5.5. Floating-Point Computation#
5.5.1. Floating-Point Introduction#
Since the adoption of the IEEE-754 Standard for Binary Floating-Point Arithmetic in 1985, virtually all mainstream computing systems, including NVIDIA’s CUDA architectures, have implemented the standard. The IEEE-754 standard specifies how the results of floating-point arithmetic should be approximated.
To get accurate results and achieve the highest performance with the required precision, it is important to consider many aspects of floating-point behavior. This is particularly important in a heterogeneous computing environment where operations are performed on different types of hardware.
The following sections review the basic properties of floating-point computation and cover Fused Multiply-Add (FMA) operations and the dot product. These examples illustrate how different implementation choices affect accuracy.
5.5.1.1. Floating-Point Format#
Floating-point format and functionality are defined in the IEEE-754 Standard.
The standard mandates that binary floating-point data be encoded on three fields:
  • Sign: one bit to indicate a positive or negative number.
  • Exponent: encodes the base 2 exponent offset by a numeric bias.
  • Significand (also called mantissa or fraction): encodes the fractional value of the number.
Floating-Point Encoding
The latest IEEE-754 standard defines the encodings and properties of the following binary formats:
  • 16-bit, also known as half-precision, corresponding to the __half data type in CUDA.
  • 32-bit, also known as single-precision, corresponding to the float data type in C, C++, and CUDA.
  • 64-bit, also known as double-precision, corresponding to the double data type in C, C++, and CUDA.
  • 128-bit, also known as quad-precision, corresponding to the __float128 or _Float128 data types in CUDA.
These types have the following bit lengths:
IEEE-754 Floating-Point Encodings
The numeric value associated with floating-point encoding for normal values is computed as follows:
\[(-1)^\mathrm{sign} \times 1.\mathrm{mantissa} \times 2^{\mathrm{exponent} - \mathrm{bias}}\]
For subnormal values, the formula is modified to:
\[(-1)^\mathrm{sign} \times 0.\mathrm{mantissa} \times 2^{1-\mathrm{bias}}\]
The exponents are biased by \(127\) and \(1023\) for single- and double-precision, respectively. The integral part of \(1.\) is implicit in the fraction.
For example, the value \(-192 = (-1)^1 \times 2^7 \times 1.5\), and is encoded as a negative sign, an exponent of \(7\), and a fractional part \(0.5\). Hence the exponent \(7\) is represented by bit strings with values 7 + 127 = 134 = 10000110 for float and 7 + 1023 = 1030 = 10000000110 for double. The mantissa 0.5 = 2^-1 is represented by a binary value with 1 in the first position. The binary encodings of \(-192\) in single-precision and double-precision are shown in the following figure:
Floating-Point Representation for ``-192``
Since the fraction field uses a limited number of bits, not all real numbers can be represented exactly. For instance, the binary representation of the mathematical value of the fraction \(2 / 3\) is 0.10101010..., which has an infinite number of bits after the binary point. Therefore, \(2 / 3\) must be rounded before it can be represented as a floating-point number with limited precision. The rounding rules and modes are specified in IEEE-754. The most frequently used mode is round-to-nearest-ties-to-even, abbreviated round-to-nearest.
5.5.1.2. Normal and Subnormal Values#
Any floating-point value with an exponent field that is neither all zeros nor all ones is called normal.
An important aspect of floating-point values is the wide gap between the smallest representable positive normal number, FLT_MIN, and zero. This gap is much wider than the gap between FLT_MIN and the second-smallest normal number.
Floating-point subnormal numbers, also called denormals, were introduced to address this issue. A subnormal floating-point value is represented with all bits in the exponent set to zero and at least one bit set in the significand. Subnormals are a required part of the IEEE-754 floating-point standard.
Subnormal numbers allow for a gradual loss of precision as an alternative to sudden rounding toward zero. However, subnormal numbers are computationally more expensive. Therefore, applications that don’t require strict accuracy may choose to avoid them to improve performance. The nvcc compiler allows disabling subnormal numbers by setting the -ftz=true option (flush-to-zero), which is also included in --use_fast_math.
A simplified visualization of the encoding of the smallest normal value and subnormal values in single-precision is shown in the following figure:
minimum normal value and subnormal values representations
where X represents both 0 and 1.
5.5.1.3. Special Values#
The IEEE-754 standard defines three special values for floating-point numbers:
Zero:
  • Mathematical zero.
  • Note that there are two possible representations of floating-point zero: +0 and -0. This differs from the representation of integer zero.
  • +0 == -0 evaluates to true.
  • Zero is encoded with all bits set to 0 in the exponent and significand.
Infinity:
  • Floating-point numbers behave according to saturation arithmetic, in which operations that overflow the representable range result in +Infinity or -Infinity.
  • Infinity is encoded with all bits in the exponent set to 1 and all bits in the significand set to 0. There are exactly two encodings for infinity values.
  • Arithmetic operations involving infinity and finite nonzero values typically result in infinity. Indeterminate forms such as Inf * 0.0, Inf - Inf, Inf / Inf, and 0.0 / 0.0 result in NaN.
Not-a-Number (NaN):
  • NaN is a special symbol that represents an undefined or non-representable value. Common examples are 0.0 / 0.0, sqrt(-1.0), or +Inf - Inf.
  • NaN is encoded with all bits in the exponent set to 1 and any bit pattern in the significand, except for all bits set to 0. There are \(2^{\mathrm{mantissa} + 1} - 2\) possible encodings.
  • Any arithmetic operation involving a NaN will result in NaN.
  • Any ordered comparison (<, <=, >, >=, ==) involving a NaN will result in false, including NaN == NaN (non-reflexive). The unordered comparison NaN != NaN returns true.
  • NaNs are provided in two forms:
    • Quiet NaNs qNaN are used to propagate errors resulting from invalid operations or values. Invalid arithmetic operations generally produce a quiet NaN. They are encoded with the most significant bit of the significand set to 1.
    • Signaling NaNs sNaN are designed to raise an invalid-operation exception. Signaling NaNs are generally explicitly created. They are encoded with the most significant bit of the significand set to 0.
    • The exact bit patterns for Quiet and Signaling NaNs are implementation-defined. CUDA provides the cuda::std::numeric_limits<T>::quiet_NaN and cuda::std::numeric_limits<T>::signaling_NaN constants to get their special values.
A simplified visualization of the encodings of special values is shown in the following figure:
Floating-Point Representation for Infinity and NaN
5.5.1.4. Associativity#
It is important to note that the rules and properties of mathematical arithmetic do not directly apply to floating-point arithmetic due to its limited precision. The example below shows single-precision values A, B, and C and the exact mathematical value of their sum computed using different associativity.
\[\begin{split}\begin{aligned} A &= 2^{1} \times 1.00000000000000000000001 \\ B &= 2^{0} \times 1.00000000000000000000001 \\ C &= 2^{3} \times 1.00000000000000000000001 \\ (A + B) + C &= 2^{3} \times 1.01100000000000000000001011 \\ A + (B + C) &= 2^{3} \times 1.01100000000000000000001011 \end{aligned}\end{split}\]
Mathematically, \((A + B) + C\) is equal to \(A + (B + C)\).
Let \(\mathrm{rn}(x)\) denote one rounding step on \(x\). Performing the same computations in single-precision floating-point arithmetic in round-to-nearest mode according to IEEE-754, we obtain:
\[\begin{split}\begin{aligned} A + B &= 2^{1} \times 1.1000000000000000000000110000\ldots \\ \mathrm{rn}(A+B) &= 2^{1} \times 1.10000000000000000000010 \\ B + C &= 2^{3} \times 1.0010000000000000000000100100\ldots \\ \mathrm{rn}(B+C) &= 2^{3} \times 1.00100000000000000000001 \\ A + B + C &= 2^{3} \times 1.0110000000000000000000101100\ldots \\ \mathrm{rn}\big(\mathrm{rn}(A+B) + C\big) &= 2^{3} \times 1.01100000000000000000010 \\ \mathrm{rn}\big(A + \mathrm{rn}(B+C)\big) &= 2^{3} \times 1.01100000000000000000001 \end{aligned}\end{split}\]
For reference, the exact mathematical results are also computed above. The results computed according to IEEE-754 differ from the exact mathematical results. Additionally, the results corresponding to the sums \(\mathrm{rn}(\mathrm{rn}(A + B) + C)\) and \(\mathrm{rn}(A + \mathrm{rn}(B + C))\) differ from each other. In this case, \(\mathrm{rn}(A + \mathrm{rn}(B + C))\) is closer to the correct mathematical result than \(\mathrm{rn}(\mathrm{rn}(A + B) + C)\).
This example shows that seemingly identical computations can produce different results, even when all basic operations comply with IEEE-754.
5.5.1.5. Fused Multiply-Add (FMA)#
The Fused Multiply-Add (FMA) operation computes the result with only one rounding step. Without the FMA, the result would require two rounding steps: one for multiplication and one for addition. Because the FMA uses only one rounding step, it produces a more accurate result.
The Fused Multiply-Add operation can affect the propagation of NaNs differently than two separate operations. However, FMA NaN handling is not universally identical across all targets. Different implementations with multiple NaN operands may prefer a quiet NaN or propagate one operand’s payload. Additionally, IEEE-754 does not strictly mandate a deterministic payload selection order when multiple NaN operands are present. NaNs may also occur in intermediate computations, for example, \(\infty \times 0 + 1\) or \(1 \times \infty - \infty\), resulting in an implementation-defined NaN payload.
For clarity, first consider an example using decimal arithmetic to illustrate how the FMA operation works. We will compute \(x^2 - 1\) using five total digits of precision, with four digits after the decimal point.
  • For \(x = 1.0008\), the correct mathematical result is \(x^2 - 1 = 1.60064 \times 10^{-4}\). The closest number using only four digits after the decimal point is \(1.6006 \times 10^{-4}\).
  • The Fused Multiply-Add operation achieves the correct result using only one rounding step \(\mathrm{rn}(x \times x - 1) = 1.6006 \times 10^{-4}\).
  • The alternative is to compute the multiply and add steps separately. \(x^2 = 1.00160064\) translates to \(\mathrm{rn}(x \times x) = 1.0016\). The final result is \(\mathrm{rn}(\mathrm{rn}(x \times x) -1) = 1.6000 \times 10^{-4}\).
Rounding the multiply and add separately yields a result that is off by \(0.00064\). The corresponding FMA computation is wrong by only \(0.00004\) and its result is closest to the correct mathematical answer. The results are summarized below:
\[\begin{split}\begin{aligned} x &= 1.0008 \\ x^{2} &= 1.00160064 \\ x^{2} - 1 &= 1.60064 \times 10^{-4} && \text{true value} \\ \mathrm{rn}\big(x^{2} - 1\big) &= 1.6006 \times 10^{-4} && \text{fused multiply-add} \\ \mathrm{rn}\big(x^{2}\big) &= 1.0016 \\ \mathrm{rn}\big(\mathrm{rn}(x^{2}) - 1\big) &= 1.6000 \times 10^{-4} && \text{multiply, then add} \end{aligned}\end{split}\]
Below is another example, using binary single precision values:
\[\begin{split}\begin{aligned} A &= 2^{0} \times 1.00000000000000000000001 \\ B &= -2^{0} \times 1.00000000000000000000010 \\ \mathrm{rn}\big(A \times A + B\big) &= 2^{-46} \times 1.00000000000000000000000 && \text{fused multiply-add} \\ \mathrm{rn}\big(\mathrm{rn}(A \times A) + B\big) &= 0 && \text{multiply, then add} \end{aligned}\end{split}\]
  • Computing multiplication and addition separately results in the loss of all bits of precision, yielding \(0\).
  • Computing the FMA, on the other hand, provides a result equal to the mathematical value.
Fused multiply-add helps prevent loss of precision during subtractive cancellation. Subtractive cancellation occurs when quantities of similar magnitude with opposite signs are added. In this case, many of the leading bits cancel out, resulting in fewer meaningful bits. The fused multiply-add computes a double-width product during multiplication. Thus, even if subtractive cancellation occurs during addition, there are enough valid bits remaining in the product to yield a precise result.
Fused Multiply-Add Support in CUDA:
CUDA provides the Fused Multiply-Add operation in several ways for both float and double data types:
Fused Multiply-Add Support on Host Platforms:
Whether to use the fused operation depends on the availability of the operation on the platform and how the code is compiled. It is important to understand the host platform’s support for Fused Multiply-Add when comparing CPU and GPU results.
5.5.1.6. Dot Product Example#
Consider the problem of finding the dot product of two short vectors \(\overrightarrow{a}\) and \(\overrightarrow{b}\) both with four elements.
\[\begin{split}\overrightarrow{a} = \begin{bmatrix} a_{1} \\ a_{2} \\ a_{3} \\ a_{4} \end{bmatrix} \qquad \overrightarrow{b} = \begin{bmatrix} b_{1} \\ b_{2} \\ b_{3} \\ b_{4} \end{bmatrix} \qquad \overrightarrow{a} \cdot \overrightarrow{b} = a_{1}b_{1} + a_{2}b_{2} + a_{3}b_{3} + a_{4}b_{4}\end{split}\]
Although this operation is easy to write down mathematically, implementing it in software involves several alternatives that could lead to slightly different results. All of the strategies presented here use operations that are fully compliant with IEEE-754.
Example Algorithm 1: The simplest way to compute the dot product is to use a sequential sum of products, keeping the multiplications and additions separate.
The final result can be represented as \(((((a_1 \times b_1) + (a_2 \times b_2)) + (a_3 \times b_3)) + (a_4 \times b_4))\).
Example Algorithm 2: Compute the dot product sequentially using fused multiply-add.
The final result can be represented as \((a_4 \times b_4) + ((a_3 \times b_3) + ((a_2 \times b_2) + (a_1 \times b_1 + 0)))\).
Example Algorithm 3: Compute the dot product using a divide-and-conquer strategy. First, we find the dot products of the first and second halves of the vectors. Then, we combine these results using addition. This algorithm is called the “parallel algorithm” because the two subproblems can be computed in parallel since they are independent of each other. However, the algorithm does not require a parallel implementation; it can be implemented with a single thread.
The final result can be represented as \(((a_1 \times b_1) + (a_2 \times b_2)) + ((a_3 \times b_3) + (a_4 \times b_4))\).
5.5.1.7. Rounding#
The IEEE-754 standard requires support for several operations. These include arithmetic operations such as addition, subtraction, multiplication, division, square root, fused multiply-add, finding the remainder, conversion, scaling, sign, and comparison operations. The results of these operations are guaranteed to be consistent across all implementations of the standard for a given format and rounding mode.
Rounding Modes
The IEEE-754 standard defines four rounding modes: round-to-nearest, round towards positive, round towards negative, and round towards zero. CUDA supports all four modes. By default, operations use round-to-nearest. Intrinsic mathematical functions can be used to select other rounding modes for individual operations.
Rounding Mode
Interpretation
rn
Round to nearest, ties to even
rz
Round towards zero
ru
Round towards \(\infty\)
rd
Round towards \(-\infty\)
5.5.1.8. Notes on Host/Device Computation Accuracy#
The accuracy of a floating-point computation result is affected by several factors. This section summarizes important considerations for achieving reliable results in floating-point computations. Some of these aspects have been described in greater detail in previous sections.
These aspects are also important when comparing the results between CPU and GPU. Differences between host and device execution must be interpreted carefully. The presence of differences does not necessarily mean the GPU’s result is incorrect or that there is a problem with the GPU.
Associativity:
Floating-point addition and multiplication in finite precision are not associative because they often result in mathematical values that cannot be directly represented in the target format, requiring rounding. The order in which these operations are evaluated affects how rounding errors accumulate and can significantly alter the final result.
Fused Multiply-Add:
Fused Multiply-Add computes \(a \times b + c\) in a single operation, resulting in greater accuracy and a faster execution time. The accuracy of the final result can be affected by its use. Fused Multiply-Add relies on hardware support and can be enabled either explicitly by calling the related function or implicitly through compiler optimization flags.
Precision:
Increasing the floating-point precision can potentially improve the accuracy of the results. Higher precision reduces loss of significance and enables the representation of a wider range of values. However, higher precision types have lower throughput and consume more registers. Additionally, using them to explicitly store input and output increases memory usage and data movement.
Compiler Flags and Optimizations:
All major compilers provide a variety of optimization flags to control the behavior of floating-point operations.
  • The highest optimization level for GCC (-O3), Clang (-O3), nvcc (-O3), and Microsoft Visual Studio (/O2) does not affect floating-point semantics. However, inlining, loop unrolling, vectorization, and common subexpression elimination could affect the results. The NVC++ compiler also requires the flags -Kieee -Mnofma for IEEE-754-compliant semantics.
  • Refer to the GCC, Clang, Microsoft Visual Studio Compiler, nvc++, and Arm C/C++ compiler documentation for detailed information about options that affect floating-point behavior.
  • See also the nvcc User Manual for detailed descriptions of compiler flags that specifically affect floating-point behavior in CUDA device code: -ftz, -prec-div, -prec-sqrt, -fmad, --use_fast_math. Besides these floating-point options, it is also important to verify the effects of other compiler optimizations in the context of the user program. Users are encouraged to verify the correctness of their results with extensive testing and compare results obtained with optimizations enabled versus all device code optimizations disabled; see also the -G compiler flag.
Library Implementations:
Functions defined outside the IEEE-754 standard are not guaranteed to be correctly rounded and depend on implementation-defined behavior. Therefore, the results may differ across different platforms, including between host, device, and different device architectures.
Deterministic Results:
A deterministic result refers to computing the same bit-wise numerical outputs every time when run with the same inputs under the same specified conditions. Such conditions include:
  • Hardware dependencies, such as execution on the same CPU processor or GPU device.
  • Compiler aspects, such as the version of the compiler and the Compiler Flags and Optimizations.
  • Run-time conditions that affect the computation, such as rounding mode or environment variables.
  • Identical inputs to the computation.
  • Thread configuration, including the number of threads involved in the computation and their organization, for example block and grid size.
  • The ordering of arithmetic atomic operations depends on hardware scheduling which can vary between runs.
Taking Advantage of the CUDA Libraries:
The CUDA Math Libraries, C Standard Library Mathematical functions, and C++ Standard Library Mathematical functions are designed to boost developer productivity for common functionalities, particularly for floating-point math and numerics-intensive routines. These functionalities provide a consistent high-level interface, are optimized, and are widely tested across platforms and edge cases. Users are encouraged to take full advantage of these libraries and avoid tedious manual reimplementations.
5.5.2. Floating-Point Data Types#
CUDA supports the Bfloat16, half-, single-, double-, and quad-precision floating-point data types. The following table summarizes the supported floating-point data types in CUDA and their requirements.
Table 43 Supported Floating-Point Types#
Precision / Name
Data Type
IEEE-754
Header / Built-in
Requirements
Bfloat16
__nv_bfloat16
<cuda_bf16.h>
Compute Capability 8.0 or higher.
Half Precision
__half
<cuda_fp16.h>
Single Precision
float
Built-in
Double Precision
double
Built-in
Quad Precision
__float128/_Float128
Built-in
<crt/device_fp128_functions.h> for mathematical functions
Host compiler support and Compute Capability 10.0 or higher.
The C or C++ spelling, _Float128 and __float128 respectively, also depends on the host compiler support.
CUDA also supports TensorFloat-32 (TF32), microscaling (MX) floating-point types, and other lower precision numerical formats that are not intended for general-purpose computation, but rather for specialized purposes involving tensor cores. These include 4-, 6-, and 8-bit floating-point types. See the CUDA Math API for more details.
The following figure reports the mantissa and exponent sizes of the supported floating-point data types.
Floating-Point Types: Mantissa and Exponent sizes
The following table reports the ranges of the supported floating-point data types.
Table 44 Supported Floating-Point Types Properties#
Precision / Name
Largest Value
Smallest Positive Value
Smallest Positive Denormal
Epsilon
Bfloat16
\(\approx 2^{128}\)
\(\approx 3.39 \cdot 10^{38}\)
\(2^{-126}\)
\(\approx 1.18 \cdot 10^{-38}\)
\(2^{-133}\)
\(2^{-7}\)
Half Precision
\(\approx 2^{16}\)
\(65504\)
\(2^{-14}\)
\(\approx 6.1 \cdot 10^{-5}\)
\(2^{-24}\)
\(2^{-10}\)
Single Precision
\(\approx 2^{128}\)
\(\approx 3.40 \cdot 10^{38}\)
\(2^{-126}\)
\(2^{-149}\)
\(2^{-23}\)
Double Precision
\(\approx 2^{1024}\)
\(\approx 1.8 \cdot 10^{308}\)
\(2^{-1022}\)
\(\approx 2.22 \cdot 10^{-308}\)
\(2^{-1074}\)
\(2^{-52}\)
Quad Precision
\(\approx 2^{16384}\)
\(\approx 1.19 \cdot 10^{4932}\)
\(2^{-16382}\)
\(\approx 3.36 \cdot 10^{-4932}\)
\(2^{-16494}\)
\(2^{-112}\)
Hint
The CUDA C++ Standard Library provides cuda::std::numeric_limits in the <cuda/std/limits> header to query the properties and the ranges of the supported floating-point types, including microscaling formats (MX). See the C++ reference for the list of queryable properties.
Complex numbers support:
5.5.3. CUDA and IEEE-754 Compliance#
All GPU devices follow the IEEE 754-2019 standard for binary floating-point arithmetic with the following limitations:
  • There is no dynamically configurable rounding mode; however, most of the operations support multiple constant IEEE rounding modes, selectable via specifically named device intrinsics functions.
  • There is no mechanism to detect floating-point exceptions, so all operations behave as if IEEE-754 exceptions are always masked. If there is an exceptional event, the default masked response defined by IEEE-754 is delivered. For this reason, although signaling NaN SNaN encodings are supported, they are not signaling and are handled as quiet exceptions.
  • Floating-point operations may alter the bit patterns of input NaN payloads. Operations such as absolute value and negation may also not comply with the IEEE 754 requirement, which could result in the sign of a NaN being updated in an implementation-defined manner.
To maximize the portability of results, users are recommended to use the default settings of the nvcc compiler’s floating-point options: -ftz=false, -prec-div=true, and -prec-sqrt=true, and not use the --use_fast_math option. Note that floating-point expression re-associations and contractions are allowed by default, similarly to the --fmad=true option. See also the nvcc User Manual for a detailed description of these compilation flags.
The IEEE-754 and C/C++ language standards do not explicitly address the conversion of a floating-point value to an integer value in cases where the rounded-to-integer value falls outside the range of the target integer format. The clamping behavior to the range of GPU devices is delineated in the PTX ISA conversion instructions section. However, compiler optimizations may leverage the unspecified behavior clause when out-of-range conversion is not invoked directly via a PTX instruction, consequently resulting in undefined behavior and an invalid CUDA program. The CUDA Math documentation issues warnings to users on a per-function/intrinsic basis. For instance, consider the __double2int_rz() instruction. This may differ from how host compilers and library implementations behave.
Atomic Functions Denormals Behavior:
Atomic operations have the following behavior regarding floating-point denormals, regardless of the setting of the compiler flag -ftz:
  • Atomic single-precision floating-point adds on global memory always operate in flush-to-zero mode, namely behave equivalent to PTX add.rn.ftz.f32 semantic.
  • Atomic single-precision floating-point adds on shared memory always operate with denormal support, namely behave equivalent to PTX add.rn.f32 semantic.
5.5.4. CUDA and C/C++ Compliance#
Floating-Point Exceptions:
Unlike the host implementation, the mathematical operators and functions supported in device code do not set the global errno variable nor report floating-point exceptions to indicate errors. Thus, if error diagnostic mechanisms are required, users should implement additional input and output screening for the functions.
Undefined Behavior with Floating-Point Operations:
Common conditions of undefined behavior for mathematical operations include:
  • Invalid arguments to mathematical operators and functions:
    • Using an uninitialized floating-point variable.
    • Using a floating-point variable outside its lifetime.
    • Signed integer overflow.
    • Dereferencing an invalid pointer.
  • Floating-point specific undefined behavior:
    • Converting a floating-point value to an integer type for which the result is not representable is undefined behavior. This also includes NaN and infinity.
Users are responsible for ensuring the validity of a CUDA program. Invalid arguments may result in undefined behavior and be subject to compiler optimizations.
Contrary to integer division by zero, floating-point division by zero is not undefined behavior and not subject to compiler optimizations; rather, it is implementation-specific behavior. C++ implementations that conform to IEC-60559 (IEEE-754), including CUDA, produce infinity. Note that invalid floating-point operations produce NaN and should not be misinterpreted as undefined behavior. Examples include zero divided by zero and infinity divided by infinity.
Floating-Point Literals Portability:
Both C and C++ allow for the representation of floating-point values in either decimal or hexadecimal notation. Hexadecimal floating-point literals, which are supported in C99 and C++17, denote a real value in scientific notation that can be precisely expressed in base-2. However, this does not guarantee that the literal will map to an actual value stored in a target variable (see the next paragraph). Conversely, a decimal floating-point literal may represent a numeric value that cannot be expressed in base-2.
According to the C++ standard rules, hexadecimal and decimal floating-point literals are rounded to the nearest representable value, larger or smaller, chosen in an implementation-defined manner. This rounding behavior may differ between the host and the device.
float f1 = 0.5f;    // 0.5, '0.5f' is a decimal floating-point literal
float f2 = 0x1p-1f; // 0.5, '0x1p-1f' is a hexadecimal floating-point literal
float f3 = 0.1f;
// f1, f2 are represented as 0 01111110 00000000000000000000000
// f3     is represented as  0 01111011 10011001100110011001101
The run-time and compile-time evaluations of the same floating-point expression are subject to the following portability issues:
  • The run-time evaluation of a floating-point expression may be affected by the selected rounding mode, floating-point contraction (FMA) and reassociation compiler settings, as well as floating-point exceptions. Note that CUDA does not support floating-point exceptions and the rounding mode is set to round-to-nearest-ties-to-even by default. Other rounding modes can be selected using intrinsic functions.
  • The compiler may use a higher-precision internal representation for constant expressions.
  • The compiler may perform optimizations, such as constant folding, constant propagation, and common subexpression elimination, which can lead to a different final value or comparison result.
C Standard Math Library Notes:
The host implementations of common mathematical functions are mapped to C Standard Math Library functions in a platform-specific way. These functions are provided by the host compiler and the respective host libm, if available.
  • Functions not available from the host compilers are implemented in the crt/math_functions.h header file. For example, erfinv() is implemented there.
  • Less common functions, such as rhypot() and cyl_bessel_i0(), are only available in the device code.
As previously mentioned, the host and device implementations of mathematical functions are independent. For more details on the behavior of these functions, please refer to the host implementation’s documentation.
5.5.5. Floating-Point Functionality Exposure#
The mathematical functions supported by CUDA are exposed through the following methods:
Built-in C/C++ language arithmetic operators:
  • x + y, x - y, x * y, x / y, x++, x--, x += y, x -= y, x *= y, x /= y.
  • Support single-, double-, and quad-precision types, float, double, and __float128/_Float128 respectively.
    • __half and __nv_bfloat16 types are also supported by including the <cuda_fp16.h> and <cuda_bf16.h> headers, respectively.
    • __float128/_Float128 type support relies on the host compiler and device compute capability, see the Supported Floating-Point Types table.
  • They are available in both host and device code.
  • Their behavior is affected by the nvcc optimization flags.
CUDA C++ Standard Library Mathematical functions:
  • Expose the full set of C++ <cmath> header functions through the <cuda/std/cmath> header and the cuda::std:: namespace.
  • Support IEEE-754 standard floating-point types, __half, float, double, __float128, as well as Bfloat16 __nv_bfloat16.
  • They often rely on the CUDA Math API functions. Therefore, there could be different levels of accuracy between the host and device code.
  • A subset of functionalities is also supported in constant expressions, such as constexpr functions, in accordance with the C++23 and C++26 standard specifications.
CUDA C Standard Library Mathematical functions (CUDA Math API):
  • Expose a subset of the C <math.h> header functions.
  • Support single and double-precision types, float and double respectively.
    • They don’t require additional headers.
  • A subset of the <math.h> header functionalities is also available for __half, __nv_bfloat16, and __float128/_Float128 types. These functions have names that resemble those of the C Standard Library.
    • __half and __nv_bfloat16 types require the <cuda_fp16.h> and <cuda_bf16.h> headers, respectively. Their host and device code availability is defined on a per-function basis.
    • __float128/_Float128 type support relies on the host compiler and device compute capability, see the Supported Floating-Point Types table. The related functions require the crt/device_fp128_functions.h header and they are only available in device code.
  • They can have a different accuracy between host and device code.
Non-standard CUDA Mathematical functions (CUDA Math API):
  • Expose mathematical functionalities that are not part of the C/C++ Standard Library.
  • Mainly support single- and double-precision types, float and double respectively.
    • Their host and device code availability is defined on a per-function basis.
  • __nv_bfloat16, __half, __float128/_Float128 are supported for a limited set of functions.
    • __float128/_Float128 type support relies on the host compiler and device compute capability, see the Supported Floating-Point Types table. The related functions require the crt/device_fp128_functions.h header.
    • They are only available in device code.
Intrinsic Mathematical functions (CUDA Math API):
  • Support single- and double-precision types, float and double respectively.
  • They are faster but less accurate than the respective CUDA Math API functions.
  • Their behavior is not affected by the nvcc floating-point optimization flags -prec-div=false, -prec-sqrt=false, and -fmad=true. The only exception is -ftz=true, which is also included in -use_fast_math.
Table 45 Summary of Math Functionality Features#
Functionality
Supported Types
Host
Device
Affected by Floating-Point Optimization Flags
(only for float and double)
float, double, __half, __nv_bfloat16, __float128/_Float128, cuda::std::complex
float, double, __half, __nv_bfloat16, __float128, cuda::std::complex
__nv_fp8_e4m3, __nv_fp8_e5m2, __nv_fp8_e8m0, __nv_fp6_e2m3, __nv_fp6_e3m2, __nv_fp4_e2m1 *
float, double
__nv_bfloat16, __half with limited support and similar names
On a per-function basis
__float128/_Float128 with limited support and similar names
float, double
__nv_bfloat16, __half, __float128/_Float128 with limited support
Intrinsic functions
float, double
Only with -ftz=true, also included in -use_fast_math
* The CUDA C++ Standard Library functions support queries for small floating-point types, such as numeric_limits<T>, fpclassify(), isfinite(), isnormal(), isinf(), and isnan().
The following sections provide accuracy information for some of these functions, when applicable. It uses ULP for quantification. For more information on the definition of the Unit in the Last Place (ULP), please see Jean-Michel Muller’s paper On the definition of ulp(x).
5.5.6. Built-In Arithmetic Operators#
The built-in C/C++ language operators, such as x + y, x - y, x * y, x / y, x++, x--, and reciprocal 1 / x, for single-, double-, and quad-precision types comply with the IEEE-754 standard. They guarantee a maximum ULP error of zero using a round-to-nearest-ties-to-even rounding mode. They are available in both host and device code.
The nvcc compilation flag -fmad=true, also included in --use_fast_math, enables contraction of floating-point multiplies and adds/subtracts into floating-point multiply-add operations and has the following effect on the maximum ULP error for the single-precision type float:
The nvcc compilation flag -prec-div=false, also included in --use_fast_math, has the following effect on the maximum ULP error for the division operator / for the single-precision type float:
5.5.7. CUDA C++ Mathematical Standard Library Functions#
CUDA provides comprehensive support for C++ Standard Library mathematical functions through the cuda::std:: namespace. The functionalities are part of the <cuda/std/cmath> header. They are available in both host and device code.
The following sections specify the mapping with the CUDA Math APIs and the error bounds of each function when executed on the device.
  • The maximum ULP error is stated as the maximum observed absolute value of the difference in ULPs between the value returned by the function and a correctly rounded result of the corresponding precision obtained according to the round-to-nearest ties-to-even rounding mode.
  • The error bounds are derived from extensive, though not exhaustive, testing. Therefore, they are not guaranteed.
5.5.7.1. Basic Operations#
CUDA Math API for basic operations are available in both host and device code, except for __float128.
All the following functions have a maximum ULP error of zero.
Table 46 C++ Mathematical Standard Library Functions
C Math API Mapping
Basic Operations
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
fabs(x)
\(|x|\)
__habs(x)
__habs(x)
fabsf(x)
fabs(x)
__nv_fp128_fabs(x)
fmod(x, y)
Remainder of \(\dfrac{x}{y}\), computed as \(x - \mathrm{trunc}\left(\dfrac{x}{y}\right) \cdot y\)
N/A
N/A
fmodf(x, y)
fmod(x, y)
__nv_fp128_fmod(x, y)
remainder(x, y)
Remainder of \(\dfrac{x}{y}\), computed as \(x - \mathrm{rint}\left(\dfrac{x}{y}\right) \cdot y\)
N/A
N/A
remainderf(x, y)
remainder(x, y)
__nv_fp128_remainder(x, y)
remquo(x, y, iptr)
Remainder and quotient of \(\dfrac{x}{y}\)
N/A
N/A
remquof(x, y, iptr)
remquo(x, y, iptr)
N/A
fma(x, y, z)
\(x \cdot y + z\)
__hfma(x, y, z), device-only
fmaf(x, y, z)
fma(x, y, z)
__nv_fp128_fma(x, y, z)
fmax(x, y)
\(\max(x, y)\)
__hmax(x, y)
__hmax(x, y)
fmaxf(x, y)
fmax(x, y)
__nv_fp128_fmax(x, y)
fmin(x, y)
\(\min(x, y)\)
__hmin(x, y)
__hmin(x, y)
fminf(x, y)
fmin(x, y)
__nv_fp128_fmin(x, y)
fdim(x, y)
\(\max(x-y, 0)\)
N/A
N/A
fdimf(x, y)
fdim(x, y)
__nv_fp128_fdim(x, y)
nan(str)
NaN value from string representation
N/A
N/A
nanf(str)
nan(str)
N/A
* Mathematical functions marked with “N/A” are not natively available for CUDA-extended floating-point types, such as __half and __nv_bfloat16. In these cases, the functions are emulated by converting to a float type and then converting the result back.
5.5.7.2. Exponential Functions#
CUDA Math API for exponential functions are available in both host and device code only for float and double types.
Table 47 C++ Mathematical Standard Library Functions
C Math API Mapping and Accuracy (Maximum ULP)
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
exp(x)
\(e^x\)
hexp(x)
0 ULP
hexp(x)
0 ULP
expf(x)
2 ULP
exp(x)
1 ULP
__nv_fp128_exp(x)
1 ULP
exp2(x)
\(2^x\)
hexp2(x)
0 ULP
hexp2(x)
0 ULP
exp2f(x)
2 ULP
exp2(x)
1 ULP
__nv_fp128_exp2(x)
1 ULP
expm1(x)
\(e^x - 1\)
N/A
N/A
expm1f(x)
1 ULP
expm1(x)
1 ULP
__nv_fp128_expm1(x)
1 ULP
log(x)
\(\ln(x)\)
hlog(x)
0 ULP
hlog(x)
0 ULP
logf(x)
1 ULP
log(x)
1 ULP
__nv_fp128_log(x)
1 ULP
log10(x)
\(\log_{10}(x)\)
hlog10(x)
0 ULP
hlog10(x)
0 ULP
log10f(x)
2 ULP
log10(x)
1 ULP
__nv_fp128_log10(x)
1 ULP
log2(x)
\(\log_2(x)\)
hlog2(x)
0 ULP
hlog2(x)
0 ULP
log2f(x)
1 ULP
log2(x)
1 ULP
__nv_fp128_log2(x)
1 ULP
log1p(x)
\(\ln(1+x)\)
N/A
N/A
log1pf(x)
1 ULP
log1p(x)
1 ULP
__nv_fp128_log1p(x)
1 ULP
5.5.7.3. Power Functions#
CUDA Math API for power functions are available in both host and device code only for float and double types.
Table 48 C++ Mathematical Standard Library Functions
Power Functions
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
pow(x, y)
\(x^y\)
N/A
N/A
powf(x, y)
4 ULP
pow(x, y)
2 ULP
__nv_fp128_pow(x, y)
1 ULP
sqrt(x)
\(\sqrt{x}\)
hsqrt(x)
0 ULP
hsqrt(x)
0 ULP
sqrtf(x)
▪ 0 ULP
▪ 1 ULP with --use_fast_math
sqrt(x)
0 ULP
__nv_fp128_sqrt(x)
0 ULP
cbrt(x)
\(\sqrt[3]{x}\)
N/A
N/A
cbrtf(x)
1 ULP
cbrt(x)
1 ULP
N/A
hypot(x, y)
\(\sqrt{x^2 + y^2}\)
N/A
N/A
hypotf(x, y)
3 ULP
hypot(x, y)
2 ULP
__nv_fp128_hypot(x, y)
1 ULP
5.5.7.4. Trigonometric Functions#
CUDA Math API for trigonometric functions are available in both host and device code only for float and double types.
Table 49 C++ Mathematical Standard Library Functions
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
sin(x)
\(\sin(x)\)
hsin(x)
0 ULP
hsin(x)
0 ULP
sinf(x)
2 ULP
sin(x)
2 ULP
__nv_fp128_sin(x)
1 ULP
cos(x)
\(\cos(x)\)
hcos(x)
0 ULP
hcos(x)
0 ULP
cosf(x)
2 ULP
cos(x)
2 ULP
__nv_fp128_cos(x)
1 ULP
tan(x)
\(\tan(x)\)
N/A
N/A
tanf(x)
4 ULP
tan(x)
2 ULP
__nv_fp128_tan(x)
1 ULP
asin(x)
\(\sin^{-1}(x)\)
N/A
N/A
asinf(x)
2 ULP
asin(x)
2 ULP
__nv_fp128_asin(x)
1 ULP
acos(x)
\(\cos^{-1}(x)\)
N/A
N/A
acosf(x)
2 ULP
acos(x)
2 ULP
__nv_fp128_acos(x)
1 ULP
atan(x)
\(\tan^{-1}(x)\)
N/A
N/A
atanf(x)
2 ULP
atan(x)
2 ULP
__nv_fp128_atan(x)
1 ULP
atan2(y, x)
\(\tan^{-1}\left(\dfrac{y}{x}\right)\)
N/A
N/A
atan2f(y, x)
3 ULP
atan2(y, x)
2 ULP
N/A
5.5.7.5. Hyperbolic Functions#
CUDA Math API for hyperbolic functions are available in both host and device code only for float and double types.
Table 50 C++ Mathematical Standard Library Functions
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
sinh(x)
\(\sinh(x)\)
N/A
N/A
sinhf(x)
3 ULP
sinh(x)
2 ULP
__nv_fp128_sinh(x)
1 ULP
cosh(x)
\(\cosh(x)\)
N/A
N/A
coshf(x)
2 ULP
cosh(x)
1 ULP
__nv_fp128_cosh(x)
1 ULP
tanh(x)
\(\tanh(x)\)
htanh(x)
0 ULP
htanh(x)
0 ULP
tanhf(x)
2 ULP
tanh(x)
1 ULP
__nv_fp128_tanh(x)
1 ULP
asinh(x)
\(\operatorname{sinh}^{-1}(x)\)
N/A
N/A
asinhf(x)
3 ULP
asinh(x)
3 ULP
__nv_fp128_asinh(x)
1 ULP
acosh(x)
\(\operatorname{cosh}^{-1}(x)\)
N/A
N/A
acoshf(x)
4 ULP
acosh(x)
3 ULP
__nv_fp128_acosh(x)
1 ULP
atanh(x)
\(\operatorname{tanh}^{-1}(x)\)
N/A
N/A
atanhf(x)
3 ULP
atanh(x)
2 ULP
__nv_fp128_atanh(x)
1 ULP
5.5.7.6. Error and Gamma Functions#
CUDA Math API for error and gamma functions are available in both host and device code for float and double types.
Error and Gamma functions are not natively available for CUDA-extended floating-point types, such as __half and __nv_bfloat16. In these cases, the functions are emulated by converting to a float type and then converting the result back.
Table 51 C++ Mathematical Standard Library Functions
cuda::std Function
Meaning
float
double
erf(x)
\(\dfrac{2}{\sqrt{\pi}} \int_0^x e^{-t^2} dt\)
erff(x)
2 ULP
erf(x)
2 ULP
erfc(x)
\(1 - \mathrm{erf}(x)\)
erfcf(x)
4 ULP
erfc(x)
5 ULP
tgamma(x)
\(\Gamma(x)\)
tgammaf(x)
5 ULP
tgamma(x)
10 ULP
lgamma(x)
\(\ln |\Gamma(x)|\)
lgammaf(x)
▪ 6 ULP for \(x \notin [-10.001, -2.264]\)
▪ larger otherwise
lgamma(x)
▪ 4 ULP for \(x \notin [-23.0001, -2.2637]\)
▪ larger otherwise
5.5.7.7. Nearest Integer Floating-Point Operations#
CUDA Math API for nearest integer floating-point operations are available in both host and device code only for float and double types.
Table 52 C++ Mathematical Standard Library Functions
C Math API Mapping
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
ceil(x)
\(\lceil x \rceil\)
hceil(x)
hceil(x)
ceilf(x)
ceil(x)
__nv_fp128_ceil(x)
floor(x)
\(\lfloor x \rfloor\)
hfloor(x)
hfloor(x)
floorf(x)
floor(x)
__nv_fp128_floor(x)
trunc(x)
Truncate to integer
htrunc(x)
htrunc(x)
truncf(x)
trunc(x)
__nv_fp128_trunc(x)
round(x)
Round to nearest integer, ties away from zero
N/A
N/A
roundf(x)
round(x)
__nv_fp128_round(x)
nearbyint(x)
Round to nearest integer, ties to even
N/A
N/A
nearbyintf(x)
nearbyint(x)
N/A
rint(x)
hrint(x)
hrint(x)
rintf(x)
rint(x)
__nv_fp128_rint(x)
lrint(x)
Round to nearest integer, ties to even (returns long int)
N/A
N/A
lrintf(x)
lrint(x)
N/A
llrint(x)
Round to nearest integer, ties to even (returns long long int)
N/A
N/A
llrintf(x)
llrint(x)
N/A
lround(x)
Round to nearest integer, ties away from zero (returns long int)
N/A
N/A
lroundf(x)
lround(x)
N/A
llround(x)
Round to nearest integer, ties away from zero (returns long long int)
N/A
N/A
llroundf(x)
llround(x)
N/A
Performance Considerations
The recommended way to round a single- or double-precision floating-point operand to an integer is to use the functions rintf() and rint(), not roundf() and round(). This is because roundf() and round() map to multiple instructions in device code, whereas rintf() and rint() map to a single instruction. truncf(), trunc(), ceilf(), ceil(), floorf(), and floor() each map to a single instruction as well.
5.5.7.8. Floating-Point Manipulation Functions#
CUDA Math API for floating-point manipulation functions are available in both host and device code, except for __float128.
Floating-point manipulation functions are not natively available for CUDA-extended floating-point types, such as __half and __nv_bfloat16. In these cases, the functions are emulated by converting to a float type and then converting the result back.
Table 53 C++ Mathematical Standard Library Functions
C Math API Mapping
cuda::std Function
Meaning
float
double
__float128
frexp(x, exp)
Extract mantissa and exponent
frexpf(x, exp)
frexp(x, exp)
__nv_fp128_frexp(x, nptr)
ldexp(x, n)
\(x \cdot 2^{\mathrm{n}}\)
ldexpf(x, n)
ldexp(x, n)
__nv_fp128_ldexp(x, n)
modf(x, iptr)
Extract integer and fractional parts
modff(x, iptr)
modf(x, iptr)
__nv_fp128_modf(x, iptr)
scalbn(x, n)
\(x \cdot 2^n\)
scalbnf(x, n)
scalbn(x, n)
N/A
scalbln(x, n)
\(x \cdot 2^n\)
scalblnf(x, n)
scalbln(x, n)
N/A
ilogb(x)
\(\lfloor \log_2(|x|) \rfloor\)
ilogbf(x)
ilogb(x)
__nv_fp128_ilogb(x)
logb(x)
logbf(x)
logb(x)
N/A
nextafter(x, y)
Next representable value toward \(y\)
nextafterf(x, y)
nextafter(x, y)
N/A
copysign(x, y)
Copy sign of \(y\) to \(x\)
copysignf(x, y)
copysign(x, y)
__nv_fp128_copysign(x, y)
5.5.7.9. Classification and Comparison#
CUDA Math API for classification and comparison functions are available in both host and device code, except for __float128.
Table 54 C++ Mathematical Standard Library Functions
C Math API Mapping
Classification and Comparison Functions
cuda::std Function
Meaning
__nv_bfloat16
__half
float
double
__float128
fpclassify(x)
Classify \(x\)
N/A
N/A
N/A
N/A
N/A
isfinite(x)
Check if \(x\) is finite
N/A
N/A
isfinite(x)
isfinite(x)
N/A
isinf(x)
Check if \(x\) is infinite
__hisinf(x)
__hisinf(x)
isinf(x)
isinf(x)
N/A
isnan(x)
Check if \(x\) is NaN
__hisnan(x)
__hisnan(x)
isnan(x)
isnan(x)
__nv_fp128_isnan(x)
isnormal(x)
Check if \(x\) is normal
N/A
N/A
N/A
N/A
N/A
signbit(x)
Check if sign bit is set
N/A
N/A
signbit(x)
signbit(x)
N/A
isgreater(x, y)
Check if \(x > y\)
__hgt(x, y)
__hgt(x, y)
N/A
N/A
N/A
isgreaterequal(x, y)
Check if \(x \geq y\)
__hge(x, y)
__hge(x, y)
N/A
N/A
N/A
isless(x, y)
Check if \(x < y\)
__hlt(x, y)
__hlt(x, y)
N/A
N/A
N/A
islessequal(x, y)
Check if \(x \leq y\)
__hle(x, y)
__hle(x, y)
N/A
N/A
N/A
islessgreater(x, y)
Check if \(x < y\) or \(x > y\)
__hne(x, y)
__hne(x, y)
N/A
N/A
N/A
isunordered(x, y)
Check if \(x\), \(y\), or both are NaN
N/A
N/A
N/A
N/A
__nv_fp128_isunordered(x, y)
5.5.8. Non-Standard CUDA Mathematical Functions#
CUDA provides mathematical functions that are not part of the C/C++ Standard Library and are instead offered as extensions. For single- and double-precision functions, host and device code availability is defined on a per-function basis.
This section specifies the error bounds of each function when executed on the device.
Table 55 Non-standard CUDA Mathematical functions
float and double
Meaning
float
double
\(\dfrac{x}{y}\)
fdividef(x, y), device-only
0 ULP, same as x / y
N/A
\(10^x\)
exp10f(x)
2 ULP
exp10(x)
1 ULP
\(\sqrt{x^2 + y^2 + z^2}\)
norm3df(x, y, z), device-only
3 ULP
norm3d(x, y, z), device-only
2 ULP
\(\sqrt{x^2 + y^2 + z^2 + t^2}\)
norm4df(x, y, z, t), device-only
3 ULP
norm4d(x, y, z, t), device-only
2 ULP
\(\sqrt{\sum_{i=0}^{\mathrm{dim}-1} p_i^{2}}\)
normf(dim, p), device-only
An error bound cannot be provided because a fast algorithm is used with accuracy loss due to round-off
norm(dim, p), device-only
\(\dfrac{1}{\sqrt{x}}\)
rsqrtf(x)
2 ULP
rsqrt(x)
1 ULP
\(\dfrac{1}{\sqrt[3]{x}}\)
rcbrtf(x)
1 ULP
rcbrt(x)
1 ULP
\(\dfrac{1}{\sqrt{x^2 + y^2}}\)
rhypotf(x, y), device-only
2 ULP
rhypot(x, y), device-only
1 ULP
\(\dfrac{1}{\sqrt{x^2 + y^2 + z^2}}\)
rnorm3df(x, y, z), device-only
2 ULP
rnorm3d(x, y, z), device-only
1 ULP
\(\dfrac{1}{\sqrt{x^2 + y^2 + z^2 + t^2}}\)
rnorm4df(x, y, z, t), device-only
2 ULP
rnorm4d(x, y, z, t), device-only
1 ULP
\(\dfrac{1}{\sqrt{\sum_{i=0}^{\mathrm{dim}-1} p_i^{2}}}\)
rnormf(dim, p), device-only
rnorm(dim, p), device-only
\(\cos(\pi x)\)
cospif(x)
1 ULP
cospi(x)
2 ULP
\(\sin(\pi x)\)
sinpif(x)
1 ULP
sinpi(x)
2 ULP
\(\sin(\pi x), \cos(\pi x)\)
sincospif(x, sptr, cptr)
1 ULP
sincospi(x, sptr, cptr)
2 ULP
\(\Phi(x)\)
normcdff(x)
5 ULP
normcdf(x)
5 ULP
\(\Phi^{-1}(x)\)
normcdfinvf(x)
5 ULP
normcdfinv(x)
8 ULP
\(\mathrm{erfc}^{-1}(x)\)
erfcinvf(x)
4 ULP
erfcinv(x)
6 ULP
\(e^{x^2}\mathrm{erfc}(x)\)
erfcxf(x)
4 ULP
erfcx(x)
4 ULP
\(\mathrm{erf}^{-1}(x)\)
erfinvf(x)
2 ULP
erfinv(x)
5 ULP
\(I_0(x)\)
cyl_bessel_i0f(x), device-only
6 ULP
cyl_bessel_i0(x), device-only
6 ULP
\(I_1(x)\)
cyl_bessel_i1f(x), device-only
6 ULP
cyl_bessel_i1(x), device-only
6 ULP
\(J_0(x)\)
j0f(x)
▪ 9 ULP for \(|x| < 8\)
▪ the maximum absolute error \(= 2.2 \cdot 10^{-6}\), otherwise
j0(x)
▪ 7 ULP for \(|x| < 8\)
▪ the maximum absolute error \(= 5 \cdot 10^{-12}\), otherwise
\(J_1(x)\)
j1f(x)
j1(x)
\(J_n(x)\)
jnf(n, x)
For \(n = 128\), the maximum absolute error \(= 2.2 \cdot 10^{-6}\)
jn(n, x)
For \(n = 128\), the maximum absolute error \(= 5 \cdot 10^{-12}\)
\(Y_0(x)\)
y0f(x)
y0(x)
\(Y_1(x)\)
y1f(x)
y1(x)
\(Y_n(x)\)
ynf(n, x)
\(\lceil 2 + 2.5n \rceil\) for \(|x| < n\)
yn(n, x)
For \(|x| > 1.5n\), the maximum absolute error \(= 5 \cdot 10^{-12}\)
Non-standard CUDA Mathematical functions for __half, __nv_bfloat16, and __float128/_Float128 are only available in device code.
Table 56 Non-standard CUDA Mathematical functions
Meaning
__nv_bfloat16
__half
\(\dfrac{1}{x}\)
hrcp(x)
0 ULP
hrcp(x)
0 ULP
N/A
\(10^x\)
hexp10(x)
0 ULP
hexp10(x)
0 ULP
__nv_fp128_exp10(x)
1 ULP
hrsqrt(x)
0 ULP
hrsqrt(x)
0 ULP
N/A
\(\tanh(x)\) (approximate)
htanh_approx(x)
1 ULP
htanh_approx(x)
1 ULP
N/A
5.5.9. Intrinsic Functions#
Intrinsic mathematical functions are faster and less accurate versions of their corresponding CUDA C Standard Library Mathematical functions.
  • They have the same name prefixed with __, such as __sinf(x).
  • They are faster because they map to fewer native instructions.
  • The flag --use_fast_math automatically translates the corresponding CUDA Math API functions into intrinsic functions. See the –use_fast_math Effect section for the full list of affected functions.
5.5.9.1. Basic Intrinsic Functions#
A subset of mathematical intrinsic functions allow specifying the rounding mode:
  • Functions suffixed with _rn operate using the round to nearest even rounding mode.
  • Functions suffixed with _rz operate using the round towards zero rounding mode.
  • Functions suffixed with _ru operate using the round up (toward positive infinity) rounding mode.
  • Functions suffixed with _rd operate using the round down (toward negative infinity) rounding mode.
The __fadd_[rn,rz,ru,rd](), __dadd_[rn,rz,ru,rd](), __fmul_[rn,rz,ru,rd](), and __dmul_[rn,rz,ru,rd]() functions map to addition and multiplication operations that the compiler never merges into the FFMA or DFMA instructions. In contrast, additions and multiplications generated from the * and + operators are often combined into FFMA or DFMA.
The following table lists the single- and double-precision floating-point intrinsic functions. All of them have a maximum ULP error of 0 and are IEEE-compliant.
5.5.9.2. Single-Precision-Only Intrinsic Functions#
The following table lists the single-precision floating-point intrinsic functions with their maximum ULP error.
Table 58 Single-Precision Only Floating-Point Intrinsic Functions
Function
Meaning
Maximum ULP Error
__fdividef(x, y)
\(\dfrac{x}{y}\)
\(2\) for \(|y| \in [2^{-126}, 2^{126}]\)
__frsqrt_rn(x)
0 ULP
__expf(x)
\(e^x\)
\(2 + \lfloor |1.173 \cdot x| \rfloor\)
__exp10f(x)
\(10^x\)
\(2 + \lfloor |2.97 \cdot x| \rfloor\)
__powf(x, y)
\(x^y\)
Derived from exp2f(y * __log2f(x))
__logf(x)
\(\ln(x)\)
\(2^{-21.41}\) abs error for \(x \in [0.5, 2]\)
▪ 3 ULP, otherwise
__log2f(x)
\(\log_2(x)\)
\(2^{-22}\) abs error for \(x \in [0.5, 2]\)
▪ 2 ULP, otherwise
__log10f(x)
\(\log_{10}(x)\)
\(2^{-24}\) abs error for \(x \in [0.5, 2]\)
▪ 3 ULP, otherwise
__sinf(x)
\(\sin(x)\)
\(2^{-21.41}\) abs error for \(x \in [-\pi, \pi]\)
▪ larger otherwise
__cosf(x)
\(\cos(x)\)
▪ larger otherwise
__sincosf(x, sptr, cptr)
\(\sin(x), \cos(x)\)
Component-wise, the same as __sinf(x) and __cosf(x)
__tanf(x)
\(\tan(x)\)
Derived from __sinf(x) * (1 / __cosf(x))
__tanhf(x)
\(\tanh(x)\)
▪ Max relative error: \(2^{-11}\)
▪ Subnormal results are not flushed to zero even under -ftz=true compiler flag.
5.5.9.3. --use_fast_math Effect#
The nvcc compiler flag --use_fast_math translates a subset of CUDA Math API functions called in device code into their intrinsic counterpart. Note that the CUDA C++ Standard Library functions are also affected by this flag. See the Intrinsic Functions section for more details on the implications of using intrinsic functions instead of CUDA Math API functions.
A more robust approach is to selectively replace mathematical function calls with intrinsic versions only where the performance gains justify it and where the changed properties, such as reduced accuracy and different special-case handling, are acceptable.
5.5.10. References#
  1. IEEE 754-2019 Standard for Floating-Point Arithmetic.
  2. Jean-Michel Muller. On the definition of ulp(x). INRIA/LIP research report, 2005.
  3. Nathan Whitehead, Alex Fit-Florea. Precision & Performance: Floating Point and IEEE 754 Compliance for NVIDIA GPUs. Nvidia Report, 2011.
  4. David Goldberg. What every computer scientist should know about floating-point arithmetic. ACM Computing Surveys, March 1991.
  5. David Monniaux. The pitfalls of verifying floating-point computations. ACM Transactions on Programming Languages and Systems, May 2008.
  6. Peter Dinda, Conor Hetland. Do Developers Understand IEEE Floating Point?. IEEE International Parallel and Distributed Processing Symposium (IPDPS), 2018.
