory.
Address space conversion functions are used to convert between generic addresses and addresses in specific address spaces. These functions are useful when the compiler cannot determine a pointer’s address space, for example, when crossing translation units or interacting with PTX instructions.
__device__ size_t __cvta_generic_to_global (const void* ptr); // PTX: cvta.to.global
__device__ size_t __cvta_generic_to_shared (const void* ptr); // PTX: cvta.to.shared
__device__ size_t __cvta_generic_to_constant(const void* ptr); // PTX: cvta.to.const
__device__ size_t __cvta_generic_to_local (const void* ptr); // PTX: cvta.to.local
__device__ void* __cvta_global_to_generic (size_t raw_ptr); // PTX: cvta.global
__device__ void* __cvta_shared_to_generic (size_t raw_ptr); // PTX: cvta.shared
__device__ void* __cvta_constant_to_generic(size_t raw_ptr); // PTX: cvta.const
__device__ void* __cvta_local_to_generic (size_t raw_ptr); // PTX: cvta.local
As an example of inter-operating with PTX instructions, the ld.shared.s32 r0, [ptr]; PTX instruction expects ptr to refer to the shared memory address space.
A CUDA program with an int* pointer to an object in __shared__ memory needs to convert this pointer to the shared address space before passing it to the PTX instruction by calling __cvta_generic_to_shared as follows:
__shared__ int smem_var;
smem_var = 42;
size_t smem_ptr = __cvta_generic_to_shared(&smem_var);
int output;
asm volatile("ld.shared.s32 %0, [%1];" : "=r"(output) : "l"(smem_ptr) : "memory");
assert(output == 42);
A common optimization that exploits these address representations is reducing data structure size by leveraging the fact that the address ranges of shared, local, and constant spaces are smaller than 32 bits, which allows storing 32-bit addresses instead of 64-bit pointers and save registers. Additionally, 32-bit arithmetic is faster than 64-bit arithmetic. To obtain the 32-bit integer representation of these addresses, truncate the 64-bit value to 32 bits by casting from an unsigned 64-bit integer to an unsigned 32-bit integer:
uint32_t smem_ptr_32bit = static_cast<uint32_t>(__cvta_generic_to_shared(&smem_var));
To recover a generic address from such a 32-bit representation, zero-extend the address back to an unsigned 64-bit integer and then call the corresponding address space conversion function:
size_t smem_ptr_64bit = static_cast<size_t>(smem_ptr_32bit); // zero-extend to 64 bits
void* generic_ptr = __cvta_shared_to_generic(smem_ptr_64bit);
assert(generic_ptr == &smem_var);
5.4.8.3. Low-Level Load and Store Functions#
T __ldg(const T* address);
The function __ldg() performs a read-only L1/Tex cache load. It supports all C++ fundamental types, CUDA vector types (except x3 components), and extended floating-point types, such as __half, __half2, __nv_bfloat16, and __nv_bfloat162.
T __ldcg(const T* address);
T __ldca(const T* address);
T __ldcs(const T* address);
T __ldlu(const T* address);
T __ldcv(const T* address);
The functions perform a load using the cache operator specified in the PTX ISA guide. They support all C++ fundamental types, CUDA vector types (except x3 components), and extended floating-point types, such as __half, __half2, __nv_bfloat16, and __nv_bfloat162.
void __stwb(T* address, T value);
void __stcg(T* address, T value);
void __stcs(T* address, T value);
void __stwt(T* address, T value);
The functions perform a store using the cache operator specified in the PTX ISA guide. They support all C++ fundamental types, CUDA vector types (except x3 components), and extended floating-point types, such as __half, __half2, __nv_bfloat16, and __nv_bfloat162.
5.4.8.4. __trap()#
Hint
It is suggested to use the cuda::std::terminate() function provided by libcu++ (C++ reference) as a portable alternative to __trap().
A trap operation can be initiated by calling the __trap() function from any device thread.
void __trap();
Execution of the kernel is aborted, raising an interrupt in the host program. Calling __trap() results in a corrupted CUDA context, causing subsequent CUDA calls and kernel invocations to fail.
5.4.8.5. __nanosleep()#
__device__ void __nanosleep(unsigned nanoseconds);
The function __nanosleep(ns) suspends the thread for a sleep duration of approximately ns nanoseconds. The maximum sleep duration is approximately one millisecond.
Example:
The following code implements a mutex with exponential back-off.
__device__ void mutex_lock(unsigned* mutex) {
unsigned ns = 8;
while (atomicCAS(mutex, 0, 1) == 1) {
__nanosleep(ns);
if (ns < 256) {
ns *= 2;
__device__ void mutex_unlock(unsigned *mutex) {
atomicExch(mutex, 0);
5.4.8.6. Dynamic Programming eXtension (DPX) Instructions#
The DPX set of functions enables finding minimum and maximum values, as well as fused addition and minimum/maximum for up to three 16- or 32-bit signed or unsigned integer parameters. There is an optional ReLU, namely clamping to zero, feature.
Comparison functions:
Three parameters. Semantic:
max(a, b, c),min(a, b, c).
int __vimax3_s32 ( int, int, int);
unsigned __vimax3_s16x2(unsigned, unsigned, unsigned);
unsigned __vimax3_u32 (unsigned, unsigned, unsigned);
unsigned __vimax3_u16x2(unsigned, unsigned, unsigned);
int __vimin3_s32 ( int, int, int);
unsigned __vimin3_s16x2(unsigned, unsigned, unsigned);
unsigned __vimin3_u32 (unsigned, unsigned, unsigned);
unsigned __vimin3_u16x2(unsigned, unsigned, unsigned);
Two parameters, with ReLU. Semantic:
max(a, b, 0),max(min(a, b), 0).
int __vimax_s32_relu ( int, int);
unsigned __vimax_s16x2_relu(unsigned, unsigned);
int __vimin_s32_relu ( int, int);
unsigned __vimin_s16x2_relu(unsigned, unsigned);
Three parameters, with ReLU. Semantic:
max(a, b, c, 0),max(min(a, b, c), 0).
int __vimax3_s32_relu ( int, int, int);
unsigned __vimax3_s16x2_relu(unsigned, unsigned, unsigned);
int __vimin3_s32_relu ( int, int, int);
unsigned __vimin3_s16x2_relu(unsigned, unsigned, unsigned);
Two parameters, also returning which parameter was smaller/larger:
int __vibmax_s32 ( int, int, bool* pred);
unsigned __vibmax_u32 (unsigned, unsigned, bool* pred);
unsigned __vibmax_s16x2(unsigned, unsigned, bool* pred);
unsigned __vibmax_u16x2(unsigned, unsigned, bool* pred);
int __vibmin_s32 ( int, int, bool* pred);
unsigned __vibmin_u32 (unsigned, unsigned, bool* pred);
unsigned __vibmin_s16x2(unsigned, unsigned, bool* pred);
unsigned __vibmin_u16x2(unsigned, unsigned, bool* pred);
Fused addition and minimum/maximum:
Three parameters, comparing (first + second) with the third. Semantic:
max(a + b, c),min(a + b, c)
int __viaddmax_s32 ( int, int, int);
unsigned __viaddmax_s16x2(unsigned, unsigned, unsigned);
unsigned __viaddmax_u32 (unsigned, unsigned, unsigned);
unsigned __viaddmax_u16x2(unsigned, unsigned, unsigned);
int __viaddmin_s32 ( int, int, int);
unsigned __viaddmin_s16x2(unsigned, unsigned, unsigned);
unsigned __viaddmin_u32 (unsigned, unsigned, unsigned);
unsigned __viaddmin_u16x2(unsigned, unsigned, unsigned);
Three parameters, with ReLU, comparing (first + second) with the third and a zero. Semantic:
max(a + b, c, 0),max(min(a + b, c), 0)
int __viaddmax_s32_relu ( int, int, int);
unsigned __viaddmax_s16x2_relu(unsigned, unsigned, unsigned);
int __viaddmin_s32_relu ( int, int, int);
unsigned __viaddmin_s16x2_relu(unsigned, unsigned, unsigned);
These instructions are hardware-accelerated or software emulated depending on compute capability. See Arithmetic Instructions section for the compute capability requirements.
The full API can be found in CUDA Math API documentation.
The DPX is an exceptionally useful tool for implementing dynamic programming algorithms such as the Smith-Waterman and Needleman-Wunsch algorithms in genomics and the Floyd-Warshall algorithm in route optimization.
Maximum value of three signed 32-bit integers, with ReLU:
int a = -15;
int b = 8;
int c = 5;
int max_value_0 = __vimax3_s32_relu(a, b, c); // max(-15, 8, 5, 0) = 8
int d = -2;
int e = -4;
int max_value_1 = __vimax3_s32_relu(a, d, e); // max(-15, -2, -4, 0) = 0
Minimum value of the sum of two 32-bit signed integers, another 32-bit signed integer and a zero (ReLU):
int a = -5;
int b = 6;
int c = -2;
int max_value_0 = __viaddmax_s32_relu(a, b, c); // max(-5 + 6, -2, 0) = max(1, -2, 0) = 1
int d = 4;
int max_value_1 = __viaddmax_s32_relu(a, d, c); // max(-5 + 4, -2, 0) = max(-1, -2, 0) = 0
Minimum value of two unsigned 32-bit integers and determining which value is smaller:
unsigned a = 9;
unsigned b = 6;
bool smaller_value;
unsigned min_value = __vibmin_u32(a, b, &smaller_value); // min_value is 6, smaller_value is true
Maximum values of three pairs of unsigned 16-bit integers:
unsigned a = 0x00050002;
unsigned b = 0x00070004;
unsigned c = 0x00020006;
unsigned max_value = __vimax3_u16x2(a, b, c); // max(5, 7, 2) and max(2, 4, 6), so max_value is 0x00070006
5.4.9. Compiler Optimization Hints#
Compiler optimization hints decorate code with additional information to help the compiler optimize generated code.
The built-in functions are always available in the device code.
Host code support depends on the host compiler.
5.4.9.1. #pragma unroll#
The compiler unrolls small loops with a known trip count by default. However, the #pragma unroll directive can be used to control the unrolling of any given loop. This directive must be placed immediately before the loop and only applies to that loop.
An integral constant expression may optionally follow. The following are cases for an integral constant expression:
If it is absent, the loop will be completely unrolled if its trip count is constant.
If it evaluates to
0or1, the loop will not be unrolled.If it is a non-positive integer or greater than
INT_MAX, the pragma will be ignored, and a warning will be issued.
Examples:
struct MyStruct {
static constexpr int value = 4;
inline constexpr int Count = 4;
__device__ void foo(int* p1, int* p2) {
// no argument specified, the loop will be completely unrolled
#pragma unroll
for (int i = 0; i < 12; ++i)
p1[i] += p2[i] * 2;
// unroll value = 5
#pragma unroll (Count + 1)
p1[i] += p2[i] * 4;
// unroll value = 1, loop unrolling disabled
#pragma unroll 1
p1[i] += p2[i] * 8;
// unroll value = 4
#pragma unroll (MyStruct::value)
p1[i] += p2[i] * 16;
// negative value, pragma unroll ignored
#pragma unroll -1
p1[i] += p2[i] * 2;
5.4.9.2. __builtin_assume_aligned()#
Hint
It is suggested to use the cuda::std::assume_aligned() function provided by libcu++ (C++ reference) as a portable and safer alternative to the built-in functions.
void* __builtin_assume_aligned(const void* ptr, size_t align)
void* __builtin_assume_aligned(const void* ptr, size_t align, <integral type> offset)
The built-in functions enable the compiler to assume that the returned pointer is aligned to at least align bytes.
The three parameter version enables the compiler to assume that
(char*) ptr - offsetis aligned to at leastalignbytes.
align must be a power of two and an integer literal.
Examples:
void* res1 = __builtin_assume_aligned(ptr, 32); // compiler can assume 'res1' is at least 32-byte aligned
void* res2 = __builtin_assume_aligned(ptr, 32, 8); // compiler can assume 'res2 = (char*) ptr - 8' is at least 32-byte aligned
5.4.9.3. __builtin_assume() and __assume()#
void __builtin_assume(bool predicate)
void __assume (bool predicate) // only with Microsoft Compiler
The built-in function enables the compiler to assume that the boolean argument is true. If the argument is false at runtime, the behavior is undefined. Note that if the argument has side effects, the behavior is unspecified.
Example:
__device__ bool is_greater_than_zero(int value) {
return value > 0;
__device__ bool f(int value) {
__builtin_assume(value > 0);
return is_greater_than_zero(value); // returns true, without evaluating the condition
5.4.9.4. __builtin_expect()#
long __builtin_expect(long input, long expected)
The built-in function tells the compiler that input is expected to equal expected, and returns the value of input. It is typically used to provide branch prediction information to the compiler.
It behaves like the C++20 [[likely]] and [[unlikely]] attributes.
Example:
// indicate to the compiler that likely "var == 0"
if (__builtin_expect(var, 0))
doit();
5.4.9.5. __builtin_unreachable()#
void __builtin_unreachable(void)
The built-in function tells the compiler that the control flow will never reach the point at which the function is called. If the control flow does reach this point at runtime, the program has undefined behavior.
This function is useful for avoiding code generation of unreachable branches and disabling compiler warnings for unreachable code.
Example:
// indicates to the compiler that the default case label is never reached.
switch (in) {
case 1: return 4;
case 2: return 10;
default: __builtin_unreachable();
5.4.9.6. Custom ABI Pragmas#
The #pragma nv_abi directive enables applications compiled in separate compilation mode to achieve performance similar to that of whole program compilation by preserving the number of registers used by a function.
The syntax for using this pragma is as follows, where EXPR refers to any integral constant expression:
#pragma nv_abi preserve_n_data(EXPR) preserve_n_control(EXPR)
The arguments that follow
#pragma nv_abiare optional and may be provided in any order; however, at least one argument is required.The
preserve_narguments limit the number of registers preserved during a function call:preserve_n_data(EXPR)limits the number of data registers.preserve_n_control(EXPR)limits the number of control registers.
The #pragma nv_abi directive can be placed immediately before a device function declaration or definition.
#pragma nv_abi preserve_n_data(16)
__device__ void dev_func();
#pragma nv_abi preserve_n_data(16) preserve_n_control(8)
__device__ int dev_func() {
return 0;
Alternatively, it can be placed directly before an indirect function call within a C++ expression statement inside a device function. Note that while indirect function calls to free functions are supported, indirect calls to function references or class member functions are not supported.
__device__ int dev_func1();
struct MyStruct {
__device__ int member_func2();
__device__ void test() {
auto* dev_func_ptr = &dev_func1; // type: int (*)(void)
#pragma nv_abi preserve_n_control(8)
int v1 = dev_func_ptr(); // CORRECT, indirect call
int v2 = dev_func1(); // WRONG, direct call; the pragma has no effect
// dev_func1 has type: int(void)
auto& dev_func_ref = &dev_func1; // type: int (&)(void)
int v3 = dev_func_ref(); // WRONG, call to a reference
// the pragma has no effect
auto member_function_ptr = &MyStruct::member_func2; // type: int (MyStruct::*)(void)
int v4 = member_function_ptr(); // WRONG, indirect call to member function
When applied to a device function’s declaration or definition, the pragma modifies the custom ABI properties for any calls to that function. When placed at an indirect function call site, it affects the ABI properties only for that specific call. Note that the pragma only affects indirect function calls when placed at a call site; it has no effect on direct function calls.
__device__ int dev_func3();
__device__ int dev_func4();
int v1 = dev_func3(); // CORRECT, the pragma affects the direct call
auto* dev_func_ptr = &dev_func4; // type: int (*)(void)
int v2 = dev_func_ptr(); // CORRECT, the pragma affects the indirect call
int v3 = dev_func_ptr(); // WRONG, the pragma has no effect
Note that a program is ill-formed if the pragma arguments for a function declaration and its corresponding definition do not match.
5.4.10. Debugging and Diagnostics#
5.4.10.1. Assertion#
void assert(int expression);
The assert() macro stops kernel execution if expression is equal to zero. If the program is run within a debugger, a breakpoint is triggered, allowing the debugger to be used to inspect the current state of the device. Otherwise, each thread for which expression is equal to zero prints a message to stderr after synchronizing with the host via cudaDeviceSynchronize(), cudaStreamSynchronize(), or cudaEventSynchronize(). The format of this message is as follows:
<filename>:<line number>:<function>:
block: [blockIdx.x,blockIdx.y,blockIdx.z],
thread: [threadIdx.x,threadIdx.y,threadIdx.z]
Assertion `<expression>` failed.
Execution of the kernel is aborted, raising an interrupt in the host program. The assert() macro results in a corrupted CUDA context, causing any subsequent CUDA calls or kernel invocations to fail with cudaErrorAssert.
The kernel execution is unaffected if expression is different from zero.
For example, the following program from source file test.cu
#include <assert.h>
__global__ void testAssert(void) {
int is_one = 1;
int should_be_one = 0;
// This will have no effect
assert(is_one);
// This will halt kernel execution
assert(should_be_one);
int main(void) {
testAssert<<<1,1>>>();
return 0;
will output:
test.cu:11: void testAssert(): block: [0,0,0], thread: [0,0,0] Assertion `should_be_one` failed.
Assertions are intended for debugging purposes. Since they can affect performance, it is recommended that they be disabled in production code. They can be disabled at compile time by defining the NDEBUG preprocessor macro before including assert.h or <cassert>, or by using the compiler flag -DNDEBUG. Note that the expression should not have side effects; otherwise, disabling the assertion will affect the functionality of the code.
5.4.10.2. Breakpoint Function#
The execution of a kernel function can be suspended by calling the __brkpt() function from any device thread.
void __brkpt();
5.4.10.3. Diagnostic Pragmas#
The following pragmas can be used to manage the severity of errors that are triggered when a specific diagnostic message is raised.
#pragma nv_diag_suppress
#pragma nv_diag_warning
#pragma nv_diag_error
#pragma nv_diag_default
#pragma nv_diag_once
The uses of these pragmas are as follows:
#pragma nv_diag_xxx <error_number1>, <error_number2> ...
The affected diagnostic is specified using the error number shown in the warning message. Any diagnostic can be changed to an error, but only warnings can have their severity suppressed or restored after being changed to an error. The nv_diag_default pragma returns the severity of a diagnostic to the severity that was in effect before any other pragmas were issued, namely, the normal severity of the message as modified by any command-line options. The following example suppresses the declared but never referenced warning of foo():
#pragma nv_diag_suppress 177 // "declared but never referenced"
void foo() {
int i = 0;
#pragma nv_diag_default 177
void bar() {
int i = 0;
The following pragmas may be used to save and restore the current diagnostic pragma state:
#pragma nv_diagnostic push
#pragma nv_diagnostic pop
Examples:
void foo() {
int i = 0;
void bar() {
int i = 0; // raise a warning
Note that these directives only affect the nvcc CUDA front-end compiler. They have no effect on the host compiler.
nvcc defines the macro __NVCC_DIAG_PRAGMA_SUPPORT__ when diagnostic pragmas are supported.
5.4.11. Warp Matrix Functions#
C++ warp matrix operations leverage Tensor Cores to accelerate matrix problems of the form D=A*B+C. These operations are supported on mixed-precision floating point data for devices of compute capability 7.0 or higher. This requires co-operation from all threads in a warp. In addition, these operations are allowed in conditional code only if the condition evaluates identically across the entire warp, otherwise the code execution is likely to hang.
5.4.11.1. Description#
All following functions and types are defined in the namespace nvcuda::wmma. Sub-byte operations are considered preview, i.e. the data structures and APIs for them are subject to change and may not be compatible with future releases. This extra functionality is defined in the nvcuda::wmma::experimental namespace.
template<typename Use, int m, int n, int k, typename T, typename Layout=void> class fragment;
void load_matrix_sync(fragment<...> &a, const T* mptr, unsigned ldm);
void load_matrix_sync(fragment<...> &a, const T* mptr, unsigned ldm, layout_t layout);
void store_matrix_sync(T* mptr, const fragment<...> &a, unsigned ldm, layout_t layout);
void fill_fragment(fragment<...> &a, const T& v);
void mma_sync(fragment<...> &d, const fragment<...> &a, const fragment<...> &b, const fragment<...> &c, bool satf=false);
fragmentAn overloaded class containing a section of a matrix distributed across all threads in the warp. The mapping of matrix elements into
fragmentinternal storage is unspecified and subject to change in future architectures.
Only certain combinations of template arguments are allowed. The first template parameter specifies how the fragment will participate in the matrix operation. Acceptable values for Use are:
matrix_awhen the fragment is used as the first multiplicand,A,matrix_bwhen the fragment is used as the second multiplicand,B, oraccumulatorwhen the fragment is used as the source or destination accumulators (CorD, respectively).The
m,nandksizes describe the shape of the warp-wide matrix tiles participating in the multiply-accumulate operation. The dimension of each tile depends on its role. Formatrix_athe tile takes dimensionm x k; formatrix_bthe dimension isk x n, andaccumulatortiles arem x n.The data type,
T, may bedouble,float,__half,__nv_bfloat16,char, orunsigned charfor multiplicands anddouble,float,int, or__halffor accumulators. As documented in Element Types and Matrix Sizes, limited combinations of accumulator and multiplicand types are supported. The Layout parameter must be specified formatrix_aandmatrix_bfragments.row_majororcol_majorindicate that elements within a matrix row or column are contiguous in memory, respectively. TheLayoutparameter for anaccumulatormatrix should retain the default value ofvoid. A row or column layout is specified only when the accumulator is loaded or stored as described below.
load_matrix_syncWaits until all warp lanes have arrived at load_matrix_sync and then loads the matrix fragment a from memory.
mptrmust be a 256-bit aligned pointer pointing to the first element of the matrix in memory.ldmdescribes the stride in elements between consecutive rows (for row major layout) or columns (for column major layout) and must be a multiple of 8 for__halfelement type or multiple of 4 forfloatelement type. (i.e., multiple of 16 bytes in both cases). If the fragment is anaccumulator, thelayoutargument must be specified as eithermem_row_majorormem_col_major. Formatrix_aandmatrix_bfragments, the layout is inferred from the fragment’slayoutparameter. The values ofmptr,ldm,layoutand all template parameters foramust be the same for all threads in the warp. This function must be called by all threads in the warp, or the result is undefined.store_matrix_syncWaits until all warp lanes have arrived at store_matrix_sync and then stores the matrix fragment a to memory.
mptrmust be a 256-bit aligned pointer pointing to the first element of the matrix in memory.ldmdescribes the stride in elements between consecutive rows (for row major layout) or columns (for column major layout) and must be a multiple of 8 for__halfelement type or multiple of 4 forfloatelement type. (i.e., multiple of 16 bytes in both cases). The layout of the output matrix must be specified as eithermem_row_majorormem_col_major. The values ofmptr,ldm,layoutand all template parameters for a must be the same for all threads in the warp.fill_fragmentFill a matrix fragment with a constant value
v. Because the mapping of matrix elements to each fragment is unspecified, this function is ordinarily called by all threads in the warp with a common value forv.mma_syncWaits until all warp lanes have arrived at mma_sync, and then performs the warp-synchronous matrix multiply-accumulate operation
D=A*B+C. The in-place operation,C=A*B+C, is also supported. The value ofsatfand template parameters for each matrix fragment must be the same for all threads in the warp. Also, the template parametersm,nandkmust match between fragmentsA,B,CandD. This function must be called by all threads in the warp, or the result is undefined.
If satf (saturate to finite value) mode is true, the following additional numerical properties apply for the destination accumulator:
If an element result is +Infinity, the corresponding accumulator will contain
+MAX_NORMIf an element result is -Infinity, the corresponding accumulator will contain
-MAX_NORMIf an element result is NaN, the corresponding accumulator will contain
+0
Because the map of matrix elements into each thread’s fragment is unspecified, individual matrix elements must be accessed from memory (shared or global) after calling store_matrix_sync. In the special case where all threads in the warp will apply an element-wise operation uniformly to all fragment elements, direct element access can be implemented using the following fragment class members.
enum fragment<Use, m, n, k, T, Layout>::num_elements;
T fragment<Use, m, n, k, T, Layout>::x[num_elements];
As an example, the following code scales an accumulator matrix tile by half.
wmma::fragment<wmma::accumulator, 16, 16, 16, float> frag;
float alpha = 0.5f; // Same value for all threads in warp
for(int t=0; t<frag.num_elements; t++)
frag.x[t] *= alpha;
5.4.11.2. Alternate Floating Point#
Tensor Cores support alternate types of floating point operations on devices with compute capability 8.0 and higher.
__nv_bfloat16This data format is an alternate fp16 format that has the same range as f32 but reduced precision (7 bits). You can use this data format directly with the
__nv_bfloat16type available incuda_bf16.h. Matrix fragments with__nv_bfloat16data types are required to be composed with accumulators offloattype. The shapes and operations supported are the same as with__half.tf32This data format is a special floating-point format supported by Tensor Cores, with the same range as f32 and reduced precision (>=10 bits). The internal layout of this format is implementation-defined. To use this floating-point format with WMMA operations, the input matrices must be manually converted to tf32 precision.
To facilitate conversion, a new intrinsic
__float_to_tf32is provided. While the input and output arguments to the intrinsic are offloattype, the output will betf32numerically. This new precision is intended to be used with Tensor Cores only, and if mixed with otherfloattype operations, the precision and range of the result will be undefined.Once an input matrix (
matrix_aormatrix_b) is converted to tf32 precision, the combination of afragmentwithprecision::tf32precision, and a data type offloattoload_matrix_syncwill take advantage of this new capability. Both the accumulator fragments must havefloatdata types. The only supported matrix size is 16x16x8 (m-n-k).The elements of the fragment are represented as
float, hence the mapping fromelement_type<T>tostorage_element_type<T>is:precision::tf32 -> float
5.4.11.3. Double Precision#
Tensor Cores support double-precision floating point operations on devices with compute capability 8.0 and higher. To use this new functionality, a fragment with the double type must be used. The mma_sync operation will be performed with the .rn (rounds to nearest even) rounding modifier.
5.4.11.4. Sub-byte Operations#
Sub-byte WMMA operations provide a way to access the low-precision capabilities of Tensor Cores. They are considered a preview feature i.e. the data structures and APIs for them are subject to change and may not be compatible with future releases. This functionality is available via the nvcuda::wmma::experimental namespace:
namespace experimental {
namespace precision {
struct u4; // 4-bit unsigned
struct s4; // 4-bit signed
struct b1; // 1-bit
enum bmmaBitOp {
bmmaBitOpXOR = 1, // compute_75 minimum
bmmaBitOpAND = 2 // compute_80 minimum
enum bmmaAccumulateOp { bmmaAccumulateOpPOPC = 1 };
For 4 bit precision, the APIs available remain the same, but you must specify experimental::precision::u4 or experimental::precision::s4 as the fragment data type. Since the elements of the fragment are packed together, num_storage_elements will be smaller than num_elements for that fragment. The num_elements variable for a sub-byte fragment, hence returns the number of elements of sub-byte type element_type<T>. This is true for single bit precision as well, in which case, the mapping from element_type<T> to storage_element_type<T> is as follows:
experimental::precision::u4 -> unsigned (8 elements in 1 storage element)
experimental::precision::s4 -> int (8 elements in 1 storage element)
experimental::precision::b1 -> unsigned (32 elements in 1 storage element)
T -> T //all other types
The allowed layouts for sub-byte fragments is always row_major for matrix_a and col_major for matrix_b.
For sub-byte operations the value of ldm in load_matrix_sync should be a multiple of 32 for element type experimental::precision::u4 and experimental::precision::s4 or a multiple of 128 for element type experimental::precision::b1 (i.e., multiple of 16 bytes in both cases).
Note
Support for the following variants for MMA instructions is deprecated and will be removed in sm_90:
experimental::precision::b1withbmmaBitOpset tobmmaBitOpXOR
bmma_syncWaits until all warp lanes have executed bmma_sync, and then performs the warp-synchronous bit matrix multiply-accumulate operation
D = (A op B) + C, whereopconsists of a logical operationbmmaBitOpfollowed by the accumulation defined bybmmaAccumulateOp. The available operations are:bmmaBitOpXOR, a 128-bit XOR of a row inmatrix_awith the 128-bit column ofmatrix_bbmmaBitOpAND, a 128-bit AND of a row inmatrix_awith the 128-bit column ofmatrix_b, available on devices with compute capability 8.0 and higher.The accumulate op is always
bmmaAccumulateOpPOPCwhich counts the number of set bits.
5.4.11.5. Restrictions#
The special format required by tensor cores may be different for each major and minor device architecture. This is further complicated by threads holding only a fragment (opaque architecture-specific ABI data structure) of the overall matrix, with the developer not allowed to make assumptions on how the individual parameters are mapped to the registers participating in the matrix multiply-accumulate.
Since fragments are architecture-specific, it is unsafe to pass them from function A to function B if the functions have been compiled for different link-compatible architectures and linked together into the same device executable. In this case, the size and layout of the fragment will be specific to one architecture and using WMMA APIs in the other will lead to incorrect results or potentially, corruption.
An example of two link-compatible architectures, where the layout of the fragment differs, is sm_70 and sm_75.
fragA.cu: void foo() { wmma::fragment<...> mat_a; bar(&mat_a); }
fragB.cu: void bar(wmma::fragment<...> *mat_a) { // operate on mat_a }
// sm_70 fragment layout
$> nvcc -dc -arch=compute_70 -code=sm_70 fragA.cu -o fragA.o
// sm_75 fragment layout
$> nvcc -dc -arch=compute_75 -code=sm_75 fragB.cu -o fragB.o
// Linking the two together
$> nvcc -dlink -arch=sm_75 fragA.o fragB.o -o frag.o
This undefined behavior might also be undetectable at compilation time and by tools at runtime, so extra care is needed to make sure the layout of the fragments is consistent. This linking hazard is most likely to appear when linking with a legacy library that is both built for a different link-compatible architecture and expecting to be passed a WMMA fragment.
Note that in the case of weak linkages (for example, a CUDA C++ inline function), the linker may choose any available function definition which may result in implicit passes between compilation units.
To avoid these sorts of problems, the matrix should always be stored out to memory for transit through external interfaces (e.g. wmma::store_matrix_sync(dst, …);) and then it can be safely passed to bar() as a pointer type [e.g. float *dst].
Note that since sm_70 can run on sm_75, the above example sm_75 code can be changed to sm_70 and correctly work on sm_75. However, it is recommended to have sm_75 native code in your application when linking with other sm_75 separately compiled binaries.
5.4.11.6. Element Types and Matrix Sizes#
Tensor Cores support a variety of element types and matrix sizes. The following table presents the various combinations of matrix_a, matrix_b and accumulator matrix supported:
Matrix A |
Matrix B |
Accumulator |
Matrix Size (m-n-k) |
__half |
__half |
float |
16x16x16 |
__half |
__half |
float |
32x8x16 |
__half |
__half |
float |
8x32x16 |
__half |
__half |
__half |
16x16x16 |
__half |
__half |
__half |
32x8x16 |
__half |
__half |
__half |
8x32x16 |
unsigned char |
unsigned char |
int |
16x16x16 |
unsigned char |
unsigned char |
int |
32x8x16 |
unsigned char |
unsigned char |
int |
8x32x16 |
signed char |
signed char |
int |
16x16x16 |
signed char |
signed char |
int |
32x8x16 |
signed char |
signed char |
int |
8x32x16 |
Alternate floating-point support:
Matrix A |
Matrix B |
Accumulator |
__nv_bfloat16 |
__nv_bfloat16 |
float |
16x16x16 |
__nv_bfloat16 |
__nv_bfloat16 |
float |
32x8x16 |
__nv_bfloat16 |
__nv_bfloat16 |
float |
8x32x16 |
precision::tf32 |
precision::tf32 |
float |
16x16x8 |
Double Precision Support:
Matrix A |
Matrix B |
Accumulator |
double |
double |
double |
8x8x4 |
Experimental support for sub-byte operations:
Matrix A |
Matrix B |
Accumulator |
precision::u4 |
precision::u4 |
int |
8x8x32 |
precision::s4 |
precision::s4 |
int |
8x8x32 |
precision::b1 |
precision::b1 |
int |
8x8x128 |
5.4.11.7. Example#
The following code implements a 16x16x16 matrix multiplication in a single warp.
#include <mma.h>
using namespace nvcuda;
__global__ void wmma_ker(half *a, half *b, float *c) {
// Declare the fragments
wmma::fragment<wmma::matrix_a, 16, 16, 16, half, wmma::col_major> a_frag;
wmma::fragment<wmma::matrix_b, 16, 16, 16, half, wmma::row_major> b_frag;
wmma::fragment<wmma::accumulator, 16, 16, 16, float> c_frag;
// Initialize the output to zero
wmma::fill_fragment(c_frag, 0.0f);
// Load the inputs
wmma::load_matrix_sync(a_frag, a, 16);
wmma::load_matrix_sync(b_frag, b, 16);
// Perform the matrix multiplication
wmma::mma_sync(c_frag, a_frag, b_frag, c_frag);
// Store the output
wmma::store_matrix_sync(c, c_frag, 16, wmma::mem_row_major);
