Picture parameter information for an H.264 picture.
Also note that only surfaces previously generated using NvMediaVideoDecoderRenderEx may be used as reference frames.
Definition at line 270 of file nvmedia_common.h.
Data Fields | |
| int32_t | field_order_cnt [2] |
| [0]: top, [1]: bottom More... | |
| NvMediaBool | is_reference |
| Will the decoded frame be used as a reference later. More... | |
| uint16_t | chroma_format_idc |
| Copy of the H.264 bitstream field. More... | |
| uint16_t | frame_num |
| uint8_t | field_pic_flag |
| uint8_t | bottom_field_flag |
| uint8_t | num_ref_frames |
| uint8_t | mb_adaptive_frame_field_flag |
| uint8_t | constrained_intra_pred_flag |
| uint8_t | weighted_pred_flag |
| uint8_t | weighted_bipred_idc |
| uint8_t | frame_mbs_only_flag |
| uint8_t | transform_8x8_mode_flag |
| int8_t | chroma_qp_index_offset |
| int8_t | second_chroma_qp_index_offset |
| int8_t | pic_init_qp_minus26 |
| uint8_t | num_ref_idx_l0_active_minus1 |
| uint8_t | num_ref_idx_l1_active_minus1 |
| uint8_t | log2_max_frame_num_minus4 |
| uint8_t | pic_order_cnt_type |
| uint8_t | log2_max_pic_order_cnt_lsb_minus4 |
| uint8_t | delta_pic_order_always_zero_flag |
| uint8_t | direct_8x8_inference_flag |
| uint8_t | entropy_coding_mode_flag |
| uint8_t | pic_order_present_flag |
| uint8_t | deblocking_filter_control_present_flag |
| uint8_t | redundant_pic_cnt_present_flag |
| uint8_t | num_slice_groups_minus1 |
| uint8_t | slice_group_map_type |
| uint32_t | slice_group_change_rate_minus1 |
| uint8_t * | slice_group_map |
| Slice group map. More... | |
| uint8_t | fmo_aso_enable |
| uint8_t | scaling_matrix_present |
| uint8_t | scaling_lists_4x4 [6][16] |
| Copy of the H.264 bitstream field, converted to raster order. More... | |
| uint8_t | scaling_lists_8x8 [2][64] |
| NvMediaReferenceFrameH264 | referenceFrames [16] |
| See NvMediaPictureInfoH264 for instructions regarding this field. More... | |
| uint32_t | nNumSlices |
| Number of slices in this picture. More... | |
| uint32_t * | pSliceDataOffsets |
| Passing NULL for pSliceDataOffsets disables error-concealment. More... | |
| uint8_t | frameType |
| 0:FrameType_B 1:FrameType_P 2:FrameType_I More... | |
| struct { | |
| uint16_t num_views_minus1 | |
| Copy of the H.264 mvc bitstream field. More... | |
| uint16_t view_id | |
| uint8_t inter_view_flag | |
| uint8_t num_inter_view_refs_l0 | |
| uint8_t num_inter_view_refs_l1 | |
| uint8_t MVCReserved8Bits | |
| uint16_t InterViewRefsL0 [16] | |
| uint16_t InterViewRefsL1 [16] | |
| } | mvcext |
| MVC extension. More... | |
| NvMediaSEIPayloadH264 | seiPayloadInfo |
| Parser only: SEI payload info. More... | |
| uint32_t | pic_width_in_mbs_minus1 |
| uint32_t | pic_height_in_map_units_minus1 |
| int32_t | last_sps_id |
| int32_t | last_pps_id |
| int32_t | qpprime_y_zero_transform_bypass_flag |
| Copy of the H.264 bitstream field, qpprime_y_zero_transform_bypass_flag. More... | |
| uint8_t NvMediaPictureInfoH264::bottom_field_flag |
Definition at line 283 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::chroma_format_idc |
Definition at line 277 of file nvmedia_common.h.
| int8_t NvMediaPictureInfoH264::chroma_qp_index_offset |
Definition at line 299 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::constrained_intra_pred_flag |
Definition at line 289 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::deblocking_filter_control_present_flag |
Definition at line 323 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::delta_pic_order_always_zero_flag |
Definition at line 315 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::direct_8x8_inference_flag |
Definition at line 317 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::entropy_coding_mode_flag |
Definition at line 319 of file nvmedia_common.h.
| int32_t NvMediaPictureInfoH264::field_order_cnt[2] |
Definition at line 272 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::field_pic_flag |
Definition at line 281 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::fmo_aso_enable |
Definition at line 335 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::frame_mbs_only_flag |
Definition at line 295 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::frame_num |
Definition at line 279 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::frameType |
Definition at line 352 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::inter_view_flag |
Definition at line 361 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::InterViewRefsL0[16] |
Definition at line 369 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::InterViewRefsL1[16] |
Definition at line 371 of file nvmedia_common.h.
| NvMediaBool NvMediaPictureInfoH264::is_reference |
Definition at line 274 of file nvmedia_common.h.
| int32_t NvMediaPictureInfoH264::last_pps_id |
Required for OTF
Definition at line 383 of file nvmedia_common.h.
| int32_t NvMediaPictureInfoH264::last_sps_id |
Required for OTF
Definition at line 381 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::log2_max_frame_num_minus4 |
Definition at line 309 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::log2_max_pic_order_cnt_lsb_minus4 |
Definition at line 313 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::mb_adaptive_frame_field_flag |
Definition at line 287 of file nvmedia_common.h.
| struct { ... } NvMediaPictureInfoH264::mvcext |
MVC extension.
| uint8_t NvMediaPictureInfoH264::MVCReserved8Bits |
Definition at line 367 of file nvmedia_common.h.
| uint32_t NvMediaPictureInfoH264::nNumSlices |
nNumSlices entries contain the offset of each slice within the bitstream data buffer. Required for nvdec.
Definition at line 348 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_inter_view_refs_l0 |
Definition at line 363 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_inter_view_refs_l1 |
Definition at line 365 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_ref_frames |
Definition at line 285 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_ref_idx_l0_active_minus1 |
Definition at line 305 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_ref_idx_l1_active_minus1 |
Definition at line 307 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::num_slice_groups_minus1 |
Definition at line 327 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::num_views_minus1 |
Definition at line 357 of file nvmedia_common.h.
| uint32_t NvMediaPictureInfoH264::pic_height_in_map_units_minus1 |
Required for OTF
Definition at line 379 of file nvmedia_common.h.
| int8_t NvMediaPictureInfoH264::pic_init_qp_minus26 |
Definition at line 303 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::pic_order_cnt_type |
Definition at line 311 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::pic_order_present_flag |
Definition at line 321 of file nvmedia_common.h.
| uint32_t NvMediaPictureInfoH264::pic_width_in_mbs_minus1 |
Required for OTF
Definition at line 377 of file nvmedia_common.h.
| uint32_t* NvMediaPictureInfoH264::pSliceDataOffsets |
Definition at line 350 of file nvmedia_common.h.
| int32_t NvMediaPictureInfoH264::qpprime_y_zero_transform_bypass_flag |
Definition at line 385 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::redundant_pic_cnt_present_flag |
Definition at line 325 of file nvmedia_common.h.
| NvMediaReferenceFrameH264 NvMediaPictureInfoH264::referenceFrames[16] |
Definition at line 345 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::scaling_lists_4x4[6][16] |
Definition at line 340 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::scaling_lists_8x8[2][64] |
Definition at line 342 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::scaling_matrix_present |
Definition at line 337 of file nvmedia_common.h.
| int8_t NvMediaPictureInfoH264::second_chroma_qp_index_offset |
Definition at line 301 of file nvmedia_common.h.
| NvMediaSEIPayloadH264 NvMediaPictureInfoH264::seiPayloadInfo |
Definition at line 375 of file nvmedia_common.h.
| uint32_t NvMediaPictureInfoH264::slice_group_change_rate_minus1 |
Definition at line 331 of file nvmedia_common.h.
| uint8_t* NvMediaPictureInfoH264::slice_group_map |
Slice group map.
Definition at line 333 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::slice_group_map_type |
Definition at line 329 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::transform_8x8_mode_flag |
Definition at line 297 of file nvmedia_common.h.
| uint16_t NvMediaPictureInfoH264::view_id |
Definition at line 359 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::weighted_bipred_idc |
Definition at line 293 of file nvmedia_common.h.
| uint8_t NvMediaPictureInfoH264::weighted_pred_flag |
Definition at line 291 of file nvmedia_common.h.
