Holds initialization parameters for the decoder class.
Definition at line 584 of file nvmedia_parser.h.
Data Fields | |
| NvMediaParserClientCb * | pClient |
| Should always be present if using parsing functionality. More... | |
| void * | pClientCtx |
| Client context. More... | |
| uint32_t | uReferenceClockRate |
| Ticks per second of PTS clock (0=default=10000000=10Mhz) More... | |
| uint16_t | uErrorThreshold |
| Threshold for deciding to bypass of picture (0=do not decode, 100=always decode) More... | |
| NvMediaVideoCodec | eCodec |
| Codec type. More... | |
| NvMediaParserSeqInfo * | pExternalSeqInfo |
| Optional external sequence header data. More... | |
| NvMediaVideoCodec NvMediaParserParams::eCodec |
Codec type.
Definition at line 595 of file nvmedia_parser.h.
| NvMediaParserClientCb* NvMediaParserParams::pClient |
Definition at line 587 of file nvmedia_parser.h.
| void* NvMediaParserParams::pClientCtx |
Client context.
Definition at line 589 of file nvmedia_parser.h.
| NvMediaParserSeqInfo* NvMediaParserParams::pExternalSeqInfo |
Definition at line 597 of file nvmedia_parser.h.
| uint16_t NvMediaParserParams::uErrorThreshold |
Definition at line 593 of file nvmedia_parser.h.
| uint32_t NvMediaParserParams::uReferenceClockRate |
Definition at line 591 of file nvmedia_parser.h.
